17-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath M9000 Command Reference(V7)(R9153P39 R9001P39)-6W40017-Network Management and Monitoring Command Reference
17-BFD commands
17-BFD commands 172.48 KB
BFD commands
Basic BFD commands
bfd authentication-mode
Use bfd authentication-mode to configure the BFD authentication mode for single-hop BFD control packets.
Use undo bfd authentication-mode to restore the default.
bfd authentication-mode { hmac-md5 | hmac-mmd5 | hmac-msha1 | hmac-sha1 | m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher | plain } string
Single-hop BFD control packets are not authenticated.
Interface view
BFD template view
Static BFD session view
context-admin
hmac-md5: Specifies the HMAC MD5 algorithm.
hmac-mmd5: Specifies the HMAC Meticulous MD5 algorithm.
hmac-msha1: Specifies the HMAC Meticulous SHA1 algorithm.
hmac-sha1: Specifies the HMAC SHA1 algorithm.
m-md5: Specifies the Meticulous MD5 algorithm.
m-sha1: Specifies the Meticulous SHA1 algorithm.
md5: Specifies the MD5 algorithm.
sha1: Specifies the SHA1 algorithm.
simple: Specifies the simple authentication mode.
key-id: Sets the authentication key ID in the range of 1 to 255.
plain: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. Its plaintext form is a case-sensitive string of 1 to 16 characters. Its encrypted form is a case-sensitive string of 33 to 53 characters.
Use this command to enhance BFD session security.
If this command is executed in static BFD session view, it takes effect only on static BFD sessions used for single-hop detection.
BFD version 0 does not support this command. The configuration does not take effect.
# Configure GigabitEthernet 1/0/1 to perform simple authentication for single-hop BFD control packets, setting the authentication key ID to 1 and plaintext key to 123456.
[Sysname-GigabitEthernet1/0/1] bfd authentication-mode simple 1 plain 123456
bfd static
bfd demand enable
Use bfd demand enable to enable the Demand BFD session mode.
Use undo bfd demand enable to restore the default.
bfd demand enable
The BFD session is in Asynchronous mode.
Interface view
context-admin
In Demand mode, the device periodically sends BFD control packets. If the peer end is operating in Asynchronous mode (default), the peer end stops sending BFD control packets. If the peer end is operating in Demand mode, both ends stop sending BFD control packets. As a best practice, configure the bfd echo enable command together with this command to detect connectivity by sending Echo packets. If the device does not receive any Echo packets from the peer end, it considers the session down.
In Asynchronous mode, the device periodically sends BFD control packets. The device considers that the session is down if it does not receive any BFD control packets within a specific interval.
# Enable the Demand BFD session mode on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] bfd demand enable
bfd detect-interface source-ip
Use bfd detect-interface source-ip to associate the interface state with BFD.
Use undo bfd detect-interface to remove the association between the interface state and BFD.
bfd detect-interface source-ip ip-address [ template template-name ]
The interface state is not associated with BFD. BFD does not set the link layer protocol of the interface to DOWN(BFD) state when detecting a failure.
Interface view
context-admin
ip-address: Specifies the source IP address for BFD control packets.
template template-name: Specifies a template by its name, a case-sensitive string of 1 to 63 characters. If you specify a nonexistent template or do not specify a template, the BFD session uses the BFD parameters configured in interface view. If you first specify a nonexistent template and then create the template, the BFD session uses the parameters configured in the template.
By creating a BFD session for single-hop detection through exchange of BFD control packets, this feature implements fast link detection. When BFD detects a link fault, it sets the link layer protocol state to DOWN(BFD). This behavior helps applications relying on the link layer protocol state achieve fast convergence.
The source IP address of control packets is specified manually, and the destination IP address is fixed at 224.0.0.184. As a best practice, specify the IP address of the interface as the source IP address. If the interface does not have an IP address, specify a unicast IP address other than 0.0.0.0 as the source IP address.
You can associate the state of the following interfaces with BFD:
·     Layer 3 Ethernet interfaces and subinterfaces. For BFD detection to take effect, do not execute this command on both a Layer 3 Ethernet interface and its subinterface.
·     Layer 3 aggregate interfaces, Layer 3 aggregate subinterfaces, and member ports (Layer 3 Ethernet interfaces only) in a Layer 3 aggregation group.
To configure this command on the preceding interfaces at the same time, you must manually specify the local and remote discriminators on each of the interfaces. As a best practice, do not configure this command on these interfaces at the same time.
·     VLAN interfaces.
To modify your configuration, remove it by using the undo form of the command and then execute the bfd detect-interface source-ip command again.
The echo function does not take effect on BFD sessions associated with interface states.
If you specify an existing template for this command, the bfd demand enable command cannot take effect.
# Associate GigabitEthernet 1/0/1 with BFD to detect the interface state, and specify the source IP address as 20.1.1.1.
[Sysname-GigabitEthernet1/0/1] bfd detect-interface source-ip 20.1.1.1
bfd demand enable
bfd echo enable
bfd template
bfd detect-interface first-fail-timer
Use bfd detect-interface first-fail-timer to configure the timer that delays reporting the first BFD session establishment failure to the data link layer.
Use undo bfd detect-interface first-fail-timer to restore the default.
bfd detect-interface first-fail-timer seconds
The first BFD session establishment failure is not reported to the data link layer.
Interface view
context-admin
seconds: Specifies the timeout time that reports the first BFD session establishment failure to the data link layer. The value range for this argument is 1 to 10000 seconds.
If the BFD session fails to be established when the timer expires, BFD reports the failure to the data link layer and sets the data link layer state of the interface to DOWN(BFD). This behavior rapidly identifies the interfaces for which BFD sessions fail to be established. In this case, the BFD session state is displayed as Down in the display bfd session command output. The line protocol state of the interface is displayed as DOWN(BFD) in the display interface command output.
If you exeucte the bfd detect-interface source-ip command on the local end, the BFD session for detecting the local interface state fails to be established when the following conditions exist:
·     The bfd detect-interface source-ip command is not executed on the remote end.
·     The local and remote ends have mismatching BFD authentication settings.
# Configure the timer that delays reporting the first BFD session establishment failure as 10 seconds for GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] bfd detect-interface first-fail-timer 10
display interface (Interface Command Reference)
bfd detect-interface special-processing
Use bfd detect-interface special-processing to enable special processing for BFD sessions.
Use undo bfd detect-interface special-processing to disable special processing for BFD sessions.
bfd detect-interface special-processing [ admin-down | authentication-change | session-up ] *
undo bfd detect-interface special-processing [ admin-down | authentication-change | session-up ] *
All types of special processing for BFD sessions are disabled.
Interface view
context-admin
admin-down: Notifies a session down event to the data link layer upon receipt of a BFD packet with the State field as AdminDown. This keyword helps rapidly discover interfaces on which BFD sessions are manually shut down. If you do not specify this keyword, the device sets the BFD session state to Down, but does not notify the session down event to the data link layer.
authentication-change: Immediately sets the session to down state upon a local authentication information change. This keyword helps rapidly discover interfaces with authentication information changes. If you do not specify this keyword, the device sets the session to down state if authentication information inconsistency still persists after a period of time.
session-up: Ignores authentication information inconsistency when the local session is up. If a large number of BFD sessions exist, examining authentication information consistency affects device performance. If you do not specify this keyword, the device examines authentication information in incoming BFD packets when the local session state is up. If the authentication information does not match on the two ends, the BFD session is declared down.
If you do not specify any parameters, this command enables or disables all types of special processing.
# Enable all types of special processing for BFD sessions on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] bfd detect-interface special-processing admin-down authentication-change session-up
bfd detect-multiplier
Use bfd detect-multiplier to set the single-hop detection time multiplier for control packet mode and the detection time multiplier for echo packet mode.
Use undo bfd detect-multiplier to restore the default.
bfd detect-multiplier value
The single-hop detection time multiplier for control packet mode and the detection time multiplier for echo packet mode are both 5.
Interface view
BFD template view
context-admin
value: Specifies a detection time multiplier. The value range for this argument is 3 to 50.
The detection time multiplier determines the maximum number of concurrent BFD packets (including control packets and echo packets) that can be discarded.
Table 1 Detection interval calculation method
Mode
Detection interval
Echo packet mode
Detection time multiplier of the sender × actual packet sending interval of the sender
Control packet mode BFD session in asynchronous mode
Detection time multiplier of the receiver × actual packet sending interval of the receiver
Control packet mode BFD session in demand mode
# Set the single-hop detection time multiplier for control packet mode and the detection time multiplier for echo packet mode to 6 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] bfd detect-multiplier 6
bfd echo enable
Use bfd echo enable to enable the echo function.
Use undo bfd echo enable to disable the echo function.
undo bfd echo [ receive | send ] enable
The echo function is disabled.
Interface view
context-admin
receive: Specifies the echo packet receiving capability.
send: Specifies the echo packet sending capability.
If you enable the echo function for a BFD session in which control packets are sent and the session comes up, BFD performs the following operations:
·     Periodically sends echo packets to detect link connectivity.
·     Decreases the control packet receiving rate at the same time.
To enable only the echo packet receiving capability, use the bfd echo receive enable command.
To enable only the echo packet sending capability, use the bfd echo send enable command.
If you do not specify the receive or send keyword, the command enables both the echo packet receiving and sending capabilities.
# Enable the echo function on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] bfd echo enable
bfd echo-source-ip
Use bfd echo-source-ip to configure the source IP address of BFD echo packets.
Use undo bfd echo-source-ip to remove the configured source IP address of BFD echo packets.
bfd echo-source-ip ip-address
No source IP address is configured for BFD echo packets.
context-admin
ip-address: Specifies the source IP address of BFD echo packets. The source IP address must be a valid unicast IPv4 address in dotted decimal notation.
The source IP address cannot be on the same network segment as any local interface's IP address. Otherwise, a large number of ICMP redirect packets might be sent from the peer, resulting in link congestion.
# Configure the source IP address of BFD echo packets as 8.8.8.8.
[Sysname] bfd echo-source-ip 8.8.8.8
bfd echo-source-ipv6
Use bfd echo-source-ipv6 to configure the source IPv6 address of BFD echo packets.
Use undo bfd echo-source-ipv6 to remove the configured source IPv6 address of BFD echo packets.
No source IPv6 address is configured for BFD echo packets.
context-admin
ipv6-address: Specifies the source IPv6 address for BFD echo packets.
The source IPv6 address of echo packets can only be a global unicast address.
The source IPv6 address cannot be on the same network segment as any local interface's IP address. Otherwise, a large number of ICMP redirect packets might be sent from the peer, resulting in link congestion.
# Configure the source IPv6 address of BFD echo packets as 80::2.
[Sysname] bfd echo-source-ipv6 80::2
bfd init-fail timer
Use bfd init-fail-timer to set the delay timer for BFD to notify upper-layer protocols of session establishment failures.
Use undo bfd init-fail-timer to restore the default.
bfd init-fail-timer seconds
BFD does not notify upper-layer protocols of session establishment failures.
context-admin
seconds: Specifies the delay time in the range of 5 to 600 seconds. After the delay time, BFD notifies the upper-layer protocol of session establishment failures.
CAUTION
CAUTION:
For session establishment failures caused by configuration mismatches at the two ends, this command can cause the upper-layer protocol to act incorrectly. Therefore, use this command with caution. BFD status mismatch and BFD authentication configuration mismatch are examples of configuration mismatches.
This command takes effect only for control packet mode.
In some cases, for an upper-layer protocol to act correctly, BFD must notify the upper-layer protocol of session establishment failures.
# Set the delay timer to 10 seconds for BFD to notify upper-layer protocols of session establishment failures.
[Sysname] bfd init-fail-timer 10
bfd min-echo-receive-interval
Use bfd min-echo-receive-interval to set the minimum interval for receiving BFD echo packets.
Use undo bfd min-echo-receive-interval to restore the default.
The minimum interval for receiving BFD echo packets is 400 milliseconds.
Interface view
BFD template view
context-admin
interval: Specifies the minimum interval for receiving BFD echo packets, in milliseconds. The value takes 0 or is in the range of 100 to 1000.
This command sets the BFD echo packet receiving interval, which is the actual BFD echo packet sending interval.
The local end stops sending echo packets after autonegotiation with the remote end if the following conditions are met:
·     The echo function is enabled on the local end.
·     The minimum interval for receiving BFD echo packets is set to 0 milliseconds on the remote end.
# Set the minimum interval for receiving BFD echo packets to 500 milliseconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] bfd min-echo-receive-interval 500
bfd min-receive-interval
Use bfd min-receive-interval to set the minimum interval for receiving single-hop BFD control packets.
Use undo bfd min-receive-interval to restore the default.
The minimum interval for receiving single-hop BFD control packets is 400 milliseconds.
Interface view
BFD template view
context-admin
interval: Specifies the minimum interval for receiving single-hop BFD control packets, in milliseconds. The value range for this argument is 100 to 1000.
Use this command to prevent the control packet sending rate of the peer end from exceeding the control packet receiving rate of the local end.
The actual control packet sending interval of the peer end takes the greater value between the following values:
·     Minimum interval for transmitting BFD control packets on the peer end.
·     Minimum interval for receiving BFD control packets on the local end.
# Set the minimum interval for receiving single-hop BFD control packets to 500 milliseconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] bfd min-receive-interval 500
bfd min-transmit-interval
Use bfd min-transmit-interval to set the minimum interval for transmitting single-hop BFD control packets.
Use undo bfd min-transmit-interval to restore the default.
The minimum interval for transmitting single-hop BFD control packets is 400 milliseconds.
Interface view
BFD template view
context-admin
interval: Specifies the minimum interval for transmitting single-hop BFD control packets, in milliseconds. The value range for this argument is 100 to 1000.
Use this command to prevent the BFD packet sending rate from exceeding the device capability.
The actual BFD control packet transmitting interval on the local end is the greater value between the following values:
·     Minimum interval for transmitting BFD control packets on the local end.
·     Minimum interval for receiving BFD control packets on the peer end.
# Set the minimum interval for transmitting single-hop BFD control packets to 500 milliseconds on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] bfd min-transmit-interval 500
bfd multi-hop authentication-mode
Use bfd multi-hop authentication-mode to configure the authentication mode for multihop BFD control packets.
Use undo bfd multi-hop authentication-mode to restore the default.
bfd multi-hop authentication-mode { hmac-md5 | hmac-mmd5 | hmac-msha1 | hmac-sha1 | m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher | plain } string
No authentication is performed.
context-admin
# Configure the simple authentication mode for multihop BFD control packets, setting the authentication key ID to 1 and key to 123456.
[Sysname] bfd multi-hop authentication-mode simple 1 plain 123456
bfd multi-hop destination-port
Use bfd multi-hop destination-port to configure the destination port number for multihop BFD control packets.
Use undo bfd multi-hop destination-port to restore the default.
The destination port number for multihop BFD control packets is 4784.
context-admin
port-number: Specifies the destination port number of multihop BFD control packets, 3784 or 4784.
# Specify the destination port number for multihop BFD control packets as 3784.
[Sysname] bfd multi-hop destination-port 3784
bfd multi-hop detect-multiplier
Use bfd multi-hop detect-multiplier to set the multihop detection time multiplier for control packet mode.
Use undo bfd multi-hop detect-multiplier to restore the default.
The multihop detection time multiplier for control packet mode is 5.
context-admin
value: Specifies the multihop detection time multiplier in the range of 3 to 50.
The detection time multiplier determines the maximum number of concurrent BFD control packets that can be discarded.
Table 2 Detection interval calculation method
Mode
Detection interval
# Set the multihop detection time multiplier to 6.
[Sysname] bfd multi-hop detect-multiplier 6
bfd multi-hop min-receive-interval
Use bfd multi-hop min-receive-interval to set the minimum interval for receiving multihop BFD control packets.
Use undo bfd multi-hop min-receive-interval to restore the default.
The minimum interval for receiving multihop BFD control packets is 400 milliseconds.
context-admin
interval: Specifies the minimum interval for receiving multihop BFD control packets, in milliseconds. The value range for this argument is 100 to 1000.
Use this command to prevent the packet sending rate of the peer end from exceeding the packet receiving capability (minimum control packet receiving interval) of the local end. If the receiving capability is exceeded, the peer end dynamically adjusts the BFD control packet sending interval to the minimum control packet receiving interval of the local end.
# Set the minimum interval for receiving multihop BFD control packets to 500 milliseconds.
[Sysname] bfd multi-hop min-receive-interval 500
bfd multi-hop min-transmit-interval
Use bfd multi-hop min-transmit-interval to set the minimum interval for transmitting multihop BFD control packets.
Use undo bfd multi-hop min-transmit-interval to restore the default.
The minimum interval for transmitting multihop BFD control packets is 400 milliseconds.
context-admin
interval: Specifies the minimum interval for transmitting multihop BFD control packets, in milliseconds. The value range for this argument is 100 to 1000.
# Set the minimum interval for transmitting multihop BFD control packets to 500 milliseconds.
[Sysname] bfd multi-hop min-transmit-interval 500
bfd session init-mode
Use bfd session init-mode to configure the mode for establishing a BFD session.
Use undo bfd session init-mode to restore the default.
BFD uses the active mode.
context-admin
active: Specifies the active mode. In active mode, BFD actively transmits BFD control packets to the remote device, regardless of whether it receives a BFD control packet from the remote device.
passive: Specifies the passive mode. In passive mode, BFD does not actively transmit a BFD control packet to the remote end; it transmits a BFD control packet only after receiving a BFD control packet from the remote end.
A minimum of one end must operate in active mode for a BFD session to be established.
# Configure the session establishment mode as passive.
[Sysname] bfd session init-mode passive
bfd static
Use bfd static to create a static BFD session and enter its view, or enter the view of an existing static BFD session.
Use undo bfd static to delete a static BFD session and all its settings.
bfd static session-name [ peer-ip ipv4-address [ vpn-instance vpn-instance-name | interface interface-type interface-number ] source-ip ipv4-address discriminator local local-value remote remote-value ]
bfd static session-name [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name | interface interface-type interface-number ] source-ipv6 ipv6-address discriminator local local-value remote remote-value ]
bfd static session-name [ peer-ip default-ip interface interface-type interface-number source-ip ip-address discriminator local discr-value remote discr-value ]
undo bfd static session-name
No static BFD sessions exist.
context-admin
session-name: Specifies a static BFD session name, a case-sensitive string of 1 to 15 characters.
peer-ip ipv4-address: Specifies the peer IPv4 address in dotted decimal notation. It must be a valid unicast IPv4 address.
peer-ipv6 ipv6-address: Specifies the peer IPv6 address.
default-ip: Specifies the peer IPv4 address as 224.0.0.184.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the static BFD session belongs to the public network.
interface interface-type interface-number: Specifies an interface by its type and number. The command performs single-hop detection on the link with the specified interface as the outgoing interface and the specified peer IP address as the next hop.
source-ip ipv4-address: Specifies the source IPv4 address for control packets, in dotted decimal notation. It must be a valid unicast IPv4 address.
source-ipv6 ipv6-address: Specifies the source IPv6 address for control packets.
discriminator: Specifies BFD session discriminators.
local local-value: Specifies the local discriminator in the range of 1 to 32768.
remote remote-value: Specifies the remote discriminator in the range of 1 to 4294967295.
A static BFD session can be used for single-hop detection and multihop detection. By working with Track, a static BFD session can provide fast failure detection. For more information about Track association with BFD, see Track in Network Management and Monitoring Configuration Guide.
The BFD session discriminators must match on the local and peer devices. For example, if you configure bfd static abc peer-ip 20.1.1.1 vpn-instance vpn1 source-ip 20.1.1.2 discriminator local 513 remote 514 on the local device, you must configure bfd static bcd peer-ip 20.1.1.2 vpn-instance vpn1 source-ip 20.1.1.1 discriminator local 514 remote 513 on the peer device.
When creating a static BFD session, you must specify a peer IP address. The system checks only the format of the IP address but not its correctness. If the peer IPv4 or IPv6 address is incorrect, the static BFD session cannot be established.
The bfd static session-name command without any parameters specified can only be used to enter the view of an existing static BFD session.
To modify a static BFD session, delete it and then configure a new static BFD session.
If you do not specify a VPN instance or an interface, the device performs multihop detection in the public network.
To detect network layer connectivity, execute the following commands:
·     bfd static session-name peer-ip ipv4-address interface interface-type interface-number source-ip ipv4-address discriminator local local-value remote remote-value
For the static BFD session to be successfully established, make sure the IPv4 addresses of the local and peer interfaces where the static BFD session resides are used as the source and peer IPv4 addresses, respectivley.
·     bfd static session-name peer-ipv6 ipv6-address interface interface-type interface-number source-ipv6 ipv6-address discriminator local local-value remote remote-value
For the static BFD session to be successfully established, make sure the IPv6 addresses of the local and peer interfaces where the static BFD session resides are used as the source and peer IPv6 addresses, respectivley.
To detect data link layer connectivity, execute the following command:
·     bfd static session-name peer-ip default-ip interface interface-type interface-number source-ip ip-address discriminator local discr-value remote discr-value
If the process-interface-status command is also executed, BFD sets the interface state to DOWN(BFD) when detecting a link failure. Specify the IP address of the interface as the source IP address. If the interface does not have an IP address, specify a unicast IP address other than 0.0.0.0 as the source IP address. An interface can use only one static BFD session to detect data link layer connectivity.
BFD supports detecting data link connectivity for the following interface types:
·     Layer 3 aggregate interfaces, Layer 3 aggregate subinterfaces, and member ports in a Layer 3 aggregation group. For BFD detection to take effect, do not execute this command on any two of the interface types at the same time.
·     VLAN interfaces.
Different static BFD sessions cannot have the same local discriminator.
# Create a static BFD session and enter its view. The static BFD session detects the link with the outgoing interface GigabitEthernet 1/0/1 and the next hop 1.1.1.2. The source IP address for the session is 1.1.1.1, the local discriminator is 1537, and the remote discriminator is 2048.
[Sysname] bfd static aaaa peer-ip 1.1.1.2 interface gigabitethernet 1/0/1 source-ip 1.1.1.1 discriminator local 1537 remote 2048
[Sysname-bfd-static-session-abc]
bfd template
Use bfd template to create a BFD template and enter its view, or enter the view of an existing BFD template.
Use undo bfd template to delete the BFD template.
bfd template template-name
undo bfd template template-name
No BFD templates exist.
context-admin
template-name: Specifies the template name, a case-sensitive string of 1 to 63 characters.
# Create BFD template bfd1 and enter BFD template view.
[Sysname] bfd template bfd1
[Sysname-bfd-template-bfd1]
display bfd session
Use display bfd session to display BFD session information.
display bfd session [ discriminator local local-value | static session-name | verbose ]
display bfd session [ [ dynamic ] [ control | echo ] [ ip ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] [ verbose ] ]
display bfd session [ [ dynamic ] [ control | echo ] [ ipv6 ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] [ verbose ] ]
display bfd session [ [ dynamic ] [ control | echo ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] | [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] ] [ verbose ] ]
display bfd session [ [ static ] [ ip ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] [ verbose ]
display bfd session [ [ static ] [ ipv6 ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] [ verbose ]
context-admin
context-operator
discriminator local local-value: Specifies a BFD session by its local discriminator in the range of 1 to 4294967295.
static session-name: Specifies a static BFD session by its name, a case-sensitive string of 1 to 15 characters.
dynamic: Specifies dynamic BFD sessions.
static: Specifies static BFD sessions.
control: Specifies BFD sessions in control mode.
echo: Specifies BFD sessions in echo mode.
ip: Specifies BFD sessions used to detect IPv4 links.
ipv6: Specifies BFD sessions used to detect IPv6 links.
state: Displays BFD sessions by session state.
down: Specifies BFD sessions in Down state.
admin-down: Specifies BFD sessions in AdminDown state.
init: Specifies BFD sessions in Init state.
up: Specifies BFD sessions in Up state.
discriminator remote remote-value: Specifies a BFD session by its remote discriminator in the range of 1 to 4294967295.
peer-ip ipv4-address: Specifies a BFD session by the peer IPv4 address in dotted decimal notation.
peer-ipv6 ipv6-address: Specifies a BFD session by the peer IPv6 address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays information for the BFD sessions of the public network.
verbose: Displays detailed BFD session information.
If you do not specify the dynamic or static keyword, this command displays all dynamic and static BFD sessions.
# Display brief information about all BFD sessions.
<Sysname> display bfd session
 Total sessions: 7        Up sessions: 7        Init mode: Active
 LD/RD           SourceIP        DestinationIP   State   Holdtime    Interface
 513/513         1.1.1.1         1.1.1.2         Up      2297ms      GE1/0/1
 IPv6 session working in control packet mode:
       Local discr: 513                  Remote discr: 513
         Source IP: FE80::20C:29FF:FED4:7171
    Destination IP: FE80::20C:29FF:FE72:AC4D
     Session state: Up                      Interface: GE1/0/1
         Hold time: 2142ms
 IPv4 static session working in control packet mode:
 1017/7101       2.1.1.1         2.1.1.2         Up      4988ms      GE1/0/1
 IPv6 static session working in control packet mode:
       Local discr: 1226                 Remote discr: 6221
         Source IP: 12::1
    Destination IP: 12::2
         Hold time: 4812ms
Total sessions
Total number of BFD sessions.
Up sessions
Total number of active BFD sessions.
Init mode
BFD operating mode: Active or Passive.
BFD session type and operating mode:
·     IPv4 session working in control packet mode.
·     IPv4 session working in echo mode.
·     IPv6 session working in control packet mode.
·     IPv6 session working in echo mode.
·     IPv4 static session working in control packet mode.
·     IPv6 static session working in control packet mode.
LD/RD
Local discriminator/Remote discriminator of the session.
Source IP
Source IPv4 address of the session.
Destination IP
Destination IPv4 address of the session.
Session state: Down, Init, Adown, or Up.
Holdtime
Length of time before session detection timer expires.
For a BFD session in Down state, this field displays 0ms.
Name of the interface of the session.
Local discr
Local discriminator of the session.
Remote discr
Session state
Session state: Down, Adown, Init, or Up.
Hold time
# Display detailed information about all BFD sessions.
<Sysname> display bfd session verbose
          Local discr: 33793                      Remote discr: 33793
            Source IP: 23.1.1.2                 Destination IP: 23.1.1.3
        Session state: Up
      Min Tx interval: 1000ms               Actual Tx interval: 1000ms
      Min Rx interval: 1000ms                   Detection time: 5000ms
             Rx count: 133                            Tx count: 142
      Connection type: Direct                      Up duration: 00:02:01
            Hold time: 4571ms                        Auth mode: None
       Detection mode: Async                              Slot: 0
             Protocol: OSPF
              Version: 1
            Diag info: No Diagnostic
          Local discr: 33794                      Remote discr: 33794
            Source IP: FE80::5457:A5FF:FE0F:306
       Destination IP: FE80::5457:A1FF:FEB5:206
        Session state: Up
             Rx count: 3262                           Tx count: 3048
      Connection type: Direct                      Up duration: 00:44:26
            Hold time: 4409ms                        Auth mode: None
             Protocol: OSPFv3
              Version: 1
         Session name: abc
          Local discr: 1017                       Remote discr: 7101
            Source IP: 2.1.1.1                  Destination IP: 2.1.1.2
        Session state: Up
             Rx count: 1012                           Tx count: 1064
      Connection type: Direct                      Up duration: 00:14:41
            Hold time: 4438ms                        Auth mode: None
             Protocol: STATIC_IPv4
              Version: 1
         Session name: blue
            Source IP: 12::1
        Session state: Up
             Rx count: 225                            Tx count: 266
      Connection type: Direct                      Up duration: 00:03:13
            Hold time: 4371ms                        Auth mode: None
             Protocol: STATIC_IPv6
              Version: 1
Total sessions
Up sessions
Init mode
Local discr
Local ID of the session.
Remote discr
Remote ID of the session.
Source IP
Source IP address of the session.
Destination IP
Destination IP address of the session.
Session state
Session state: Down, Init, or Up.
Min Tx interval
Minimum transmit interval.
Min Rx interval
Minimum receive interval.
Actual Tx interval
Actual transmit interval.
Detection time
Actual session detection timer.
Rx count
Number of packets received.
Tx count
Number of packets sent.
Connection type
Connection type of the interface: Direct or indirect.
Up duration
Time period for which the session has been up.
Hold time
For a BFD session in down state, this field displays 0ms.
Auth mode
Session authentication mode.
Connect type
Up duration
Detection mode
Detection mode:
·     Async—Asynchronous mode.
·     Demand—Demand mode.
·     Async/Echo—Asynchronous mode with echo function enabled.
·     Demand/Echo—Demand mode with echo function enabled.
Slot
Slot number of the card where the BFD session resides. (In standalone mode.)
Slot number of the card where the BFD session resides, in the form of chassis-number/slot-number. chassis-number represents the member ID of the IRF member device. slot-number represents the slot number of the card. (In IRF mode.)
Protocol
Protocol associated with BFD:
·     OSPF.
·     ISIS_BR_L1—IS-IS with the network type as broadcast and the router type as Level 1.
·     ISIS_BR_L2—IS-IS with the network type as broadcast and the router type as Level 2.
·     ISIS_P2P—IS-IS with the network type as P2P.
·     ISIS6_BR_L1—IPv6 IS-IS with the network type as broadcast and the router type as Level 1.
·     ISIS6_BR_L2—IPv6 IS-IS with the network type as broadcast and the router type as Level 2.
·     ISIS6_P2P—IPv6 IS-IS with the network type as P2P.
·     BGP.
·     STATIC4—IPv4 static routing.
·     TRACK—Track.
·     RIP.
·     IPFRR—FIB IP FRR.
·     MAD.
·     OSPFv3.
·     BGP4+.
·     PIM.
·     STATIC6—IPv6 static routing.
·     RIPNG—RIPng.
·     Interface—Interface state.
·     TUNNEL.
·     STATIC_IPv4—IPv4 static BFD session.
·     STATIC_IPv6—IPv6 static BFD session.
Diag info
Diagnostic information about the session:
·     No Diagnostic.
·     Control Detection Time Expired—A control-mode BFD session goes down because local detection times out.
·     Echo Function Failed—An echo-mode BFD session goes down, because local detection times out or the source IP address of echo packets is deleted.
·     Neighbor Signaled Session Down—The remote end notifies the local end of BFD session down.
·     Administratively Down—The local system prevents a BFD session from being established.
first-fail-timer
Use first-fail-timer to configure the timer that delays reporting the first BFD session establishment failure to the data link layer.
Use undo first-fail-timer to restore the default.
context-admin
This command takes effect only on static BFD sessions after you configure the process-interface-status command.
If the static BFD session fails to be established when the timer expires, BFD reports the failure to the data link layer and sets the data link layer state of the interface to DOWN(BFD). This behavior rapidly identifies the interfaces for which BFD sessions fail to be established. In this case, the BFD session state is displayed as Down in the display bfd session command output. The line protocol state of the interface is displayed as DOWN(BFD) in the display interface command output.
If you exeucte the command on the local end, the BFD session for detecting the local interface state fails to be established when the following conditions exist:
·     The command is not executed on the remote end.
# Configure the timer that delays reporting the first BFD session establishment failure as 100 seconds.
[Sysname] bfd static abc peer-ip default-ip interface gigabitethernet 1/0/1 source-ip 10.1.1.1 discriminator local 1 remote 1
[Sysname-bfd-static-session-1] first-fail-timer 100
bfd static
processing-interface-status
Use process-interface-status to associate the interface state with a static BFD session.
Use undo process-interface-status to restore the default.
The state of a static BFD session does not affect the state of the data link layer of the interface.
context-admin
This command enables a static BFD session with peer address 224.0.0.184 to set the link layer protocol of the interface to DOWN(BFD) when detecting a link failure. To display information about the link layer protocol state, use the display interface command.
# Associate the state of GigabitEthernet 1/0/1 with static BFD session abc.
[Sysname-bfd-static-session-abc] process-interface-status
bfd static
display interface
reset bfd session statistics
Use reset bfd session statistics to clear the BFD session statistics.
context-admin
# Clear the BFD session statistics.
<Sysname> reset bfd session statistics
snmp-agent trap enable bfd
Use snmp-agent trap enable bfd to enable SNMP notifications for BFD.
Use undo snmp-agent trap enable bfd to disable SNMP notifications for BFD.
All SNMP notifications are enabled for BFD.
context-admin
To report critical BFD events to an NMS, enable SNMP notifications for BFD. For BFD event notifications to be sent correctly, you must also configure SNMP as described in the network management and monitoring configuration guide for the device.
# Disable SNMP notifications for BFD.
[Sysname] undo snmp-agent trap enable bfd
special-processing
Use special-processing to enable special processing for a static BFD session used to detect data link layer connectivity.
Use undo special-processing to disable special processing for the static BFD session.
undo special-processing [ admin-down | authentication-change | session-up ] *
All types of special processing are disabled for a static BFD session used to detect data link layer connectivity.
context-admin
# Enable all types of special processing for a static BFD session whose outgoing interface is GigabitEthernet 1/0/1.
[Sysname-bfd-static-session-1] special-processing
bfd static
