H3C MSR 2600 Routers Hardware Information and Specifications-6W100
HomeSupportRoutersMSR2600 Series(Comware V7)Product LiteratureHardware Information & SpecificationsH3C MSR 2600 Routers Hardware Information and Specifications-6W100
02-LEDs
02-LEDs 2.15 MB
2 LEDs
LEDs
MSR2600-5-GU-CNDE
Figure2-1 Front panel LEDs
(1) System status LED (SYS)
(2) Network status LED (INTERNET)
(3) VPN status LED (VPN)
(4) Encryption module LED (CNDE)
(5) 3G status LED (WWAN)
(6) Received 3G signal strength indication LED (RSSI)
Figure2-2 Rear panel LEDs
(1) GE port LEDs (yellow)
(2) GE port LEDs (green)
MSR2600-5-GT-CNDE
Figure2-3 Front panel LEDs
Figure2-4 Rear panel LEDs
MSR2600-5-LM-CNDE
Figure2-5 Front panel LEDs
(5) 4G status LED (WWAN)
(6) Received 4G signal strength indication LED (RSSI)
Figure2-6 Rear panel LEDs
MSR2600-10
Figure2-7 LEDs
(2) Power status LED (PWR)
(3) GE port LEDs (GE0 to GE9)
MSR2600-17
Figure2-8 LEDs
(3) SFP port LED (SFP16)
(4) GE port LEDs (GE0 to GE15)
MSR2630
Figure2-9 LEDs
(1) GE port LED (GE0)
(2) GE port LED (GE1)
(3) CON/AUX port LED
(4) USB console port LED
(5) System LED (SYS)
(6) Power status LED (PWR)
MSR2600-6-X1/MSR2630-XS
Figure2-10 LEDs
(3) LEDs for GE copper ports GE0 to GE4
(4) LED for GE fiber port SFP5
MSR2600-10-X1
Figure2-11 LEDs
(3) LEDs for GE copper ports GE0 to GE9
MSR2600-15-X1/MSR2600-15-X1-T
Figure2-12 LEDs
(1) LEDs for GE copper ports GE0 to GE12
(2) LEDs for GE fiber ports SFP13 and SFP14
(3) System status LED (SYS)
(4) Power status LED (PWR)
MSR2630E-X1
Figure2-13 LEDs
(2) LEDs for GE copper ports GE2 to GE9
(3) LEDs for 10GE fiber ports SFP+10 to SFP+12
(4) LEDs for combo copper ports GE0 and GE1
(5) LEDs for combo fiber ports SFP0 and SFP1
(7) CTRL LED (CTRL)
MSR2660-XS
Figure2-14 LEDs
(1) LEDs for GE copper ports GE2 to GE9
(2) LEDs for 10GE fiber ports SFP+10 and SFP+11
(3) LEDs for combo fiber ports 0 and 1
(4) LEDs for combo copper ports 0 and 1
(5) System status LED (SYS)
MSR2680-XS
Figure2-15 MSR2680-XS LEDs
(5) LEDs for combo fiber ports 0 and 1
LED descriptions
Table2-1 Front panel LED descriptions
LED
Status
Slowly flashing green
Comware has started with the configuration file and the router has booted up.
Fast flashing green
The system software image is being copied and decompressed.
Steady green
The SDRAM is performing self-test.
Slowly flashing yellow
The SDRAM has failed self-test.
Fast flashing yellow
The BootWare extended segment does not exist.
Steady yellow
The system software image does not exist.
Off
No power input, or exceptions have occurred.
Steady green
The power system is operating correctly.
Off
No power is being input.
Steady green
The router is using the USB console port for configuration.
Off
The router is not using the USB console port.
CON/AUX port LED
Steady green
The router is using the console port for configuration.
Off
The router is not using the console port.
Steady green
The router has been connected to the network.
Off
The router has not been connected to the network.
Steady green
A VPN link is present.
Off
No VPN link is present.
Steady green
The router has been connected to the wireless network and is operating in 3G mode.
Flashing green at 8 Hz
Data is being received or transmitted. The router is operating in 3G mode.
Steady yellow
The router has been connected to the wireless network and is operating in 2G mode.
Flashing yellow at 8 Hz
Data is being received or transmitted. The router is operating in 2G mode.
Off
No link is present or no wireless network is available.
Steady green
Strong signal.
Middle or low signal strength.
Off
Weak or no signal.
Steady green
The router has been connected to the wireless network and is operating in 4G mode.
Data is being received or transmitted. The router is operating in 4G mode.
Steady yellow
Off
No link is present or the router is operating is 2G mode.
Steady green
Strong signal.
Off
Weak or no signal.
Steady green
The power is being supplied correctly.
Flashing green
Encrypted data is being received or transmitted.
10GE fiber port LED
Steady green
A 10 Gbps link is present on the port.
Flashing green
The port is sending or receiving data at 10 Gbps.
Steady yellow
A 1000 Mbps link is present on the port.
Flashing yellow
The port is sending or receiving data at 1000 Mbps.
Off
No link is present on the port.
CTRL LED
Steady green
A WebSocket connection is present between the router and controller.
Flashing yellow
The router is connecting to the controller.
Off
No link is present between the router and controller.
GE copper port LED
Combo copper port LED
Steady green
Flashing green
Steady yellow
A 10/100 Mbps link is present on the port.
Flashing yellow
The port is sending or receiving data at 10/100 Mbps.
Off
Combo fiber port LED
Steady green
Flashing green
Steady yellow
A 100 Mbps link is present on the port.
Flashing yellow
The port is sending or receiving data at 100 Mbps.
Off
SFP port LED
Steady green
Flashing green
Steady yellow
Flashing yellow
Off
SFP port LED (for the MSR2600-15-X1/MSR2600-15-X1-T)
Steady green
Flashing green
Off
