| 00-Preface | 99.97 KB |
Preface
The access controllers documentation set describes the software features for the access controllers and guide you through the software configuration procedures. These guides also provide configuration examples to help you apply software features to different network scenarios.
The Interface Configuration Guide describes Ethernet interface, loopback interface, null interface, and loopback interface configurations and bulk interface configuration,PoE.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
