05-Network Connectivity Configuration Guide
HomeSupportWirelessvAC1000 Virtual Access ControllerConfigure & DeployConfiguration GuidesH3C vAC1000 Virtual Access Controller Configuration Guides(R5435P03)-6W10005-Network Connectivity Configuration Guide
10-IP forwarding basics configuration
10-IP forwarding basics configuration 66.96 KB
Configuring IP forwarding basic settings························································ 1
About FIB table······························································································································· 1
Display and maintenance commands for FIB table············································································ 1
Configuring load sharing··················································································· 3
About load sharing·························································································································· 3
Configuring load sharing mode········································································································ 3
Enabling IPv4 bandwidth-based load sharing···················································································· 3
Loading sharing configuration examples··························································································· 4
Example: Configuring load sharing based on source and destination addresses·························· 4
About FIB table
A device uses the FIB table to make packet forwarding decisions.
A device selects optimal routes from the routing table, and puts them into the FIB table. Each FIB entry specifies the next hop IP address and output interface for packets destined for a specific subnet or host.
For more information about the routing table, see "Configuring basic IP routing."
Use the display fib command to display the FIB table. The following example displays the entire FIB table.
<Sysname> display fib
Destination count: 4 FIB entry count: 4
Flag:
  U:Useable   G:Gateway   H:Host   B:Blackhole   D:Dynamic   S:Static
  R:Relay     F:FRR
Destination/Mask   Nexthop         Flag     OutInterface/Token       Label
10.2.0.0/16        10.2.1.1        U        GE1/0                    Null
10.2.1.1/32        127.0.0.1       UH       InLoop0                  Null
127.0.0.0/8        127.0.0.1       U        InLoop0                  Null
127.0.0.1/32       127.0.0.1       UH       InLoop0                  Null
A FIB entry includes the following items:
·     Destination—Destination IP address.
·     Mask—Network mask. The mask and the destination address identify the destination network. A logical AND operation between the destination address and the network mask yields the address of the destination network. For example, if the destination address is 192.168.1.40 and the mask 255.255.255.0, the address of the destination network is 192.168.1.0. A network mask includes a certain number of consecutive 1s. It can be expressed in dotted decimal format or by the number of the 1s.
·     Nexthop—IP address of the next hop.
·     Flag—Route flag.
·     OutInterface—Output interface.
·     Token—MPLS Label Switched Path index number.
·     Label—Inner label.
Display FIB entries.
display fib  [ ip-address [ mask | mask-length ] ]
About load sharing
If a routing protocol finds multiple equal-cost best routes to the same destination, the device forwards packets over the equal-cost routes to implement load sharing.
In the per-flow load sharing mode, the device forwards flows over equal-cost routes. Packets of one flow travel along the same routes. You can configure the device to identify a flow based on the following criteria: source IP address, destination IP address, source port number, destination port number, IP protocol number, and ingress port.
In a complex network, when the traffic is not laod balanced proportionally, you can use the algorithm keyword to specify an algorithm to improve the sharing.
In the per-packet load sharing mode, the device forwards packets over equal-cost routes.
2.     Configure load sharing.
ip load-sharing mode { per-flow [ dest-ip | dest-port | ip-pro | src-ip | src-port ] * | per-packet } global
By default, the device performs per-flow load sharing.
This feature load shares flow traffic among multiple output interfaces based on their load percentages. The device calculates the load percentage for each output interface in terms of the interface expected bandwidth.
Devices that run load sharing protocols implement load sharing based on the ratios defined by these protocols.
2.     Enable IPv4 bandwidth-based load sharing.
bandwidth-based-sharing
By default, the IPv4 bandwidth-based load sharing is disabled.
3.     (Optional.) Configure the expected bandwidth of the interface.
a.     Enter interface view.
b.     Configure the expected bandwidth of the interface.
bandwidth bandwidth
By default, the expected bandwidth is the physical bandwidth of the interface.
As shown in Figure 1, Switch A has two equal-cost routes to Switch B. Configure load sharing on Switch A to forward packets through Switch B to the destination IP address 1.2.3.4/24.
Figure 1 Network diagram
# On Switch A, assign GigabitEthernet 1/0 to VLAN 10, and GigabitEthernet 2/0 to VLAN 20.
[SwitchA] vlan 10
[SwitchA-vlan10] port gigabitethernet 1/0
[SwitchA-vlan10] quit
[SwitchA] vlan 20
[SwitchA-vlan20] port gigabitethernet 2/0
[SwitchA-vlan20] quit
# On Switch A, configure IP addresses for VLAN-interface 10 and VLAN-interface 20.
[SwitchA-Vlan-interface10] ip address 10.1.1.1 24
[SwitchA-Vlan-interface20] ip address 20.1.1.1 24
# On Switch B, assign GigabitEthernet 1/0 to VLAN 10, and GigabitEthernet 2/0 to VLAN 20.
[SwitchB] vlan 10
[SwitchB-vlan10] port gigabitethernet 1/0
[SwitchB-vlan10] quit
[SwitchB] vlan 20
[SwitchB-vlan20] port gigabitethernet 2/0
[SwitchB-vlan20] quit
# On Switch B, configure IP addresses for VLAN-interface 10 and VLAN-interface 20.
[SwitchB-Vlan-interface10] ip address 10.1.1.2 24
[SwitchB] interface vlan-interface 20
[SwitchB-Vlan-interface20] ip address 20.1.1.2 24
[SwitchB-Vlan-interface20] quit
# On Switch A, configure two static routes to the destination IP address.
[SwitchA] ip route-static 1.2.3.4 24 10.1.1.2
[SwitchA] ip route-static 1.2.3.4 24 20.1.1.2
[SwitchA] quit
# On Switch A, display FIB entries matching the destination IP address 1.2.3.4.
<SwitchA> display fib 1.2.3.4
Destination count: 1 FIB entry count: 2
Flag:
  R:Relay     F:FRR
1.2.3.0/24         10.1.1.2        USGR     Vlan10                   Null
1.2.3.0/24         20.1.1.2        USGR     Vlan20                   Null
# On Switch A, configure per-flow load sharing based on the source IP address and destination IP address.
[SwitchA] ip load-sharing mode per-flow dest-ip src-ip global
# Verify that Switch A implements load sharing.
<SwitchA> display counters outbound interface GigabitEthernet
Interface         Total (pkts)   Broadcast (pkts)   Multicast (pkts)  Err (pkts)
GE1/0                  1045                  0                  0           0
GE2/0                  1044                  0                  0           0
