12-Security Command Reference
HomeSupportRoutersMSR5600 Series(Comware V7)Reference GuidesCommand ReferencesH3C MSR 5600 Routers Command Reference(V7)-R6728-6W10012-Security Command Reference
20-Session management commands
20-Session management commands 303.34 KB
The MSR 56-60 and MSR 56-80 routers installed with the MPU-100-G modules do not support parameters or commands that are available only in IRF mode.
display session aging-time application
Use display session aging-time application to display the aging time for sessions of different application layer protocols or applications.
# Display the aging time for sessions of different application layer protocols and applications.
<Sysname> display session aging-time application
Application                                                    Aging time(s)
bootpc                                                         120
bootps                                                         120
dns                                                            1
ftp                                                            3600
ftp-data                                                       240
gprs-data                                                      60
gprs-sig                                                       60
gtp-control                                                    60
gtp-user                                                       60
h225                                                           3600
h245                                                           3600
https                                                          600
ils                                                            3600
l2tp                                                           120
mgcp-callagent                                                 60
mgcp-gateway                                                   60
netbios-dgm                                                    3600
netbios-ns                                                     3600
netbios-ssn                                                    3600
ntp                                                            120
pptp                                                           3600
qq                                                             120
ras                                                            300
rip                                                            120
rsh                                                            60
rtsp                                                           3600
sccp                                                           3600
sip                                                            300
snmp                                                           120
snmptrap                                                       120
sqlnet                                                         600
stun                                                           600
syslog                                                         120
tacacs-ds                                                      120
tftp                                                           60
who                                                            120
xdmcp                                                          3600
others:                                                        1200
Application
Name of an application layer protocol or an application.
Aging time(s)
Aging time in seconds.
others:1200
All application layer protocols and applications whose aging time is 1200 seconds is displayed as others.
display session aging-time state
Use display session aging-time stat to display the aging time for sessions in different protocol states.
# Display the aging time for sessions in different protocol states.
<Sysname> display session aging-time state
State                     Aging Time(s)
SYN                       10
TCP-EST                   3600
FIN                       10
UDP-OPEN                  10
UDP-READY                 30
ICMP-REQUEST              30
ICMP-REPLY                10
RAWIP-OPEN                30
RAWIP-READY               60
UDPLITE-OPEN              30
UDPLITE-READY             60
DCCP-REQUEST              30
DCCP-EST                  3600
DCCP-CLOSEREQ             30
SCTP-INIT                 30
SCTP-EST                  3600
SCTP-SHUTDOWN             30
ICMPV6-REQUEST            60
ICMPV6-REPLY              30
TCP-TIME-WAIT             2
TCP-CLOSE                 2
Protocol state.
Aging Time(s)
display session relation-table
Use display session relation-table to display relation entries.
In standalone mode:
display session relation-table { ipv4 | ipv6 } [ slot slot-number ]
In IRF mode:
display session relation-table { ipv4 | ipv6 } [ chassis chassis-number slot slot-number ]
ipv4: Specifies IPv4 relation entries.
ipv6: Specifies IPv6 relation entries.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays relation entries for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays relation entries for all cards. (In IRF mode.)
# (In standalone mode.) Display all IPv4 relation entries.
<Sysname> display session relation-table ipv4
Slot 1:
Source IP/port:      192.168.1.100/-
Destination IP/port: 192.168.2.100/99
DS-Lite tunnel peer: -
VPN instance/VLAN ID/Inline ID: 1/-/-
Protocol: TCP(6)    TTL: 1234s    App: FTP-DATA
Source IP/port:      -/-
Destination IP/port: 192.168.2.200/1212
Protocol: TCP(6)    TTL: 3100s    App: H225
Total entries found:  2
# (In standalone mode.) Display all IPv6 relation entries.
<Sysname> display session relation-table ipv6
Slot 1:
Source IP:             2011::0002
Destination IP/port: 2011::0008/1212
Protocol: TCP(6)    TTL: 567s    App: FTP-DATA
Total entries found:  1
Source IP/port
Source IP address and port number of the session. If the IP or port number is not specified, this field displays a hyphen (-).
For an IPv6 relation entry, the source port number is not displayed.
Destination IP/port
Destination IP address and port number of the session.
DS-Lite tunnel peer
Peer tunnel interface address of the DS-Lite tunnel to which the session belongs. If no peer tunnel interface address is specified, a hyphen (-) is displayed.
VPN instance/VLAN ID/ Inline ID
MPLS L3VPN instance to which the relation entry belongs.
VLAN and inline to which the relation entry belongs during Layer 2 forwarding.
If a parameter is not specified, a hyphen (-) is displayed for the proper field.
Protocol
Transport layer protocol.
TTL
Remaining lifetime of the relation entry, in seconds.
App
Application layer protocol.
Total entries found
Total number of found relation entries.
display session statistics
Use display session statistics to display unicast session statistics.
In standalone mode:
display session statistics [ history-max | summary ] [ slot slot-number ]
In IRF mode:
display session statistics [ history-max | summary ] [ chassis chassis-number slot slot-number ]
history-max: Displays history statistics of the maximum unicast sessions and the maximum unicast session establishment rates. If you do not specify this keyword, the command displays all unicast session statistics.
summary: Displays summary information about unicast session statistics. If you do not specify this keyword, the command displays detailed information about unicast session statistics.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays unicast session statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays unicast session statistics for all cards. (In IRF mode.)
If you do not specify any parameters, this command displays detailed information about the current unicast session statistics.
# Display detailed information about unicast session statistics.
<Sysname> display session statistics
Slot 1:
Current sessions: 3
          TCP sessions:                    0
          UDP sessions:                    0
         ICMP sessions:                    3
       ICMPv6 sessions:                    0
     UDP-Lite sessions:                    0
         SCTP sessions:                    0
         DCCP sessions:                    0
        RAWIP sessions:                    0
          DNS sessions:                    0
          FTP sessions:                    0
          GTP sessions:                    0
         H323 sessions:                    0
         HTTP sessions:                    0
          ILS sessions:                    0
         MGCP sessions:                    0
          NBT sessions:                    0
         PPTP sessions:                    0
          RSH sessions:                    0
         RTSP sessions:                    0
         SCCP sessions:                    0
          SIP sessions:                    0
         SMTP sessions:                    0
       SQLNET sessions:                    0
          SSH sessions:                    0
       TELNET sessions:                    0
         TFTP sessions:                    0
        XDMCP sessions:                    0
History average sessions per second:
      Past hour: 1
      Past 24 hours: 0
      Past 30 days: 0
History average session establishment rate:
      Past hour: 0/s
      Past 24 hours: 0/s
      Past 30 days: 0/s
Current relation-table entries: 0
Relation table establishment rate: 0/s
Session establishment rate: 0/s
          TCP:                   0/s
          UDP:                   0/s
         ICMP:                   0/s
       ICMPv6:                   0/s
     UDP-Lite:                   0/s
         SCTP:                   0/s
         DCCP:                   0/s
        RAWIP:                   0/s
Received TCP      :                   0 packets                    0 bytes
Received UDP      :                 118 packets                13568 bytes
Received ICMP     :                 105 packets                 8652 bytes
Received ICMPv6   :                   0 packets                    0 bytes
Received UDP-Lite :                   0 packets                    0 bytes
Received SCTP     :                   0 packets                    0 bytes
Received DCCP     :                   0 packets                    0 bytes
Received RAWIP    :                   0 packets                    0 bytes
Current sessions
Total number of unicast sessions.
TCP sessions
Number of TCP sessions.
UDP sessions
Number of UDP sessions.
ICMP sessions
Number of ICMP sessions.
ICMPv6 sessions
Number of ICMPv6 sessions.
UDP-Lite sessions
Number of UDP-Lite sessions.
SCTP sessions
Number of SCTP sessions.
DCCP sessions
Number of DCCP sessions.
RAWIP sessions
Number of Raw IP sessions.
DNS sessions
Number of DNS unicast sessions.
FTP sessions
Number of FTP unicast sessions.
GTP sessions
Number of GTP unicast sessions.
H323 sessions
Number of H.323 unicast sessions.
HTTP sessions
Number of HTTP unicast sessions.
ILS sessions
Number of ILS unicast sessions.
MGCP sessions
Number of MGCP unicast sessions.
NBT sessions
Number of NBT unicast sessions.
PPTP sessions
Number of PPTP unicast sessions.
RSH sessions
Number of RSH unicast sessions.
RTSP sessions
Number of RTSP unicast sessions.
SCCP sessions
Number of SCCP unicast sessions.
SIP sessions
Number of SIP unicast sessions.
SMTP sessions
Number of SMTP unicast sessions.
SQLNET sessions
Number of SQLNET unicast sessions.
SSH sessions
Number of SSH unicast sessions.
TELNET sessions
Number of Telnet unicast sessions.
TFTP sessions
Number of TFTP unicast sessions.
XDMCP sessions
Number of XDMCP unicast sessions.
History statistics of average sessions per second.
Past hour
The average number of sessions per second in the most recent hour.
Past 24 hours
The average number of sessions per second in the most recent 24 hours.
Past 30 days
The average number of sessions per second in the most recent 30 days.
History statistics of average session establishment rates.
Past hour
The average session establishment rate in the most recent hour.
Past 24 hours
The average session establishment rate in the most recent 24 hours.
Past 30 days
The average session establishment rate in the most recent 30 days.
Total number of relation entries.
Rate of relation table establishment.
Unicast session establishment rate, and rates for establishing unicast sessions of different protocols.
Received TCP
Number of received TCP packets and bytes.
Received UDP
Number of received UDP packets and bytes.
Received ICMP
Number of received ICMP packets and bytes.
Received ICMPv6
Number of received ICMPv6 packets and bytes.
Received UDP-Lite
Number of received UDP-Lite packets and bytes.
Received SCTP
Number of received SCTP packets and bytes.
Received DCCP
Number of received DCCP packets and bytes.
Received RAWIP
Number of received Raw IP packets and bytes.
# (In standalone mode.) Display summary information about unicast session statistics.
<Sysname> display session statistics summary
Slot Sessions  TCP       UDP       Rate      TCP rate  UDP rate
1    1   3         0         0         0/s       0/s       0/s
Table 5 Command output
Sessions
TCP
Number of TCP unicast sessions.
UDP
Number of UDP unicast sessions.
Rate
Rate of unicast session creation.
TCP rate
Rate of TCP unicast session creation.
UDP rate
Rate of UDP unicast session creation.
# (In standalone mode.) Display history statistics of the maximum unicast sessions and maximum unicast session establishment rates.
<Sysname> display session statistics history-max
Slot 1
Max sessions: 20084                            Time: 2017-03-04 12:03:53
Max session establishment rate: 9080/s         Time: 2017-03-04 12:03:53
Max TCP sessions: 20084                        Time: 2017-03-04 12:03:53
Max TCP session establishment rate: 9080/s     Time: 2017-03-04 12:03:53
Max UDP sessions: 0                            Time: 2017-03-04 12:03:53
Max UDP session establishment rate: 0          Time: 2017-03-04 12:03:53
Table 6 Command output
Max sessions
History statistics of the maximum unicast sessions.
History statistics of the maximum rate at which unicast sessions were created.
Max TCP sessions
History statistics of the maximum TCP unicast sessions.
History statistics of the maximum rate at which TCP unicast sessions were created.
Max UDP sessions
History statistics of the maximum UDP unicast sessions.
History statistics of the maximum rate at which UDP unicast sessions were created.
display session statistics ipv4
Use display session statistics ipv4 to display IPv4 unicast session statistics.
In standalone mode:
display session statistics ipv4 [ [ responder ] { application application-name | destination-ip destination-ip | destination-port destination-port | interface interface-type interface-number | protocol { dccp | dns | ftp | gtp | h323 | http | icmp | ils | mgcp | nbt | pptp | raw-ip | rsh | rtsp | sccp | sctp | sip | smtp | sqlnet | ssh | tcp | telnet | tftp | udp | udp-lite | xdmcp } | source-ip source-ip | source-port source-port | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmp-reply | icmp-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } | vpn-instance vpn-instance-name } * ] [ slot slot-number ]
In IRF mode:
display session statistics ipv4 [ [ responder ] { application application-name | destination-ip destination-ip | destination-port destination-port | interface interface-type interface-number | protocol { dccp | dns | ftp | gtp | h323 | http | icmp | ils | mgcp | nbt | pptp | raw-ip | rsh | rtsp | sccp | sctp | sip | smtp | sqlnet | ssh | tcp | telnet | tftp | udp | udp-lite | xdmcp } | source-ip source-ip | source-port source-port | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmp-reply | icmp-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } | vpn-instance vpn-instance-name } * ] [ chassis chassis-number slot slot-number ]
responder: Displays statistics about IPv4 unicast sessions from the responder to the initiator. If you do not specify this keyword, the command displays statistics about IPv4 unicast sessions from the initiator to the responder.
application application-name: Specifies an application protocol by its name. The application-name argument is a case-insensitive string of 1 to 63 characters. The names invalid and other are not allowed.
destination-ip destination-ip: Specifies a destination IPv4 address for a unicast session.
destination-port destination-port: Specifies a destination port by its number. The destination-port argument specifies the destination port of an IPv6 unicast session. The value range for the destination-port argument is 0 to 65535.
interface interface-type interface-num: Specifies an interface by its type and number.
protocol { dccp | dns | ftp | gtp | h323 | http | icmp | ils | mgcp | nbt | pptp | raw-ip | rsh | rtsp | sccp | sctp | sip | smtp | sqlnet | ssh | tcp | telnet | tftp | udp | udp-lite | xdmcp }: Specifies an IPv4 protocol.
source-ip source-ip: Specifies a source IPv4 address for a unicast session.
source-zone source-zone-name: Specifies a source security zone by its name, a case-insensitive string of 1 to 31 characters.
state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmp-reply | icmp-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready }: Specifies a protocol state.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays IPv4 unicast session statistics in the public network.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv4 unicast session statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv4 unicast session statistics for all cards. (In IRF mode.)
If you do not specify any parameters, this command displays all IPv4 unicast session statistics.
# Display statistics for unicast sessions from IP address 111.15.111.66.
<Sysname> display session statistics ipv4 source-ip 111.15.111.66
Slot 1:
Current sessions: 3
          TCP sessions:                    0
          UDP sessions:                    0
         ICMP sessions:                    3
         SCTP sessions:                    0
         DCCP sessions:                    0
        RAWIP sessions:                    0
          DNS sessions:                    0
          FTP sessions:                    0
          GTP sessions:                    0
         H323 sessions:                    0
         HTTP sessions:                    0
          ILS sessions:                    0
         MGCP sessions:                    0
          NBT sessions:                    0
         PPTP sessions:                    0
          RSH sessions:                    0
         RTSP sessions:                    0
         SCCP sessions:                    0
          SIP sessions:                    0
         SMTP sessions:                    0
       SQLNET sessions:                    0
          SSH sessions:                    0
       TELNET sessions:                    0
         TFTP sessions:                    0
        XDMCP sessions:                    0
# Display statistics for IPv4 unicast TCP sessions.
<Sysname> display session statistics ipv4 protocol tcp
Slot 1:
Current sessions: 3
          TCP sessions:                    3
Table 7 Command output
Current sessions
TCP sessions
UDP sessions
ICMP sessions
Number of ICMP unicast sessions.
UDP-Lite sessions
Number of UDP-Lite unicast sessions.
SCTP sessions
Number of SCTP unicast sessions.
DCCP sessions
Number of DCCP unicast sessions.
RAWIP sessions
Number of Raw IP unicast sessions.
DNS sessions
FTP sessions
GTP sessions
H323 sessions
HTTP sessions
ILS sessions
MGCP sessions
NBT sessions
PPTP sessions
RSH sessions
RTSP sessions
SCCP sessions
SIP sessions
SMTP sessions
SQLNET sessions
SSH sessions
TELNET sessions
TFTP sessions
XDMCP sessions
display session statistics ipv6
Use display session statistics ipv6 to display IPv6 unicast session statistics.
In standalone mode:
display session statistics ipv6 [ [ responder ] { application application-name | destination-ip destination-ip | destination-port destination-port | interface interface-type interface-number | protocol { dccp | dns | ftp | gtp | h323 | http | icmpv6 | ils | mgcp | nbt | pptp | raw-ip | rsh | rtsp | sccp | sctp | sip | smtp | sqlnet | ssh | tcp | telnet | tftp | udp | udp-lite | xdmcp } | source-ip source-ip | source-port source-port | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } | vpn-instance vpn-instance-name } * ] [ slot slot-number ]
In IRF mode:
display session statistics ipv6 [ [ responder ] { application application-name | destination-ip destination-ip | destination-port destination-port | interface interface-type interface-number | protocol { dccp | dns | ftp | gtp | h323 | http | icmpv6 | ils | mgcp | nbt | pptp | raw-ip | rsh | rtsp | sccp | sctp | sip | smtp | sqlnet | ssh | tcp | telnet | tftp | udp | udp-lite | xdmcp } | source-ip source-ip | source-port source-port | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } | vpn-instance vpn-instance-name } * ] [ chassis chassis-number slot slot-number ]
responder: Displays statistics about IPv6 unicast sessions from the responder to the initiator. If you do not specify this keyword, the command displays statistics about IPv6 unicast sessions from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv6 address for a unicast session.
protocol { dccp | dns | ftp | gtp | h323 | http | icmpv6 | ils | mgcp | nbt | pptp | raw-ip | rsh | rtsp | sccp | sctp | sip | smtp | sqlnet | ssh | tcp | telnet | tftp | udp | udp-lite | xdmcp }: Specifies an IPv6 protocol.
source-ip source-ip: Specifies a source IPv6 address for a unicast session.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of an IPv6 unicast session. The value range for the source-port argument is 0 to 65535.
state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready }: Specifies a protocol state.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays IPv6 unicast session statistics in the public network.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays IPv6 unicast session statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays IPv6 unicast session statistics for all cards. (In IRF mode.)
# Display statistics for unicast sessions from IPv6 address 100::2.
<Sysname> display session statistics ipv6 source-ip 100::2
Slot 1:
Current sessions: 3
          TCP sessions:                    0
          UDP sessions:                    0
       ICMPv6 sessions:                    3
         SCTP sessions:                    0
         DCCP sessions:                    0
        RAWIP sessions:                    0
          DNS sessions:                    0
          FTP sessions:                    0
          GTP sessions:                    0
         H323 sessions:                    0
         HTTP sessions:                    0
          ILS sessions:                    0
         MGCP sessions:                    0
          NBT sessions:                    0
         PPTP sessions:                    0
          RSH sessions:                    0
         RTSP sessions:                    0
         SCCP sessions:                    0
          SIP sessions:                    0
         SMTP sessions:                    0
       SQLNET sessions:                    0
          SSH sessions:                    0
       TELNET sessions:                    0
         TFTP sessions:                    0
        XDMCP sessions:                    0
# Display statistics for IPv6 unicast TCP sessions.
<Sysname> display session statistics ipv6 protocol tcp
Slot 1:
Current sessions: 3
          TCP sessions:                    3
Table 8 Command output
Current sessions
TCP sessions
UDP sessions
ICMPv6 sessions
Number of ICMPv6 unicast sessions.
UDP-Lite sessions
SCTP sessions
DCCP sessions
RAWIP sessions
DNS sessions
FTP sessions
GTP sessions
H323 sessions
HTTP sessions
ILS sessions
MGCP sessions
NBT sessions
PPTP sessions
RSH sessions
RTSP sessions
SCCP sessions
SIP sessions
SMTP sessions
SQLNET sessions
SSH sessions
TELNET sessions
TFTP sessions
XDMCP sessions
display session statistics multicast
Use display session statistic multicast to display multicast session statistics.
In standalone mode:
display session statistics multicast [ slot slot-number ]
In IRF mode:
display session statistics multicast [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays multicast session statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays multicast session statistics for all cards. (In IRF mode.)
# (In standalone mode.) Display information about multicast session statistics.
<Sysname> display session statistics multicast
Slot 1:
Current sessions: 0
History max sessions: 0                                Time: 2017-04-25 11:28:00
History max session establishment rate: 0/s            Time: 2017-04-25 11:28:00
Received:                   0 packets                    0 bytes
Sent    :                   0 packets                    0 bytes
Table 9 Command output
Current sessions
Total number of multicast sessions.
Rate of multicast session creation.
History statistics of the maximum multicast sessions.
History statistics of the maximum rate at which multicast sessions were created.
Received
Number of received multicast packets and bytes.
Sent
Number of sent multicast packets and bytes.
display session table ipv4
Use display session table ipv4 to display information about IPv4 unicast session entries that match specific criteria.
In standalone mode:
display session table ipv4 [ slot slot-number ] [ [ responder ] { application application-name | destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | interface interface-type interface-number | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmp-reply | icmp-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } | vpn-instance vpn-instance-name } * ] [ verbose ]
In IRF mode:
display session table ipv4 [ chassis chassis-number slot slot-number ] [ [ responder ] { application application-name | destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | interface interface-type interface-number | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmp-reply | icmp-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } | vpn-instance vpn-instance-name } * ] [ verbose ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information for all cards. (In IRF mode.)
responder: Displays entries of IPv4 unicast sessions from the responder to the initiator. If you do not specify this keyword, the command displays entries of IPv4 unicast sessions from the initiator to the responder.
destination-ip start-destination-ip [ end-destination-ip ]: Specifies a destination IPv4 address or IPv4 address range for a unicast session. The start destination-ip argument specifies the start destination IPv4 address. The end destination-ip argument specifies the end destination IPv4 address.
destination-port destination-port: Specifies a destination port by its number. The destination-port argument specifies the destination port of a unicast session. The value range for the destination-port argument is 0 to 65535.
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }: Specifies an IPv4 transport layer protocol, including DCCP, ICMP, Raw IP, SCTP, TCP, UDP, and UDP-Lite.
source-ip start-source-ip [ end-source-ip ]: Specifies a source IPv4 address or IPv4 address range for a unicast session. The start source-ip argument specifies the start source IPv4 address. The end source-ip argument specifies the end source IPv4 address.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of a unicast session. The value range for the source-port argument is 0 to 65535.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays IPv4 unicast session entries in the public network.
verbose: Displays detailed information about IPv4 unicast session entries. If you do not specify this keyword, the command displays brief information about IPv4 unicast session entries.
If you do not specify any parameters, this command displays all IPv4 unicast session entries.
# (In standalone mode.) Display brief information about all IPv4 unicast session entries.
<Sysname> display session table ipv4
Slot 1:
Initiator:
  Source      IP/port: 192.168.1.18/1877
  Destination IP/port: 192.168.1.55/22
  Protocol: TCP(6)
  Inbound interface: GigabitEthernet1/0/1
  Source security zone: Trust
Total sessions found: 1
# (In standalone mode.) Display detailed information about all IPv4 unicast session entries.
<Sysname> display session table ipv4 verbose
Slot 1:
Initiator:
  DS-Lite tunnel peer:-
  Protocol: TCP(6)
Responder:
  Source      IP/port: 192.168.1.55/22
  Destination IP/port: 192.168.1.18/1877
  Protocol: TCP(6)
  Inbound interface: GigabitEthernet1/0/2
  Source security zone: Local
State: TCP_SYN_SENT
Application: SSH
Start time: 2011-07-29 19:12:36  TTL: 28s
Initiator->Responder:         1 packets         48 bytes
Responder->Initiator:         0 packets          0 bytes
Table 10 Command output
Initiator
Information about the unicast session from the initiator to the responder.
Responder
Information about the unicast session from the responder to the initiator.
DS-Lite tunnel peer
Address of the DS-Lite tunnel peer.
When the unicast session does not belong to any DS-Lite tunnel, this field displays a hyphen (-).
MPLS L3VPN instance to which the unicast session belongs.
VLAN and inline to which the session belongs during Layer 2 forwarding.
If a parameter is not specified, a hyphens (-) is displayed for the proper field.
Protocol
Transport layer protocol:
·     DCCP.
·     ICMP.
·     ICMPv6.
·     Raw IP.
·     SCTP.
·     TCP.
·     UDP.
·     UDP-Lite.
The number in the brackets indicates the protocol number.
Inbound interface
Interface on which packets are received.
Security zone to which the inbound interface belongs. If the inbound interface does not belong to any security zone, this field displays a hyphen (-).
Unicast session state.
Application
Application layer protocol, FTP or DNS.
If it is an unknown protocol identified by an unknown port, this field displays OTHER.
Start time
Unicast session establishment time.
TTL
Remaining lifetime of the unicast session, in seconds.
Number of packets and bytes from the initiator to the responder.
Number of packets and bytes from the responder to the initiator.
Total number of found unicast session entries.
display session table ipv6
Use display session table ipv6 to display information about IPv6 unicast session entries that match specific criteria.
In standalone mode:
display session table ipv6 [ slot slot-number ] [ [ responder ] { application application-name | destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | interface interface-type interface-number | protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } | vpn-instance vpn-instance-name } * ] [ verbose ]
In IRF mode:
display session table ipv6 [ chassis chassis-number slot slot-number ] [ [ responder ] { application application-name | destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | interface interface-type interface-number | protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port | state { dccp-closereq | dccp-closing | dccp-open | dccp-partopen | dccp-request | dccp-respond | dccp-timewait | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | sctp-closed | sctp-cookie-echoed | sctp-cookie-wait | sctp-established | sctp-shutdown-ack-sent | sctp-shutdown-recd | sctp-shutdown-sent | tcp-close | tcp-close-wait | tcp-est | tcp-fin-wait | tcp-last-ack | tcp-syn-recv | tcp-syn-sent | tcp-syn-sent2 | tcp-time-wait | udp-open | udp-ready | udplite-open | udplite-ready } | vpn-instance vpn-instance-name } * ] [ verbose ]
chassis chassis-number slot slot-number: Specifies a card on a member device. The chassis-number argument represents the member ID of the member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays information for all cards. (In IRF mode.)
responder: Displays entries of IPv6 unicast sessions from the responder to the initiator. If you do not specify this keyword, the command displays entries of IPv6 unicast sessions from the initiator to the responder.
destination-ip start-destination-ip [ end-destination-ip ]: Specifies a destination IPv6 address or IPv6 address range for a unicast session. The start destination-ip argument specifies the start destination IPv6 address. The end destination-ip argument specifies the end destination IPv6 address.
protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite }: Specifies an IPv6 transport layer protocol, including DCCP, ICMPv6, Raw IP, SCTP, TCP, UDP, and UDP-Lite.
source-ip start-source-ip [ end-source-ip ]: Specifies a source IPv6 address or IPv6 address range for a unicast session. The start source-ip argument specifies the start source IPv6 address. The end source-ip argument specifies the end source IPv6 address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays IPv6 unicast session entries in the public network.
verbose: Displays detailed information about IPv6 unicast session entries. If you do not specify this keyword, the command displays brief information about IPv6 unicast session entries.
If you do not specify any parameters, this command displays all IPv6 unicast session entries.
# (In standalone mode.) Display brief information about all IPv6 unicast session entries.
<Sysname> display session table ipv6
Slot 1:
Initiator:
  Source      IP/port: 2011::2/58473
  Destination IP/port: 2011::8/32768
  Protocol: IPV6-ICMP(58)
# (In standalone mode.) Display detailed information about all IPv6 unicast session entries.
<Sysname> display session table ipv6 verbose
Slot 1:
Initiator:
Responder:
  Source      IP/port: 2011::8/58473
  Destination IP/port: 2011::2/33024
State: ICMPV6_REQUEST
Application: OTHER
Start time: 2011-07-29 19:23:41  TTL: 55s
Initiator->Responder:         1 packets         104 bytes
Table 11 Command output
Initiator
Responder
DS-Lite tunnel peer
When the unicast session is not tunneled by DS-Lite, this field displays a hyphen (-).
VLAN and inline to which the unicast session belongs during Layer 2 forwarding.
Protocol
·     DCCP.
·     ICMP.
·     ICMPv6.
·     Raw IP.
·     SCTP.
·     TCP.
·     UDP.
·     UDP-Lite.
Inbound interface
Application
Start time
TTL
display session table multicast ipv4
Use display session table multicast ipv4 to display information about IPv4 multicast session entries that match specific criteria.
In standalone mode:
display session table multicast ipv4 [ slot slot-number ] [ [ responder ] { destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port } * ] [ verbose ]
In IRF mode:
display session table multicast ipv4 [ chassis chassis-number slot slot-number ] [ [ responder ] { destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port } * ] [ verbose ]
responder: Displays entries of IPv4 multicast sessions from the responder to the initiator. If you do not specify this keyword, the command displays entries of IPv4 multicast sessions from the initiator to the responder.
destination-ip start-destination-ip [ end-destination-ip ]: Specifies a destination IPv4 address or IPv4 address range for a multicast session. The start destination-ip argument specifies the start destination IPv4 address. The end destination-ip argument specifies the end destination IPv4 address.
destination-port destination-port: Specifies a destination port by its number. The destination-port argument specifies the destination port of a multicast session. The value range for the destination-port argument is 0 to 65535.
protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite }: Specifies an IPv4 transport layer protocol.
source-ip start-source-ip [ end-source-ip ]: Specifies a source IPv4 address or IPv4 address range for a multicast session. The start source-ip argument specifies the start source IPv4 address. The end source-ip argument specifies the end source IPv4 address.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of a multicast session. The value range for the source-port argument is 0 to 65535.
verbose: Displays detailed information about IPv4 multicast session entries. If you do not specify this keyword, the command displays brief information about IPv4 multicast session entries.
If you do not specify any parameters, this command displays all IPv4 multicast session entries.
# (In standalone mode.) Display brief information about all IPv4 multicast session entries.
<Sysname> display session table multicast ipv4
Slot 1:
Inbound initiator:
  Source      IP/port: 3.3.3.4/1609
  Destination IP/port: 232.0.0.1/1025
  Protocol: UDP(17)
Outbound interface list:
    GigabitEthernet1/0/3
Total sessions found: 3
# (In standalone mode.) Display detailed information about all IPv4 multicast session entries.
<Sysname> display session table multicast ipv4 verbose
Slot 1:
Total sessions found: 0
CPU 1 on slot 2:
Inbound initiator:
  Protocol: UDP(17)
Inbound responder:
  Source      IP/port: 232.0.0.1/1025
  Destination IP/port: 3.3.3.4/1609
  Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
Start time: 2014-03-03 15:59:22  TTL: 18s
Initiator->Responder:            1 packets         84 bytes
Outbound initiator:
  Protocol: UDP(17)
Outbound responder:
  Protocol: UDP(17)
Outbound interface: GigabitEthernet1/0/2
Destination security zone: aaa
State: UDP_OPEN
Application: OTHER
Outbound initiator:
  Protocol: UDP(17)
Outbound responder:
  Protocol: UDP(17)
Outbound interface: GigabitEthernet1/0/3
Destination security zone: bbb
State: UDP_OPEN
Application: OTHER
Table 12 Command output
Inbound initiator
Information about the multicast session from the initiator to the responder on the inbound interface.
Inbound responder
Information about the multicast session from the responder to the initiator on the inbound interface.
Outbound initiator
Information about the multicast session from the initiator to the responder on the outbound interface.
Outbound responder
Information about the multicast session from the responder to the initiator on the outbound interface.
DS-Lite tunnel peer
If the multicast session is not tunneled by DS-Lite, this field displays a hyphen (-).
MPLS L3VPN instance to which the multicast session belongs.
VLAN and inline to which the multicast session belongs during Layer 2 forwarding.
Protocol
·     DCCP.
·     ICMP.
·     Raw IP.
·     SCTP.
·     TCP.
·     UDP.
·     UDP-Lite.
Multicast session state.
Application
Start time
Time when the multicast session was created.
TTL
Remaining lifetime of the multicast session, in seconds.
Inbound interface
Inbound interface of the first packet from the initiator to responder.
Outbound interface
Outbound interface of the first packet from the initiator to responder.
Outbound interfaces of the first packet from the initiator to responder.
Security zone to which the outbound interface belongs. If the outbound interface does not belong to any security zone, this field displays a hyphen (-).
Total number of found multicast session entries.
display session table multicast ipv6
Use display session table multicast ipv6 to display information about IPv6 multicast session entries that match specific criteria.
In standalone mode:
display session table multicast ipv6 [ slot slot-number ] [ [ responder ] { destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port } * ] [ verbose ]
In IRF mode:
display session table multicast ipv6 [ chassis chassis-number slot slot-number ] [ [ responder ] { destination-ip start-destination-ip [ end-destination-ip ] | destination-port destination-port | protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } | source-ip start-source-ip [ end-source-ip ] | source-port source-port } * ] [ verbose ]
responder: Displays entries of IPv6 multicast sessions from the responder to the initiator. If you do not specify this keyword, the command displays entries of IPv4 multicast sessions from the initiator to the responder.
destination-ip start-destination-ip [ end-destination-ip ]: Specifies a destination IPv6 address or IPv6 address range for a multicast session. The start destination-ip argument specifies the start destination IPv6 address. The end destination-ip argument specifies the end destination IPv6 address.
protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite }: Specifies an IPv6 transport layer protocol.
source-ip start-source-ip [ end-source-ip ]: Specifies a source IPv6 address or IPv6 address range for a multicast session. The start source-ip argument specifies the start source IPv6 address. The end source-ip argument specifies the end source IPv6 address.
verbose: Displays detailed information about IPv6 multicast session entries. If you do not specify this keyword, the command displays brief information about IPv6 multicast session entries.
If you do not specify any parameters, this command displays all IPv6 multicast session entries.
# (In standalone mode.) Display brief information about all IPv6 multicast session entries.
<Sysname> display session table multicast ipv6
Slot 1:
Inbound initiator:
  Source      IP/port: 3::4/1617
  Destination IP/port: FF0E::1/1025
  Protocol: UDP(17)
# (In standalone mode.) Display detailed information about all IPv6 multicast session entries.
<Sysname> display session table multicast ipv6 verbose
Slot 1:
Inbound initiator:
  Protocol: UDP(17)
Inbound responder:
  Source      IP/port: FF0E::1/1025
  Destination IP/port: 3::4/1617
  Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
Start time: 2014-03-03 16:10:58  TTL: 23s
Initiator->Responder:            5 packets        520 bytes
Outbound initiator:
  Protocol: UDP(17)
Outbound responder:
  Protocol: UDP(17)
State: UDP_OPEN
Application: OTHER
Outbound initiator:
  Protocol: UDP(17)
Outbound responder:
  Protocol: UDP(17)
Destination security zone: ccc
State: UDP_OPEN
Application: OTHER
Table 13 Command output
Inbound initiator
Inbound responder
Outbound initiator
Outbound responder
DS-Lite tunnel peer
Protocol
·     DCCP.
·     ICMPv6.
·     Raw IP.
·     SCTP.
·     TCP.
·     UDP.
·     UDP-Lite.
Application
Start time
TTL
Inbound interface
Outbound interface
reset session relation-table
Use reset session relation-table to clear relation entries.
In standalone mode:
reset session relation-table [ ipv4 | ipv6 ] [ slot slot-number ]
In IRF mode:
reset session relation-table [ ipv4 | ipv6 ] [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears relation entries for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on a member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears relation entries for all cards. (In IRF mode.)
If you do not specify any parameters, this command clears all relation entries.
# Clear all IPv4 relation entries.
<Sysname> reset session relation-table ipv4
reset session statistics
Use reset session statistics to clear unicast session statistics.
In standalone mode:
reset session statistics [ slot slot-number ]
In IRF mode:
reset session statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears unicast session statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on a member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears unicast session statistics for all cards. (In IRF mode.)
# Clear all unicast session statistics.
<Sysname> reset session statistics
reset session statistics multicast
Use reset session statistics multicast to clear multicast session statistics.
In standalone mode:
reset session statistics multicast [ slot slot-number ]
In IRF mode:
reset session statistics multicast [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears multicast session statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on a member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears multicast session statistics for all cards. (In IRF mode.)
# Clear all multicast session statistics.
<Sysname> reset session statistics multicast
reset session table
Use reset session table to clear IP unicast session entries.
In standalone mode:
reset session table [ slot slot-number ]
In IRF mode:
reset session table [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears unicast session entries for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on a member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears unicast session entries for all cards. (In IRF mode.)
# Clear all unicast session entries.
<Sysname> reset session table
reset session table ipv4
Use reset session table ipv4 to clear information about IPv4 unicast session entries that match specific criteria.
In standalone mode:
reset session table ipv4 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ]
In IRF mode:
reset session table ipv4 [ chassis chassis-number slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on a member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears information for all cards. (In IRF mode.)
source-ip source-ip: Specifies a source IPv4 address. The source-ip argument specifies the source IPv4 address of a unicast session from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv4 address. The destination-ip argument specifies the destination IPv4 address of a unicast session from the initiator to the responder.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of a unicast session from the initiator to the responder. The value range for the source-port argument is 0 to 65535.
destination-port destination-port: Specifies a destination port by its number. The destination-port argument specifies the destination port of a unicast session from the initiator to the responder. The value range for the destination-port argument is 0 to 65535.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you want to clear IPv4 unicast session entries on the public network, do not specify this option.
If you do not specify any parameters, this command clears all IPv4 unicast session entries on the public network.
# Clear all IPv4 unicast session entries.
<Sysname> reset session table ipv4
# Clear the IPv4 unicast session entries with the source IP address of 10.10.10.10.
<Sysname> reset session table ipv4 source-ip 10.10.10.10
reset session table ipv6
Use reset session table ipv6 to clear information about IPv6 unicast session entries that match the specified criteria.
In standalone mode:
reset session table ipv6 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ]
In IRF mode:
reset session table ipv6 [ chassis chassis-number slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ]
source-ip source-ip: Specifies a source IPv6 address. The source-ip argument specifies the source IPv6 address of a unicast session from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv6 address. The destination-ip argument specifies the destination IPv6 address of a unicast session from the initiator to the responder.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you want to clear IPv6 unicast session entries on the public network, do not specify this option.
If you do not specify any parameters, this command clears all IPv6 unicast session entries on the public network.
# Clear all IPv6 unicast session entries.
<Sysname> reset session table ipv6
# Clear the IPv6 unicast session entries with the source IP address of 2011::0002.
<Sysname> reset session table ipv6 source-ip 2011::0002
reset session table multicast
Use reset session table multicast to clear IP multicast session entries.
In standalone mode:
reset session table multicast [ slot slot-number ]
In IRF mode:
reset session table multicast [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command clears multicast session entries for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on a member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command clears multicast session entries for all cards. (In IRF mode.)
# Clear all multicast session entries.
<Sysname> reset session table multicast
reset session table multicast ipv4
Use reset session table multicast ipv4 to clear information about IPv4 multicast session entries that match specific criteria.
In standalone mode:
reset session table multicast ipv4 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ]
In IRF mode:
reset session table multicast ipv4 [ chassis chassis-number slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmp | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ]
source-ip source-ip: Specifies a source IPv4 address. The source-ip argument specifies the source IPv4 address of a multicast session from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv4 address. The destination-ip argument specifies the destination IPv4 address of a multicast session from the initiator to the responder.
source-port source-port: Specifies a source port by its number. The source-port argument specifies the source port of a multicast session from the initiator to the responder. The value range for the source-port argument is 0 to 65535.
destination-port destination-port: Specifies a destination port by its number. The destination-port argument specifies the destination port of a multicast session from the initiator to the responder. The value range for the destination-port argument is 0 to 65535.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you want to clear IPv4 multicast session entries on the public network, do not specify this option.
If you do not specify any parameters, this command clears all IPv4 multicast session entries on the public network.
# Clear all IPv4 multicast session entries.
<Sysname> reset session table multicast ipv4
# Clear the IPv4 multicast session entries with the source IP address of 10.10.10.10.
<Sysname> reset session table multicast ipv4 source-ip 10.10.10.10
reset session table multicast ipv6
Use reset session table multicast ipv6 to clear information about IPv6 multicast session entries that match specific criteria.
In standalone mode:
reset session table multicast ipv6 [ slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ]
In IRF mode:
reset session table multicast ipv6 [ chassis chassis-number slot slot-number ] [ source-ip source-ip ] [ destination-ip destination-ip ] [ protocol { dccp | icmpv6 | raw-ip | sctp | tcp | udp | udp-lite } ] [ source-port source-port ] [ destination-port destination-port ] [ vpn-instance vpn-instance-name ]
source-ip source-ip: Specifies a source IPv6 address. The source-ip argument specifies the source IPv6 address of a multicast session from the initiator to the responder.
destination-ip destination-ip: Specifies a destination IPv6 address. The destination-ip argument specifies the destination IPv6 address of a multicast session from the initiator to the responder.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you want to clear IPv6 multicast session entries on the public network, do not specify this option.
If you do not specify any parameters, this command clears all IPv6 multicast session entries on the public network.
# Clear all IPv6 multicast session entries.
<Sysname> reset session table multicast ipv6
# Clear the IPv6 multicast session entries with the source IP address of 2011::0002.
<Sysname> reset session table multicast ipv6 source-ip 2011::0002
Use session aging-time application to set the aging time for sessions of an application layer protocol or an application.
Use undo session aging-time application to restore the default. If you do not specify an application layer protocol or an application, this command restores the default aging time for all sessions of the supported application layer protocols and applications.
session aging-time application application-name time-value
undo session aging-time application [ application-name ]
The aging time is 1200 seconds for sessions of application layer protocols or applications except for the following sessions:
·     BOOTPC sessions: 120 seconds.
·     BOOTPS sessions: 120 seconds.
·     DNS sessions: 1 second.
·     FTP sessions: 3600 seconds.
·     FTP-DATA sessions: 240 seconds.
·     GPRS-DATA sessions: 60 seconds.
·     GPRS-SIG sessions: 60 seconds.
·     GTP-CONTROL sessions: 60 seconds.
·     GTP-USER sessions: 60 seconds.
·     H.225 sessions: 3600 seconds.
·     H.245 sessions: 3600 seconds.
·     HTTPS sessions: 600 seconds.
·     ILS sessions: 3600 seconds.
·     L2TP sessions: 120 seconds.
·     MGCP-CALLAGENT sessions: 60 seconds.
·     MGCP-GATEWAY sessions: 60 seconds.
·     NETBIOS-DGM sessions: 3600 seconds.
·     NETBIOS-NS sessions: 3600 seconds.
·     NETBIOS-SSN sessions: 3600 seconds.
·     NTP sessions: 120 seconds.
·     PPTP sessions: 3600 seconds.
·     QQ sessions: 120 seconds.
·     RAS sessions: 300 seconds.
·     RIP sessions: 120 seconds.
·     RSH sessions: 60 seconds.
·     RTSP session: 3600 seconds.
·     SCCP sessions: 3600 seconds.
·     SIP sessions: 300 seconds.
·     SNMP sessions: 120 seconds.
·     SNMPTRAP sessions: 120 seconds.
·     SQLNET sessions: 600 seconds.
·     STUN sessions: 600 seconds.
·     SYSLOG sessions: 120 seconds.
·     TACACS-DS sessions: 120 seconds.
·     TFTP sessions: 60 seconds.
·     WHO sessions: 120 seconds.
·     XDMCP sessions: 3600 seconds.
application-name: Specifies an application layer protocol or an application by its name, a case-insensitive string of 1 to 63 characters. Valid characters can be digits, letters, hyphens (-), and underscores (_). The names invalid and other are not allowed. The application layer protocol or application must exist on the device.
time-value: Specifies the aging time in seconds. The value range 1 to 100000.
This command sets the aging time for stable sessions of the specified application layer protocols or applications. For TCP sessions, the stable state is ESTABLISHED. For UDP sessions, the stable state is READY.
For sessions of application layer protocols or applications that are not supported by this command, the aging time is set by the session aging-time state command. For persistent sessions, the aging time is set by the session persistent acl command.
Supported application layer protocols or applications specified in this command depend on the APR module. For information about APR, see Security Configuration Guide.
# Set the aging time for FTP sessions to 1800 seconds.
[Sysname] session aging-time application ftp 1800
# Set the aging time for 126WebEmail sessions to 1800 seconds.
[Sysname] session aging-time application 126WebEmail 1800
display session aging-time application
nbar application
port-mapping
Use session aging-time state to set the aging time for the sessions in a protocol state.
Use undo session aging-time state to restore the default for the sessions in a protocol state. If you do not specify a protocol state, this command restores all aging time for sessions in different protocol states to the default.
session aging-time state { fin | icmp-reply | icmp-request | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | syn | tcp-close | tcp-est | tcp-time-wait | udp-open | udp-ready } time-value
undo session aging-time state [ fin | icmp-reply | icmp-request | icmpv6-reply | icmpv6-request | rawip-open | rawip-ready | syn | tcp-close | tcp-est | tcp-time-wait | udp-open | udp-ready ]
The aging time for sessions in different protocol states is as follows:
·     FIN_WAIT: 30 seconds.
·     ICMP-REPLY: 30 seconds.
·     ICMP-REQUEST: 60 seconds.
·     ICMPv6-REPLY: 30 seconds.
·     ICMPv6-REQUEST: 60 seconds.
·     RAWIP-OPEN: 30 seconds.
·     RAWIP-READY: 60 seconds.
·     TCP SYN-SENT and SYN-RCV: 30 seconds.
·     TCP-CLOSE: 2 seconds.
·     TCP ESTABLISHED: 3600 seconds.
·     TCP TIME-WAIT: 2 seconds.
·     UDP-OPEN: 30 seconds.
·     UDP-READY: 60 seconds.
fin: Specifies the TCP FIN_WAIT state.
icmp-reply: Specifies the ICMP REPLY state.
icmp-request: Specifies the IGMP REQUEST state.
icmpv6-reply: Specifies the ICMPv6 REPLY state.
icmpv6-request: Specifies the IGMPv6 REQUEST state.
rawip-open: Specifies the RAWIP-OPEN state.
rawip-ready: Specifies the RAWIP-READY state.
syn: Specifies the TCP SYN-SENT and SYN-RCV states.
tcp-close: Specifies the TCP CLOSE state.
tcp-est: Specifies the TCP ESTABLISHED state.
tcp-time-wait: Specifies the TCP TIME-WAIT state.
udp-open: Specifies the UDP OPEN state.
udp-ready: Specifies the UDP READY state.
time-value: Specifies the aging time in seconds. For the TCP CLOSE and TCP TIME-WAIT states, the value range is 0 to 100000. For other states, the value range is 1 to 100000.
This command sets the aging time for stable sessions of the application layer protocols that are not supported by the session aging-time application command. For persistent sessions, the aging time is set by the session persistent acl command.
# Set the aging time for TCP sessions in SYN-SENT and SYN-RCV states to 60 seconds.
[Sysname] session aging-time state syn 60
display session aging-time state
session alarm rate-abrupt enable
Use session alarm rate-abrupt enable to enable alarms for abrupt session creation rate changes.
Use undo session alarm rate-abrupt enable to disable alarms for abrupt session creation rate changes.
Alarms are disabled for abrupt session creation rate changes.
This command enables the device to generate alarms for abrupt increase or drop in the session creation rate when the alarm thresholds for abrupt session creation rate changes are crossed.
# Enable alarms for abrupt session creation rate changes.
[Sysname] session alarm rate-abrupt enable
session alarm rate-abrupt threshold
Use session alarm rate-abrupt threshold to set the alarm thresholds for abrupt session creation rate changes.
Use undo session alarm rate-abrupt threshold to restore the default.
session alarm rate-abrupt threshold threshold-value [ base-threshold base-value ]
The session creation rate change threshold is 20%, and the base session creation rate threshold is 10%.
threshold-value: Sets the session creation rate change threshold in percentage. The value range for this argument is 1 to 100.
base-threshold base-value: Sets the base session creation rate threshold in percentage. The value range for this argument is 1 to 100. If you do not specify this option, the default setting applies.
With alarms enabled for abrupt session creation rate changes, the system collects the session creation rate at an interval of 10 seconds and checks whether the following indicators reach the corresponding alarm thresholds:
·     Session creation rate change in percentage—Obtained by dividing the difference between the session creation rates at the beginning and end of a collection interval by the session creation rate at the beginning of the collection interval.
·     Base session creation rate in percentage—Obtained by dividing the session creation rate at the beginning of a collection interval by 100000.
If both of the following conditions are met in a detection interval, the system generates an alarm for the abrupt change of the session creation rate:
·     The session creation rate change threshold is reached.
·     The base session creation rate threshold is crossed.
# Set the session creation rate change threshold to 30%.
[Sysname] session alarm rate-abrupt threshold 30
session alarm try-rate-abrupt enable
Use session alarm try-rate-abrupt enable to enable alarms for abrupt session attempt rate changes.
Use undo session alarm try-rate-abrupt enable to disable alarms for abrupt session attempt rate changes.
Alarms are disabled for abrupt session attempt rate changes.
This command enables the device to generate alarms for abrupt increase or drop in the session creation attempt rate when the alarm thresholds for abrupt session attempt rate changes are reached.
# Enable alarms for abrupt session attempt rate changes.
[Sysname] session alarm try-rate-abrupt enable
session alarm try-rate-abrupt threshold
Use session alarm try-rate-abrupt threshold to set the alarm thresholds for abrupt session attempt rate changes.
Use undo session alarm try-rate-abrupt threshold to restore the default.
session alarm try-rate-abrupt threshold threshold-value [ base-threshold base-value ]
The session attempt rate change threshold is 20%, and the base session attempt rate threshold is 10%.
threshold-value: Sets the session attempt rate change threshold in percentage. The value range for this argument is 1 to 100.
base-threshold base-value: Sets the base session attempt rate threshold in percentage. The value range for this argument is 1 to 100. If you do not specify this option, the default setting applies.
With alarms enabled for abrupt session attempt rate changes, the system collects the session creation attempt rate at an interval of 10 seconds and checks whether the following indicators reach the corresponding alarm thresholds:
·     Session attempt rate change in percentage—Obtained by dividing the difference between the session creation attempt rates at the beginning and end of a collection interval by the session creation attempt rate at the beginning of the collection interval.
·     Base session attempt rate in percentage—Obtained by dividing the session creation attempt rate at the beginning of a collection interval by 100000.
If both of the following conditions are met in a detection interval, the system generates an alarm for the abrupt change of the session creation attempt rate:
·     The session attempt rate change threshold is reached.
·     The base session attempt rate threshold is crossed.
# Set the session attempt rate change threshold to 30%.
[Sysname] session alarm try-rate-abrupt threshold 30
session alarm usage-abrupt enable
Use session alarm usage-abrupt enable to enable alarms for abrupt session table usage changes.
Use undo session alarm usage-abrupt enable to disable alarms for abrupt session table usage changes.
Alarms are disabled for abrupt session table usage changes.
This command enables the device to generate alarms for abrupt increase or drop in the session table usage when the alarm thresholds for abrupt session table usage changes are reached.
# Enable alarms for abrupt session table usage changes.
[Sysname] session alarm usage-abrupt enable
session alarm usage-abrupt threshold
Use session alarm usage-abrupt threshold to set the alarm thresholds for abrupt session table usage changes.
Use undo session alarm usage-abrupt threshold to restore the default.
session alarm usage-abrupt threshold threshold-value [ base-threshold base-value ]
The session table usage change threshold is 20%, and the base session table usage threshold is 10%.
threshold-value: Sets the session table usage change threshold in percentage. The value range for this argument is 1 to 100.
base-threshold base-value: Sets the base session table usage threshold in percentage. The value range for this argument is 1 to 100. If you do not specify this option, the default setting applies.
With alarms enabled for abrupt session table usage changes, the system collects the session table usage at an interval of 10 seconds and checks whether the following indicators reach the corresponding alarm thresholds:
·     Session table usage change in percentage—Obtained by dividing the difference between the session entry counts at the beginning and end of a collection interval by the session entry count at the beginning of the collection interval.
·     Base session table usage in percentage—Obtained by dividing the session entry count at the beginning of a collection interval by the supported maximum number of session entries.
If both of the following conditions are met in a detection interval, the system generates an alarm for the abrupt change of the session table usage:
·     The session table usage change threshold is reached.
·     The base session table usage threshold is crossed.
# Set the session table usage change threshold to 30%.
[Sysname] session alarm usage-abrupt threshold 30
session alg fragment
Use session alg fragment to enable ALG to process IP fragments and TCP segments.
Use undo session alg fragment to disable ALG from processing IP fragments and TCP segments.
session alg fragment sip
undo session alg fragment sip
ALG does not process IP fragments and TCP segments.
sip: Specifies IP fragments and TCP segments of SIP.
This command enables ALG to process IP fragments and TCP segments of specified protocols. In the current software version, ALG can process only IP fragments and TCP segments of SIP.
# Enable ALG to process IP fragments and TCP segments of SIP.
<Sysname> system
[Sysname] session alg fragment sip
session log { bytes-active | packets-active }
Use session log { bytes-active | packets-active } to set a threshold for traffic-based logging.
Use undo session log { bytes-active | packets-active } to restore the default.
session log { bytes-active bytes-value | packets-active packets-value }
No threshold is set for traffic-based logging.
bytes-value: Specifies the byte-based threshold in the range of 1 to 100000 MB.
packets-value: Specifies the packet-based threshold in the range of 1 to 100000 mega-packets.
For this command to take effect, make sure the session statistics collection for software fast forwarding feature is enabled.
If you set both the traffic-based and time-based logging, the device outputs a session log when whichever is reached. After outputting a session log, the device resets the traffic counter and restarts the interval for the session.
# Configure the device to output session logs on a per-10-mega-packet basis.
[Sysname] session statistics enable
[Sysname] session log packets-active 10
session log enable
session log enable
Use session log enable to enable session logging.
Use undo session log enable to disable session logging.
session log enable { ipv4 | ipv6 } [ acl acl-number ] { inbound | outbound }
undo session log enable { ipv4 | ipv6 } [ acl acl-number ] { inbound | outbound }
Session logging is disabled.
Interface view
ipv4: Logs IPv4 sessions.
ipv6: Logs IPv6 sessions.
acl acl-number: Specifies an ACL by its number in the range of 2000 to 3999. If you do not specify an ACL, this command enables session logging for all IPv4 or IPv6 sessions on the interface.
inbound: Specifies the inbound direction.
outbound: Specifies the outbound direction.
If you do not specify the inbound or the outbound keyword, this command enables session logging on both directions.
A maximum of one IPv4 ACL and one IPv6 ACL can be applied to each direction.
After session logging is enabled, the device outputs session logs as follows:
·     Outputs a session log when the specified traffic threshold or interval is reached.
·     Outputs a session log when a session entry is created or removed only if the logging for session creation or deletion is enabled.
The session logging feature must work with the flow log or fast log output feature to generate session logs. Session logs can be output in flow log or fast log output format. By default, they are output in flow log format. For information about flow log and fast log output, see Network Management and Monitoring.
# Enable IPv4 session logging in the inbound direction of GigabitEthernet 1/0/1.
[Sysname] session log flow-begin
[Sysname] session log flow-end
[Sysname-GigabitEthernet1/0/1] session log enable ipv4 inbound
# Enable session logging on GigabitEthernet 1/0/2 for IPv4 sessions that match ACL 2050 in the outbound direction.
[Sysname-GigabitEthernet1/0/2] session log enable ipv4 acl 2050 outbound
# Enable session logging on GigabitEthernet 1/0/3 for IPv6 sessions that match ACL 2050 in the outbound direction.
[Sysname] interface gigabitethernet 1/0/3
[Sysname-GigabitEthernet1/0/3] session log enable ipv6 acl 2050 outbound
session log bytes-active
session log time-active
Use session log flow-begin to enable logging for session creation.
Use undo session log flow-begin to disable logging for session creation.
Logging for session creation is disabled.
For the device to output a session log when a session entry is created, make sure both session logging and logging for session creation are enabled.
# Enable logging for session creation.
session log enable
Use session log flow-end to enable logging for session deletion.
Use undo session log flow-end to disable logging for session deletion.
Logging for session deletion is disabled.
For the device to output a session log when a session entry is deleted, make sure both session logging and logging for session deletion are enabled.
# Enable logging for session deletion.
session log enable
Use session log time-active to set the time-based session logging.
Use undo session log time-active to restore the default.
session log time-active time-value
The device does not output session logs.
time-value: Specifies the interval in minutes. The value range for the time-value argument is 10 to 120 and the value must be integer times of 10.
If you set both time-based and traffic-based logging, the device outputs a session log when whichever is reached. After outputting a session log, the device resets the traffic counter and restarts the interval for the session.
# Configure the device to output session logs every 50 minutes.
<Sysname> system
[Sysname] session log time-active 50
session log enable
Use session persistent acl to specify persistent sessions.
Use undo session persistent acl to restore the default.
session persistent acl [ ipv6 ] acl-number [ aging-time time-value ]
undo session persistent acl [ ipv6 ] acl-number
No persistent sessions exist.
ipv6: Specifies an IPv6 ACL. To specify an IPv4 ACL, do not specify this keyword.
aging-time time-value: Specifies the aging time for persistent sessions in hours. The value range for the time-value argument is 0 to 360, and the default value is 24. To disable the aging for persistent sessions, set the value to 0.
This command is effective only on TCP sessions in ESTABLISHED state.
For a TCP session in ESTABLISHED state, the priority of the aging time is as follows:
·     Aging time for persistent sessions.
·     Aging time for sessions of application layer protocols.
·     Aging time for sessions in different protocol states.
A persistent session is not removed until one of the following events occurs:
·     The session entry ages out.
·     The device receives a connection close request from the initiator or responder.
·     You manually clear the session entries.
The configuration of persistent sessions applies only to new sessions. It has no effect on existing sessions.
Repeat this command to use multiple ACLs to specify persistent sessions.
# Specify IPv4 ACL 2000 for identifying persistent sessions and set the aging time to 72 hours.
[Sysname] session persistent acl 2000 aging-time 72
# Specify IPv6 ACL 3000 for identifying persistent sessions and set the aging time to 100 hours.
[Sysname] session persistent acl ipv6 3000 aging-time 100
session state-machine mode
Use session state-machine mode to set the mode of session state machine.
Use undo session state-machine mode to restore the default.
session state-machine mode { compact | loose }
The session state machine is in strict mode.
compact: Specifies compact mode.
loose: Specifies loose mode.
When asymmetric-path traffic exists in a hot backup system operating in session active/standby mode, set the mode of session state machine to loose to avoid abnormal traffic loss.
When asymmetric-path traffic exists in a hot backup system operating in session dual-active mode, set the mode of session state machine to compact for disconnected sessions to age out timely.
As a best practice, change the mode of session state machine only when asymmetric-path traffic exists. This feature degrades performance of session-based security check. Make sure you are fully aware of the impact of this command when you use it on a live network.
# Set the mode of session state machine to loose.
[Sysname] session state-machine mode loose
Use session statistics enable to enable session statistics collection for software fast forwarding.
Use undo session statistics enable to disable session statistics collection for software fast forwarding.
Session statistics collection is disabled for software fast forwarding.
This command enables the device to collect the session-based outbound and inbound packets and bytes for software fast forwarding.
To display statistics per session, use the display session table command. To display statistics per packet type, use the display session statistics command.
This command is CPU and memory intensive. Before using this command, make sure you fully understand its impact on system performance.
# Enable session statistics collection for software fast forwarding.
session synchronization { dns | http } *
Use session synchronization { dns | http } * to enable session synchronization for DNS, HTTP, or both.
Use undo session synchronization { dns | http } * to disable session synchronization for DNS, HTTP, or both.
Session synchronization is disabled for DNS and HTTP.
dns: Specifies the DNS protocol.
http: Specifies the HTTP protocol.
DNS or HTTP connections usually do not last long. When a DNS or HTTP connection is terminated because of an active/standby switchover, the client will immediately reinitiate a connection request. The connection exception is barely noticed.
DNS and HTTP sessions do not require session synchronization except for the following conditions:
·     Users are aware that the current HTTP or DNS sessions will last for a long time.
·     HTTP or DNS session backup is required.
For this command to take effect, you must also configure the session synchronization enable command.
This command takes effect only on sessions of the application protocols HTTP and DNS. Sessions of other application protocols will be backed up if the session synchronization enable command is configured.
# Enable session synchronization for stateful failover, and enable session synchronization for HTTP.
[Sysname] session synchronization enable
[Sysname] session synchronization http
Use session synchronization enable to enable session synchronization for stateful failover.
Use undo session synchronization enable to disable session synchronization for stateful failover.
session synchronization enable [ asymmetric ]
Session synchronization for stateful failover is disabled.
asymmetric: Specifies asymmetric traffic. If you do not specify this keyword, this command supports only symmetric traffic.
This features enables the master and backup devices to synchronize sessions and dynamic entries of session-based services.
In a network that has asymmetric traffic, heavy service traffic might cause service delay or service unavailable because sessions cannot be backed up timely. For example, one device forwards the TCP SYN packets, and another device forwards its ACK packets. If the session tables of the two devices are not synchronized, the TCP packets will be dropped because of state error. To resolve this issue, use the session synchronization enable asymmetric command.
This command cannot be used together with the hot-backup enable command. For information about the hot-backup enable command, see RMB in High Availability Command Reference.
# Enable session synchronization for stateful failover.
<Sysname> session synchronization enable
# Enable session synchronization for both symmetric and asymmetric traffic.
<Sysname> session synchronization enable asymmetric
hot-backup enable (High Availability Command Reference)
