10-MPLS Command Reference
HomeSupportRoutersMSR5600 Series(Comware V7)Reference GuidesCommand ReferencesH3C MSR 5600 Routers Command Reference(V7)-R6728-6W10010-MPLS Command Reference
10-VPLS commands
10-VPLS commands 289.69 KB
VPLS commands
The MSR 56-60 and MSR 56-80 devices installed with MPU-100-G do not support parameters or commands that are available only in IRF mode.
address-family l2vpn
Use address-family l2vpn to create the BGP L2VPN address family and enter its view, or enter the view of the existing BGP L2VPN address family.
Use undo address-family l2vpn to delete the BGP L2VPN address family and all settings from BGP L2VPN address family view.
No BGP L2VPN address family exists.
BGP instance view
To establish a BGP PW to a remote PE, you must execute the peer enable command in BGP L2VPN address family view to enable the remote PE.
# Create the BGP L2VPN address family and enter BGP L2VPN address family view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn
[Sysname-bgp-default-l2vpn]
peer enable (Layer 3—IP Routing Command Reference)
auto-discovery
Use auto-discovery to enable a VSI to automatically discover neighbors through BGP and enter auto-discovery VSI view.
Use undo auto-discovery to restore the default.
auto-discovery bgp
undo auto-discovery
A VSI does not use BGP to automatically discover neighbors.
VSI view
bgp: Enables the VSI to automatically discover neighbors through BGP.
After the remote PEs are discovered through BGP, you can use the signaling-protocol command to specify the signaling protocol (LDP or BGP) to establish PWs to the discovered remote PEs.
# Enable VSI aaa to automatically discover neighbors through BGP and enter auto-discovery VSI view.
[Sysname] vsi aaa
[Sysname-vsi-aaa] auto-discovery bgp
[Sysname-vsi-aaa-auto]
display l2vpn pw
display l2vpn vsi
backup-peer
Use back-peer in VSI LDP PW view to configure a VSI LDP backup PW and enter its view, or enter the view of an existing VSI LDP backup PW.
Use back-peer in VSI static PW view to configure a VSI static backup PW and enter its view, or enter the view of an existing VSI static backup PW.
Use undo backup-peer to restore the default.
VSI LDP PW view:
backup-peer ip-address [ pw-id pw-id ] [ pw-class class-name | tunnel-policy tunnel-policy-name ] *
undo backup-peer ip-address pw-id pw-id
VSI static PW view:
backup-peer ip-address [ pw-id pw-id ] in-label label-value out-label label-value [ pw-class class-name | tunnel-policy tunnel-policy-name ] *
No backup PWs exist for VPLS.
VSI LDP PW view
VSI static PW view
ip-address: Specifies the LSR ID of the peer PE on the backup PW.
pw-id pw-id: Specifies a PW ID for the backup PW, in the range of 1 to 4294967295.
in-label label-value: Specifies the incoming label for the backup PW. The value range for the label-value argument is 16 to 1023.
out-label label-value: Specifies the outgoing label for the backup PW. The value range is 16 to 1048575.
pw-class class-name: Specifies a PW class by its name, a case-sensitive string of 1 to 19 characters. You can specify a PW class to configure the PW data encapsulation type and control word for the backup PW. If you do not specify a PW class, the PW data encapsulation type of the backup PW is VLAN and the backup PW does not support control word.
tunnel-policy tunnel-policy-name: Specifies a tunnel policy by its name, a case-insensitive string of 1 to 19 characters. If you do not specify a tunnel policy, the backup PW uses the default tunnel policy.
This command configures a backup PW for a PW to implement PW redundancy. The backup PW is used when the primary PW fails.
You must assign the backup PW a different peer LSR ID and PW ID than any existing VPLS PWs or cross-connect PWs.
A backup PW has the same hub and no-split-horizon attributes as its primary PW.
If both the default PW ID in the default-pw-id command and a PW ID in the backup-peer command are configured, the PW ID in the backup-peer command is used. If only the default PW ID is configured, the default PW ID is used. If no default PW ID is configured, you must provide a PW ID in the backup-peer command.
When you add a static PW, you must make sure that static PW uses a different incoming label than an existing static LSP or static CRLSP. If the incoming label is duplicated, you cannot make the static PW take effect by changing the incoming label of the static LSP or CRLSP. Instead, you must delete the static PW and then reconfigure the static PW with an unused incoming label.
# Configure a primary and a backup LDP PW for VSI vpn1, and specify the peer PE address and PW ID of the primary PW as 4.4.4.4 and 100, and those of the backup PW as 5.5.5.5 and 200.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] pwsignaling ldp
[Sysname-vsi-vpn1-ldp] peer 4.4.4.4 pw-id 100
[Sysname-vsi-vpn1-ldp-4.4.4.4-100] backup-peer 5.5.5.5 pw-id 200
[Sysname-vsi-vpn1-ldp-4.4.4.4-100-backup]
default-pw-id
display l2vpn ldp
display l2vpn pw
peer
bandwidth (VSI LDP PW view/VSI static PW view)
Use bandwidth to set the expected bandwidth for a PW.
bandwidth bandwidth-value
undo bandwidth
The expected bandwidth is 10000000 kbps.
VSI LDP PW view
VSI static PW view
bandwidth-value: Specifies the expected bandwidth in the range of 1 to 10000000 kbps.
# Set the expected bandwidth to 10000 kbps for a static PW.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] pwsignaling static
[Sysname-vsi-vpn1-static] peer 5.5.5.5 pw-id 200 in-label 100 out-label 200
[Sysname-vsi-vpn1-static-5.5.5.5-200] bandwidth 10000
# Set the expected bandwidth to 10000 kbps for an LDP PW.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1-ldp-4.4.4.4-100] bandwidth 10000
default-pw-id
Use default-pw-id to set the default PW ID for a VSI.
Use undo default-pw-id to restore the default.
default-pw-id default-pw-id
undo default-pw-id
No default PW ID is set for a VSI.
VSI view
default-pw-id: Specifies the default PW ID for the VSI, in the range of 1 to 4294967295.
After you set the default PW ID for a VSI, you do not need to provide a PW ID in the backup-peer and peer commands.
# Set the default PW ID to 200 for VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] default-pw-id 200
backup-peer
peer
description
Use description to configure a description for a VSI.
No description is configured for a VSI.
VSI view
text: Specifies a description, a case-sensitive string of 1 to 80 characters.
# Configure a description of vsi for vpn1 for VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] description vsi for vpn1
display l2vpn vsi
display bgp l2vpn auto-discovery
Use display bgp l2vpn auto-discovery to display VPLS PE information discovered by BGP.
display bgp [ instance instance-name ] l2vpn auto-discovery [ peer ip-address { advertised | received } [ statistics ] | route-distinguisher route-distinguisher [ pe-address ip-address [ advertise-info ] ] | statistics ]
instance instance-name: Displays VPLS PE information in a BGP instance. The instance-name argument specifies the BGP instance name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays VPLS PE information in the default BGP instance.
peer ip-address: Displays VPLS PE information advertised to or received from a BGP peer specified by its IP address.
advertised: Displays VPLS PE information advertised to the BGP peer.
received: Displays VPLS PE information received from the BGP peer.
statistics: Displays BGP VPLS PE statistics.
route-distinguisher route-distinguisher: Displays BGP VPLS PE information for the route distinguisher (RD), which is a string of 3 to 21 characters. You can specify an RD in one of the following formats:
·     16-bit AS number:32-bit user-defined number. For example, 101:3.
·     32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
·     32-bit AS number:16-bit user-defined number, where the AS number must be equal to or greater than 65536. For example, 65536:1.
pe-address ip-address: Displays BGP VPLS PE information for a PE. The ip-address argument specifies the PE address.
advertise-info: Displays BGP VPLS PE advertisement information.
If you do not specify any parameters, this command displays brief information about all VPLS PEs discovered by BGP.
# Display brief information about all VPLS PEs discovered by BGP in the default BGP instance.
<Sysname> display bgp l2vpn auto-discovery
 BGP local router ID is 192.168.1.140
 Total number of automatically discovered PEs: 3
 Route distinguisher: 2:2
     PE address      Nexthop         VPLS ID
* >  1.1.1.9         0.0.0.0         100:100
* >i 2.2.2.9         2.2.2.9         100:100
* >i 3.3.3.9         3.3.3.9         100:100
Status codes
Status codes:
·     * – valid—Valid route.
·     > – best—Best route.
·     d – damped—Dampened route.
·     h – history—History route.
·     s – suppressed—Suppressed route.
·     S – Stale—Stale route.
·     i – internal—Internal route.
·     e – external—External route.
Origin
Origin of the label block:
·     i – IGP—Originated in the AS.
·     e – EGP—Learned through EGP.
·     ? – incomplete—Unknown origin.
# Display detailed information about the VPLS PE that has RD 2:2 and IP address 2.2.2.9 in the default BGP instance.
<Sysname> display bgp l2vpn auto-discovery route-distinguisher 2:2 pe-address 2.2.2.9
 BGP local router ID: 192.168.1.140
 Local AS number: 100
 Total number of automatically discovered PEs: 1
 Paths:   1 available, 1 best
 Original nexthop: 2.2.2.9
 Ext-Community   : <RT: 2:2>, <VPLS ID: 100:100>
 AS-path         : (null)
 Origin          : igp
 Attribute value : localpref 100, pref-val 0
 PE address      : 2.2.2.9
 State           : valid, internal, best
Original nexthop
Original next hop. If the VPLS PE information was obtained from a BGP update, this field displays the next hop address in the received update.
Ext-Community
Extended community attribute:
·     RTRoute Target.
·     VPLS ID—VPLS instance identifier.
AS-path
AS path attribute, which records all ASs that the VPLS PE information passed to prevent routing loops.
Origin
·     igp—Originated in the AS.
·     egp—Learned through EGP.
·     incomplete—Unknown origin.
Attribute value
Attribute of the VPLS PE information:
·     MED—Multi-Exit Discriminator attribute.
·     localpref—Local preference value.
·     pref-val—Preferred value.
·     pre—Preference value.
State of the VPLS PE information:
·     valid.
·     internal.
·     external.
·     local.
·     best.
# Display BGP advertisement information for the specified VPLS PE in the default BGP instance.
<Sysname> display bgp l2vpn auto-discovery route-distinguisher 2:2 pe-address 1.1.1.9 advertise-info
 Paths:   1 best
 VPLS ID         : 100:100
 PE address      : 1.1.1.9
 Advertised to peers (2 in total):
    2.2.2.9
    3.3.3.9
display bgp l2vpn signaling
Use display bgp l2vpn signaling to display VPLS label block information maintained by BGP.
display bgp [ instance instance-name ] l2vpn signaling [ peer ip-address { advertised | received } [ statistics ] | route-distinguisher route-distinguisher [ site-id site-id [ label-offset label-offset [ advertise-info ] ] ] | statistics ]
instance instance-name: Displays VPLS label block information in a BGP instance. The instance-name argument specifies the BGP instance name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays VPLS label block information in the default BGP instance.
peer ip-address: Displays VPLS label block information advertised to or received from a BGP peer. The ip-address argument specifies the peer address.
advertised: Displays VPLS label block information advertised to the BGP peer.
received: Displays VPLS label block information received from the BGP peer.
statistics: Displays VPLS label block statistics.
route-distinguisher route-distinguisher: Displays BGP VPLS label block information for the route distinguisher (RD), which is a string of 3 to 21 characters. You can specify an RD in one of the following formats:
site-id site-id: Displays BGP VPLS label block information for a site. The site-id argument specifies the site ID. The site ID range is 0 to 120.
label-offset label-offset: Displays information about the BGP VPLS label block with an offset. The label-offset argument specifies the offset in the range of 0 to 65535.
advertise-info: Displays BGP VPLS label block advertisement information.
If you do not specify any parameters, this command displays brief information about all BGP VPLS label blocks.
# Display brief information about all BGP VPLS label blocks in the default BGP instance.
<Sysname> display bgp l2vpn signaling
 BGP local router ID is 192.168.1.135
 Total number of label blocks: 2
     Site ID  LB offset  LB range  LB base    Nexthop
* >  1        0          10        1034       192.1.1.1
* >i 2        0          10        1162       192.3.3.3
Status codes
Status codes:
Origin
LB offset
Offset of the label block.
LB range
Size of the label block.
LB base
Initial value of the label block.
# Display detailed information about the BGP VPLS label block that has RD 1:1, site ID 2, and offset 0 in the default BGP instance.
<Sysname> display bgp l2vpn signaling route-distinguisher 1:1 site-id 2 label-offset 0
 Route distinguisher: 1:1
 Total number of label blocks: 1
 Ext-Community   : <RT: 1:1>, <L2VPN info: MTU 1500, Encap type BGP VPLS>
 AS-path         : (null)
 Origin          : igp
 Site ID         : 2
 LB offset       : 0
 LB base         : 1418
 LB range        : 10
Original nexthop
Original next hop. If the label block was obtained from a BGP route update, this field displays the next hop address in that BGP route update.
Ext-Community
·     RT—Route target.
·     L2VPN info—L2VPN information, including the MTU and encapsulation type.
AS-path
AS path attribute, which records all ASs that the label block passed to prevent routing loops.
Origin
Attribute value
Attribute of the label block:
LB offset
LB base
LB range
State of the label block:
·     valid.
·     internal.
·     external.
·     local.
·     best.
# Display BGP advertisement information for the specified VPLS label block in the default BGP instance.
<Sysname> display bgp l2vpn signaling route-distinguisher 1:1 site-id 1 label-offset 0 advertise-info
 Paths:   1 best
 Site ID         : 1
 LB offset       : 0
 LB base         : 1418
 LB range        : 10
    2.2.2.9
    3.3.3.9
Table 5 Command output
LB offset
LB base
LB range
display l2vpn auto-discovery
Use display l2vpn auto-discovery to display information about automatically discovered VPLS PEs.
display l2vpn auto-discovery [ peer ip-address ] [ vsi vsi-name ]
peer ip-address: Displays information about the specified VPLS PE. If you do not specify a PE, this command displays information about all automatically discovered VPLS PEs.
vsi vsi-name: Displays automatically discovered VPLS PEs for a VSI. The vsi-name argument specifies the VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays automatically discovered VPLS PEs for all VSIs.
# Display information about all automatically discovered VPLS PEs.
<Sysname> display l2vpn auto-discovery
Total number of automatically discovered peers: 2
VSI Name: bbb
RD                    PE_address      VPLS ID               Nexthop
2:2                   1.1.1.9         100:100               1.1.1.9
2:2                   3.3.3.9         100:100               3.3.3.9
route-distinguisher
vpls-id
display l2vpn bgp
Use display l2vpn bgp to display VPLS label block information.
display l2vpn bgp [ local | peer ip-address ] [ vsi vsi-name ] [ verbose ]
local: Displays local VPLS label block information.
peer ip-address: Displays VPLS label block information received from a remote peer. The ip-address argument specifies the peer address.
vsi vsi-name: Displays VPLS label block information for a VSI. The vsi-name argument specifies the VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays VPLS label block information for all VSIs.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
If you specify a peer, this command displays both the label block received from the peer and the local label block that matches the received label block.
If you do not specify a peer or local, this command displays label blocks received from all peers and local label blocks that match the received ones.
A local label block matches a received label block if the following condition is met: local label block LO ≤ remote site ID ≤ local label block LO + local label block LR – 1.
# Display brief information about label blocks received from all peers.
<Sysname> display l2vpn bgp
Total number of BGP PWs: 2, 2 up, 0 down
VSI Name: aaa
Rmt Site   Offset  RD                    Nexthop          In/Out Label     State
1          0       1:1                   1.1.1.9          1419/1420        Up
3          0       1:1                   3.3.3.9          1421/1282        Up
Table 6 Command output
Rmt Site
ID of the remote site.
Offset
# Display detailed information about label blocks received from all peers.
<Sysname> display l2vpn bgp verbose
VSI Name: aaa
 Remote Site ID     : 1
 Offset             : 0
 RD                 : 1:1
 PW State           : Up
 Encapsulation      : BGP-VPLS
 MTU                : 1500
 MTU Negotiation    : Enabled
 Nexthop            : 1.1.1.9
 Local VC Label     : 1419
 Remote VC Label    : 1420
 Link ID            : 9
 Local Label Block  : 1418/10/0
 Remote Label Block : 1418/10/0
 Export Route Target: 1:1
Table 7 Command output
MTU Negotiation
PW MTU negotiation state.
Local VC Label
Incoming label of the PW.
Remote VC Label
Outgoing label of the PW.
Link ID
Link ID of the PW.
Local Label Block
Local label block: label base/label range/label-block offset.
Remote Label Block
Remote label block: label base/label range/label-block offset.
Export Route Target
Route target of the remote label block.
# Display brief information about all local label blocks.
<Sysname> display l2vpn bgp local
VSI Name: aaa
Site   Offset  Range  Label Base    RD
2      0       10     1418          1:1
Table 8 Command output
Offset
Range
Range of the label block.
Label Base
RD
RD of the label block. If no RD is configured, this field displays a hyphen (-).
# Display detailed information about all local label blocks.
<Sysname> display l2vpn bgp local verbose
VSI Name: aaa
 Site ID            : 2
 Offset             : 0
 RD                 : 1:1
 Range              : 10
 Label Base         : 1418
 Link ID            : 8,9,10,11,12,13,14,15,16
Table 9 Command output
Offset
RD
Range
Label Base
Link ID
Link IDs of the PWs established using the label block.
display l2vpn pw
display l2vpn forwarding
Use display l2vpn forwarding to display L2VPN forwarding information.
In standalone mode:
display l2vpn forwarding { ac | pw } [ vsi vsi-name ] [ slot slot-number ] [ verbose ]
In IRF mode:
display l2vpn forwarding { ac | pw } [ vsi vsi-name ] [ chassis chassis-number slot slot-number ] [ verbose ]
ac: Displays AC forwarding information.
pw: Displays PW forwarding information.
vsi vsi-name: Displays L2VPN forwarding information for a VSI. The vsi-name argument specifies the VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays L2VPN forwarding information for all VSIs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays L2VPN forwarding information for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays L2VPN forwarding information for the global active MPU. (In IRF mode.)
# Display brief AC forwarding information for all VSIs.
<Sysname> display l2vpn forwarding ac
Total number of VSIs: 1
Total number of ACs: 2
AC                               VSI Name                        Link ID
GE1/0/1                          test                            3
GE1/0/2                          test                            4
Table 10 Command output
Total number of VSIs, including VSIs that are not bound to any ACs.
AC
AC type: Layer 3 interface.
Link ID
Link ID of the AC in the VSI.
# Display detailed AC forwarding information for all VSIs.
<Sysname> display l2vpn forwarding ac verbose
VSI Name: vpls1
  Interface: GE1/0/1
    Link ID      : 0
    Access Mode  : Ethernet
  Interface: GE1/0/2
    Link ID      : 1
Table 11 Command output
Link ID
Access Mode
AC access mode:
·     VLAN.
·     Ethernet.
AC Attributes
Hub-spoke attribute of the AC:
·     Hub link—The AC is the hub link in the VPLS hub-spoke network.
·     Spoke link—The AC is a spoke link in the VPLS hub-spoke network.
This field is displayed only when the VSI bound to the AC has the hub-spoke attribute.
# Display brief PW forwarding information for all VSIs.
<Sysname> display l2vpn forwarding pw
Total number of PWs: 2, 2 up, 0 blocked, 0 down
VSI Name                        In/Out Label    NID        Link ID    State
aaa                             1272/1275       1034       8          Up
aaa                             1271/1273       1035       9          Up
Table 12 Command output
Total number of VSIs, including VSIs that do not contain PWs.
NID
NHLFE ID for the public tunnel that carries the PW.
If equal-cost tunnels are available, this field displays multiple NIDs.
If no tunnel is available, this field displays None.
Link ID
Link ID of the PW in the VSI.
PW state: Up, Down, or Blocked.
Blocked indicates that the PW is blocked.
# Display detailed PW forwarding information for all VSIs.
<Sysname> display l2vpn forwarding pw verbose
VSI Name: aaa
  Link ID: 8
    PW Type         : VLAN                  PW State : Up
    In Label        : 1272                  Out Label: 1275
    MTU             : 1500
    PW Attributes   : Main
    VCCV CC         : Router-Alert
    VCCV BFD        : Fault Detection with BFD
    Tunnel Group ID : 0x960000000
    Tunnel NHLFE IDs: 1034
Table 13 Command output
Link ID
PW Type
Data encapsulation type of the PW.
PW State
PW Attributes
PW attribute:
·     Main—The PW is the primary PW.
·     Backup—The PW is the backup PW.
·     No-split-horizon—Split horizon forwarding is disabled.
·     Hub link—The PW is the hub link in the VPLS hub-spoke network.
·     Spoke link—The PW is a spoke link in the VPLS hub-spoke network.
VCCV CC
VCCV CC type:
·     Control-Word—Control word.
·     Router-Alert—MPLS Router Alert Label.
·     TTL—TTL expiry (MPLS PW Label with TTL=1.)
This field displays a hyphen (-) if no VCCV CC type is specified.
VCCV BFD
VCCV BFD type:
·     Fault Detection with BFD—BFD packets use IP/UDP encapsulation (with IP/UDP headers).
·     Fault Detection with Raw-BFD—BFD packets use PW-ACH encapsulation (without IP/UDP headers).
This field displays a hyphen (-) if BFD is not used to verify PW connectivity.
Tunnel Group ID
ID of the tunnel group for the PW.
Tunnel NHLFE IDs
NHLFE ID of the public tunnel that carries the PW.
display l2vpn interface
Use display l2vpn interface to display L2VPN information for Layer 3 interfaces bound to VSIs.
display l2vpn interface [ vsi vsi-name | interface-type interface-number ] [ verbose ]
vsi vsi-name: Displays L2VPN information for the Layer 3 interfaces bound to a VSI. The vsi-name argument specifies the VSI name, a case-sensitive string of 1 to 31 characters.
interface-type interface-number: Displays L2VPN information for an interface specified by its type and number.
If you do not specify any parameters, this command displays L2VPN information for all Layer 3 interfaces bound to VSIs.
# Display brief L2VPN information for all Layer 3 interfaces bound to VSIs.
<Sysname> display l2vpn interface
Total number of interfaces: 2, 2 up, 0 down
Interface                Owner                           Link ID   State    Type
GE1/0/1                  vpls1                           1         Up       VSI
GE1/0/2                  vpls1                           2         Down     VSI
Table 14 Command output
Owner
VSI name.
Link ID
L2VPN type. The value can only be VSI on a VPLS network.
# Display detailed L2VPN information for all Layer 3 interfaces bound to VSIs.
<Sysname> display l2vpn interface verbose
Interface: GE1/0/1
    Owner         : vsi1
    Link ID       : 0
    State         : Up
    Type          : VSI
Table 15 Command output
Owner
VSI name.
Link ID
Physical status of the interface: Up or Down.
display l2vpn ldp
Use display l2vpn ldp to display LDP PW label information.
display l2vpn ldp [ peer ip-address [ pw-id pw-id | vpls-id vpls-id ] | vsi vsi-name ] [ verbose ]
peer ip-address: Displays information about PW labels advertised by a peer PE through LDP. The ip-address argument specifies the LSR ID of the peer PE. If you do not specify a peer PE, this command displays information about LDP PW labels advertised by all peer PEs.
pw-id pw-id: Displays FEC 128 LDP PW label information for a PW. The pw-id argument specifies the PW ID in the range of 1 to 4294967295. If you specify the peer ip-address option without the pw-id pw-id option, this command displays all LDP PW label information advertised by the specified peer PE.
vpls-id vpls-id: Displays FEC 129 LDP PW label information for a VPLS instance. The vpls-id argument specifies the VPLS instance ID, a string of 3 to 21 characters. You can specify a VPLS ID in one of the following formats:
vsi vsi-name: Displays LDP PW label information for a VSI. The vsi-name argument specifies the VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays LDP PW label information for all VSIs.
LDP advertises FEC-to-PW label bindings in the following ways:
·     After you specify a remote PE with the peer command, LDP advertises an FEC 128-to-PW label binding to the remote PE.
·     After BGP discovers a remote PE, LDP advertises an FEC 129-to-PW label binding to the remote PE.
This command can display PW labels as follows:
·     If you specify the pw-id pw-id option, this command displays PW labels for FEC 128.
·     If you specify the vpls-id vpls-id option, this command displays PW labels for FEC 129.
·     If you do not specify pw-id pw-id or vpls-id vpls-id, this command displays PW labels for both FEC 128 and FEC 129.
# Display brief information about all PW labels advertised by LDP.
<Sysname> display l2vpn ldp
Total number of LDP PWs: 2, 2 up, 0 down
Peer            PW ID/VPLS ID         In/Out Label    State Owner
192.3.3.3       1001                  775125/775126   Up    vpls1
192.3.3.3       1003                  775117/775122   Up    vpls3
Table 16 Command output
PW ID/VPLS ID
PW ID for FEC 128, or VPLS ID of the PE for FEC 129.
PW state: Up or Down.
Owner
Name of the VSI to which the PW belongs.
# Display detailed information about all PW labels advertised by LDP.
<Sysname> display l2vpn ldp verbose
Peer: 2.2.2.9          PW ID: 500
  VSI Name: ccc
  PW State: Up
  PW Status Communication: Notification method
  PW Preferential Forwarding Status Bit: Process
  PW ID FEC (Local/Remote):
    PW Type         : VLAN/VLAN
    Group ID        : 0/0
    Label           : 1552/1552
    Control Word    : Disabled/Disabled
    VCCV CV Type    : -/-
    VCCV CC Type    : -/-
    MTU             : 1500/1500
    PW Status   : PW forwarding/PW forwarding
Peer: 2.2.2.9          VPLS ID: 100:100
  VSI Name: bbb
  PW State: Up
  PW Preferential Forwarding Status Bit: Ignore
    Local AII       : (1.1.1.9, 2.2.2.9)
    Remote AII      : (2.2.2.9, 1.1.1.9)
    PW Type         : VLAN/VLAN
    Group ID        : 0/0
    Label           : 1553/1553
    VCCV CV Type    : -/-
    VCCV CC Type    : -/-
    MTU             : 1500/1500
Table 17 Command output
PW status communication method:
·     Notification method—Notifies the PW status through Notification messages.
·     Label withdraw method—Assigns a PW label to the PW when the AC associated with PW comes up, and withdraws the PW label when the AC goes down.
PW state processing mode:
·     Process—Process the received PW states.
·     Ignore—Ignore the received PW states.
PW ID FEC information advertised from the local PE to the peer PE/PW ID FEC information advertised from the peer PE to the local PE.
VCCV CV Type
VCCV CV type:
·     LSP Ping—Uses MPLS LSP ping to verify PW connectivity.
·     BFD—Uses BFD to verify PW connectivity. BFD packets use IP/UDP encapsulation (with IP/UDP headers).
·     Raw-BFD—Uses BFD to verify PW connectivity. BFD packets use PW-ACH encapsulation (without IP/UDP headers).
This field displays a hyphen (-) if VCCV is not performed on the PW.
VCCV CC Type
VCCV CC type:
VCCV is an MPLS OAM technology. For more information about VCCV, see MPLS Configuration Guide.
MTU
Maximum transmission unit of the VSI.
MTU Negotiation
PW Status
PW status:
·     PW forwarding—PW is ready for packet forwarding.
·     PW not forwarding—PW is not ready for packet forwarding.
·     AC receive fault—AC cannot receive packets.
·     AC transmit fault—AC cannot send packets.
·     PW receive fault—PW cannot receive packets.
·     PW transmit fault—PW cannot send packets.
·     PW standby—The PW is in standby state.
·     Unknown—Unknown protocol.
VPLS ID
ID of the VPLS instance.
Local AII
Source Attachment Individual Identifier (SAII) and Target Attachment Individual Identifier (TAII) advertised to the remote PE.
Remote AII
SAII and TAII received from the remote PE.
display l2vpn mac-address
Use display l2vpn mac-address to display MAC address table information for VSIs.
display l2vpn mac-address [ vsi vsi-name ] [ dynamic ] [ count ]
vsi vsi-name: Displays MAC address table information for a VSI. The vsi-name argument specifies the VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays MAC address table information for all VSIs.
dynamic: Displays dynamically generated MAC address entries. If you do not specify this keyword, the command displays all types of MAC address entries. The device supports only dynamic MAC address entries in the current software version.
count: Displays the number of MAC address entries. If you do not specify this keyword, the command displays information about MAC address entries.
# Display MAC address table information for all VSIs.
<Sysname> display l2vpn mac-address
MAC Address      State    VSI Name                         Link ID/Name  Aging
0000-0000-000a   Dynamic  vpn1                             1             Aging
0000-0000-0009   Dynamic  vpn1                             2             Aging
--- 2 mac address(es) found  ---
# Display the total number of MAC address entries of all VSIs.
<Sysname> display l2vpn mac-address count
Table 18 Command output
MAC address type. The MAC address type can only be Dynamic in the current software version, which indicates that the MAC address is dynamically learned.
Link ID/Name
The Link ID field represents the outgoing link ID of the MAC address entry. It is the link ID of the AC or PW in the VSI.
The Name field applies to a VXLAN VSI. VPLS VSIs do not support the Name field.
Aging
Whether the MAC address entry will be aged.
XX mac address(es) found
Total number of MAC address entries of the VSI.
reset l2vpn mac-address
display l2vpn pw
Use display l2vpn pw to display L2VPN PW information.
display l2vpn pw [ vsi vsi-name ] [ protocol { bgp | ldp | static } ] [ verbose ]
vsi vsi-name: Displays L2VPN PW information for a VSI. The vsi-name argument specifies the VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays L2VPN PW information for all VSIs.
protocol: Displays PWs created by a signaling protocol. If you do not specify a protocol, this command displays PWs created by all protocols.
bgp: Displays BGP PW information.
ldp: Displays LDP PW information, including PWs for FEC 128 (LDP PWs) and FEC 129 (BGP auto-discovery LDP PWs).
static: Displays static PW information.
After you enable PW statistics, you can use the display l2vpn pw verbose command to display PW statistics.
# Display brief information about all PWs.
<Sysname> display l2vpn pw
Flags: M - main, B - backup, BY - bypass, H - hub link, S - spoke link, N - no split horizon
Total number of PWs: 5
5 up, 0 blocked, 0 down, 0 defect, 0 idle, 0 duplicate
VSI Name: aaa
Peer            PW ID/Rmt Site    In/Out Label    Proto   Flag  Link ID  State
2.2.2.9         2                 1420/1419       BGP     M     9        Up
3.3.3.9         3                 1421/1281       BGP     M     10       Up
VSI Name: bbb
2.2.2.9         -                 1553/1553       LDP     M     8        Up
3.3.3.9         -                 1554/1416       LDP     M     9        Up
VSI Name: ccc
2.2.2.9         500               1552/1552       LDP     M     8        Up
Table 19 Command output
PW ID/Rmt Site
This field displays the following:
·     PW ID for an LDP PW (FEC 128) or a static PW.
·     A hyphen (-) for a BGP auto-discovery LDP PW (FEC 129).
·     Remote site ID for a BGP PW.
Proto
Protocol used to establish the PW: LDP, Static, or BGP.
Flag
PW attribute flag:
·     M—Primary PW.
·     B—Backup PW.
·     H—The PW is the hub link in the VPLS hub-spoke network.
·     S—The PW is a spoke link in the VPLS hub-spoke network.
·     N—Split horizon forwarding is disabled.
Link ID
PW state:
·     Up—The PW is available.
·     Down—The PW is not available.
·     Blocked—The PW is a backup PW.
·     Defect—BFD has detected a defect on the PW.
·     Idle—The incoming label of the PW is not available.
·     Dup—The incoming label of the static PW is occupied by a static LSP or a static CRLSP.
# Display detailed information about all L2VPN PWs.
<Sysname> display l2vpn pw verbose
VSI Name: aaa
  Peer: 2.2.2.9          Remote Site: 2
    Signaling Protocol  : BGP
    Link ID             : 9          PW State : Up
    In Label            : 1420       Out Label: 1419
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
    Tunnel Group ID     : 0x800000960000000
    Tunnel NHLFE IDs    : 1038
VSI Name: bbb
    Signaling Protocol  : LDP
    Link ID             : 8          PW State : Up
    In Label            : 1553       Out Label: 1553
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
VSI Name: ccc
    In Label            : 1552       Out Label: 1552
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
Table 20 Command output
Peer
IP address of the peer PE to which the PW is destined.
Signaling Protocol
Link ID
PW State
PW state:
·     Duplicate—The incoming label of the static PW is occupied by a static LSP or a static CRLSP.
Wait to Restore Time
Wait time to switch traffic from the backup PW to the primary PW when the primary PW recovers, in seconds. If the switchover is disabled, this field displays Infinite.
This field is available when both primary and backup PW exist, and is displayed only for the primary PW.
Remaining Time
Remaining wait time for traffic switchover, in seconds. This field is displayed after the switchover wait timer is started.
MTU
Negotiated MTU of the PW.
PW Attributes
PW attribute:
VCCV CC
VCCV CC type:
VCCV BFD
VCCV BFD type:
Tunnel Group ID
Tunnel NHLFE IDs
VPLS ID
Remote Site
display l2vpn pw-class
Use display l2vpn pw-class to display PW class information.
display l2vpn pw-class [ class-name ] [ verbose ]
class-name: Displays information about the PW class specified by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a PW class, this command displays information about all PW classes.
verbose: Displays detailed PW class information. If you do not specify this keyword, the command displays brief PW class information.
# Display information about all PW classes.
<Sysname> display l2vpn pw-class
Total number of PW classes: 2
PW Class Name       PW Type              Control Word   VCCV CC        VCCV BFD
pw1                 Ethernet             Enabled        Control-Word   BFD
pw2                 VLAN                 Disabled       Control-Word   BFD
Table 21 Command output
VCCV CC
VCCV CC type:
VCCV BFD
VCCV BFD type:
# Display detailed information about all PW classes.
<Sysname> display l2vpn pw-class verbose
PW Class Name : pw1
  PW Type     : Ethernet
  Control Word: Enabled
  VCCV BFD    : BFD
  Sequencing  : Both
PW Class Name : pw2
  PW Type     : VLAN
  Control Word: Disabled
  VCCV BFD    : BFD
  Sequencing  : -
Table 22 Command output
PW Type
PW data encapsulation type: Ethernet or VLAN.
VCCV CC
VCCV CC type:
VCCV BFD
VCCV BFD type:
·     BFD—BFD packets use IP/UDP encapsulation (with IP/UDP headers).
·     Raw-BFD—BFD packets use PW-ACH encapsulation (without IP/UDP headers).
Sequencing
Packet sequencing on the PW. The value is Both, which means sequencing is enabled for both incoming and outgoing packets on a PW.
A hyphen (-) in this field indicates that packet sequencing is disabled on the PW.
pw-class
display l2vpn vsi
Use display l2vpn vsi to display VSI information.
display l2vpn vsi [ name vsi-name ] [ verbose ]
name vsi-name: Displays information about a VSI. The vsi-name argument specifies the VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays information about all VSIs.
# Display brief information about all VSIs.
<Sysname> display l2vpn vsi
Total number of VSIs: 2, 1 up, 1 down, 0 admin down
VSI Name                        VSI Index       MTU    State
vpls1                           0               1500   Up
vpls2                           1               1500   Down
Table 23 Command output
VSI state:
·     Up.
·     Down.
·     Admin down—The VSI is manually brought down by using the shutdown command.
# Display detailed information about all VSIs.
<Sysname> display l2vpn vsi verbose
VSI Name: vpls1
  VSI Index               : 0
  VSI Description         : vsi for vpls1
  VSI State               : Up
  Bandwidth               : -
  Broadcast Restrain      : -
  Multicast Restrain      : -
  Unknown Unicast Restrain: -
  MAC Table Limit         : Unlimited
  Drop Unknown            : Disabled
  PW Redundancy           : Slave
  VXLAN ID                : -
  LDP PWs:
    Peer            PW ID            Link ID    State
    192.3.3.3       1                8          Up
    192.3.3.3       1001             8          Blocked
  BGP PWs:
    Peer            Remote Site      Link ID    State
    192.4.4.4       1                9          Up
  ACs:
    AC                               Link ID    State
    GE1/0/1                          1          Up
Table 24 Command output
VSI Description
If no description is configured for the VSI, this field is not displayed.
VSI State
VSI state:
·     Up.
·     Down.
Bandwidth
Maximum bandwidth for the known unicast traffic in the VSI, in kbps.
Broadcast Restrain
Broadcast suppression bandwidth for the VSI, in kbps.
Multicast Restrain
Multicast suppression bandwidth for the VSI, in kbps.
Unknown unicast suppression bandwidth for the VSI, in kbps.
MAC Table Limit
Maximum number of MAC addresses that the VSI can learn.
This field displays Unlimited if no limit is set on the number of MAC addresses that the VSI can learn.
Drop Unknown
Whether the VSI drops packets with unknown source MAC addresses after it has leaned the maximum number of MAC addresses:
·     Enabled—Drops packets with unknown source MAC addresses.
·     Disabled—Forwards packets with unknown source MAC addresses.
PW Redundancy
PW redundancy mode:
·     Slave—Master/slave mode and the local PE operates as the slave node.
·     Master—Master/slave mode and the local PE operates as the master node.
Hub-Spoke
Hub-spoke capability. If the hub-spoke capability is enabled, this field displays Enabled. If the hub-spoke capability is disabled, this field is not displayed.
Flooding
VPLS does not support this field.
VXLAN ID
PW state: Up, Down, Blocked, or BFD Defect.
AC
vsi
l2vpn enable
Use l2vpn enable to enable L2VPN.
Use undo l2vpn enable to disable L2VPN.
l2vpn enable
undo l2vpn enable
L2VPN is disabled.
You must enable L2VPN before configuring other L2VPN settings.
# Enable L2VPN.
[Sysname] l2vpn enable
l2vpn switchover
Use l2vpn switchover to switch traffic from a PW to its backup or primary PW.
l2vpn switchover peer ip-address pw-id pw-id
peer ip-address: Specifies the LSR ID of the peer PE.
pw-id pw-id: Specifies a PW by its ID in the range of 1 to 4294967295.
The specified LSR ID and PW ID uniquely identify a PW.
If a PW has a backup PW or primary PW, this command switches traffic from the PW to the backup or primary PW. If the PW does not have a backup or primary PW, this command does not perform the switchover.
# Switch traffic from PW 100 destined for 3.3.3.3 to its backup PW.
<Sysname> l2vpn switchover peer 3.3.3.3 pw-id 100
mac-learning enable
Use mac-learning enable to enable MAC address learning for a VSI.
Use undo mac-learning enable to disable MAC address learning for a VSI.
mac-learning enable
MAC address learning is enabled for a VSI.
VSI view
If MAC address learning is disabled for a VSI, the VSI does not learn the source MAC addresses of received packets.
# Disable MAC address learning for VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] undo mac-learning enable
display l2vpn vsi
mtu
Use mtu to set an MTU for a VSI.
mtu size
undo mtu
A VSI has an MTU of 1500 bytes.
VSI view
size: Specifies an MTU value. The value range for this argument is 300 to 65535.
The VSI MTU specifies the maximum length of a packet transmitted on a PW, including the control word, PW label, and network layer packet.
When PW MTU negotiation is enabled, you can establish an LDP PW between two PEs only when you configure the same PW MTU on the two PEs. When PW MTU negotiation is disabled, you can establish an LDP PW between two PEs even if you configure different PW MTUs on the two PEs.
# Set the MTU to 1400 bytes for VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] mtu 1400
display l2vpn vsi
mtu-negotiate disable
Use mtu-negotiate disable to disable PW MTU negotiation.
Use undo mtu-negotiate disable to enable PW MTU negotiation.
PW MTU negotiation is enabled.
VSI LDP signaling view
By default, the establishment of an LDP PW requires the same PW MTU on the two PEs of the PW. Configure this command if you want to establish a PW between two PEs that are configured with different PW MTUs. If the PW MTUs of the two PEs of a PW are different, the MTU specified on the local device takes effect.
# In VSI LDP signaling view, disable PW MTU negotiation.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1-ldp] mtu-negotiate disable
mtu
peer
Use peer in VSI LDP signaling view to configure a VSI LDP PW and enter its view, or enter the view of an existing VSI LDP PW.
Use peer in VSI static configuration view to configure a VSI static PW and enter its view, or enter the view of an existing VSI static PW.
Use undo peer to delete a VPLS PW.
VSI LDP signaling view:
peer ip-address [ pw-id pw-id ] [ hub | ignore-standby-state | no-split-horizon | pw-class class-name | tunnel-policy tunnel-policy-name ] *
undo peer ip-address pw-id pw-id
VSI static configuration view:
peer ip-address [ pw-id pw-id ] [ in-label label-value out-label label-value [ hub | no-split-horizon | pw-class class-name | tunnel-policy tunnel-policy-name ] * ]
No PWs exist for VPLS.
pw-id pw-id: Specifies a PW ID for the PW, in the range of 1 to 4294967295.
in-label label-value: Specifies the incoming label of the PW. The value range for the label-value argument is 16 to 1023.
out-label label-value: Specifies the outgoing label of the PW. The value range is 16 to 1048575.
hub: Specifies the PW as the hub link in the VSI. By default, a PW in the VSI enabled with the hub-spoke capability is a spoke link.
ignore-standby-state: Ignores the PW active/standby status bit received from the remote PE. This keyword is applicable only to LDP PWs.
no-split-horizon: Disables split horizon forwarding for the PW. By default, a PW must use the split horizon forwarding scheme to forward packets.
pw-class class-name: Specifies a PW class by its name, a case-sensitive string of 1 to 19 characters. You can specify a PW class to configure the PW data encapsulation type and control word. If you do not specify a PW class, the PW data encapsulation type is VLAN and the PW does not support control word.
tunnel-policy tunnel-policy-name: Specifies a tunnel policy by its name, a case-insensitive string of 1 to 19 characters. If you do not specify a tunnel policy, the PW uses the default tunnel policy.
A PE uses the PW Preferential Forwarding Status bit in LDP messages to advertise the local PWs' active/standby states. When the bit is set, it indicates that the local PW is in standby state. When the bit is cleared, it indicates that the local PW is in active state.
In master/slave mode of PW redundancy, the slave PE selects the forwarding PW among the set of redundant PWs based on the status bit received from the master PE. If you specify the ignore-standby-state keyword, the PE ignores the status bit received from the master PE and uses the primary PW to forward packets as long as the primary PW is up.
To create a static PW, you must specify the incoming and outgoing labels. To enter VSI static PW view of an existing static PW, you do not need to specify the incoming and outgoing labels.
The PW ID for a PW must be the same on the PEs at the ends of the PW.
On a PE, the LSR ID of the peer PE and the PW ID uniquely identify a PW. The peer LSR ID and PW ID combination of a PW must be unique among all VPLS PWs and cross-connect PWs.
If both the default PW ID in the default-pw-id command and a PW ID in the peer command are configured, the PW ID in the peer command is used. If only the default PW ID is configured, the default PW ID is used. If no default PW ID is configured, you must provide a PW ID in the peer command.
# Configure an LDP PW for VSI vpn1 and enter VSI LDP PW view: specify the peer PE address as 4.4.4.4, set the PW ID to 200, and disable split horizon forwarding for the PW.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1-ldp] peer 4.4.4.4 pw-id 200 no-split-horizon
[Sysname-vsi-vpn1-ldp-4.4.4.4-200]
# Configure a static PW for VSI vpn1 and enter VSI static PW view: specify the peer PE address as 5.5.5.5, set the PW ID to 200, incoming label to 100, and outgoing label to 200, and disable split horizon forwarding for the PW.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1-static] peer 5.5.5.5 pw-id 200 in-label 100 out-label 200 no-split-horizon
default-pw-id
display l2vpn ldp
display l2vpn pw
pw-class
tunnel-policy
peer auto-discovery
Use peer auto-discovery to enable BGP to exchange VPLS PE information with the specified peers.
Use undo peer auto-discovery to disable BGP from exchanging VPLS PE information with the specified peers.
peer { group-name | ip-address [ mask-length ] } auto-discovery [ non-standard ]
undo peer { group-name | ip-address [ mask-length ] } auto-discovery
BGP can exchange VPLS PE information with a BGP L2VPN peer or peer group through RFC 6074 MP_REACH_NLRI.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The specified peer group must have been created.
ip-address: Specifies a peer by its IP address. The specified peer must have been created.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ip-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command enables BGP to exchange VPLS PE information with all dynamic peers in the subnet.
non-standard: Uses non-standard MP_REACH_NLRI to exchange VPLS PE information. If you do not specify this keyword, RFC 6074 MP_REACH_NLRI is used to exchange VPLS PE information.
L2VPN can use MP-BGP to exchange VPLS PE information and find remote PEs in the same VPLS instance.
To enable BGP to exchange VPLS PE information with the specified peers through RFC 6074 MP_REACH_NLRI, you can also use the peer enable command in BGP L2VPN address family view. To disable the capability, use the undo peer auto-discovery command.
# Enable BGP to exchange VPLS PE information with the peer 3.3.3.9 through RFC 6074 MP_REACH_NLRI.
[Sysname] bgp 100
[Sysname-bgp-default-l2vpn] peer 3.3.3.9 auto-discovery
peer signaling
Use peer signaling to enable BGP to exchange label block information with the specified peers.
Use undo peer signaling to disable BGP to exchange label block information with the specified peers.
peer { group-name | ip-address [ mask-length ] } signaling
undo peer { group-name | ip-address [ mask-length ] } signaling
BGP can exchange label block information with a BGP L2VPN peer or peer group.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ip-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command enables BGP to exchange label block information with all dynamic peers in the subnet.
L2VPN uses MP-BGP to exchange label blocks when creating a BGP PW.
To enable BGP to exchange label block information with the specified peers, you can also use the peer enable command in BGP L2VPN address family view. To disable the capability, use the undo peer signaling command.
# Enable BGP to exchange label block information with peer 3.3.3.9.
[Sysname] bgp 100
[Sysname-bgp-default-l2vpn] peer 3.3.3.9 signaling
policy vpn-target
Use policy vpn-target to enable route target-based filtering of incoming BGP L2VPN information.
Use undo policy vpn-target to disable route target-based filtering of incoming BGP L2VPN information.
policy vpn-target
Route target-based filtering of incoming BGP L2VPN information is enabled.
If route target-based filtering is enabled, L2VPN accepts only the incoming BGP L2VPN information whose export route target attribute matches the local import route target attribute. If route target-based filtering is disabled, L2VPN accepts all incoming BGP L2VPN information.
To establish a BGP PW between two MP-IBGP peers that use a route reflector, you must disable route target-based filtering of incoming BGP L2VPN information on the route reflector.
# Disable route target-based filtering of incoming BGP L2VPN information.
[Sysname] bgp 100
[Sysname-bgp-default-l2vpn] undo policy vpn-target
pw-redundancy
Use pw-redundancy to specify the master/slave PW redundancy mode and configure the local PE as the master node.
Use undo pw-redundancy to restore the default.
pw-redundancy master
undo pw-redundancy
The PW redundancy mode is master/slave and the local PE operates as the slave node.
master: Uses the master/slave PW redundancy mode and configures the local PE as the master node.
This command is applicable only to LDP PWs.
For LDP PWs, PEs use LDP to negotiate the active/standby states of the PWs. In master/slave mode, one endpoint PE of a PW operates as the master node and the other endpoint PE operates as the slave node. The master PE determines the active/standby state of the PW and uses LDP to advertise the PW state to the slave PE. The slave PE uses the same PW state as the master PE based on the information received from the master PE. In this way, the master and slave PEs for the set of redundant PWs can use the same active PW to forward user traffic.
The slave PE does not need to send the PW states to the master PE and the master PE ignores the PW states sent by the slave PE.
Do not execute this command on the local PE if the remote PE does not support the master/slave PW redundancy mode.
# Use the master/slave PW redundancy mode and configure the local PE as the master node.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1-ldp] pw-redundancy master
backup-peer
display l2vpn ldp
display l2vpn pw
peer
pwsignaling
Use pwsignaling to specify a PW signaling protocol for a VSI, and enter the VSI signaling protocol view.
Use undo pwsignaling to remove the specified PW signaling protocol for a VSI.
pwsignaling { ldp | static }
undo pwsignaling { ldp | static }
No PW signaling protocol is specified for a VSI.
VSI view
ldp: Establishes PWs through LDP (FEC 128) and enters VSI LDP signaling view.
static: Establishes PWs statically and enters VSI static configuration view.
# Configure VSI vpn1 to use LDP to establish LDP PWs, and enter VSI LDP signaling view.
[Sysname] vsi vpn1
display l2vpn pw
Use reset l2vpn mac-address to clear MAC address entries for VSIs.
reset l2vpn mac-address [ vsi vsi-name ]
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears MAC address entries for all VSIs.
When a VSI learns wrong MAC addresses or has learned the maximum number of MAC addresses, use this command to clear MAC addresses for the VSI. Then, the VSI can learn MAC addresses again.
# Clear MAC address entries for VSI vpn1.
<Sysname> reset l2vpn mac-address vsi vpn1
display l2vpn mac-address vsi
revertive
Use revertive to specify the switchover mode and set the switchover wait time.
Use undo revertive to restore the default.
revertive { wtr wtr-time | never }
undo revertive { wtr | never }
The switchover mode is revertive and the switchover wait time is 0 seconds. When the primary PW recovers, traffic is immediately switched back from the backup PW to the primary PW.
wtr wtr-time: Specifies the switchover mode as revertive and specifies the wait time in the range of 0 to 3600 seconds. When the primary PW recovers, the PE waits for the specified time before switching traffic from the backup PW to the primary PW.
never: Specifies the switchover mode as non-revertive. After the primary PW recovers, traffic is not switched from the backup PW to the primary PW.
# Specify the revertive mode and set the switchover wait time to 120 seconds for static PWs in VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1-static] revertive wtr 120
display l2vpn pw
route-distinguisher
Use route-distinguisher to configure a route distinguisher (RD) for an auto-discovery VSI.
Use undo route-distinguisher to restore the default.
No RD is configured for an auto-discovery VSI.
Auto-discovery VSI view
route-distinguisher: Specifies an RD, a string of 3 to 21 characters. An RD can be in one of the following formats:
VPLS uses RDs to differentiate the sites with the same site ID but in different VPNs.
BGP adds the configured RD before the site ID. The RD and the site ID uniquely identify a VPN site.
The configured RD applies to both BGP neighbor auto-discovery and VPLS label block advertisement.
You cannot configure the same RD for different BGP VSIs.
To modify an RD, execute the undo route-distinguisher command to remove the RD and then execute the route-distinguisher command.
# Configure RD 22:1 for BGP VSI aaa.
[Sysname] vsi aaa
[Sysname-vsi-aaa-auto] route-distinguisher 22:1
rr-filter
Use rr-filter to create a route reflector (RR) reflection policy.
Use undo rr-filter to restore the default.
undo rr-filter
An RR does not filter reflected L2VPN information.
ext-comm-list-number: Specifies an extended community list number in the range of 1 to 199.
After this command is executed, only the L2VPN information that is permitted by the specified extended community list is reflected.
By configuring different RR reflection policies on RRs in a cluster, you can implement load balancing among the RRs.
For more information about extended community lists, see Layer 3—IP Routing Configuration Guide.
# Configure the RR to reflect only the BGP L2VPN information that is permitted by extended community list 10.
[Sysname] bgp 100
[Sysname-bgp-default-l2vpn] rr-filter 10
ip extcommunity-list (Layer 3—IP Routing Command Reference)
shutdown
Use shutdown to disable a VSI.
Use undo shutdown to enable a VSI.
shutdown
A VSI is enabled.
VSI view
After you disable a VSI, the VSI cannot provide VPLS services.
Use the shutdown command when you want to temporarily disable VPLS. When a VSI is disabled, you can still configure the VSI. After the configuration, use the undo shutdown command to enable the VSI. The VSI will provide VPLS services using the new settings.
# Disable VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] shutdown
display l2vpn vsi
signaling-protocol
Use signaling-protocol to specify a signaling protocol and enter the specified signaling view. The specified signaling protocol is used to establish PWs to the automatically discovered remote PEs.
Use undo signaling-protocol to restore the default.
signaling-protocol { bgp | ldp }
No signaling protocol is specified.
bgp: Specifies the signaling protocol as BGP and enters auto-discovery VSI BGP signaling view.
ldp: Specifies the signaling protocol as LDP and enters auto-discovery VSI LDP signaling view.
You can specify only one signaling protocol in the same auto-discovery VSI view. To modify the signaling protocol, execute the undo signaling-protocol command to remove the signaling protocol and then execute the signaling-protocol command.
# Use LDP (FEC 129) to establish a PW to a remote PE discovered by BGP and enter auto-discovery VSI LDP signaling view.
[Sysname] vsi aaa
[Sysname-vsi-aaa-auto] signaling-protocol ldp
[Sysname-vsi-aaa-auto-ldp]
display l2vpn pw
display l2vpn vsi
site
Use site to create a local site.
Use undo site to delete a local site.
site site-id [ range range-value ] [ default-offset default-offset ]
undo site site-id
No sites exist.
Auto-discovery VSI BGP signaling view
site-id: Specifies a local site ID. The value range for this argument is 0 to 120.
range range-value: Specifies the maximum number of sites in a VPLS instance, in the range of 2 to 1 + the maximum number of site-id. The default value is 10.
default-offset default-offset: Specifies the start site ID, 0 or 1. The default value is 0.
You can create multiple local sites for a VSI.
You can use the site command to increase the range value for an existing site. You cannot decrease the range value for an existing site with the site command. To decrease the range value, execute the undo site command to delete the site and then execute the site command.
You cannot modify the default-offset for a site with the site command. To modify it, execute the undo site command to delete the site and then execute the site command.
# Create site 1, configure the VPLS instance to contain a maximum of 30 sites, and set the start site ID to 0 for VSI aaa.
[Sysname] vsi aaa
[Sysname-vsi-aaa-auto] signaling-protocol bgp
[Sysname-vsi-aaa-auto-bgp] site 1 range 30 default-offset 0
display l2vpn pw
display l2vpn vsi
snmp-agent trap enable l2vpn
Use snmp-agent trap enable l2vpn to enable SNMP notifications for L2VPN PW.
Use undo snmp-agent trap enable l2vpn to disable SNMP notifications for L2VPN PW.
snmp-agent trap enable l2vpn [ pw-delete | pw-switch | pw-up-down ] *
undo snmp-agent trap enable l2vpn [ pw-delete | pw-switch | pw-up-down ] *
SNMP notifications for L2VPN PW are disabled.
pw-delete: Enables PW deletion notifications.
pw-switch: Enables PW primary/backup switchover notifications.
pw-up-down: Enables PW up-down notifications.
This feature enables L2VPN to generate SNMP notifications when PW deletions, PW status changes, or PW switchovers occur. For L2VPN event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
If you do not specify a notification type, this command enables all types of notifications for L2VPN PW.
# Enable PW up-down SNMP notifications.
[Sysname] snmp-agent trap enable l2vpn pw-up-down
display snmp-agent trap-list (Network Management and Monitoring Command Reference)
tunnel-policy (auto-discovery VSI view)
Use tunnel-policy to specify a tunnel policy for an auto-discovery VSI.
Use undo tunnel-policy to restore the default.
undo tunnel-policy
No tunnel policy is specified.
tunnel-policy-name: Specifies a tunnel policy by its name, a case-sensitive string of 1 to 19 characters.
The PWs on the auto-discovery VSI use the specified tunnel policy to select public tunnels.
If you do not specify a tunnel policy or specify a nonexistent tunnel policy, the default tunnel policy applies. The default tunnel policy selects only one public tunnel for a PW in this order: LSP tunnel, GRE tunnel, CRLSP tunnel.
# Specify tunnel policy policy1 for auto-discovery VSI aaa.
[Sysname] tunnel-policy policy1
[Sysname-tunnel-policy-policy1] quit
[Sysname] vsi aaa
[Sysname-vsi-aaa-auto] tunnel-policy policy1
tunnel-policy (system view)
vpls-id
Use vpls-id to set the VPLS ID for a VSI.
Use undo vpls-id to restore the default.
vpls-id vpls-id
undo vpls-id
No VPLS ID is specified for a VSI.
Auto-discovery VSI LDP signaling view
vpls-id: Specifies a VPLS ID, a string of 3 to 21 characters. You can specify a VPLS ID in one of the following formats:
A VPLS ID uniquely identifies a VPLS instance. Two PEs must have the same VPLS ID to establish a PW.
VPLS IDs are used in the scenarios where BGP is used to find remote PEs and where FEC 129 LDP is used to establish PWs to the remote PEs.
The local PE advertises a BGP update that includes the configured VPLS ID as an extended community attribute to the remote PE. The remote PE compares the received VPLS ID with its own VPLS ID. If the two VPLS IDs are identical, the two PEs use FEC 129 LDP to establish a PW. If not, the PEs do not establish a PW.
To change a VPLS ID, execute the undo vpls-id command to remove the VPLS ID and then execute the vpls-id command.
# Configure the VPLS ID 100:1 for VSI aaa.
[Sysname] vsi aaa
[Sysname-vsi-aaa] auto-discovery bgp
[Sysname-vsi-aaa-auto-ldp] vpls-id 100:1
display l2vpn pw
display l2vpn vsi
vpn-target
Use vpn-target to configure route targets for an auto-discovery VSI.
Use undo vpn-target to remove route targets for an auto-discovery VSI.
undo vpn-target { vpn-target&<1-8> | all } [ both | export-extcommunity | import-extcommunity ]
No route targets are configured for an auto-discovery VSI.
vpn-target&<1-8>: Specifies a space-separated list of a maximum of eight route targets.
A route target is a string of 3 to 21 characters in one of the following formats:
both: Uses the specified route targets as both import targets and export targets. The both keyword is used when you do not specify any of both, export-extcommunity, and import-extcommunity.
export-extcommunity: Uses the specified route targets as export targets.
import-extcommunity: Uses the specified route targets as import targets.
all: Removes all route targets.
A local PE sets the route targets as export targets in BGP update messages when it advertises L2VPN information through the update messages to a remote peer. The peer uses its import targets to match the received export targets. If a match is found, the peer accepts the L2VPN information.
If you repeat this command, all the configured route targets take effect.
# Configure import route targets as 10:1 100:1 1000:1 and export route targets as 20:1 200:1 2000:1 for auto-discovery VSI aaa.
[Sysname] vsi aaa
[Sysname-vsi-aaa-auto] vpn-target 10:1 100:1 1000:1 import-extcommunity
[Sysname-vsi-aaa-auto] vpn-target 20:1 200:1 2000:1 export-extcommunity
vsi
Use vsi to create a VSI and enter its view, or enter the view of an existing VSI.
Use undo vsi to delete a VSI.
vsi vsi-name [ hub-spoke ]
undo vsi vsi-name
No VSIs exist.
vsi-name: Specifies a name for the VSI, a case-sensitive string of 1 to 31 characters.
hub-spoke: Enables the hub-spoke capability for the VSI. If you do not specify this keyword, the VSI does not have the hub-spoke capability.
You can create multiple PWs for a VSI manually, or by using LDP or BGP.
Hub-spoke is a VPLS networking model that includes one hub site and multiple spoke sites. The spoke sites communicate with one another through the hub site.
For a hub-spoke network, you must enable the hub-spoke capability for the VSI. In the VSI with hub-spoke capability, the link (AC or PW) towards the hub site is the hub link and other links towards the branch sites are spoke links. By default, all links in the VSI are spoke links. You must specify an AC or a PW as the hub link in the VSI when you configure the xconnect vsi command or the peer command.
# Create a VSI named vpls1 and enter VSI view.
[Sysname] vsi vpls1
[Sysname-vsi-vpls1]
display l2vpn vsi
xconnect vsi
Use xconnect vsi to bind a Layer 3 interface to a VSI.
Use undo xconnect vsi to restore the default.
xconnect vsi vsi-name [ access-mode { ethernet | vlan } | hub ] * [ track track-entry-number&<1-3> ]
undo xconnect vsi
An interface is not bound to any VSI.
Layer 3 interface view
vsi-name: Specifies the name of a VSI, a case-sensitive string of 1 to 31 characters.
access-mode: Specifies the AC access mode. This keyword is available when the AC is a Layer 3 subinterface, and the default access mode is VLAN. When the AC is a Layer 3 interface, this keyword is not available.
ethernet: Specifies the access mode as Ethernet.
vlan: Specifies the access mode as VLAN.
hub: Specifies the AC as the hub link in the VSI. By default, an AC bound to a VSI enabled with hub-spoke capability is a spoke link in the VSI.
track track-entry-number&<1-3>: Specifies a space-separated list of up to three track entry numbers in the range of 1 to 1024. The AC is up only if a minimum of one associated track entry is in positive state.
After you bind a Layer 3 interface to a VSI, packets received from the interface are forwarded according to the MAC address table of the VSI.
The AC access mode determines how the PE considers the VLAN tag in Ethernet frames received from the AC and how the PE forwards Ethernet frames to the AC.
·     VLAN access mode—Ethernet frames received from the AC must carry a VLAN tag in the Ethernet header. The PE considers the VLAN tag as a P-tag assigned by the service provider. Ethernet frames sent to the AC must also carry the P-tag.
·     Ethernet access mode—If Ethernet frames from the AC have a VLAN tag in the header, the PE considers it as a U-tag and ignores it. Ethernet frames sent to the AC do not carry the P-tag.
To specify the AC as the hub link by using this command, you must first enable the hub-spoke capability for the specified VSI. By default, an AC is a spoke link in a VSI enabled with the hub-spoke capability.
# Bind GigabitEthernet 1/0/1 to VSI vpn1, and associate the interface with track entries 1, 2, and 3.
[Sysname] vsi vpn1 hub-spoke
[Sysname-vsi-vpn1] quit
[Sysname-GigabitEthernet1/0/1] xconnect vsi vpn1 track 1 2 3
vsi
