11-Layer 3—IP Services Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath M9000 Command Reference(V7)(R9153P39 R9001P39)-6W40011-Layer 3—IP Services Command Reference
07-Multi-CPU packet distribution commands
07-Multi-CPU packet distribution commands 34.22 KB
forwarding policy
Use forwarding policy to specify a multi-CPU packet distribution policy.
Use undo forwarding policy to restore the default.
forwarding policy { per-flow [ mode { destination-ip | destination-port | source-ip | source-port } | three-tuple ] | per-packet }
The device uses the flow-based policy.
context-admin
per-flow: Specifies the flow-based forwarding. The device distributes packets of the same flow to one CPU or multiple CPUs. The CPU processes flow packets by following the first-in first-out rule.
mode: Specifies a flow-based forwarding mode.
destination-ip: Identifies a flow by destination IP address.
destination-port: Identifies a flow by destination port.
source-ip: Identifies a flow by source IP address.
source-port: Identifies a flow by source port.
three-tuple: Identifies a data flow by the three-tuple (source IP address, destination IP address, and protocol number).
per-packet: Specifies the packet-based forwarding. The device forwards packets in sequence to different CPUs, even though they are the same flow. This policy does not ensure packet order.
If you do not specify any keyword for flow identification, the device identifies a flow by source IP address, destination IP address, source port number, destination port number, and protocol number.
# Specify the flow-based policy.
[Sysname] forwarding policy per-flow three-tuple
