06-MPLS Configuration Guide
HomeSupportSwitchesS9820 SeriesConfigure & DeployConfiguration GuidesH3C S9820-8C Switch Configuration Guides-Release 66xx-6W10306-MPLS Configuration Guide
04-Tunnel policy configuration
04-Tunnel policy configuration 39.75 KB
Configuring tunnel policies
About tunnel policies
A tunnel policy enables a PE to forward traffic of an MPLS VPN over multiple LSP tunnels to the peer PE for load sharing.
If the traffic of a VPN is load-shared over multiple tunnels, the device or the upper layer application might take time to re-order the packets of the VPN. This is because the time delays on different tunnels might differ massively.
For more information about MPLS VPN, see "Configuring MPLS L3VPN."
Configuring a tunnel policy
2.     Create a tunnel policy, and enter tunnel policy view.
tunnel-policy tunnel-policy-name
3.     Configure the tunnel policy.
select-seq lsp load-balance-number number
By default, the policy selects only one tunnel.
Display and maintenance commands for tunnel policies
Display tunnel information.
display mpls tunnel { all | statistics | [ vpn-instance vpn-instance-name ] destination { ipv4-address | ipv6-address } }
Display tunnel policy information.
display tunnel-policy [ tunnel-policy-name ]
