H3C MSR 2600 Routers Hardware Information and Specifications-6W100
HomeSupportRoutersMSR2600 Series(Comware V7)Product LiteratureHardware Information & SpecificationsH3C MSR 2600 Routers Hardware Information and Specifications-6W100
01-Chassis views and technical specifications
01-Chassis views and technical specifications 3.07 MB
1 Chassis views and technical specifications
Chassis views
The following figures are for illustration only.
MSR2600-5-GU-CNDE
Figure1-1 Front view
(1) USB port
(2) Reset button (RESET)
Figure1-2 Rear view
(1) Power adapter receptacle
(2) Console port/AUX port (CON/AUX)
(3) GE WAN port (GE0)
(4) 3G antenna main port (MAIN)
(5) GE LAN ports (GE1 to GE4)
(6) 3G antenna auxiliary port (DIV)
(7) Grounding screw
MSR2600-5-GT-CNDE
Figure1-3 Front view
(1) USB port
Figure1-4 Rear view
(4) 3G antenna auxiliary port (DIV)
(6) 3G antenna main port (MAIN)
(7) Grounding screw
MSR2600-5-LM-CNDE
Figure1-5 Front view
(1) USB port
Figure1-6 Rear view
(4) 4G antenna port
(6) 4G antenna port
(7) Grounding screw
MSR2600-10
Figure1-7 Front view
(1) AC power receptacle
(2) GE port (GE1)
(3) GE ports (GE2 to GE9)
(4) Console port/AUX port (CON/AUX)
(5) Reset button (RESET)
(6) USB port
(7) GE port (GE0)
Figure1-8 Rear view
(1) SIC slot 3
(2) SIC slot 2
(3) SIC slot 1
(4) Grounding screw
MSR2600-17
Figure1-9 Front view
(2) GE ports (GE0 to GE15)
(3) GE fiber port (SFP16)
(6) USB port
Figure1-10 Rear view
(1) SIC slot 4
(2) SIC slot 3
(3) SIC slot 2
(4) SIC slot 1
(5) Grounding screw
MSR2630
Figure1-11 Front view
(2) Power switch
(3) GE port (GE0)
(4) GE port (GE1)
(5) Console port/AUX port (CON/AUX)
(6) USB console port (CON)
(7) USB port
Figure1-12 Rear view
(1) SIC slot 3
(2) SIC slot 2
(3) SIC slot 1
(4) Grounding screw
MSR2600-6-X1/MSR2630-XS
Figure1-13 Front view
(2) GE copper port GE0
(3) GE copper ports GE1 to GE4
(4) GE fiber port SFP5
(5) Console port (CONSOLE)
(6) Reset button (RESET)
(7) USB port
Figure1-14 Rear view
(1) SIC slot 2
(2) SIC slot 1
(3) Grounding screw
MSR2600-10-X1
Figure1-15 Front view
(2) GE port GE1
(3) GE ports GE2 to GE9
(4) Serial console/auxiliary port (CON/AUX)
(6) USB port
(7) GE port GE0
Figure1-16 Rear view
(1) SIC slot 3
(2) SIC slot 2
(3) SIC slot 1
(4) Grounding screw
MSR2600-15-X1/MSR2600-15-X1-T
Figure1-17 Front view
(2) GE copper ports GE0 to GE11
(3) GE copper port GE12
(4) GE fiber ports SFP13 and SFP14
(5) Console port
(6) USB port
(7) Reset button (RESET)
Figure1-18 Rear view
(1) SIC slot 2
(2) SIC slot 1
(3) Grounding screw
MSR2630E-X1
Figure1-19 Front view
(2) USB port
(3) Console port
(4) GE fiber ports SFP0 and SFP1 (combo interfaces)
(5) GE ports GE0 and GE1 (combo interfaces)
(6) 10GE fiber ports SFP+10 to SFP+12
(7) GE ports GE2 to GE9
(8) Reset button (RESET)
Figure1-20 Rear view
(1) SIC slot 2
(2) SIC slot 1
(5) Grounding screw
MSR2660-XS
Figure1-21 Front view
(2) GE ports GE2 to GE9
(3) 10GE fiber ports SFP+10 and SFP+11
(6) Console port
(7) USB port
Figure1-22 Rear view
(1) Grounding screw
MSR2680-XS
Figure1-23 Front view
(2) USB port
(3) Console port
Figure1-24 Rear view
(1) SIC slot 2
(1) SIC slot 1
(3) Grounding screw
Technical specifications
Table1-1 Technical specifications (1)
Item
MSR2630
MSR2600-5-GU-CNDE
MSR2600-5-GT-CNDE
MSR2600-5-LM-CNDE
MSR2600-10
MSR2600-17
Console/AUX port
1
1
1
1
1
1
USB console port
1
N/A
N/A
N/A
N/A
N/A
USB port
1
1
1
1
1
1
GE port
2
5
5
5
10
16
SFP fiber port
N/A
N/A
N/A
N/A
N/A
1
USB Bluetooth adapter
Supported
Not supported
Not supported
Not supported
Not supported
Not supported
Reset button
N/A
1
1
1
1
1
Built-in 3G/4G module
N/A
1, WCDMA (China Unicom)
1, CDMA2000 (China Telecom)
1, LTE FDD (China Unicom) and LTE TDD (China Mobile)
N/A
N/A
Memory
1 GB DDR3
256 MB DDR3
256 MB DDR3
256 MB DDR3
512 MB DDR3
512 MB DDR3
Flash
256 MB
128 MB
128 MB
128 MB
256 MB
256 MB
SIC/DSIC slot
3 SIC slots
(Slots 1 and 2 can be used for a DSIC interface module by removing the slot divider.)
N/A
N/A
N/A
3 SIC slots
4 SIC slots
Dimensions (H × W × D)
(excluding rubber feet and mounting brackets)
44.2 × 360 × 303.5 mm (1.74 × 14.17 × 11.95 in)
44.2 x 300 x 200 mm (1.74 x 11.81 x 7.87 in)
44.2 × 360 × 323.5 mm (1.74 × 14.17 × 12.74 in)
Rated AC voltage
100 to 240 VAC @ 50/60 Hz
90 to 264 VAC @ 50/60 Hz
85 to 264 VAC @ 50/60 Hz
Rated power for AC power supply
54 W
24 W
24 W
24 W
30 W
54 W
Operating temperature
0°C to 45°C (32°F to 113°F)
0°C to 40°C (32°F to 104°F)
Relative humidity (noncondensing)
5% to 90%
5% to 90%
5% to 90%
5% to 90%
5% to 90%
5% to 90%
Table1-2 Technical specifications (2)
Item
MSR2600-10-X1
Console/AUX port
N/A
1
N/A
Console port
1
N/A
1
USB port
1
1
1
GE port
5
10
13
SFP fiber port
1
N/A
2
Supported only by the MSR2600-6-X1
Supported
Not supported
Reset button
1
1
1
Memory
1GB DDR3
1GB DDR3
1GB DDR3
Flash
256 MB
256 MB
512 MB
SIC slot
2
3
2
Dimensions (H × W × D) (excluding rubber feet and mounting brackets)
44.2 × 360 × 300 mm (1.74 × 14.17 × 11.81 in)
Rated AC voltage
Max power consumption
30 W
30 W
36 W
Storage temperature
–40°C to +70°C (–40°F to +158°F)
Humidity
5% RH to 95% RH, noncondensing
Table1-3 Technical specifications (3)
Item
MSR2660-XS
MSR2630E-X1/MSR2680-XS
Console port
1
1
USB port
1
1
GE port
10 (including two combo interfaces)
SFP fiber port
2 (combo interfaces)
SFP+ fiber port
2
3
Reset button
1
1
Memory
2GB DDR4
4GB DDR4
Flash
4 GB
4 GB
SIC slot
N/A
2
43.6 × 266 × 161 mm (1.72 × 10.47 × 6.34 in)
Rated AC voltage
14.7 W
39 W
Storage temperature
Humidity
For routers that support a USB Bluetooth adapter, you can connect a USB Bluetooth adapter to a USB port on the router for fast device configuration and deployment from your mobile phone. For more information, see H3C MSR&LA Router Series Deployment Guide via Bluetooth.
Antenna specifications
Table1-4 4G antenna specifications
Item
Specification
Frequency range
698-960 MHz/1710-2700 MHz
Voltage Standing Wave Ratio (VSWR)
< 2.5
Input impedance
50 ohms
Gain
2 dBi
5 W
Input interface
TNC male
Length
214 mm (8.43 in)
Color
Black
Weight
50 g (1.76 oz)
–40°C to +85°C (–40°F to +185°F)
Table1-5 3G antenna specifications
Item
Specification
Frequency range
806-960 MHz/1710-2170 MHz
< 2.5
Input impedance
50 ohms
Gain
0 dBi
25 W
Input interface
TNC male
Length
254 mm (10.00 in)
Color
Gray
Weight
45 g (1.59 oz)
–30°C to +70°C (–22°F to +158°F)
Interface module specifications
The router supports SIC and DSIC interface modules. For more information about the interface module specifications, see H3C MSR Router Series Interface Module Guide.
Link mode of interfaces
For information about link mode change of interfaces on interface modules, see H3C MSR Router Series Interface Module Guide.
Table1-6 Fixed interfaces that can operate only as Layer 3 Ethernet interfaces
Router model
Interfaces
MSR2600-5-GU-CNDE
GE0
MSR2600-5-GT-CNDE
GE0
MSR2600-5-LM-CNDE
GE0
MSR2600-10
GE0, GE1
MSR2600-17
GE0, GE1, SFP16
MSR2630
GE0, GE1
GE0, SFP5
MSR2600-10-X1
GE0, GE1
GE0 to GE4, SFP13, SFP14
MSR2630E-X1
Combo 0 (GE0, SFP0), Combo 1 (GE1, SFP1), SFP+10 to SFP+12
MSR2660-XS
Combo 0 (GE0, SFP0), Combo 1 (GE1, SFP1), SFP+10 and SFP+11
MSR2680-XS
Table1-7 Fixed interfaces that operate as Layer 2 interfaces by default and can be changed to Layer 3 interfaces
Router model
Interfaces
MSR2600-5-GU-CNDE
GE1 to GE4
MSR2600-5-GT-CNDE
GE1 to GE4
MSR2600-5-LM-CNDE
GE1 to GE4
MSR2600-10
GE2 to GE9
MSR2600-17
GE2 to GE15
MSR2630
N/A
GE1 to GE4
MSR2600-10-X1
GE2 to GE9
GE5 to GE12
MSR2630E-X1
GE2 to GE5
MSR2660-XS
GE2 to GE5
MSR2680-XS
GE2 to GE5
Table1-8 Fixed interfaces that can operate only as Layer 2 Ethernet interfaces
Router model
Interfaces
MSR2600-5-GU-CNDE
N/A
MSR2600-5-GT-CNDE
N/A
MSR2600-5-LM-CNDE
N/A
MSR2600-10
N/A
MSR2600-17
N/A
MSR2630
N/A
N/A
MSR2600-10-X1
N/A
N/A
MSR2630E-X1
GE6 to GE9
MSR2660-XS
GE6 to GE9
MSR2680-XS
GE6 to GE9
