20-VXLAN Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath M9000 Command Reference(V7)(R9153P39 R9001P39)-6W40020-VXLAN Command Reference
Table of Contents
Related Documents
01-VXLAN commands
01-VXLAN commands 132.84 KB
VXLAN commands
The following compatibility matrixes show the support of hardware platforms for VXLAN:
Hardware platform
Module type
VXLAN compatibility
M9006
M9010
M9014
Blade IV firewall module
Yes
Blade V firewall module
Yes
NAT module
Yes
Application delivery engine (ADE) module
Yes
Anomaly flow cleaner (AFC) module
No
M9010-GM
Encryption module
Yes
M9016-V
Yes
M9008-S
M9012-S
Yes
Yes
Intrusion prevention service (IPS) module
Yes
Video network gateway module
Yes
No
M9008-S-6GW
IPv6 module
Yes
M9008-S-V
Yes
M9000-AI-E8
Yes
Yes
M9000-AI-E16
Yes
Basic VXLAN commands
description
Use description to configure a description for a VSI.
A VSI does not have a description.
VSI view
context-admin
text: Specifies a description, a case-sensitive string of 1 to 80 characters.
# Configure a description for VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] description vsi for vpn1
display l2vpn vsi
display l2vpn interface
Use display l2vpn interface to display L2VPN information for Layer 3 interfaces that are mapped to VSIs.
display l2vpn interface [ vsi vsi-name | interface-type interface-number ] [ verbose ]
context-admin
context-operator
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters.
verbose: Displays detailed information about Layer 3 interfaces. If you do not specify this keyword, the command displays brief information about Layer 3 interfaces.
If you do not specify any parameters, this command displays brief L2VPN information for all Layer 3 interfaces that are mapped to VSIs.
# Display brief L2VPN information for all Layer 3 interfaces that are mapped to VSIs.
<Sysname> display l2vpn interface
Total number of interfaces: 2, 1 up, 1 down
Interface                Owner                           Link ID   State    Type
GE1/0/1                  vxlan3                          1         Up       VSI
GE1/0/2                  vxlan4                          2         Down     VSI
Layer 3 interface name.
Owner
VSI name.
Link ID
The interface's link ID on the VSI.
Physical state of the interface:
·     Up—The interface is physically up.
·     Down—The interface is physically down.
L2VPN type of the interface. This field displays VSI for the VXLAN feature.
# Display detailed L2VPN information for all Layer 3 interfaces that are mapped to VSIs.
<Sysname> display l2vpn interface verbose
Interface: GE1/0/1
    Owner         : vsi1
    Link ID       : 0
    State         : Up
    Type          : VSI
Interface: GE1/0/2
    Owner         : vsi2
    Link ID       : 0
    State         : Down
    Type          : VSI
Owner
VSI name.
Link ID
display l2vpn service-instance
display l2vpn mac-address
Use display l2vpn mac-address to display MAC address entries for VSIs.
display l2vpn mac-address [ vsi vsi-name ] [ dynamic ] [ count ]
context-admin
context-operator
vsi vsi-name: Specifies a VSI name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays MAC address entries for all VSIs.
dynamic: Specifies dynamic MAC address entries learned in the data plane. If you do not specify this keyword, the command displays all MAC address entries, including:
·     Dynamic remote- and local-MAC entries.
VXLAN does not support static local-MAC entries.
count: Displays the number of MAC address entries. If you do not specify this keyword, the command displays detailed information about MAC address entries.
# Display MAC address entries for all VSIs.
<Sysname> display l2vpn mac-address
MAC Address      State    VSI Name                        Link ID/Name  Aging
0000-0000-000c   Dynamic  vpn1                            Tunnel60      Aging
0000-0000-000d   Dynamic  vpn1                            Tunnel99      Aging
--- 3 mac address(es) found  ---
# Display the total number of MAC address entries in all VSIs.
<Sysname> display l2vpn mac-address count
Entry state:
Dynamic—Local- or remote-MAC entry dynamically learned in the data plane.
Link ID/Name
For a local MAC address, this field displays the AC's link ID on the VSI.
For a remote MAC address, this field displays the tunnel interface name.
Aging
Entry aging state:
·     Aging.
·     NotAging.
reset l2vpn mac-address
Use display l2vpn service-instance to display information about Ethernet service instances.
context-admin
context-operator
interface interface-type interface-number: Specifies a Layer 2 Ethernet interface or Layer 2 aggregate interface by its interface type and number. If you do not specify an interface, this command displays Ethernet service instance information for all Layer 2 Ethernet interfaces and Layer 2 aggregate interfaces.
service-instance instance-id: Specifies an Ethernet service instance by its ID in the range of 1 to 4096. If you do not specify an Ethernet service instance, this command displays information about all Ethernet service instances on the specified Layer 2 Ethernet interface or Layer 2 aggregate interface.
verbose: Displays detailed information about Ethernet service instances. If you do not specify this keyword, the command displays brief information about Ethernet service instances.
# Display brief information about all Ethernet service instances.
<Sysname> display l2vpn service-instance
Total number of service-instances: 4, 4 up, 0 down
Total number of ACs: 2, 2 up, 0 down
Interface                SrvID Owner                           LinkID State Type
GE1/0/1                  3     vsi12                           1      Up    VSI
GE1/0/1                  4     vsi13                           1      Up    VSI
Total number of ACs
Total number of attachment circuits (ACs) and the number of ACs in each state (up or down).
Name of a Layer 2 Ethernet interface or Layer 2 aggregate interface.
SrvID
Ethernet service instance ID.
Owner
VSI name. This field is empty if an Ethernet service instance is not mapped to any VSI.
LinkID
Ethernet service instance's link ID on the VSI.
Ethernet service instance state:
·     Up.
·     Down.
L2VPN type of the Ethernet service instance:
·     VSI.
·     VPWS.
# Display detailed information about all Ethernet service instances on GigabitEthernet 1/0/1.
<Sysname> display l2vpn service-instance interface gigabitethernet 1/0/1 verbose
Interface: GE1/0/1
  Service Instance: 1
    Encapsulation : s-vid 16
    VSI Name      : vsi10
    Link ID       : 1
    State         : Up
Table 5 Command output
Service Instance
Encapsulation
Frame match criterion of the Ethernet service instance. If the Ethernet service instance does not contain a match criterion, the command does not display this field.
Link ID
·     Up.
·     Down.
service-instance
display l2vpn vsi
Use display l2vpn vsi to display information about VSIs.
display l2vpn vsi [ name vsi-name ] [ verbose ]
context-admin
context-operator
name vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays information about all VSIs.
verbose: Displays detailed information about VSIs. If you do not specify this keyword, the command displays brief information about VSIs.
# Display brief information about all VSIs.
<Sysname> display l2vpn vsi
Total number of VSIs: 1, 1 up, 0 down, 0 admin down
VSI Name                        VSI Index       MTU    State
vpna                            0               1500   Up
Table 6 Command output
MTU
MTU on the VSI.
VSI state:
·     Up—The VSI is up.
·     Down—The VSI is down.
·     Admin down—The VSI has been manually shut down by using the shutdown command.
# Display detailed information about all VSIs.
<Sysname> display l2vpn vsi verbose
VSI Name: vpna
  VSI Index               : 0
  VSI State               : Up
  Bandwidth               : -
  Broadcast Restrain      : -
  Multicast Restrain      : -
  Unknown Unicast Restrain: -
  MAC Table Limit         : -
  MAC Learning rate       : -
  Drop Unknown            : -
  PW Redundancy           : Slave
  VXLAN ID                : 10
  Tunnels:
    Tunnel Name          Link ID    State  Type      Flood Proxy  Split horizon
    Tunnel1              0x5000001  Up     Manual    Disabled     Enabled
    Tunnel2              0x5000002  Up     Manual    Disabled     Enabled
  ACs:
    AC                               Link ID    State
    GE1/0/1                          0          Up
Table 7 Command output
VSI Description
Description of the VSI. If the VSI does not have a description, the command does not display this field.
VSI State
VSI state:
·     Up—The VSI is up.
·     Administratively down—The VSI has been manually shut down by using the shutdown command.
MTU
MTU on the VSI.
Bandwidth
Maximum bandwidth (in kbps) for known unicast traffic on the VSI.
Broadcast Restrain
Broadcast restraint bandwidth (in kbps).
Multicast Restrain
Multicast restraint bandwidth (in kbps).
Unknown unicast restraint bandwidth (in kbps).
MAC Learning
State of the MAC learning feature.
MAC Table Limit
Maximum number of MAC address entries on the VSI.
MAC Learning Rate
MAC address entry learning rate of the VSI.
Drop Unknown
Action on source MAC-unknown frames received after the maximum number of MAC entries is reached.
PW Redundancy
PW redundancy mode:
·     Slave—Master/slave mode and the local PE operates as the slave node.
·     Master—Master/slave mode and the local PE operates as the master node.
This field is not supported by a VXLAN network.
Tunnel state:
·     Up—The tunnel is operating correctly.
·     Blocked—The tunnel is a backup tunnel. Its tunnel interface is up, but the tunnel is blocked because the primary tunnel is operating correctly. ‌
·     Defect—The tunnel interface is up, but BFD cannot detect the remote VTEP. This state is not supported in the current software version.
·     Down—The tunnel interface is down.
Tunnel assignment method:
Manual—The tunnel was manually assigned to the VXLAN.
Flood Proxy
Flood proxy state:
·     Enabled—Flood proxy is enabled. The VTEP sends broadcast, multicast, and unknown unicast traffic to a flood proxy server through the tunnel. The flood proxy server replicates and forwards flood traffic to remote VTEPs.
·     Disabled—Flood proxy is disabled.
Split horizon
State of split horizon:
·     Enabled—Split horizon is enabled on the VXLAN tunnel. The VXLAN tunnel does not forward the traffic that is received on other VXLAN tunnels.
·     Disabled—Split horizon is disabled on the VXLAN tunnel. The VXLAN tunnel forwards the traffic that is received on other VXLAN tunnels.
ACs
ACs that are bound to the VSI.
Link ID
AC state:
·     Up.
·     Down.
display vxlan tunnel
Use display vxlan tunnel to display VXLAN tunnel information for VXLANs.
display vxlan tunnel [ vxlan-id vxlan-id [ tunnel tunnel-number ] ]
context-admin
context-operator
vxlan-id: Specifies a VXLAN ID in the range of 0 to 16777215. If you do not specify a VXLAN, this command displays VXLAN tunnel information for all VXLANs.
tunnel tunnel-number: Specifies a VXLAN tunnel. The tunnel-number argument represents the tunnel interface number. The value range for the tunnel-number argument is 0 to 65534. If you do not specify a VXLAN tunnel, this command displays information about all VXLAN tunnels associated with the specified VXLAN.
# Display VXLAN tunnel information for all VXLANs.
<Sysname> display vxlan tunnel
Total number of VXLANs: 1
VXLAN ID: 10, VSI name: vpna, Total tunnels: 3 (3 up, 0 down, 0 defect, 0 blocked)
Tunnel name          Link ID    State  Type         Flood proxy  Split horizon
# Display VXLAN tunnel information for VXLAN 10.
<Sysname> display vxlan tunnel vxlan-id 10
# Display information about VXLAN tunnel 0 for VXLAN 10.
<Sysname> display vxlan tunnel vxlan-id 10 tunnel 0
Interface: Tunnel0
  Link ID       : 0x5000000
  State         : Up
  Type          : Manual
  Flood Proxy   : Disabled
  Split horizon : Enabled
Table 8 Command output
Link ID
Tunnel's link ID in the VXLAN.
Tunnel state:
Flood proxy
Flood proxy state:
Split horizon
tunnel
vxlan
encapsulation
Use encapsulation to configure a frame match criterion for an Ethernet service instance.
Use undo encapsulation to restore the default.
encapsulation s-vid vlan-id-list [ only-tagged ]
encapsulation { default | tagged | untagged }
undo encapsulation
An Ethernet service instance does not contain a frame match criterion.
Ethernet service instance view
context-admin
s-vid: Matches frames that are tagged with the specified outer 802.1Q VLAN IDs.
vlan-id: Specifies an 802.1Q VLAN ID in the range of 1 to 4094.
vlan-id-list: Specifies a space-separated list of up to eight VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the format of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094.
only-tagged: Matches tagged frames. If the outer 802.1Q VLAN is not the PVID, the matching result does not differ, whether or not you specify the only-tagged keyword. If the outer 802.1Q VLAN is the PVID, the matching result depends on whether or not the only-tagged keyword is specified.
·     To match only PVID-tagged frames, specify the only-tagged keyword.
·     To match both untagged frames and PVID-tagged frames, do not specify the only-tagged keyword.
default: Matches frames that do not match any other Ethernet service instance on the interface. On an interface, you can configure this criterion only in one Ethernet service instance. The Ethernet service instance matches any frames if it is the only instance on the interface.
tagged: Matches any frames that have an 802.1Q VLAN tag.
untagged: Matches any frames that do not have an 802.1Q VLAN tag.
An Ethernet service instance can contain only one match criterion. To change the match criterion, first execute the undo encapsulation command to remove the original criterion. When you remove the match criterion in an Ethernet service instance, the mapping between the service instance and the VSI is removed automatically.
# Configure Ethernet service instance 1 on GigabitEthernet 1/0/1 to match frames that have an outer 802.1Q VLAN ID of 111.
[Sysname-GigabitEthernet1/0/1] service-instance 1
[Sysname-GigabitEthernet1/0/1-srv1] encapsulation s-vid 111
l2vpn enable
Use l2vpn enable to enable L2VPN.
Use undo l2vpn enable to disable L2VPN.
l2vpn enable
undo l2vpn enable
L2VPN is disabled.
context-admin
You must enable L2VPN before you can configure L2VPN settings.
# Enable L2VPN.
[Sysname] l2vpn enable
mtu
Use mtu to set the MTU for a VSI.
mtu size
undo mtu
The default MTU of a VSI is 1500 bytes.
VSI view
context-admin
size: Specifies an MTU value. The value range for this argument is 300 to 65535.
The MTU set by using this command limits the maximum length of the packets that a VSI receives from ACs and forwards through VXLAN tunnels. The MTU does not limit the maximum length of other packets in the VXLAN VSI.
Fragmentation is disabled for a VSI that uses the default MTU. If you set a MTU for a VSI, the packets longer than the MTU are fragmented.
# Set the MTU to 1400 bytes for VSI vxlan1.
[Sysname] vsi vxlan1
[Sysname-vsi-vxlan1] mtu 1400
display l2vpn vsi
Use reset l2vpn mac-address to clear dynamic MAC address entries on VSIs.
reset l2vpn mac-address [ vsi vsi-name ]
context-admin
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears all dynamic MAC address entries on all VSIs.
Use this command when the number of dynamic MAC address entries reaches the limit or the device learns incorrect MAC addresses.
# Clear the dynamic MAC address entries on VSI vpn1.
<Sysname> reset l2vpn mac-address vsi vpn1
display l2vpn mac-address vsi
service-instance
Use service-instance to create an Ethernet service instance and enter its view, or enter the view of an existing Ethernet service instance.
Use undo service-instance to delete an Ethernet service instance.
undo service-instance instance-id
No Ethernet service instances exist.
context-admin
instance-id: Specifies an Ethernet service instance ID in the range of 1 to 4096.
# On Layer 2 Ethernet interface GigabitEthernet 1/0/1, create Ethernet service instance 1 and enter Ethernet service instance view.
shutdown
Use shutdown to shut down a VSI.
Use undo shutdown to bring up a VSI.
shutdown
VSIs are not manually shut down.
VSI view
context-admin
Use this command to temporarily disable a VSI to provide Layer 2 switching services. The shutdown action does not change settings on the VSI. You can continue to configure the VSI. After you bring up the VSI again, the VSI provides services based on the latest settings.
# Shut down VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] shutdown
display l2vpn vsi
tunnel
Use tunnel to assign a VXLAN tunnel to a VXLAN.
Use undo tunnel to remove a VXLAN tunnel from a VXLAN.
tunnel tunnel-number [ flooding-proxy ]
undo tunnel tunnel-number
A VXLAN does not contain VXLAN tunnels.
VXLAN view
context-admin
tunnel-number: Specifies a tunnel interface number. The value range for this argument is 0 to 1023. The tunnel must be a VXLAN tunnel.
flooding-proxy: Enables flood proxy on the tunnel for the VTEP to send flood traffic to the flood proxy server. The flood proxy server replicates and forwards flood traffic to remote VTEPs. If you do not specify this keyword, flood proxy is disabled on the tunnel.
This command assigns a VXLAN tunnel to a VXLAN to provide Layer 2 connectivity for the VXLAN between two sites. In unicast mode, the system floods unknown unicast, multicast, and broadcast traffic to each tunnel in the VXLAN.
You can assign multiple VXLAN tunnels to a VXLAN, and configure a VXLAN tunnel to trunk multiple VXLANs.
On a VSI, you can enable flood proxy on multiple VXLAN tunnels. The first tunnel that is enabled with flood proxy works as the primary proxy tunnel to forward broadcast, multicast, and unknown unicast traffic. Other proxy tunnels are backups that do not forward traffic when the primary proxy tunnel is operating correctly.
To modify the flood proxy setting on a VXLAN tunnel, you must first use the undo tunnel command to remove the tunnel.
# Assign VXLAN tunnels 1 and 2 to VXLAN 10000.
[Sysname] vsi vpna
[Sysname-vsi-vpna] vxlan 10000
[Sysname-vsi-vpna-vxlan-10000] tunnel 1
[Sysname-vsi-vpna-vxlan-10000] tunnel 2
tunnel global source-address
Use tunnel global source-address to specify a global source address for VXLAN tunnels.
Use undo tunnel global source-address to restore the default.
tunnel global source-address ip-address
No global source address is specified for VXLAN tunnels.
context-admin
ip-address: Specifies an IP address.
A VXLAN tunnel uses the global source address if you do not specify a source interface or source address for the tunnel.
The global source address takes effect only on VXLAN tunnels.
# Specify 1.1.1.1 as the global source address for VXLAN tunnels.
[Sysname] tunnel global source-address 1.1.1.1
vsi
Use vsi to create a VSI and enter its view, or enter the view of an existing VSI.
Use undo vsi to delete a VSI.
vsi vsi-name
undo vsi vsi-name
No VSIs exist.
context-admin
A VSI acts as a virtual switch to provide Layer 2 switching services for a VXLAN on a VTEP. A VSI has all functions of a physical Ethernet switch, including source MAC address learning, MAC address aging, and flooding.
A VSI can provide services only for one VXLAN.
# Create VSI vxlan10 and enter VSI view.
[Sysname] vsi vxlan10
[Sysname-vsi-vxlan10]
display l2vpn vsi
vxlan
Use vxlan to create a VXLAN and enter its view, or enter the view of an existing VXLAN.
Use undo vxlan to restore the default.
vxlan vxlan-id
undo vxlan
No VXLANs exist.
VSI view
context-admin
You can create only one VXLAN for a VSI. The VXLAN ID for each VSI must be unique.
# Create VXLAN 10000 for VSI vpna and enter VXLAN view.
[Sysname] vsi vpna
vsi
vxlan fast-forwarding enable
Use vxlan fast-forwarding enable to enable VXLAN fast forwarding.
Use undo vxlan fast-forwarding enable to disable VXLAN fast forwarding.
VXLAN fast forwarding is disabled.
context-admin
VXLAN fast forwarding enables the device to bypass QoS and security services when the device forwards data traffic over VXLAN tunnels based on the software. As a best practice, enable this feature to improve forwarding speed only when QoS and security services are not configured on the following interfaces:
·     VSI interfaces.
·     Traffic outgoing interfaces for VXLAN tunnels.
When VXLAN fast forwarding is enabled, a VXLAN tunnel cannot use ECMP routes to load share traffic. Instead, it selects one route from the ECMP routes to forward VXLAN packets.
# Enable VXLAN fast forwarding.
<Sysname> system
[Sysname] vxlan fast-forwarding enable
vxlan invalid-udp-checksum discard
Use vxlan invalid-udp-checksum discard to enable the device to drop the VXLAN packets that fail UDP checksum check.
Use undo vxlan invalid-udp-checksum discard to restore the default.
The device does not check the UDP checksum of VXLAN packets.
context-admin
This command enables the device to check the UDP checksum of VXLAN packets.
The device always sets the UDP checksum of VXLAN packets to 0. For compatibility with third-party devices, a VXLAN packet can pass the check if its UDP checksum is 0 or correct. If its UDP checksum is incorrect, the VXLAN packet fails the check and is dropped.
# Enable the device to drop the VXLAN packets that fail UDP checksum check.
[Sysname] vxlan invalid-udp-checksum discard
vxlan udp-port
Use vxlan udp-port to set the destination UDP port number for VXLAN packets.
Use undo vxlan udp-port to restore the default.
vxlan udp-port port-number
undo vxlan udp-port
The destination UDP port number is 4789 for VXLAN packets.
context-admin
port-number: Specifies a UDP port number in the range of 1 to 65535. As a best practice, specify a port number in the range of 1024 to 65535 to avoid conflict with well-known ports.
You must configure the same destination UDP port number on all VTEPs in a VXLAN.
# Set the destination UDP port number to 6666 for VXLAN packets.
[Sysname] vxlan udp-port 6666
xconnect vsi
Use xconnect vsi to map an AC to a VSI.
Use undo xconnect vsi to restore the default.
xconnect vsi vsi-name [ access-mode { ethernet | vlan } ] [ track track-entry-number&<1-3> ]
undo xconnect vsi
An AC is not mapped to any VSI.
Interface view
context-admin
vsi-name: Specifies the VSI name, a case-sensitive string of 1 to 31 characters.
access-mode: Specifies an access mode. If the AC is an Ethernet service instance or Layer 3 subinterface, you can specify this keyword. The default access mode is VLAN. If the AC is a Layer 3 interface, you cannot specify this keyword.
ethernet: Specifies the Ethernet access mode.
vlan: Specifies the VLAN access mode.
track track-entry-number&<1-3>: Specifies a space-separated list of up to three track entry numbers in the range of 1 to 1024. The AC is up only if a minimum of one associated track entry is in positive state.
For traffic that matches a Layer 3 interface, the system uses the VSI's MAC address table to make a forwarding decision.
For traffic that matches an Ethernet service instance on an interface, the system uses the VSI's MAC address table to make a forwarding decision.
To execute this command for an Ethernet service instance, you must first use the encapsulation command to add a traffic match criterion to the service instance.
The access mode determines how a VTEP processes the 802.1Q VLAN tags in the inner Ethernet frames assigned to the VSI.
·     VLAN access mode—Ethernet frames received from or sent to the local site must contain 802.1Q VLAN tags.
¡     For an Ethernet frame received from the local site, the VTEP removes all its 802.1Q VLAN tags before forwarding the frame.
¡     For an Ethernet frame destined for the local site, the VTEP adds 802.1Q VLAN tags to the frame before forwarding the frame.
In VLAN access mode, VXLAN packets sent between VXLAN sites do not contain 802.1Q VLAN tags. VXLAN can provide Layer 2 connectivity for different 802.1Q VLANs between sites. You can use different 802.1Q VLANs to provide the same service in different sites.
·     Ethernet access mode—The VTEP does not process the 802.1Q VLAN tags of Ethernet frames received from or sent to the local site.
¡     For an Ethernet frame received from the local site, the VTEP forwards the frame with the 802.1Q VLAN tags intact.
¡     For an Ethernet frame destined for the local site, the VTEP forwards the frame without adding 802.1Q VLAN tags.
In Ethernet access mode, VXLAN packets sent between VXLAN sites contain 802.1Q VLAN tags. VXLAN cannot provide Layer 2 connectivity for different 802.1Q VLANs between sites. You must use the same 802.1Q VLAN to provide the same service between sites.
After you modify the access mode on a Layer 3 subinterface AC, local VMs that access the VXLAN network through the subinterface cannot communicate with remote VMs. To resolve this issue, you must clear the ARP entries on the local VMs or configure them to periodically send gratuitous ARP packets.
# Map GigabitEthernet 1/0/1 to VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] quit
[Sysname-GigabitEthernet1/0/1] xconnect vsi vpn1
encapsulation
vsi
