- 04-Network Connectivity Configuration Guide
- 01-About the network connectivity configuration guide
- 02-MAC address table configuration
- 03-Ethernet link aggregation configuration
- 04-Port isolation configuration
- 05-VLAN configuration
- 06-Loop detection configuration
- 07-Spanning tree configuration
- 08-LLDP configuration
- 09-Layer 2 forwarding configuration
- 10-ARP configuration
- 11-IP addressing configuration
- 12-DHCP configuration
- 13-DHCPv6 configuration
- 14-DNS configuration
- 15-NAT configuration
- 16-IP performance optimization configuration
- 17-IPv6 basics configuration
- 18-Basic IP routing configuration
- 19-Static routing configuration
- 20-IPv6 static routing configuration
- 21-Multicast overview
- 22-IGMP snooping configuration
- 23-MLD snooping configuration
| 04-Port isolation configuration | 93.72 KB |
Assigning a port to the isolation group
Display and maintenance commands for port isolation
1 Configuring port isolation
About port isolation
The port isolation feature isolates Layer 2 traffic for data privacy and security without using VLANs.
Ports in an isolation group cannot communicate with each other. However, they can communicate with ports outside the isolation group.
You can configure community VLANs in an isolation group. Ports in an isolation group can communicate with each other if they belong to a community VLAN.
As shown in Figure1-1:
· To isolate Host A from Host C, and Host B from Host D, assign Port B and Port C on Device A to isolation group 1.
· To enable Layer 2 communication between Host B and Host D, specify VLAN 3 as a community VLAN in isolation group 1. Host B and Host D belong to VLAN 3.
Figure1-1 Community VLANs in an isolation group
The device supports only one isolation group that is automatically created as isolation group 1. You cannot remove the isolation group or create other isolation groups on the device. The number of ports assigned to the isolation group is not limited.
· The configuration in Layer 2 Ethernet interface view applies only to the interface.
· The configuration in Layer 2 aggregate interface view applies to the Layer 2 aggregate interface and its aggregation member ports. If the device fails to apply the configuration to the aggregate interface, it does not assign any aggregation member port to the isolation group. If the failure occurs on an aggregation member port, the device skips the port and continues to assign other aggregation member ports to the isolation group.
1. Enter system view.
2. Enter interface view.
3. Assign the port to the isolation group.
port-isolate enable
By default, the port is not in the isolation group.
Task |
Command |
Display port isolation group information. |
display port-isolate group |
