04-Network Connectivity Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C Access Points Cloud Mode Configuration Guides(E2453 R2453)-6W10004-Network Connectivity Configuration Guide
24-IGMP snooping configuration
24-IGMP snooping configuration 319.80 KB
1 Configuring IGMP snooping· 1-1
About IGMP snooping· 1-1
Fundamentals of IGMP snooping· 1-1
IGMP snooping ports· 1-1
How IGMP snooping works· 1-3
Protocols and standards· 1-4
Restrictions and guidelines: IGMP snooping configuration· 1-4
VLAN-based IGMP snooping tasks at a glance· 1-5
Enabling the IGMP snooping feature· 1-5
Enabling IGMP snooping for VLANs· 1-6
Configuring basic IGMP snooping features· 1-6
Specifying an IGMP snooping version· 1-6
Setting the maximum number of IGMP snooping forwarding entries· 1-7
Configuring static multicast MAC address entries· 1-7
Setting the IGMP last member query interval 1-8
Configuring IGMP snooping port features· 1-9
Setting aging timers for dynamic ports· 1-9
Configuring a static member port 1-10
Configuring a static router port 1-10
Configuring a port as a simulated member host 1-10
Enabling fast-leave processing· 1-11
Disabling a port from becoming a dynamic router port 1-12
Configuring the IGMP snooping querier 1-12
Enabling the IGMP snooping querier 1-12
Configuring parameters for IGMP general queries and responses· 1-13
Configuring parameters for IGMP messages· 1-14
Configuring source IP addresses for IGMP messages· 1-14
Setting the 802.1p priority for IGMP messages· 1-15
Configuring IGMP snooping policies· 1-15
Configuring a multicast group policy· 1-15
Enabling dropping unknown multicast data· 1-16
Enabling IGMP report suppression· 1-17
Setting the maximum number of multicast groups on a port 1-17
Enabling multicast group replacement 1-17
Display and maintenance commands for IGMP snooping· 1-18
IGMP snooping configuration examples· 1-19
Example: Configuring IGMP snooping on a wireless network· 1-19
Troubleshooting IGMP snooping· 1-21
Layer 2 multicast forwarding cannot function· 1-21
Multicast group policy does not work· 1-22
About IGMP snooping
IGMP snooping runs on a Layer 2 device as a multicast constraining mechanism to improve multicast forwarding efficiency. It creates Layer 2 multicast forwarding entries from IGMP packets that are exchanged between the hosts and the Layer 3 device.
As shown in Figure1-1, when IGMP snooping is not enabled, the Layer 2 switch floods multicast packets to all hosts in a VLAN. When IGMP snooping is enabled, the Layer 2 switch forwards multicast packets of known multicast groups to only the receivers.
Figure1-1 Multicast packet transmission without and with IGMP snooping
IGMP snooping ports
As shown in Figure1-2, IGMP snooping runs on Switch A and Switch B, and Host A and Host C are receivers in a multicast group. IGMP snooping ports are divided into member ports and router ports.
Figure1-2 IGMP snooping ports
Router ports
On an IGMP snooping Layer 2 device, the ports toward Layer 3 multicast devices are called router ports. In Figure1-2, Port A1 of Switch A and Port B1 of Switch B are router ports.
Router ports contain the following types:
·     Dynamic router port—When a port receives an IGMP general query whose source address is not 0.0.0.0, the port is added into the dynamic router port list. At the same time, an aging timer is started for the port. If the port receives another IGMP general query before the timer expires, the timer is reset. If the port does not receive another IGMP general query when the timer expires, the port is removed from the dynamic router port list.
·     Static router port—When a port is statically configured as a router port, it is added into the static router port list. The static router port does not age out, and it can be deleted only manually.
Do not confuse the "router port" in IGMP snooping with the "routed interface" commonly known as the "Layer 3 interface." The router port in IGMP snooping is a Layer 2 interface.
Member ports
On an IGMP snooping Layer 2 device, the ports toward receiver hosts are called member ports. In Figure1-2, Port A2 and Port A3 of Switch A and Port B2 of Switch B are member ports.
Member ports contain the following types:
·     Dynamic member port—When a port receives an IGMP report, it is added to the associated dynamic IGMP snooping forwarding entry as an outgoing interface. At the same time, an aging timer is started for the port. If the port receives an IGMP report before the timer expires, the timer is reset. If the port does not receive an IGMP report when the timer expires, the port is removed from the associated dynamic forwarding entry.
·     Static member port—When a port is statically configured as a member port, it is added to the associated static IGMP snooping forwarding entry as an outgoing interface. The static member port does not age out, and it can be deleted only manually.
Unless otherwise specified, router ports and member ports in this document include both static and dynamic router ports and member ports.
The ports in this section are dynamic ports. For information about how to configure and remove static ports, see "Configuring a static member port" and "Configuring a static router port."
IGMP messages types include general query, IGMP report, and leave message. An IGMP snooping-enabled Layer 2 device performs differently depending on the message types.
General query
The IGMP querier periodically sends IGMP general queries to all hosts and devices on the local subnet to check for the existence of multicast group members.
After receiving an IGMP general query, the Layer 2 device forwards the query to all ports in the VLAN except the receiving port. The Layer 2 device also performs one of the following actions:
·     If the receiving port is a dynamic router port in the dynamic router port list, the Layer 2 device restarts the aging timer for the port.
·     If the receiving port does not exist in the dynamic router port list, the Layer 2 device adds the port to the dynamic router port list. It also starts an aging timer for the port.
IGMP report
A host sends an IGMP report to the IGMP querier for the following purposes:
·     Responds to queries if the host is a multicast group member.
·     Applies for a multicast group membership.
After receiving an IGMP report from a host, the Layer 2 device forwards the report through all the router ports in the VLAN. It also resolves the address of the reported multicast group, and looks up the forwarding table for a matching entry as follows:
·     If no match is found, the Layer 2 device creates a forwarding entry with the receiving port as an outgoing interface. It also marks the receiving port as a dynamic member port and starts an aging timer for the port.
·     If a match is found but the matching forwarding entry does not contain the receiving port, the Layer 2 device adds the receiving port to the outgoing interface list. It also marks the receiving port as a dynamic member port and starts an aging timer for the port.
·     If a match is found and the matching forwarding entry contains the receiving port, the Layer 2 device restarts the aging timer for the port.
A Layer 2 device does not forward an IGMP report through a non-router port because of the host IGMP report suppression mechanism. If a non-router port has member host attached, the member hosts suppress their IGMP reports upon receiving IGMP reports forwarded by the non-router port. The Layer 2 device cannot know the existence of the member hosts attached to the non-router port.
Leave message
An IGMPv1 receiver host does not send any leave messages when it leaves a multicast group. The Layer 2 device cannot immediately update the status of the port that connects to the receiver host. The Layer 2 device does not remove the port from the outgoing interface list in the associated forwarding entry until the aging time for the group expires.
An IGMPv2 or IGMPv3 host sends an IGMP leave message when it leaves a multicast group.
When the Layer 2 device receives an IGMP leave message on a dynamic member port, the Layer 2 device first examines whether a forwarding entry matches the group address in the message.
·     If no match is found, the Layer 2 device discards the IGMP leave message.
·     If a match is found but the receiving port is not an outgoing interface in the forwarding entry, the Layer 2 device discards the IGMP leave message.
·     If a match is found and the receiving port is not the only outgoing interface in the forwarding entry, the Layer 2 device performs the following actions:
¡     Discards the IGMP leave message.
¡     Sends an IGMP group-specific query to identify whether the group has active receivers attached to the receiving port.
¡     Sets the aging timer for the receiving port to twice the IGMP last member query interval.
·     If a match is found and the receiving port is the only outgoing interface in the forwarding entry, the Layer 2 device performs the following actions:
¡     Forwards the IGMP leave message to all router ports in the VLAN.
After receiving the IGMP leave message on a port, the IGMP querier resolves the multicast group address in the message. Then, it sends an IGMP group-specific query to the multicast group through the receiving port.
After receiving the IGMP group-specific query, the Layer 2 device forwards the query through all router ports and member ports of the group in the VLAN. Then, it waits for the responding IGMP report from the directly connected hosts. For the dynamic member port that received the leave message, the Layer 2 device also performs one of the following actions:
·     If the port receives an IGMP report before the aging timer expires, the Layer 2 device resets the aging timer.
·     If the port does not receive an IGMP report when the aging timer expires, the Layer 2 device removes the port from the forwarding entry for the multicast group.
RFC 4541, Considerations for Internet Group Management Protocol (IGMP) and Multicast Listener Discovery (MLD) Snooping Switches
The IGMP snooping configurations made on Layer 2 aggregate interfaces do not interfere with the configurations made on member ports. In addition, the configurations made on Layer 2 aggregate interfaces do not take part in aggregation calculations. The configuration made on a member port of the aggregate group takes effect after the port leaves the aggregate group.
To configure IGMP snooping features for VLANs, you must enable IGMP snooping for the specific VLANs even though IGMP snooping is enabled globally.
Some features can be configured for a VLAN in VLAN view or for multiple VLANs in IGMP-snooping view. The configuration made in VLAN view and the configuration made in IGMP-snooping view have the same priority, and the most recent configuration takes effect.
Some features can be configured for a VLAN in VLAN view or globally for all VLANs in IGMP-snooping view. The VLAN-specific configuration takes priority over the global configuration.
Some features can be configured for an interface in interface view or for all interfaces of the specified VLANs in IGMP-snooping view. The interface-specific configuration takes priority over the configuration made in IGMP-snooping view.
To configure IGMP snooping for VLANs, perform the following tasks:
1.     Enabling the IGMP snooping feature
2.     Enabling IGMP snooping for VLANs
3.     (Optional.) Configuring basic IGMP snooping features
¡     Specifying an IGMP snooping version
¡     Setting the maximum number of IGMP snooping forwarding entries
¡     Configuring static multicast MAC address entries
¡     Setting the IGMP last member query interval
4.     (Optional.) Configuring IGMP snooping port features
¡     Setting aging timers for dynamic ports
¡     Configuring a static member port
¡     Configuring a static router port
¡     Configuring a port as a simulated member host
¡     Enabling fast-leave processing
¡     Disabling a port from becoming a dynamic router port
5.     (Optional.) Configuring the IGMP snooping querier
¡     Enabling the IGMP snooping querier
¡     Configuring parameters for IGMP general queries and responses
6.     (Optional.) Configuring parameters for IGMP messages
¡     Configuring source IP addresses for IGMP messages
¡     Setting the 802.1p priority for IGMP messages
7.     (Optional.) Configuring IGMP snooping policies
¡     Configuring a multicast group policy
¡     Enabling dropping unknown multicast data
¡     Enabling IGMP report suppression
¡     Setting the maximum number of multicast groups on a port
¡     Enabling multicast group replacement
You must enable the IGMP snooping feature before you configure other IGMP snooping features.
2.     Enable the IGMP snooping feature and enter IGMP-snooping view.
igmp-snooping
By default, the IGMP snooping feature is disabled.
You can enable IGMP snooping for multiple VLANs by using the enable vlan command in IGMP-snooping view or for a VLAN by using the igmp-snooping enable command in VLAN view. The configuration in VLAN view has the same priority as the configuration in IGMP-snooping view.
IGMP snooping configuration in a VLAN takes effect only on the member ports in the VLAN.
Enabling IGMP snooping for multiple VLANs
2.     Enter IGMP-snooping view.
igmp-snooping
3.     Enable IGMP snooping for the specified VLANs.
enable vlan vlan-list
By default, IGMP snooping is disabled in a VLAN.
Enabling IGMP snooping for a VLAN
2.     Enter VLAN view.
vlan vlan-id
3.     Enable IGMP snooping for the VLAN.
Different IGMP snooping versions process different versions of IGMP messages.
·     IGMPv2 snooping processes IGMPv1 messages, IGMPv2 messages, and IGMPv3 queries, but it floods IGMPv3 reports in the VLAN instead of processing them.
·     IGMPv3 snooping processes IGMPv1, IGMPv2, and IGMPv3 messages.
If you change the IGMP snooping version from 2 to 3, the device performs the following actions:
·     Clears all IGMP snooping forwarding entries that are dynamically created.
·     Keeps static IGMPv3 snooping forwarding entries (*, G).
·     Clears static IGMPv3 snooping forwarding entries (S, G), which will be restored when the IGMP snooping version is switched back to 3.
For more information about static IGMP snooping forwarding entries, see "Configuring a static member port."
Specifying an IGMP snooping version for multiple VLANs
igmp-snooping
3.     Specify an IGMP snooping version for multiple VLANs.
By default, the IGMP snooping version for a VLAN is 2.
Specifying an IGMP snooping version for a VLAN
2.     Enter VLAN view.
vlan vlan-id
3.     Specify an IGMP snooping version for the VLAN.
igmp-snooping version version-number
You can modify the maximum number of IGMP snooping forwarding entries, including dynamic entries and static entries. When the number of forwarding entries on the device reaches the upper limit, the device does not automatically remove any existing entries. To allow new entries to be created, remove some entries manually.
igmp-snooping
3.     Set the maximum number of IGMP snooping forwarding entries.
entry-limit limit
By default, the maximum number of IGMP snooping forwarding entries is 4294967295.
In Layer 2 multicast, multicast MAC address entries can be dynamically created through Layer 2 multicast protocols (such as IGMP snooping). You can also manually configure static multicast MAC address entries by binding multicast MAC addresses and ports to control the destination ports of the multicast data.
You must specify an unused multicast MAC address when configuring a static multicast MAC address entry. A multicast MAC address is the MAC address in which the least significant bit of the most significant octet is 1.
Configuring a static multicast MAC address entry in system view
2.     Configure a static multicast MAC address entry.
Configuring a static multicast MAC address entry in interface view
2.     Enter Layer 2 interface view.
¡     Enter Layer 2 Ethernet interface view.
¡     Enter Layer 2 aggregate interface view.
3.     Configure a static multicast MAC address entry.
A receiver host starts a report delay timer for a multicast group when it receives an IGMP group-specific query for the group. This timer is set to a random value in the range of 0 to the maximum response time advertised in the query. When the timer value decreases to 0, the host sends an IGMP report to the group.
The IGMP last member query interval defines the maximum response time advertised in IGMP group-specific queries. Set an appropriate value for the IGMP last member query interval to speed up hosts' responses to IGMP group-specific queries and avoid IGMP report traffic bursts.
Setting the IGMP last member query interval globally
igmp-snooping
3.     Set the IGMP last member query interval globally.
last-member-query-interval interval
By default, the global IGMP last member query interval is 1 second.
Setting the IGMP last member query interval for a VLAN
2.     Enter VLAN view.
vlan vlan-id
3.     Set the IGMP last member query interval for the VLAN.
igmp-snooping last-member-query-interval interval
By default, the IGMP last member query interval is 1 second for a VLAN.
A dynamic router port is removed from the dynamic router port list if it does not receive an IGMP general query when its aging timer expires.
A dynamic member port is removed from the dynamic member port if it does not receive an IGMP report when its aging timer expires.
Set an appropriate value for the aging timers of dynamic ports. For example, if the memberships of multicast groups frequently change, set a relatively small value for the aging timer of the dynamic member ports. If the memberships of multicast groups rarely change, set a relatively large value.
IGMP group-specific queries originated by the Layer 2 device trigger the adjustment of aging timers for dynamic member ports. If a dynamic member port receives such a query, its aging timer is set to twice the IGMP last member query interval. For more information about setting the IGMP last member query interval on the Layer 2 device, see "Setting the IGMP last member query interval."
Setting the aging timers for dynamic ports globally
igmp-snooping
3.     Set the aging timer for dynamic router ports globally.
router-aging-time seconds
By default, the aging timer for dynamic router ports is 260 seconds.
4.     Set the global aging timer for dynamic member ports globally.
host-aging-time seconds
By default, the aging timer for dynamic member ports is 260 seconds.
Setting the aging timers for dynamic ports in a VLAN
2.     Enter VLAN view.
vlan vlan-id
3.     Set the aging timer for dynamic router ports in the VLAN.
igmp-snooping router-aging-time seconds
4.     Set the aging timer for dynamic member ports in the VLAN.
igmp-snooping host-aging-time seconds
You can configure a port as a static member port for a multicast group so that hosts attached to the port can always receive multicast for the group. The static member port does not respond to IGMP queries. When you complete or cancel this configuration on a port, the port does not send an unsolicited IGMP report or leave message.
3.     Configure the port as a static member port.
igmp-snooping static-group group-address [ source-ip source-address ] vlan vlan-id
By default, a port is not a static member port.
You can configure a port as a static router port for a multicast group so that all multicast data for the group received on the port will be forwarded.
3.     Configure the port as a static router port.
igmp-snooping static-router-port vlan vlan-id
By default, a port is not a static router port.
When a port is configured as a simulated member host, it is equivalent to an independent host in the following ways:
·     It sends an unsolicited IGMP report when you complete the configuration.
·     It responds to IGMP general queries with IGMP reports.
·     It sends an IGMP leave message when you cancel the configuration.
The version of IGMP running on the simulated member host is the same as the version of IGMP snooping running on the port. The port ages out in the same way as a dynamic member port.
3.     Configure the port as a simulated member host.
igmp-snooping host-join group-address [ source-ip source-address ] vlan vlan-id
By default, the port is not a simulated member host.
This feature enables the Layer 2 device to immediately remove a port from the forwarding entry for a multicast group when the port receives a leave massage. The Layer 2 device no longer sends or forwards IGMP group-specific queries for the group to the port.
Do not enable fast-leave processing on a port that has multiple receiver hosts in a VLAN. If you do so, the remaining receivers cannot receive multicast data for a group after a receiver leaves the group.
Enabling fast-leave processing globally
igmp-snooping
3.     Enable fast-leave processing globally.
fast-leave [ vlan vlan-list ]
By default, fast-leave processing is disabled globally.
Enabling fast-leave processing on a port
3.     Enable fast-leave processing on the port.
igmp-snooping fast-leave [ vlan vlan-list ]
By default, fast-leave processing is disabled on a port.
A receiver host might send IGMP general queries for testing purposes. On the Layer 2 device, the port that receives IGMP general queries becomes a dynamic router port. Before the aging timer for the port expires, the following problems might occur:
·     All multicast data for the VLAN to which the port belongs flows to the port. Then, the port forwards the data to attached receiver hosts. The receiver hosts will receive multicast data that it does not want to receive.
·     The port forwards the IGMP general queries to its upstream Layer 3 devices. These messages might affect the multicast routing protocol state (such as the IGMP querier or DR election) on the Layer 3 devices. This might further cause network interruption.
To solve these problems, you can disable a port from becoming a dynamic router port. This also improves network security and the control over receiver hosts.
This configuration and the static router port configuration do not interfere with each other.
3.     Disable the port from becoming a dynamic router port.
igmp-snooping router-port-deny [ vlan vlan-list ]
By default, a port is allowed to become a dynamic router port.
This feature enables the Layer 2 device to periodically send IGMP general queries to establish and maintain multicast forwarding entries at the data link Layer. You can configure an IGMP snooping querier on a network without Layer 3 multicast devices.
Do not enable the IGMP snooping querier on a multicast network that runs IGMP. An IGMP snooping querier does not take part in IGMP querier elections. However, it might affect IGMP querier elections if it sends IGMP general queries with a low source IP address.
Enabling the IGMP snooping querier for a VLAN
2.     Enter VLAN view.
vlan vlan-id
3.     Enable the IGMP snooping querier for the VLAN.
igmp-snooping querier
By default, the IGMP snooping querier is disabled for a VLAN.
You can modify the IGMP general query interval based on the actual condition of the network.
A receiver host starts a report delay timer for each multicast group that it has joined when it receives an IGMP general query. This timer is set to a random value in the range of 0 to the maximum response time advertised in the query. When the timer value decreases to 0, the host sends an IGMP report to the corresponding multicast group.
Set an appropriate value for the maximum response time for IGMP general queries to speed up hosts' responses to IGMP general queries and avoid IGMP report traffic bursts.
To avoid mistakenly deleting multicast group members, make sure the IGMP general query interval is greater than the maximum response time for IGMP general queries.
Configuring parameters for IGMP general queries and responses globally
igmp-snooping
3.     Set the maximum response time for IGMP general queries.
max-response-time seconds
By default, the maximum response time for IGMP general queries is 10 seconds.
Configuring parameters for IGMP general queries and responses in a VLAN
2.     Enter VLAN view.
vlan vlan-id
3.     Set the IGMP general query interval in the VLAN.
igmp-snooping query-interval interval
By default, the IGMP general query interval is 125 seconds for a VLAN.
4.     Set the maximum response time for IGMP general queries in the VLAN.
igmp-snooping max-response-time seconds
By default, the maximum response time for IGMP general queries is 10 seconds for a VLAN.
The IGMP snooping querier might send IGMP general queries with the source IP address 0.0.0.0. The port that receives such queries will not be maintained as a dynamic router port. This might prevent the associated dynamic IGMP snooping forwarding entry from being correctly created at the data link layer and eventually cause multicast traffic forwarding failures. To avoid this problem, you can configure a non-all-zero IP address as the source IP address of the IGMP queries on the IGMP snooping querier. This configuration might affect the IGMP querier election within the subnet.
You can also change the source IP address of IGMP reports or leave messages sent by a simulated member host.
Configuring the source IP addresses for IGMP messages in a VLAN
2.     Enter VLAN view.
vlan vlan-id
3.     Configure the source IP address for IGMP general queries.
igmp-snooping general-query source-ip ip-address
By default, the source IP address of IGMP general queries is the IP address of the current VLAN interface. If the current VLAN interface does not have an IP address, the source IP address is 0.0.0.0.
4.     Configure the source IP address for IGMP group-specific queries.
igmp-snooping special-query source-ip ip-address
By default, the source IP address of IGMP group-specific queries is one of the following:
¡     The source address of IGMP group-specific queries if the IGMP snooping querier of the VLAN has received IGMP general queries.
¡     The IP address of the current VLAN interface if the IGMP snooping querier does not receive an IGMP general query.
¡     0.0.0.0 if the IGMP snooping querier does not receive an IGMP general query and the current VLAN interface does not have an IP address.
5.     Configure the source IP address for IGMP reports.
igmp-snooping report source-ip ip-address
By default, the source IP address of IGMP reports is the IP address of the current VLAN interface. If the current VLAN interface does not have an IP address, the source IP address is 0.0.0.0.
6.     Configure the source IP address for IGMP leave messages.
igmp-snooping leave source-ip ip-address
By default, the source IP address of IGMP leave messages is the IP address of the current VLAN interface. If the current VLAN interface does not have an IP address, the source IP address is 0.0.0.0.
When congestion occurs on outgoing ports of the Layer 2 device, it forwards IGMP messages in their 802.1p priority order, from highest to lowest. You can assign a higher 802.1p priority to IGMP messages that are created or forwarded by the device.
Setting the 802.1p priority for IGMP messages globally
igmp-snooping
3.     Set the 802.1p priority for IGMP messages.
dot1p-priority priority
Setting the 802.1p priority for IGMP messages in a VLAN
2.     Enter VLAN view.
vlan vlan-id
3.     Set the 802.1p priority for IGMP messages in the VLAN.
igmp-snooping dot1p-priority priority
This feature enables the Layer 2 device to filter IGMP reports by using an ACL that specifies the multicast groups and the optional sources. It is used to control the multicast groups that hosts can join. This configuration takes effect only on the multicast groups that ports join dynamically.
In a multicast application, a host sends an unsolicited IGMP report when a user requests a multicast program. The Layer 2 device uses the multicast group policy to filter the IGMP report. The host can join the multicast group only if the IGMP report is permitted by the multicast group policy.
Configuring a multicast group policy globally
igmp-snooping
3.     Configure a multicast group policy globally.
group-policy ipv4-acl-number [ vlan vlan-list ]
By default, no multicast group policies are configured, and hosts can join any multicast groups.
Configuring a multicast group policy on a port
3.     Configure a multicast group policy on the port.
igmp-snooping group-policy ipv4-acl-number [ vlan vlan-list ]
By default, no multicast group policies are configured on a port, and hosts attached to the port can join any multicast groups.
Unknown multicast data refers to multicast data for which no forwarding entries exist in the IGMP snooping forwarding table. This feature enables the device to forward unknown multicast data only to the router port. If the device does not have a router port, unknown multicast data will be dropped.
If you do not enable this feature, the unknown multicast data is flooded in the VLAN to which the data belongs.
The drop-unknown command in IGMP-snooping view and the igmp-snooping drop-unknown command in VLAN view are mutually exclusive. You cannot configure them on the same device.
When dropping unknown IPv4 multicast data is enabled, the device also drops unknown IPv6 multicast data.
When you enable this feature for a VLAN, the device still forwards unknown multicast data out of router ports except the receiving router port in this VLAN.
Enabling dropping unknown multicast data globally
igmp-snooping
3.     Enable dropping unknown multicast data globally.
drop-unknown
By default, dropping unknown multicast data is disabled globally. Unknown multicast data is flooded.
Enabling dropping unknown multicast data for a VLAN
2.     Enter VLAN view.
vlan vlan-id
3.     Enable dropping unknown multicast data for the VLAN.
By default, dropping unknown multicast data is disabled for a VLAN. Unknown multicast data is flooded in the VLAN.
This feature enables the Layer 2 device to forward only the first IGMP report for a multicast group to its directly connected Layer 3 device. Other reports for the same group in the same query interval are discarded. Use this feature to reduce multicast traffic.
igmp-snooping
3.     Enable IGMP report suppression.
report-aggregation
By default, IGMP report suppression is enabled.
You can set the maximum number of multicast groups on a port to regulate the port traffic. This feature takes effect only on the multicast groups that a port joins dynamically.
If the number of multicast groups on a port exceeds the limit, the system removes all the forwarding entries associated with the port. The receiver hosts attached to that port can join multicast groups again before the number of multicast groups on the port reaches the limit. When the number of multicast groups on the port reaches the limit, the port automatically drops IGMP reports for new groups.
3.     Set the maximum number of multicast groups on the port.
igmp-snooping group-limit limit [ vlan vlan-list ]
By default, no limit is placed on the maximum number of multicast groups on a port.
When multicast group replacement is enabled, the port does not drop IGMP reports for new groups if the number of multicast groups on the port reaches the upper limit. Instead, the port leaves the multicast group that has the lowest IP address and joins the new group contained in the IGMP report. The multicast group replacement feature is typically used in the channel switching application.
This feature does not take effect if the following conditions exist:
·     The number of the IGMP snooping forwarding entries on the device reaches or exceeds the upper limit.
·     The multicast group that the port newly joins is not included in the multicast group list maintained by the device.
Enabling multicast group replacement globally
igmp-snooping
3.     Enable multicast group replacement globally.
By default, multicast group replacement is disabled globally.
Enabling multicast group replacement on a port
3.     Enable multicast group replacement on the port.
igmp-snooping overflow-replace [ vlan vlan-list ]
By default, multicast group replacement is disabled on a port.
Display IGMP snooping status.
display igmp-snooping [ global | vlan vlan-id ]
Display dynamic IGMP snooping group entries.
display igmp-snooping group [ group-address | source-address ] * [ vlan vlan-id ] [ verbose ]
Display dynamic router port information.
display igmp-snooping router-port [ verbose | vlan vlan-id ]
Display static IGMP snooping group entries.
display igmp-snooping static-group [ group-address | source-address ] * [ vlan vlan-id ] [ verbose ]
Display static router port information.
display igmp-snooping static-router-port [ vlan vlan-id ]
Display statistics for the IGMP messages learned by IGMP snooping.
display igmp-snooping statistics
Display Layer 2 multicast fast forwarding entries.
display l2-multicast fast-forwarding cache [ vlan vlan-id ] [ source-address | group-address ] *
Display information about Layer 2 IP multicast groups.
display l2-multicast ip [ group group-address | source source-address ] * [ vlan vlan-id ]
Display Layer 2 IP multicast group entries.
display l2-multicast ip forwarding [ group group-address | source source-address ] * [ vlan vlan-id ]
Display information about Layer 2 MAC multicast groups.
display l2-multicast mac [ mac-address ] [ vlan vlan-id ]
Display Layer 2 MAC multicast group entries.
display l2-multicast mac forwarding [ mac-address ] [ vlan vlan-id ]
Display static multicast MAC address entries.
Clear dynamic IGMP snooping group entries.
reset igmp-snooping group { group-address [ source-address ] | all } [ vlan vlan-id ]
Clear dynamic router port information.
reset igmp-snooping router-port { all | vlan vlan-id }
Clear statistics for IGMP messages learned through IGMP snooping.
reset igmp-snooping statistics
As shown in Figure1-3:
·     The source sends multicast traffic to multicast group 224.1.1.1.
·     The client is a receiver host of the multicast group.
·     The route between the source and the client is reachable.
Configure the AP so that the client can receive the multicast traffic from the source.
Figure1-3 Network diagram
1.     Assign an IP address and subnet mask to each interface, as shown in Figure1-3. (Details not shown.)
2.     Configure Router A:
# Enable IP multicast routing.
[RouterA] multicast routing
[RouterA-mrib] quit
# Enable PIM-DM on GigabitEthernet 1/0/1.
[RouterA-GigabitEthernet1/0/1] pim dm
# Enable IGMP on GigabitEthernet 1/0/2.
[RouterA-GigabitEthernet1/0/2] igmp enable
3.     Configure WLAN services:
# Create VLAN 100.
<AP> system-view
[AP] vlan 100
[AP-vlan100] quit
# Create service template 1, and set the SSID to Multicast for the service template.
[AP] wlan service-template 1
[AP-wlan-st-1] ssid Multicast
# Bind VLAN 100 to service template 1, and enable the service template.
[AP-wlan-st-1] vlan 100
[AP-wlan-st-1] service-template enable
[AP-wlan-st-1] quit
# Bind service template 1 to WLAN radio interface 1/0/1.
[AP] interface WLAN-Radio 1/0/1
[AP-WLAN-Radio1/0/1] service-template 1
[AP-WLAN-Radio1/0/1] quit
4.     Configure IGMP snooping:
# Enable the IGMP snooping feature.
[AP] igmp-snooping
[AP-igmp-snooping] quit
# In VLAN 100, enable IGMP snooping, and specify IGMP snooping version 3.
[AP] vlan 100
[AP-vlan100] igmp-snooping enable
[AP-vlan100] igmp-snooping version 3
[AP-vlan100] quit
5.     Configure GigabitEthernet 1/0/1 on the AP as a trunk port, and assign the port to VLAN 100. (The Ethernet interface configuration on the AP varies by AP model.)
[AP] interface gigabitethernet 1/0/1
[AP-GigabitEthernet1/0/1] port link-type trunk
[AP-GigabitEthernet1/0/1] port trunk permit vlan 100
[AP-GigabitEthernet1/0/1] quit
6.     Configure the client to access the WLAN service with the SSID Multicast and request multicast traffic for multicast group 224.1.1.1. (Details not shown.)
# Display detailed information about dynamic IGMP snooping group entries for VLAN 100 on the AP.
[AP] display igmp-snooping group vlan 100 verbose
Total 1 entries.
VLAN 100: Total 1 entries.
  (0.0.0.0, 224.1.1.1)
    Attribute: local port
    FSM information: normal
    Host slots (0 in total):
    Host ports (1 in total):
      WLAN-BSS1/0/20                        (00:03:23)
The output shows that WLAN-BSS 1/0/20 on the AP has joined multicast group 224.1.1.1.
Symptom
Layer 2 multicast forwarding cannot function on the Layer 2 device.
Solution
To resolve the problem:
1.     Use the display igmp-snooping command to display IGMP snooping status.
2.     If IGMP snooping is not enabled, use the igmp-snooping command in system view to enable the IGMP snooping feature. Then, use the igmp-snooping enable command in VLAN view to enable IGMP snooping for the VLAN.
3.     If IGMP snooping is enabled globally but not enabled for the VLAN, use the igmp-snooping enable command in VLAN view to enable IGMP snooping for the VLAN.
4.     If the problem persists, contact H3C Support.
Symptom
Hosts can receive multicast data for multicast groups that are not permitted by the multicast group policy.
Solution
1.     Use the display acl command to verify that the configured ACL meets the multicast group policy requirements.
2.     Use the display this command in IGMP-snooping view or in a corresponding interface view to verify that the correct multicast group policy has been applied. If the applied policy is not correct, use the group-policy or igmp-snooping group-policy command to apply the correct multicast group policy.
3.     Use the display igmp-snooping command to verify that dropping unknown multicast data is enabled. If it is not, use the drop-unknown or igmp-snooping drop-unknown command to enable dropping unknown multicast data.
