10-MPLS Command Reference
HomeSupportRoutersMSR5600 Series(Comware V7)Reference GuidesCommand ReferencesH3C MSR 5600 Routers Command Reference(V7)-R6728-6W10010-MPLS Command Reference
01-Basic MPLS commands
01-Basic MPLS commands 169.94 KB
Basic MPLS commands
The MSR 56-60 and MSR 56-80 devices installed with MPU-100-G do not support parameters or commands that are available only in IRF mode.
display mpls forwarding ilm
Use display mpls forwarding ilm to display Incoming Label Map (ILM) entries.
In standalone mode:
display mpls forwarding ilm [ label ] [ slot slot-number ]
In IRF mode:
display mpls forwarding ilm [ label ] [ chassis chassis-number slot slot-number ]
label: Displays the ILM entry with the specified incoming label. The value range for this argument is 16 to 1048575.If you do not specify an incoming label, this command displays ILM entry information for all incoming labels.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays ILM entries for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays ILM entries for the global active MPU. (In IRF mode.)
An ILM entry records the label operation type, outgoing label, and other forwarding information.
After an LSR receives a labeled packet, it performs the following operations:
1.     Identifies the ILM entry that matches the top label of the packet.
2.     Performs the specified label operation.
3.     Forwards the packet.
# Display all ILM entries.
<Sysname> display mpls forwarding ilm
Total ILM entries: 3
Flags: T - Forwarded through a tunnel
       N - Forwarded through the outgoing interface to the nexthop IP address
       B - Backup forwarding information
       A - Active forwarding information
InLabel Oper    VRF   Flag SwapLabel Forwarding Info
30      SWAP    0     T    1000      1024
1279    POP     0     -    -         -
1407    SWAP    0     NA   1271      GE1/0/3                   50.2.0.2
                      NB   1270      Tun0                     0.0.0.0
Total ILM entries
Total number of ILM entries.
InLabel
Incoming label.
Oper
Operation type:
·     POP—Pops the label.
·     POPGO—Pops the label and forwards the packet to another tunnel.
·     SWAP—Swaps the label.
VRF
Index of a VPN instance.
Flag
Forwarding flag:
·     T—Forwarded through a tunnel.
·     N—Forwarded through the outgoing interface to the next hop IP address.
·     B—Backup forwarding information.
·     A—Active forwarding information.
SwapLabel
Outgoing label value.
Forwarding Info
Forwarding information:
·     When the forwarding flag is N, the forwarding information records the outgoing interface and the next hop.
·     When the forwarding flag is T, the forwarding information records the NID.
display mpls forwarding nhlfe
Use display mpls forwarding nhlfe to display Next Hop Label Forwarding Entry (NHLFE) entries.
In standalone mode:
display mpls forwarding nhlfe [ nid ] [ slot slot-number ]
In IRF mode:
display mpls forwarding nhlfe [ nid ] [ chassis chassis-number slot slot-number ]
nid: Displays the NHLFE entry with the specified NID. The NID value range is 0 to 4294967294.If you do not specify an NID, this command displays NHLFE entry information for all NIDs.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays NHLFE entries for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays NHLFE entries for the global active MPU. (In IRF mode.)
An NHLFE entry records label forwarding information, such as the outgoing label and outgoing interface. NHLFE entries are mainly used to add multiple labels to packets.
To add multiple labels to a packet, an LSR performs the following operations:
1.     Obtains the bottom label and NID in the matching FIB or ILM entry.
2.     Obtains the outer label in the NHLFE entry identified by the NID.
# Display the NHLFE entry with NID 2048.
<Sysname> display mpls forwarding nhlfe 2048
NID        Tnl-Type Flag OutLabel Forwarding Info
2048       LSP      NA   2025     GE1/0/2                   10.11.112.26
# Display all NHLFE entries.
Total NHLFE entries: 5
10         -        TA   -        2049
20         -        TA   -        2050
2049       LSP      NA   3024     GE1/0/2                   10.11.112.26
                    TB   3026     20
2050       LSP      NA   3025     GE1/0/1                   10.11.113.26
Total NHLFE entries
Total number of NHLFE entries.
NID
NHLFE entry index.
Tnl-Type
Tunnel type:
·     LOCAL—Direct LSP tunnel.
·     LSP—Static LSP tunnel, or LSP tunnel signaled using LDP or BGP.
·     TE—TE tunnel.
·     GRE—GRE tunnel.
·     CRLSP—Static CRLSP tunnel or CRLSP tunnel signaled using RSVP.
·     SRLSP—Static SRLSP tunnel or SRLSP tunnel signaled using ISIS or OSPF.
·     - (a hyphen)—The tunnel type is invalid.
Flag
Forwarding flag:
OutLabel
Outgoing label.
Forwarding Info
display mpls interface
Use display mpls interface to display MPLS interface information, including the interface name, interface status, and interface MPLS MTU.
display mpls interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by the interface type and number. If you do not specify an interface, this command displays MPLS information for all MPLS-enabled interfaces.
# Display all MPLS interfaces.
<Sysname> display mpls interface
Interface               Status       MPLS MTU
GE1/0/1                 Up           1500
GE1/0/2                 Up           1500
The MPLS MTU of an interface is in bytes.
mpls enable
mpls mtu
display mpls label
Use display mpls label to display MPLS label usage information.
display mpls label { label-value1 [ to label-value2 ] | all }
label-value1: Specifies a label value. The label value range is 16 to 1048575.If used with the label-value2 argument, the label-value1 argument represents the start label of a label range.
to label-value2: Specifies the end label of the label range. The value range for the end label is 16 to 1048575. If you specify a label range by using the label-value1 argument and the to label-value2 option, this command displays usage information for the specified range of labels.
all: Specifies all labels.
# Display usage information for labels 1025 through 1027.
<Sysname> display mpls label 1025 to 1027
Label          Owner          State
1025           LDP            Alloc
1026           LDP            Alloc
1027           LDP            Inuse
Label
Label value.
Owner
Protocol that is using the label:
·     Static—Static LSP.
·     LDP.
·     BGP.
·     StaticCR—Static CRLSP or static SRLSP.
·     RSVP.
·     L2VPN.
·     ISIS.
·     OSPF.
This field displays a hyphen (-) when the label state is Idle.
Usage state of the label:
·     Idle—The label is idle.
·     Alloc—The label has been allocated.
·     Pending—The label has been released but is still used by an LSP entry.
·     Inuse—The label has been allocated and used by an LSP entry.
display mpls lsp
Use display mpls lsp to display LSP information.
display mpls lsp [ egress | in-label label-value | ingress | outgoing-interface interface-type interface-number | protocol { bgp | isis | ldp | local | ospf | rsvp-te [ p2mp ] | sr-te | static | static-cr } | transit ] [ vpn-instance vpn-instance-name ] [ ipv4-address mask-length | ipv6 [ ipv6-address prefix-length ] ] [ verbose ]
egress: Displays the LSPs taking the current LSR as egress.
in-label label-value: Displays the LSPs using the specified label as the incoming label. The value range for the label-value argument is 0 to 1048575.
ingress: Displays the LSPs taking the current LSR as ingress.
outgoing-interface interface-type interface-number: Displays the LSPs using the specified interface as the outgoing interface. The interface-type interface-number argument specifies an interface by its type and number.
protocol: Displays the LSPs established by a protocol.
bgp: Displays BGP LSPs.
isis: Displays IS-IS SRLSPs.
ldp: Displays LDP LSPs.
local: Displays the LSPs to the direct next hops, or the LSPs that use the local MPLS TE tunnel interfaces or tunnel bundle interfaces as the LSP heads.
ospf: Displays OSPF SRLSPs.
rsvp-te: Displays CRLSPs established by RSVP-TE.
p2mp: Displays P2MP CRLSPs established by RSVP-TE. If you do not specify this keyword, the command displays information about P2P CRLSPs and P2MP CRLSPs established by RSVP-TE.
sr-te: Displays SRLSPs established by SR-TE.
static: Displays static LSPs.
static-cr: Displays static CRLSPs and static SRLSPs.
transit: Displays the LSPs taking the current LSR as a transit LSR.
vpn-instance vpn-instance-name: Displays LSPs for the specified MPLS L3VPN instance. The vpn-instance-name is a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays LSPs for the public network.
ipv4-address mask-length: Displays the IPv4 LSP for an FEC specified by an IPv4 address and a mask length. The value range for the mask length is 0 to 32.
ipv6: Displays IPv6 LSP information. If you do not specify this keyword, the command displays IPv4 LSP information.
ipv6-address prefix-length: Displays the IPv6 LSP for an FEC specified by an IPv6 address and a prefix length. The value range for the prefix length is 0 to 128.
verbose: Displays detailed LSP information. If you do not specify this keyword, the command displays brief LSP information.
If you do not specify any parameters, this command displays brief information about all LSPs. If you specify only the verbose keyword, this command displays detailed information about all LSPs.
# Display brief information about all IPv4 LSPs.
<Sysname> display mpls lsp
FEC                         Proto    In/Out Label    Out Inter/NHLFE/LSINDEX
100.100.100.100/24          LDP      -/1049          GE1/0/1
Backup                               -/1050          GE1/0/2
100.100.100.10/24           LDP      -/1051          GE1/0/3
100.100.100.10/24           LDP      -/1049          GE1/0/4
101.100.100.10/24           LDP      1026/1049       GE1/0/1
102.100.100.10/24           LDP      1027/-          -
103.100.100.10/24           LDP      1028/1049       Tunnel10
110.100.100.20/24           BGP      -/1049          GE1/0/1
111.100.100.10/24           BGP      2028/1049       GE1/0/1
112.100.100.10/24           BGP      2029/-          GE1/0/1
113.100.100.10/24           BGP      2030/1049       NHLFE1500
114.100.100.10/24           BGP      2031/1050       Tunnel100
100.100.100.100             Local    -/-             GE1/0/1
101.101.101.101/32          Static   -/100           GE1/0/1
-                           Static   100/200         GE1/0/1
-                           Static   101/-           GE1/0/1
200.200.200.200/64000/64000 RSVP     -/1030          GE1/0/5
201.200.200.200/64000/64000 RSVP     1024/1031       GE1/0/5
202.200.200.200/64000/64000 RSVP     1025/-          -
150.140.150.100/64001/0     StaticCR -/1000          GE1/0/5
-                           StaticCR 50/1001         GE1/0/5
-                           StaticCR 51/-            -
FEC
Forwarding equivalence class:
·     IP address/mask—Classifies FECs by destination address.
·     IP address/mask/LSINDEX—Classifies FECs by label stack index.
·     IP address—Classifies FECs by next hop.
·     IP address/Out Label—Classifies FECs by next hop and outgoing label.
·     Ingress LSR ID/Tunnel ID/LSP ID—RSVP TE FEC or static SRLSP FEC.
·     - (a hyphen)—The LSP is a static transit LSP, static egress LSP, adjacency path for static SRLSPs, static transit CRLSP, or static egress CRLSP.
·     Backup—The LSP is a backup LSP of the previous LSP.
Proto
Label distribution protocol:
·     LDP.
·     BGP.
·     RSVP.
·     Static.
·     Local—LSP to a direct next hop, or LSP that uses a local MPLS TE tunnel interface or tunnel bundle interface as the LSP head.
·     IS-IS.
·     OSPF.
·     SR-TE—SRLSP established by SR-TE.
·     RSVP-P2MP—P2MP CRLSP established by RSVP-TE.
In/Out Label
Incoming label/outgoing label.
Outgoing interface name, NHLFE entry index, or label stack index of the LSP.
NHLFEnumber specifies the ingress LSP selected for the current LSP after route recursion. The ingress LSP is the one that matches the NHLFE entry with an NID of number.
LSINDEXnumber specifies the ingress LSP selected for the current LSP after route recursion. The ingress LSP is the one that matches the LSINDEX entry with a label stack index of number.
# Display IPv6 LSP information.
<Sysname> display mpls lsp ipv6
FEC      : 100:100:100:100:100:100:100:100/128
Protocol : BGP      In-Label     : 1200
Out-Label: 1300     Out-Interface: GE1/0/1
BkLabel  : 1400     BkInterface  : GE1/0/2
Table 5 Command output
FEC
·     Ingress LSR ID/Tunnel ID/LSP ID—RSVP TE FEC.
·     - (a hyphen)—The LSP is a static transit LSP, static egress LSP, static transit CRLSP, or static egress CRLSP.
Protocol
·     LDP.
·     BGP.
·     RSVP.
·     Static.
BkLabel
Outgoing label of the backup LSP.
BkInterface
Outgoing interface of the backup LSP.
# Display detailed information about all LSPs.
<Sysname> display mpls lsp verbose
Destination  : 56.10.10.2
FEC          : 56.10.10.2/32
Protocol     : LDP
LSR Type     : Egress
Service      : Statistics
In-Label     : 1024
State        : Active
Inbound Statistics:
  Octets    : 13000
  Packets   : 100
  Errors    : 0
  Discards  : 0
Destination  : 56.10.10.4
FEC          : 56.10.10.2/32
Protocol     : LDP
LSR Type     : Transit
In-Label     : 1026
Inbound Statistics:
  Octets    : 10600
  Packets   : 100
  Errors    : 0
  Discards  : 0
Path ID      : 0x40000000.1
State        : Active
Out-Label    : 1800
Nexthop      : 10.1.1.2
BkLabel      : 1900
BkNexthop    : 20.1.1.2
Outbound Statistics:
  Octets    : 12600
  Packets   : 100
  Errors    : 0
  Discards  : 0
FEC          : 56.10.10.2/32
Protocol     : LDP
LSR Type     : Ingress
Service      : -
NHLFE ID     : 2000
State        : Active
Out-Label    : 1800
Nexthop      : 10.1.1.2
Table 6 Command output
Destination
LSP destination address.
FEC
·     Ingress LSR ID/Tunnel ID/LSP ID—RSVP TE or static SRLSP FEC.
Protocol
·     LDP.
·     BGP (instance-name)—The instance-name specifies a BGP instance name. The value of default represents the default BGP instance.
·     RSVP.
·     Static.
·     IS-IS—IS-IS SRLSP.
·     OSPF—OSPF SRLSP.
LSR Type
LSR type:
·     Ingress—The current LSR is the ingress node of the LSP.
·     Transit—The current LSR is a transit node of the LSP.
·     Egress—The current LSR is the egress node of the LSP.
Service
Service deployed on the LSP.
The service can only be Statistics, which indicates the MPLS forwarding statistics feature.
Path ID
Forwarding path. The value is in the format of 0xnn.m. The nn represents the NHLFE group ID of the outer LSPs that carry the current LSP, and m represents the sequence number of the equivalence path.
NHLFE ID
NHLFE entry index.
LSP state:
·     Active—The LSP is in use.
·     Inactive—The LSP is idle.
Inbound Statistics
MPLS forwarding statistics in inbound direction:
·     Octets—Number of received octets.
·     Packets—Number of received packets.
·     Errors—Number of received error packets.
·     Discards—Number of discarded packets.
LsIndex
Label stack index of the LSP.
BkLabel
BkNexthop
Next hop address of the backup LSP.
BkInterface
BkLsIndex
Label stack index of the backup LSP.
Outbound Statistics
MPLS forwarding statistics in outbound direction:
·     Octets—Number of sent octets.
·     Packets—Number of sent packets.
·     Errors—Number of error packets.
display mpls lsp statistics
Use display mpls lsp statistics to display LSP statistics.
display mpls lsp statistics [ ipv6 ]
ipv6: Displays IPv6 LSP statistics. If you do not specify this keyword, the command displays IPv4 LSP statistics.
# Display IPv4 LSP statistics.
<Sysname> display mpls lsp statistics
LSP Type      Ingress/Transit/Egress  Active
Static LSP    0/0/0                   0/0/0
Static CRLSP  0/0/0                   0/0/0
LDP LSP       2/2/1                   2/2/1
RSVP CRLSP    0/0/0                   0/0/0
BGP LSP       0/0/0                   0/0/0
Local LSP     2/0/0                   2/0/0
IS-IS LSP     0/0/0                   0/0/0
OSPF LSP      0/0/0                   0/0/0
Total         4/2/1                   4/2/1
# Display IPv6 LSP statistics.
<Sysname> display mpls lsp statistics ipv6
LDP LSP       6/6/2                   6/6/2
BGP LSP       0/0/0                   0/0/0
Total         8/6/2                   8/6/2
Table 7 Command output
LSP Type
LSP types:
·     Static LSP.
·     Static CRLSP—Static CRLSP or static SRLSP.
·     LDP LSP.
·     Local LSP—LSP to a direct next hop, or LSP that uses a local MPLS TE tunnel interface or tunnel bundle interface as the LSP head.
·     RSVP CRLSP.
·     BGP LSP.
·     IS-IS LSP—IS-IS SRLSP.
·     OSPF LSP—OSPF SRLSP.
Total
Total number of LSPs.
Ingress
Number of LSPs that take the local device as the ingress node.
Transit
Number of LSPs that take the local device as a transit node.
Egress
Number of LSPs that take the local device as the egress node.
Active
Number of active LSPs of a type.
display mpls multicast-lsp protocol mldp p2mp
Use display mpls multicast-lsp protocol mldp p2mp to display information about P2MP LSPs signaled by using mLDP.
display mpls multicast-lsp protocol mldp p2mp [ root-ip ip-address { lsp-id lsp-id | opaque-value opaque-value } ]
root-ip ip-address: Specifies the root IP address of the P2MP LSPs to be displayed. If you do not specify this option, the command displays information about all P2MP LSPs signaled by using mLDP.
lsp-id lsp-id: Specifies the LSP ID of the P2MP LSPs to be displayed. The value range for the lsp-id argument is 0 to 4294967295.
opaque-value opaque-value: Specifies the opaque value of the P2MP LSPs to be displayed. The opaque-value argument is a hexadecimal string of 1 to 255 characters.
# Display information about all mLDP-signaled P2MP LSPs.
<Sysname> display mpls multicast-lsp protocol mldp p2mp
Root IP      : 1.1.1.1
Opaque value : 01000400000001
Tunnel ID    : 1
Protocol     : mLDP
LSR type     : Ingress
NHLFE ID     : 2000
State        : Active
Out label    : 1800
Nexthop      : 10.1.1.2
Out interface: GE1/0/1
Root IP      : 1.1.1.9
Opaque value : 010004e4000000
Tunnel ID    : 1
Protocol     : mLDP
LSR type     : Transit
In label     : 1279
Path ID      : 0x250000002.1
State        : Active
Out label    : 1279
Nexthop      : 20.1.1.2
Out interface: GE1/0/2
Table 8 Command output
Root IP
IP address of the root node of the mLDP P2MP LSPs.
Opaque value
Original opaque value in the mLDP protocol packet.
Tunnel ID
ID of the mLDP P2MP tunnel.
Protocol
Signaling protocol. The value of this field is mLDP, which indicates that the LSP is a P2MP LSP signaled by using mLDP.
LSR type
LSR type:
·     Ingress—Ingress node.
·     Transit—Transit node.
·     Egress—Egress node.
·     Bud—Both transit and egress nodes.
In label
Incoming label.
Path ID
Forwarding path. The value is in the format of 0xnn.m. nn represents the NHLFE group ID of the outer LSPs that carry the current LSP, and m represents the sequence number of the equivalence path.
NHLFE ID
NHLFE entry index.
LSP state:
·     Active.
·     Inactive.
Out label
Outgoing label.
Nexthop
Next hop address.
Out interface
Outgoing interface.
display mpls multicast-lsp statistics p2mp
Use display mpls multicast-lsp statistics p2mp to display P2MP LSP statistics.
# Display P2MP LSP statistics.
<Sysname> display mpls multicast-lsp statistics p2mp
LSP type      Ingress/Transit/Egress/Bud     Active
mLDP LSP      1/0/0/0                        1/0/0/0
Total         1/0/0/0                        1/0/0/0
Table 9 Command output
LSP Type
LSP type. The value of this field is mLDP, which indicates that the LSP is signaled by using mLDP.
Total
Ingress
Number of LSPs that use the local device as the ingress node.
Transit
Number of LSPs that use the local device as a transit node.
Egress
Number of LSPs that use the local device as the egress node.
Bud
Number of LSPs that use the local device as both transit and egress nodes.
Active
Total number of active LSPs.
display mpls nib
Use display mpls nib to display MPLS Nexthop Information Base (NIB) information.
display mpls nib [ nib-id ]
nib-id: Specifies a next hop ID in the range of 1 to FFFFFFFFFFFFFFFE. If you do not specify a next hop, this command displays information about all MPLS next hops.
# Display information about all MPLS next hops.
<Sysname> display mpls nib
NIB ID: 0x40000000
  Users: 1
  Status: Active
  ECMP number: 1
      Outgoing NHLFE ID: 1024
      Backup outgoing NHLFE ID: 1027
Table 10 Command output
NIB ID
ID of the next hop.
Users
Number of ILM entries that use this next hop.
Status
Next hop status:
·     Active—The next hop is active.
·     Dummy—The next hop is inactive.
ECMP number
Number of equal-cost NHLFE entries.
Outgoing NHLFE ID
ID of the NHLFE entry to which the next hop corresponds.
ID of the backup NHLFE entry.
display mpls nid
Use display mpls nid to display usage information for NIDs.
display mpls nid [ nid-value1 [ to nid-value2 ] ]
nid-value1: Specifies an NID. The NID value range is 0 to 65535. If used with the nid-value2 argument, the nid-value1 argument represents the start NID of an NID range.
to nid-value2: Specifies the end NID of the NID range. The value range for the end NID is 0 to 65535. If you specify an NID range by using the nid-value1 argument and the to nid-value2 option, this command displays usage information for the specified range of NIDs.
NIDs are 32-bit binary numbers. They include fixed NIDs and dynamic NIDs.
·     Fixed NIDs—Generated for tunnel interfaces or tunnel bundle interfaces. The highest four bits are a value other than 0000.
·     Dynamic NIDs—NIDs except fixed NIDs. The highest four bits are 0s.
This command displays usage information only for dynamic NIDs.
If you do not specify any parameters, this command displays usage information for all dynamic NIDs.
# Display usage information for dynamic NIDs 1028 through 1500.
<Sysname> display mpls nid 1028 to 1500
NID alloc state: '.' means not used, '$' means used
1028   :...$.... ........ ........ ........  ........ ........ ........ ........
1092   :........ ........ ........ ........  ........ ........ ........ ........
1156   :........ ........ ........ ........  ........ ........ ........ ........
1220   :........ ........ ........ ........  ........ ........ ........ ........
1284   :........ ........ ........ ........  ........ ........ ........ ........
1348   :........ ........ ........ ........  ........ ........ ........ ........
1412   :........ ........ ........ ........  ........ ........ ........ ........
1476   :........ ........ ........ .
display mpls summary
Use display mpls summary to display MPLS summary information.
# Display MPLS summary information.
<Sysname> display mpls summary
MPLS LSR ID      : 1.1.1.1
Egress Label Type: Implicit-null
Labels:
  Range                                 Idle          Owner
  16-2047                               2032          Static
                                                      StaticCR
                                                      StaticPW
                                                      Static SR Adj
  15000-15999(default SRLB)             1000          Default SR Adj
  16000-24000(default SRGB, reusable)   8001          Default SR Prefix
  24001-599999                          575999        LDP
                                                      RSVP
                                                      BGP
                                                      BGP SR EPE
                                                      OSPF SR Adj
                                                      ISIS SR Adj
                                                      mLDP
  600000-709999                         110000        BGP
  710000-774999                         65000         VPWS
  775000-1039999                        265000        VPLS
  1040000-1048000                       8001          LDP
                                                      RSVP
                                                      BGP
Protocols:
  Type                                  State
  LDP                                   Normal
  RSVP                                  Normal
  BGP(default)                          Normal
  Static                                Normal
  CCC                                   Normal
  StaticCR                              Normal
  Local                                 Normal
  BGP(xy)                               Normal
  BGP(abc)                              Normal
Table 11 Command output
Egress Label Type
Label type that the egress node assigns to the penultimate hop:
·     Implicit-null.
·     Explicit-null.
·     Non-null.
Labels
Label information.
Range
Label range.
·     If labels within the label range can be reused, this field displays (reusable) behind the label range.
·     If the default label range is used, this field displays (default) behind the label range.
·     If the configured global label range is used, this field displays (global) behind the label range.
·     If the label range is the SRGB range, this field displays (SRGB) behind the label range.
·     If the label range is the SRLB range, this field displays (SRLB) behind the label range.
Idle
Number of idle labels in the label range.
Owner
Label range owner.
·     LDP.
·     mLDP.
·     BGP.
·     RSVP.
·     StaticStatic LSP.
·     StaticCR—Static CRLSP.
·     StaticPW—Static PW.
·     Static SR Adj—Static SR adjacency SID.
·     Default SR Adj—Default SR adjacency SID.
·     SR Adj—Configured global SR adjacency SID.
·     Default SR Prefix—Default SR prefix SID.
·     SR Prefix—Configured global SR prefix SID.
·     OSPF SR Adj—SR adjacency SID automatically allocated to OSPF.
·     ISIS SR Adj—SR adjacency SID automatically allocated to IS-IS.
·     ISIS-1 SR Prefix—SR prefix SID of IS-IS process 1.
·     OSPF-1 SR Prefix—SR prefix SID of OSPF process 1.
·     VPWS.
·     VPLS.
·     BGP SR EPE—BGP PeerNode SID, PeerAdj SID, or PeerSet SID.
·     VRF—Label range specified for all VPN instances.
Protocols
Label distribution protocols that generated LSPs and their running states.
Protocol type:
·     LDP.
·     mLDP.
·     BGP (instance-name). The instance-name specifies a BGP instance name. The value of default represents the default BGP instance.
·     RSVP.
·     TE.
·     CCC.
·     IS-IS.
·     OSPF.
Label distribution protocol running state:
·     Normal—The protocol is in normal state.
·     Recover—The protocol is in the GR process.
ftn enable
Use ftn enable to enable the device to maintain FEC-to-NHLFE map (FTN) entries in the RIB.
Use undo ftn enable to disable the device to maintain FTN entries in the RIB.
ftn enable
undo ftn enable
The device does not maintain FTN entries in the RIB.
RIB IPv4 address family view
FTN entries are FIB entries that contain outgoing labels. When an LSR receives an unlabeled packet, it searches the corresponding FTN entry based on the destination IP address. If a match is found, the LSR adds the outgoing label in the FTN entry to the packet and forwards the labeled packet.
For the device to collect FTN forwarding statistics, you must execute the ftn enable command first, and then use the mpls-forwarding statistics prefix-list command to enable FTN forwarding statistics.
# Enable the device to maintain FTN entries in the RIB.
[Sysname] rib
[system-rib] address-family ipv4
[system-rib-ipv4] ftn enable
mpls enable
Use mpls enable to enable MPLS on an interface.
Use undo mpls enable to disable MPLS on an interface.
mpls enable
undo mpls enable
MPLS is disabled on an interface.
Interface view
# Enable MPLS on GigabitEthernet 1/0/1.
<Sysname> System-view
[Sysname-GigabitEthernet1/0/1] mpls enable
mpls forwarding split-horizon
Use mpls forwarding split-horizon to enable split horizon for MPLS forwarding.
Use undo mpls forwarding split-horizon to disable split horizon for MPLS forwarding.
Split horizon is disabled for MPLS forwarding.
# Enable split horizon for MPLS forwarding.
[Sysname] mpls forwarding split-horizon
mpls label advertise
Use mpls label advertise to specify the type of label the egress node will advertise to the penultimate hop.
Use undo mpls label advertise to restore the default.
mpls label advertise { explicit-null | implicit-null | non-null }
As egress, the device advertises an implicit null label to the penultimate hop.
explicit-null: Specifies the egress node to advertise an explicit null label of 0 or 2 to the penultimate hop. The explicit null label value is 0 in IPv4 networks and 2 in IPv6 networks.
implicit-null: Specifies the egress node to advertise an implicit null label of 3 to the penultimate hop.
non-null: Specifies the egress node to advertise a non-null label to the penultimate hop.
As a best practice, configure the egress node to advertise an implicit null label to the penultimate hop if the penultimate hop supports PHP.
If you want to simplify packet forwarding on egress but keep labels to determine QoS policies, configure the egress node to advertise an explicit null label to the penultimate hop.
Use non-null labels only in particular scenarios. For example, when OAM is configured on the egress node, the egress node can get the OAM function entity status only through non-null labels.
As a penultimate hop, the device accepts the implicit null label, explicit null label, or non-null label advertised by the egress node.
For LDP LSPs, the mpls label advertise command triggers LDP to delete the LSPs established before the command is executed and re-establishes new LSPs.
For BGP LSPs, the mpls label advertise command takes effect only on the BGP LSPs established after the command is executed. To apply the new setting to BGP LSPs established before the command is executed, delete the routes corresponding to the BGP LSPs, and then redistribute the routes.
# Configure the egress node to advertise an implicit null label to the penultimate hop.
[Sysname] mpls label advertise implicit-null
reset mpls ldp
mpls lsr-id
Use mpls lsr-id to configure an LSR ID for the local LSR.
Use undo mpls lsr-id to restore the default.
mpls lsr-id lsr-id
undo mpls lsr-id
An LSR has no LSR ID.
lsr-id: Specifies an ID for identifying the LSR, in dotted decimal notation.
As a best practice, use the address of a loopback interface on the LSR as the LSR ID.
# Configure the LSR ID as 3.3.3.3 for the local node.
[Sysname] mpls lsr-id 3.3.3.3
lsr-id
mpls mtu
Use mpls mtu to set the MPLS MTU for an interface.
Use undo mpls mtu to restore the default.
mpls mtu size
undo mpls mtu
The MPLS MTU of an interface is not configured. Fragmentation for MPLS packets is based on the IP MTU. If IP MTU is not configured, fragmentation for MPLS packets is based on the MTU of the interface. The length of a fragment does not include that of the MPLS label. Thus, after an MPLS label is added into a fragment, the length of the MPLS fragment might exceed the interface MTU.
Interface view
size: Specifies the MPLS MTU of the interface, in the range of 46 to 65535 bytes.
This command is effective only when MPLS is enabled on the interface.
If the MPLS MTU is larger than the interface MTU, data forwarding might fail.
MPLS TE tunnel interfaces do not support this command.
# Set the MPLS MTU of GigabitEthernet 1/0/1 to 1000 bytes.
[Sysname-GigabitEthernet1/0/1] mpls mtu 1000
mpls statistics
Use mpls statistics to enable MPLS label forwarding statistics for LSPs.
Use undo mpls statistics to disable MPLS label forwarding statistics for LSPs.
mpls statistics { all | [ vpn-instance vpn-instance-name ] { ipv4 ipv4-address mask-length | ipv6 ipv6-address prefix-length } | static | te ingress-lsr-id tunnel-id }
undo mpls statistics { all | [ vpn-instance vpn-instance-name ] { ipv4 ipv4-address mask-length | ipv6 ipv6-address prefix-length } | static | te ingress-lsr-id tunnel-id }
MPLS label forwarding statistics are disabled for all LSPs.
all: Specifies all LSPs.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command enables MPLS forwarding statistics for public LSPs.
ipv4 ipv4-address mask-length: Specifies the IPv4 LSP for an FEC specified by an IPv4 address and a mask length. The mask length is in the range of 0 to 32.
ipv6 ipv6-address prefix-length: Specifies the BGP-IPv6 LSP for an FEC specified by an IPv6 address and a prefix length. The prefix length is in the range of 0 to 128.
static: Specifies static LSPs and static CRLSPs.
te ingress-lsr-id tunnel-id: Specifies an RSVP-TE tunnel. The ingress-lsr-id represents the LSR ID of the ingress node of the tunnel. The tunnel-id argument represents the ID of the tunnel. The value range for the tunnel-id argument is 0 to 10239.
MPLS label forwarding forwards a labeled packet based on its incoming label. MPLS label forwarding statistics for specific LSPs is enabled by using the mpls statistics command. MPLS label forwarding statistics for a VPN instance is enabled by using the mpls statistics enable command. The mpls statistics enable command enables MPLS label forwarding statistics for a VPN instance and for all LSPs in the VPN instance. For more information about enabling MPLS label forwarding statistics for a VPN instance, see MPLS L3VPN configuration in MPLS Configuration Guide.
FTN forwarding adds a label to an unlabeled packet, and forwards the labeled packet. FTN forwarding statistics collection is enabled by the mpls-forwarding statistics prefix-list command in RIB IPv4 address family view.
To display MPLS label forwarding statistics for the specified LSPs by using the display mpls lsp verbose command, you must perform the following tasks:
·     Use the mpls statistics command to enable the MPLS label forwarding statistics feature for the LSPs.
·     Use the mpls statistics interval command to set the MPLS label forwarding statistics collection interval.
¡     The interval setting is optional for RSVP-TE tunnels. After you enable MPLS label forwarding statistics for an RSVP-TE tunnel, the statistics collection interval is automatically set to 30 seconds. You can modify the interval by using the mpls statistics interval command.
¡     For other types of LSPs, you must set the statistics collection interval.
The undo mpls statistics all command cannot disable MPLS label forwarding statistics for a VPN instance or a protocol after the mpls statistics command is executed with the vpn-instance, ipv4, ipv6, static, or te keyword specified. To disable MPLS label forwarding statistics for the VPN instance or protocol, execute the undo mpls statistics command with the vpn-instance, ipv4, ipv6, static, or te keyword specified.
# Enable MPLS label forwarding statistics for the LSP destined for 2.2.2.2/32.
[Sysname] mpls statistics ipv4 2.2.2.2 32
reset mpls statistics
Use mpls statistics interval to set the MPLS label forwarding statistics collection interval.
Use undo mpls statistics interval to delete the MPLS label forwarding statistics collection interval.
mpls statistics interval interval
The MPLS forwarding statistics collection interval is not set.
interval: Specifies the MPLS label forwarding statistics collection interval in the range of 30 to 65535 seconds.
To display MPLS label forwarding statistics for the specified LSPs by using the display mpls lsp verbose command, perform the following tasks:
·     Use the mpls statistics command to enable the MPLS label forwarding statistics feature for the specified LSPs.
·     Set the MPLS label forwarding statistics collection interval.
¡     For other types of LSPs, you must set the statistics collection interval by using the mpls statistics interval command.
To display MPLS label forwarding statistics for the specified VPN instance by using the display ip vpn-instance mpls statistics command, perform the following tasks:
·     Use the mpls statistics enable command to enable MPLS label forwarding statistics for the specified VPN instance. For more information, see MPLS L3VPN configuration in MPLS Configuration Guide.
·     Use the mpls statistics interval command to set the statistics collection interval.
# Set the MPLS label forwarding statistics collection interval to 30 seconds.
[Sysname] mpls statistics interval 30
mpls statistics
mpls ttl expiration enable
Use mpls ttl expiration enable to enable sending MPLS TTL-expired messages.
Use undo mpls ttl expiration enable to disable sending MPLS TTL-expired messages.
The MPLS TTL-expired messages sending feature is enabled.
This command enables an LSR to generate an ICMP TTL-expired message upon receiving an MPLS packet with TTL being 1.
·     If the MPLS packet has only one label, the LSR sends the ICMP TTL-expired message back to the source through IP routing.
·     If the MPLS packet has multiple labels, the LSR forwards the ICMP TTL-expired message along the LSP of the MPLS packet to the egress node. Then, the egress node sends the message back to the source.
# Disable sending MPLS TTL-expired messages.
[Sysname] undo mpls ttl expiration enable
mpls ttl propagate
Use mpls ttl propagate to enable TTL propagation.
Use undo mpls ttl propagate to disable TTL propagation.
mpls ttl propagate { public | vpn }
undo mpls ttl propagate { public | vpn }
TTL propagation is enabled for public network packets and is disabled for VPN packets.
public: Specifies public network packets.
vpn: Specifies VPN packets.
When TTL propagation is enabled, MPLS performs the following operations:
·     Copies the IP TTL to the label TTL for packets entering the MPLS network.
·     Copies the label TTL to the IP TTL for packets leaving the MPLS network.
If you enable TTL propagation on both ingress and egress, the IP tracert facility can show the real path in the MPLS network.
When TTL propagation is disabled, MPLS performs the following operations:
·     Sets the label TTL to 255 for packets entering the MPLS network.
·     Pops the label for packets leaving the MPLS network, without copying the label TTL value to the IP TTL.
The IP tracert facility cannot show the real path in the MPLS network.
Within an MPLS network, TTL is always copied between the labels of an MPLS packet. The mpls ttl propagate command affects only the propagation between IP TTL and label TTL.
As a best practice, set the same TTL processing mode on all LSRs of an LSP.
To enable TTL propagation for a VPN, you must enable it on all PE devices in the VPN. This allows you to obtain the same traceroute result (hop count) from those PEs.
# Enable TTL propagation for VPN packets.
[Sysname] mpls ttl propagate vpn
Use mpls-forwarding statistics prefix-list to enable FTN forwarding statistics for a destination network.
Use undo mpls-forwarding statistics prefix-list to disable FTN forwarding statistics for a destination network.
mpls-forwarding statistics prefix-list prefix-list-name
undo mpls-forwarding statistics prefix-list prefix-list-name
FTN forwarding statistics are disabled for all destination networks.
Parameter
prefix-list-name: Specifies an IPv4 address prefix list, a case-sensitive string of 1 to 63 characters. This command applies only to the destination networks that permitted by the prefix list.
FTN forwarding adds a label to an unlabeled packet, and forwards the labeled packet. FTN forwarding statistics collection is enabled by this command.
MPLS label forwarding forwards a labeled packet based on its incoming label. MPLS label forwarding statistics collection is enabled by the mpls statistics command.
Before executing this command, use the ftn enable command to enable the device to maintain FTN entries in the RIB.
# Enable FTN forwarding statistics for destination network 2.2.2.0/24.
[Sysname] ip prefix-list abc permit 2.2.2.0 24
[Sysname] rib
[system-rib-ipv4] mpls-forwarding statistics prefix-list abc
ftn enable
mpls statistics
Use reset mpls statistics to clear MPLS forwarding statistics for the specified LSPs.
reset mpls statistics { all | [ vpn-instance vpn-instance-name ] { ipv4 ipv4-address mask-length | ipv6 ipv6-address prefix-length } | static | te ingress-lsr-id tunnel-id }
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command clears MPLS forwarding statistics for public LSPs.
te ingress-lsr-id tunnel-id: Specifies an RSVP-TE tunnel. The ingress-lsr-id argument represents the LSR ID of the ingress node of the tunnel. The tunnel-id argument represents the ID of the tunnel. The value range for the tunnel-id argument is 0 to 10239.
# Clear MPLS forwarding statistics for the LSP destined for 2.2.2.2/32.
<Sysname> reset mpls statistics ipv4 2.2.2.2 32
mpls statistics
snmp-agent trap enable mpls
Use snmp-agent trap enable mpls to enable SNMP notifications for MPLS.
Use undo snmp-agent trap enable mpls to disable SNMP notifications for MPLS.
SNMP notifications for MPLS are disabled.
To report critical MPLS events to an NMS, enable SNMP notifications for MPLS. For MPLS event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
# Enable SNMP notifications for MPLS.
[Sysname] snmp-agent trap enable mpls
