- 09-Radio Resources Management Command Reference
- 01-WLAN RRM commands
- 02-WLAN load balancing commands
- 03-WLAN radio load balancing commands
- 04-Band navigation commands
- 05-Spectrum management commands
- 06-Radio management commands
- 07-WLAN radio resource measurement commands
- 08-Channel scanning commands
00-Preface | 100.41 KB |
Preface
This command reference describes radio resource management related configuration commands. It includes the following feature modules:
· WLAN RRM.
· WLAN load balancing.
· WLAN radio load balancing.
· Band navigation.
· Spectrum management.
· Radio management.
· WLAN radio resource measurement.
· Channel scanning.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the vAC1000 virtual access controller.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
