17-Network Management and Monitoring Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath M9000 Command Reference(V7)(R9153P39 R9001P39)-6W40017-Network Management and Monitoring Command Reference
15-Mirroring commands
15-Mirroring commands 46.83 KB
Flow mirroring commands
IMPORTANT
IMPORTANT:
For information about the commands except the mirror-to command in this chapter, see QoS policy commands in ACL and QoS Command Reference.
The number of flow mirroring configurations supported on an interface module varies by interface module type. A flow mirroring configuration mirrors the inbound or outbound traffic of one or more source interfaces to a designated destination interface. The destination interface is configured by using the mirror-to command in a traffic behavior used by a QoS policy. The source interfaces are the interfaces to which the QoS policy is applied.
A maximum of four flow mirroring configurations are supported on the following interface modules:
·     NSQM1MBFEA0.
·     NSQM2MBFDA0.
·     NSQM1TGS32QSSG0.
·     NSQ1CGC2SE0.
·     NSQM2QGS4SC0.
·     NSQ1QGS4SF0.
·     NSQ1TGS32SF0.
·     NSQM2TGS16SF0.
·     NSQ1TGS8EA0.
·     NSQM2GP24TSSC0.
A maximum of four inbound flow mirroring configurations plus a maximum of four outbound flow mirroring configurations are supported on the following interface modules:
·     NSQ1GP24TXEA0.
·     NSQ1TGX4EA0.
·     NSQ1GP48EB0.
·     NSQ1GT48EA0.
mirror-to interface
Use mirror-to interface to configure a mirroring action that mirrors traffic to an interface.
Use undo mirror-to interface to delete a mirroring action that mirrors traffic to an interface.
mirror-to interface interface-type interface-number
undo mirror-to interface interface-type interface-number
No mirroring actions exist to mirror traffic to interfaces.
Traffic behavior view
context-admin
You can execute this command multiple times for a traffic behavior to mirror traffic to different interfaces.
# Create traffic behavior 1 and configure the action of mirroring traffic to GigabitEthernet 1/0/1 for the traffic behavior.
[Sysname] traffic behavior 1
[Sysname-behavior-1] mirror-to interface gigabitethernet 1/0/1
