- 05-Network Connectivity Configuration Guide
- 01-About the network connectivity configuration guide
- 02-ARP configuration
- 03-DHCP configuration
- 04-DHCPv6 configuration
- 05-GRE configuration
- 06-IGMP snooping configuration
- 07-IP addressing configuration
- 08-Basic IP routing configuration
- 09-IP performance optimization configuration
- 10-IP forwarding basics configuration
- 11-L2TP configuration
- 12-LLDP configuration
- 13-MAC address table configuration
- 14-NAT configuration
- 15-PPP configuration
- 16-MLD snooping configuration
- 17-VLAN configuration
- 18-Policy-based routing configuration
- 19-Layer 2 forwarding configuration
- 20-IPv6 static routing configuration
- 21-IPv6 policy-based routing configuration
- 22-IPv6 basics configuration
- 23-Static routing configuration
- 24-Ethernet link aggregation configuration
- 25-DNS configuration
- 26-Multicast overview
| 00-Preface | 76.31 KB |
Preface
The H3C vAC1000 virtual access controller documentation set describes the software features for the vAC1000 virtual access controller and guide you through the software configuration procedures. These guides also provide configuration examples to help you apply software features to different network scenarios.
This configuration guide includes the following feature modules:
· About the network connectivity
· ARP.
· DHCP.
· DHCPv6.
· GRE.
· IGMP snooping.
· IP addressing.
· Basic IP routing
· IP performance optimization.
· IP forwarding,
· L2TP.
· LLDP.
· MAC address table.
· NAT.
· PPP.
· MLD snooping.
· VLAN.
· Policy-based routing.
· Layer 2 forwarding.
· IPv6 static routing.
· IPv6 policy-based routing.
· IPv6 basics.
· Static routing.
· Ethernet link aggregation.
· DNS.
· Multicast overview
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the vAC1000 virtual access controller.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
