17-DPI Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(R5447P04)-6W10017-DPI Command Reference
03-URL filtering commands
03-URL filtering commands 150.49 KB
The following compatibility matrixes show the support of hardware platforms for URL filtering:
Hardware series
Model
Product code
URL filtering compatibility
WX1800H series
WX1804H-PWR
EWP-WX1804H-PWR-CN
Yes
WX2500H series
WX2508H-PWR-LTE
WX2510H-PWR
WX2510H-F-PWR
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
Yes
MAK series
MAK204
MAK206
EWP-MAK204
EWP-MAK206
Yes
WX3000H series
WX3010H
WX3010H-X-PWR
WX3010H-L-PWR
WX3024H
WX3024H-L-PWR
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
Yes:
·     WX3010H
·     WX3010H-X
·     WX3024H
·     WX3024H-F
No:
·     WX3010H-L
·     WX3024H-L
WX3500H series
WX3508H
WX3508H
WX3510H
WX3510H
WX3520H
WX3520H-F
WX3540H
WX3540H
EWP-WX3508H
EWP-WX3508H-F
EWP-WX3510H
EWP-WX3510H-F
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
EWP-WX3540H-F
Yes
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
Yes
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
Yes
Access controller modules
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
Yes
Hardware series
Model
Product code
WX1800H series
WX1804H-PWR
WX1810H-PWR
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
Yes
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
Yes
WX5800H series
WX5860H
EWP-WX5860H-GL
Yes
add
Use add to add a blacklist or whitelist rule to a URL filtering policy.
Use undo add to delete a blacklist or whitelist rule from a URL filtering policy.
add { blacklist | whitelist } [ id ] host { regex host-regex | text host-name } [ uri { regex uri-regex | text uri-name } ]
undo add { blacklist | whitelist } { id | all }
No blacklist or whitelist rules exist in a URL filtering policy.
URL filtering policy view
blacklist: Specifies the blacklist rule type.
whitelist: Specifies the whitelist rule type.
id: Specifies a rule ID. The value must be an integer in the range of 1 to 65535. The ID of a blacklist or whitelist rule must be unique among all rules of the same type. If you do not specify a rule ID, the system automatically assigns an available ID to the rule according to the largest rule ID N used on the device:
·     If N is smaller than 65535, the smallest available ID that is larger than N is used.
·     If N equals to 65535, the smallest available ID is used.
host: Matches the host field in the URL.
uri: Matches the URI field in the URL.
regex regex: Specifies a case-sensitive regular expression string for fuzzy match. The string can start with only letters, digits, or underscores (_), and it must contain three consecutive non-wildcard characters.
·     If the host keyword is specified, the string can contain 3 to 224 characters.
·     If the uri keyword is specified, the string can contain 3 to 245 characters.
text string: Specifies a case-insensitive text string for exact match.
·     If the host keyword is specified, the string can contain 3 to 224 characters. Valid characters are letters, digits, underscores (_), hyphens (-), colons (:), left square brackets ([), right square brackets (]), and dots (.).
all: Specifies all rules of the specified type.
The device supports using URL-based whitelist and blacklist rules to filter HTTP packets. If the URL in an HTTP packet matches a blacklist rule, the packet is dropped. If the URL matches a whitelist rule, the packet is permitted to pass through.
When you configure a regular expression in a blacklist or whitelist rule, follow these restrictions and guidelines:
·     The regular expression pattern can contain a maximum of four branches. For example, 'abc(c|d|e|\x3D)' is valid, and 'abc(c|onreset|onselect|onchange|style\x3D)' is invalid.
·     Nested braces are not allowed. For example, 'ab((abcs*?))' is invalid.
·     A branch cannot be specified after another branch. For example, 'ab(a|b)(c|d)^\\r\\n]+?' is invalid.
·     A minimum of four non-wildcard characters must exist before an asterisk (*) or question mark (?). For example, 'abc*' is invalid and 'abcd*DoS\x2d\d{5}\x20\x2bxi\\r\\nJOIN' is valid.
# In URL filtering policy news, add a blacklist rule to match URLs that contain games.com in the host field.
[Sysname] url-filter policy news
[Sysname-url-filter-policy-news] add blacklist 1 host text games.com
# In URL filtering policy news, add a whitelist rule to match URLs that contain sina.com in the host field.
[Sysname-url-filter-policy-news] add whitelist 1 host text sina.com
category action
Use category action to specify actions for a URL category.
Use undo category action to remove the action setting from a URL category.
category category-name action { drop | permit | redirect parameter-profile parameter-name | reset } [ logging [ parameter-profile parameter-name ] ]
undo category category-name
A URL category does not have any action specified.
category-name: Specifies a URL category by its name, a case-insensitive string of 1 to 63 characters.
action: Specifies the action for the matching packets.
drop: Drops matching packets.
permit: Permits matching packets to pass.
redirect: Redirects matching packets to a webpage.
reset: Disconnects the TCP connection for matching packets.
logging: Logs matching packets.
parameter-profile parameter-name: Specifies a parameter profile by its name, a case-insensitive string of 1 to 63 characters. If you do not specify a profile, or if the specified profile does not exist, the URL filtering action uses the default parameter settings. For information about configuring parameter profiles, see "DPI engine commands."
If an HTTP packet matches a URL filtering rule in a URL category, the action specified for the category applies to the packet.
If the packet matches none of URL filtering rules in the URL filtering policy, the default action specified for the policy applies to the packet. If the default action is not configured, the device permits the packet to pass.
If you execute this command for a URL category multiple times, the most recent configuration takes effect.
# In the URL filtering policy news, specify the drop action for the URL category sina.
[Sysname-url-filter-policy-news] category sina action drop
inspect redirect parameter-profile
url-filter category
url-filter policy
default-action
Use default-action to specify the default action for a URL filtering policy.
Use undo default-action to restore the default.
default-action { drop | permit | redirect parameter-profile parameter-name | reset } [ logging [ parameter-profile parameter-name ] ]
undo default-action
A URL filtering policy does not have any default action.
permit: Permits packets to pass.
parameter-profile parameter-name: Specifies a DPI action parameter profile by its name, a case-insensitive string of 1 to 63 characters. If you do not specify a profile, or if the specified profile does not exist, the DPI action uses the default parameter settings. For information about configuring parameter profiles for DPI actions, see "DPI engine commands."
The default action applies to packets that do not match any URL filtering rules.
# Set the default action to drop for URL filtering policy cmcc.
[Sysname] url-filter policy cmcc
[Sysname-url-filter-policy-cmcc] default-action drop
url-filter policy
description
Use description to configure a description for a URL category.
A user-defined URL category does not have a description.
URL category view
text: Specifies a description, a case-insensitive string of 1 to 255 characters. Spaces are allowed.
Use this command to configure descriptions for URL categories for easy maintenance.
# Configure the description as News information for URL category news.
[Sysname] url-filter category news
[Sysname-url-filter-category-news] description News information
display url-filter category
Use display url-filter category to display URL category information.
display url-filter category [ verbose ]
verbose: Display detailed URL category information. If you do not specify this keyword, this command displays the summarized URL category information.
# Display URL category information.
<Sysname> display url-filter category
URL category summary:
      Predefined categories: 108
           Predefined rules: 2000
    User-defined categories: 0
         User-defined rules: 0
URL category details:
# Display detailed URL category information.
<Sysname> display url-filter category verbose
           Type: Predefined
       Severity: 23
          Rules: 15
    Description: 3C
           Type: Predefined
       Severity: 585
          Rules: 5
    Description: AdultPlace
           Type: Predefined
       Severity: 500
          Rules: 21
Total number of URL categories, including the predefined and user-defined categories.
Number of predefined URL categories.
Predefined rules
Number of predefined URL filtering rules.
Number of user-defined URL categories.
User-defined rules
Number of user-defined URL filtering rules.
List of URL categories.
Name
Name of the URL category.
Type of the URL category, Predefined or User Defined.
Severity
Severity level of the URL category.
Rules
Number of URL filtering rules in the URL category.
Description of the URL category.
display url-filter signature information
Use display url-filter signature information to display information about the URL filtering signature library.
# Display information about the URL filtering signature library.
<Sysname> display url-filter signature information
URL filter signature library information:
Type      SigVersion         ReleaseTime               Size
Current   1.0.0              Wed Jan 21 06:43:53 2015  36096
(null)    -                  -                         -
Factory   1.0.0              Wed Jan 21 06:43:53 2015  36096
Version of the URL filtering signature library:
·     Current—Current version.
·     Last—Previous version.
·     Factory—Factory default version.
SigVersion
Version number.
ReleaseTime
Time when the URL filtering signature library was released.
Size
Size of the URL filtering signature library, in bytes.
display url-filter statistics
Use display url-filter statistics to display URL filtering statistics.
# Display URL filtering statistics.
<Sysname> display url-filter statistics
Total HTTP requests                           : 0
Total permitted HTTP requests                 : 0
Total denied HTTP requests                    : 0
Requests that matched the blacklist           : 0
Requests that matched the whitelist           : 0
Requests that matched a user-defined rule     : 0
Requests that matched a predefined rule       : 0
Requests that matched a cached rule           : 0
Requests that matched the default action      : 0
Predefined URL filtering rules                : 2000
Total HTTP requests
Total number of HTTP packets.
Total number of permitted HTTP packets.
Total number of denied HTTP packets.
Number of HTTP packets that matched a blacklist rule.
Number of HTTP packets that matched a whitelist rule.
Number of HTTP packets that matched a user-defined URL filtering rule.
Number of HTTP packets that matched a predefined URL filtering rule.
Number of HTTP packets that matched a cached URL filtering rule.
Number of HTTP packets on which the default action is executed.
Total number of predefined URL filtering rules.
include pre-defined
Use include pre-defined to add the URL filtering rules of a predefined URL category to a user-defined URL category.
Use undo include pre-defined to restore the default.
include pre-defined category-name
A user-defined URL category does not contain the URL filtering rules of any predefined URL category.
URL category view
category-name: Specifies a predefined URL category by its name, a case-sensitive string of 1 to 63 characters. The specified URL category must exist on the device.
To simplify URL category configuration, you can use this command to add the URL filtering rules of a predefined URL category to a user-defined URL category.
You can add URL filtering rules of only one predefined URL category to a user-defined URL category. If you execute this command for a URL category multiple times, the most recent configuration takes effect.
# Add the URL filtering rules of predefined URL category pre-Arts to URL category news.
[Sysname-url-filter-category-news] include pre-defined pre-Arts
rename (URL category view)
Use rename to rename a URL category.
rename new-name
URL category view
new-name: Specify a new name for the URL category, a case-insensitive string of 1 to 63 characters.
If you change the name for a URL category that is used by a URL filtering policy, the URL category name in the policy is also changed.
# Rename URL category news to hello, and enter the view of URL category hello.
[Sysname-url-filter-category-news] rename hello
[Sysname-url-filter-category-hello]
rename (URL filtering policy view)
Use rename to rename a URL filtering policy.
rename new-name
new-name: Specify a new name for the URL filtering policy, a case-insensitive string of 1 to 31 characters.
If you change the name of a URL filtering policy that has been assigned to a DPI application profile, the policy name in the DPI application profile is also changed.
# Rename URL filtering policy news to hello, and enter the view of URL filtering policy hello.
[Sysname-url-filter-policy-news] rename hello
[Sysname-url-filter-policy-hello]
reset url-filter statistics
Use reset url-filter statistics to clear URL filtering statistics.
# Clear URL filtering statistics.
<Sysname> reset url-filter statistics
rule
Use rule to create a URL filtering rule for a user-defined URL category.
Use undo rule to delete a URL filtering rule from a user-defined URL category.
rule rule-id host { regex regex | text string } [ uri { regex regex | text string } ]
undo rule rule-id
A user-defined URL category does not have any URL filtering rules.
URL category view
rule-id: Assigns an ID to the URL filtering rule, in the range of 1 to 65535.
host: Matches URLs by the hostname field.
uri: Matches URLs by the URI field.
regex regular-expression: Specifies a case-sensitive regular expression string for fuzzy match. The string can start with only letters, digits, or underscores (_), and it must contain three consecutive non-wildcard characters.
·     If the uri keyword is specified, the string can contain 3 to 253 characters.
·     If the uri keyword is specified, the string can contain 3 to 255 characters.
A URL filtering rule supports the following URL matching methods:
·     Exact match by text—Performs an exact text string match on the hostname or URI field of the URL.
¡     If a rule is configured with the host keyword, a URL matches the rule only if it contains a host name exactly the same as the specified text sting. For example, the rule 1 host text abc.com.cn command matches URLs that carry the abc.com.cn hostname, but it does not match URLs carrying the dfabc.com.cn hostname.
¡     If a rule is configured with the uri keyword, a URL matches the rule if it contains a URI that begins with the complete text string in the rule. For example, the rule 2 uri text /sina/news command matches URLs that contain URIs /sina/news, /sina/news/sports, and /sina/news_sports. However, the command does not match URLs that contain URI /sina.
·     Fuzzy match by regular expression—Performs a fuzzy regular expression match on the hostname or URI field of the URL. For example, the rule 3 host regex sina.*cn command matches URLs that carry the news.sina.com.cn hostname.
When you configure a regular expression in a URL filtering rule, follow these restrictions and guidelines:
# In URL category news, create a URL filtering rule to match URLs that carry the sina.com hostname.
[Sysname-url-filter-category-news] rule 10 host text sina.com
url-filter category
update schedule
Use update schedule to configure a schedule for automatic URL filtering signature library update.
Use undo update schedule to restore the default.
The device starts the URL filtering signature library update at a random time between 01:00:00 and 03:00:00 every day.
Automatic URL filtering signature library update configuration view
daily: Updates the URL filtering signature library every day.
weekly: Updates the URL filtering signature library every week.
fri: Updates the URL filtering signature library every Friday.
mon: Updates the URL filtering signature library every Monday.
sat: Updates the URL filtering signature library every Saturday.
sun: Updates the URL filtering signature library every Sunday.
thu: Updates the URL filtering signature library every Thursday.
tue: Updates the URL filtering signature library every Tuesday.
wed: Updates the URL filtering signature library every Wednesday.
start-time time: Specifies the start time in hh:mm:ss format. The value range is 00:00:00 to 23:59:59.
tingle minutes: Specifies the  tolerance time in minutes. The value range is 0 to 120. An automatic library update will occur at a random time between the following time points:
·     Start time minus half the tolerance time.
·     Start time plus half the tolerance time.
# Configure the device to automatically update the URL filtering signature library every Sunday at a random time between 20:25:00 and 20:35:00.
[Sysname] url-filter signature auto-update
[Sysname-url-filter-autoupdate] update schedule weekly sun start-time 20:30:00 tingle 10
url-filter signatures auto-update
url-filter apply policy
Use url-filter apply policy to apply a URL filtering policy to a DPI application profile.
Use undo url-filter apply policy to remove the URL filtering policy from a DPI application profile.
url-filter apply policy policy-name
No URL filtering policy is applied to a DPI application profile.
DPI application profile view
policy-name: Specifies a URL filtering policy by its name, a case-insensitive string of 1 to 31 characters.
A URL filtering policy takes effect only after it is applied to a DPI application profile.
You can apply only one URL filtering policy to a DPI application profile. If you execute this command multiple times, the most recent configuration takes effect.
# Apply URL filtering policy news to DPI application profile abc.
[Sysname] app-profile abc
[Sysname-app-profile-abc] url-filter apply policy news
app-profile
display app-profile
display url-filter policy
url-filter category
Use url-filter category to create a user-defined URL category and enter its view, or enter the view of an existing URL category.
Use undo url-filter category to delete a URL category.
url-filter category category-name [ severity severity-level ]
undo url-filter category category-name
The device has only predefined URL categories with the name prefix Pre-.
category-name: Specify the URL category name, a case-insensitive string of 1 to 63 characters. Valid characters are letters, digits, underscores (_), hyphens (-), and dots (.). The category name cannot start with Pre-.
severity severity-value: Specifies a severity level for the URL category. The value range is 1000 to 65535, and the default is 65535. The larger the value, the higher the severity level. The severity level of each user-defined URL category must be unique. This option is required when you create a URL category.
URL filtering provides the URL categorization feature to facilitate filtering rule management.
You can classify multiple URL filtering rules into a URL category and specify an action for the category. If a matching rule is in multiple URL categories, the system takes the action for the category with the highest severity level.
URL filtering supports the following types of URL categories:
·     Predefined URL categories.
The predefined URL categories contain the predefined URL filtering rules. Each predefined URL category has a unique severity level in the range of 1 to 999, and a category name that begins with Pre-. Predefined URL categories cannot be modified.
·     User-defined URL categories.
You can create user-defined URL categories and configure filtering rules for them. The severity level of a user-defined URL category is in the range of 1000 to 65535. You can edit the filtering rules and change the severity level for a user-defined URL category.
# Create a URL category named news and set its severity level to 2000.
[Sysname] url-filter category news severity 2000
url-filter copy category
Use url-filter copy policy to copy a URL category.
url-filter copy category old-name new-name severity severity-level
old-name: Specifies the name of the URL category to be copied. The specified URL category must already exist.
new-name: Specifies a name for the new URL category. The name is a case-insensitive string of 1 to 63 characters and cannot begin with Pre.
severity severity-level: Assigns a unique severity level to the new URL category. The value range is 1000 to 65535. The larger the value, the higher the severity level.
This command allows you to create a new URL category by copying an existing one.
# Create URL category test by copying URL category news.
[Sysname] url-filter copy category news test severity 1001
[Sysname-url-filter-category-test]
url-filter category
Use url-filter copy policy to copy a URL filtering policy.
url-filter copy policy old-name new-name
old-name: Specifies the name of the URL filtering policy to be copied, a case-insensitive string of 1 to 31 characters.
new-name: Specifies a name for the new URL filtering policy, a case-insensitive string of 1 to 31 characters.
This command allows you to create a new URL filtering policy by copying an existing one.
# Create two URL filtering policies by copying URL filtering policy news.
[Sysname] url-filter copy policy news news1
[Sysname-url-filter-policy-news_1] quit
[Sysname] url-filter copy policy news new2
[Sysname-url-filter-policy-news_2] quit
url-filter policy
url-filter log directory root
Use url-filter log directory root to configure URL filtering to log only access to resources in the root directories of websites.
Use undo url-filter log directory root to restore the default.
URL filtering logs access to Web resources in all directories.
After this command is configured, the url-filter log except pre-defined and url-filter log except user-defined commands become invalid.
# Configure URL filtering to log only access to resources in the root directories of websites.
[Sysname] url-filter log directory root
category action logging
default-action logging
url-filter log enable
Use url-filter log enable to enable DPI engine logging.
Use undo url-filter log enable to disable DPI engine logging.
DPI engine logging is disabled.
You can enable DPI engine logging for audit. Log messages generated by DPI engine are output to the device information center. The information center then sends the messages to designated destinations based on log output rules. For more information about the information center, see System Management Configuration Guide.
DPI engine logging is memory intensive. To guarantee system performance, enable DPI engine logging only when necessary.
# Enable DPI engine logging.
[Sysname] url-filter log enable
Use url-filter log except pre-defined to disable URL filtering logging for access to resources of a predefined resource type.
Use undo url-filter log except pre-defined to enable URL filtering logging for access to resources of a predefined resource type.
url-filter log except pre-defined { css | gif | ico | jpg | js | png | swf | xml }
undo url-filter log except pre-defined { css | gif | ico | jpg | js | png | swf | xml }
URL filtering does not log access to resources of the predefined resource types (CSS, GIF, ICO, JPG, JS, PNG, SWF, and XML resources).
css: Specifies the CSS resource type.
gif: Specifies the GIF resource type.
ico: Specifies the ICO resource type.
jpg: Specifies the JPG resource type.
js: Specifies the JS resource type.
png: Specifies the PNG resource type.
swf: Specifies the SWF resource type.
xml: Specifies the XML resource type.
Repeat this command to disable URL filtering logging for access to multiple types of predefined resources.
This command does not take effect if the url-filter log directory root command is configured. To validate this command, you must execute undo url-filter log directory root command.
# Disable URL filtering logging for access to CSS resources.
[Sysname] url-filter log except pre-defined css
Use url-filter log except user-defined to disable URL filtering logging for access to resources of a user-defined resource type.
Use undo url-filter log except user-defined to enable URL filtering logging for access to resources of a user-defined resource type.
url-filter log except user-defined text
undo url-filter log except user-defined [ text ]
URL filtering logs access to all resources except for resources of the predefined types.
text: Specifies a Web resource type. The value is a case-insensitive string of 1 to 63 characters.
Repeat this command to disable URL logging for access to multiple types of user-defined resources.
Executing the undo url-filter log except user-defined command without the text parameter enables URL logging for access to all resources except resources of the predefined resource types.
# Disable URL filtering logging for access to HTML resources.
[Sysname] url-filter log except user-defined html
url-filter policy
Use url-filter policy to create a URL filtering policy and enter its view, or enter the view of an existing URL filtering policy.
Use undo url-filter policy to delete a URL filtering policy.
url-filter policy policy-name
undo url-filter policy policy-name
No URL filtering policies exist.
policy-name: Assigns a name to the URL filtering policy, a case-insensitive string of 1 to 31 characters.
In a URL filtering policy, you can specify an action for each URL category. You can also use the default action command to specify the default action for packets that do not match any URL filtering rules in the policy.
A URL filtering policy takes effect only after it is applied to a DPI application profile. For information DPI application profiles, see DPI engine configuration in Security Configuration Guide.
If DRS is enabled, the name of a URL filtering policy cannot be drs to avoid configuration changes or other unexpected errors after reboot. To enable DRS, use the wlan drs enable command. For more information about DRS, see WLAN DRS configuration in WLAN Command Reference.
# Create a URL filtering policy named news and enter its view.
Use url-filter signature auto-update to enable automatic URL filtering signature library update and enter automatic URL filtering signature library update configuration view.
Use undo url-filter signature auto-update to disable automatic URL filtering signature library update.
Automatic URL filtering signature library update is disabled.
The automatic update enables the device to periodically access the company's website to download the latest URL filtering signatures and update the local signature library.
You can schedule the time for automatic signature update by using the update schedule command.
# Enable automatic URL filtering signature library update and enter automatic URL filtering signature library update configuration view.
update schedule
url-filter signature auto-update-now
Use url-filter signature auto-update-now to trigger an automatic URL filtering signature library update manually.
This command immediately starts the automatic signature library update process. The device accesses the company's website to update the local URL filtering signature library.
You can execute this command anytime you find a new version of signature library on the company's website.
# Trigger an automatic URL filtering signature library update manually.
[Sysname] url-filter signature auto-update-now
url-filter signature rollback
Use url-filter signature rollback to roll back the URL filtering signature library.
url-filter signature rollback { factory | last }
factory: Rolls back the URL filtering signature library to the factory default version.
last: Rolls back the URL filtering signature library to the previous version.
If a URL filtering signature library update causes exceptions or a high false alarm rate, you can roll back the URL filtering signature library.
Before rolling back the URL filtering signature library, the device backs up the current signature library as the "previous version." For example, the previous library version is V1 and the current library version is V2. If you perform a rollback to the previous version, library version V1 becomes the current version and library version V2 becomes the previous version. If you perform a rollback to the previous version again, the library rolls back to library version V2.
# Roll back the URL filtering signature library to the previous version.
[Sysname] url-filter signature rollback last
url-filter signature update
Use url-filter signature update to manually update the URL filtering signature library.
url-filter signature update file-path
file-path: Specifies the URL filtering signature file path, a string of 1 to 255 characters.
If the device cannot access the company's website, use one of the following methods to manually update the URL filtering signature library:
·     Local update—Updates the URL filtering signature library on the device by using the locally stored update URL filtering signature file.
(In IRF mode.) Store the update file on the master device for successful signature library update.
The following describes the format of the file-path parameter for different update scenarios.
Update scenario
Format of file-path
Remarks
The update file is stored in the current working directory.
filename
To display the current working directory, use the pwd command (see file system management in Fundamentals Command Reference).
The update file is stored in a different directory on the same storage medium.
filename
Before updating the signature library, you must first use the cd command to open the directory where the file is stored.
For information about the cd command, see file system management in Fundamentals Command Reference.
The update file is stored on a different storage medium.
path/filename
Before updating the signature library, you must first use the cd command to open the root directory of the storage medium where the file is stored.
·     FTP/TFTP update—Updates the URL filtering signature library on the device by using the file stored on the FTP or TFTP server.
Update scenario
Format of file-path
Remarks
The update file is stored on an FTP server.
ftp://username:password@server address/filename
The username parameter represents the FTP login username.
The password parameter represents the FTP login password.
The server address parameter represents the IP address or host name of the FTP server.
Replace the following special characters in the FTP login username and password with their respective escape characters:
·     Colon (:)—%3A or %3a.
·     At sign (@)—%40.
·     Forward slash (/)—%2F or %2f.
The update file is stored on a TFTP server.
tftp://server address/filename
The server address parameter represents the IP address or host name of the TFTP server.
To update the signature library successfully, make sure the device and the FTP or TFTP server can reach each other. If you specify the FTP or TFTP server by its host name, you must also make sure the device can resolve the host name into an IP address through static or dynamic DNS. For more information about DNS, see Network Connectivity Configuration Guide.
# Manually update the local URL filtering signature library by using a signature file stored on a TFTP server.
[Sysname] url-filter signature update tftp://192.168.0.10/url-filter-1.0.2-en.dat
# Manually update the local URL filtering signature library by using a signature file stored on an FTP server. The FTP login username and password are user:123 and user@abc/123, respectively.
[Sysname] url-filter signature update ftp://user%3A123:user%40abc%[email protected]/url-filter-1.0.2-en.dat
# Manually update the local URL filtering signature library by using a signature file stored on the device. The file is stored in directory cfa0:/url-filter-1.0.23-en.dat, and the current working directory is cfa0:.
[Sysname] url-filter signature update url-filter-1.0.23-en.dat
# Manually update the local URL filtering signature library by using a signature file stored on the device. The file is stored in directory cfa0:/dpi/url-filter-1.0.23-en.dat, and the current working directory is cfa0:.
<Sysname> cd dpi
# Manually update the local URL filtering signature library by using a signature file stored on the device. The file is stored in directory cfb0:/dpi/url-filter-1.0.23-en.dat, and the current working directory is cfa0:.
<Sysname> cd cfb0:/
[Sysname] url-filter signature update dpi/url-filter-1.0.23-en.dat
