10-WLAN Roaming Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(R5447P04)-6W10010-WLAN Roaming Command Reference
02-WLAN roaming center commands
02-WLAN roaming center commands 129.56 KB
The following compatibility matrixes show the support of hardware platforms for WLAN roaming center:
Hardware series
Model
Product code
WLAN roaming center compatibility
WX1800H series
WX1804H-PWR
EWP-WX1804H-PWR-CN
No
WX2500H series
WX2508H-PWR-LTE
WX2510H-PWR
WX2510H-F-PWR
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
No
MAK series
MAK204
MAK206
EWP-MAK204
EWP-MAK206
No
WX3000H series
WX3010H
WX3010H-X-PWR
WX3010H-L-PWR
WX3024H
WX3024H-L-PWR
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
No
WX3500H series
WX3508H
WX3508H
WX3510H
WX3510H
WX3520H
WX3520H-F
WX3540H
WX3540H
EWP-WX3508H
EWP-WX3508H-F
EWP-WX3510H
EWP-WX3510H-F
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
EWP-WX3540H-F
No
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
Yes: WX5540E
No: WX5510E
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
Yes
Access controller modules
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
Yes:
·     LSUM1WCME0
·     EWPXM1WCME0
·     LSQM1WCMX40
·     LSUM1WCMX40RT
·     EWPXM1MAC0F
No:
·     LSQM1WCMX20
·     LSUM1WCMX20RT
·     EWPXM2WCMD0F
Hardware series
Model
Product code
WX1800H series
WX1804H-PWR
WX1810H-PWR
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
No
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
Yes
WX5800H series
WX5860H
EWP-WX5860H-GL
Yes
address-security cache
Use address-security cache to set the aging timer for address security entries.
Use undo address-security cache to restore the default.
address-security cache { ipv4-aging-time aging-time | ipv6-aging-time aging-time }
undo address-security cache { ipv4-aging-time | ipv6-aging-time }
The aging timer is 14400 seconds for IPv4 entries and 604800 seconds for IPv6 entries.
WLAN roaming center view
ipv4-aging-time: Specifies IPv4 address security entries.
ipv6-aging-time: Specifies IPv6 address security entries.
aging-time: Specifies the aging timer. The value range is 600 to 86400 seconds for IPv4 entries and 600 to 1296000 seconds for IPv6 entries.
Client roaming centers generate address security entries at client associations to record client MAC address, IP address, and username information, and synchronize the entries to the WLAN roaming center. When the aging timer of an entry expires, the client roaming center deletes the entry.
As a best practice, set an aging time not larger than the lease of IP addresses assigned to clients by the DHCP server.
# Set the aging timer of IPv4 address security entries to 600 seconds.
[Sysname] wlan roaming-center
[Sysname-wlan-roaming-center] address-security cache ipv4-aging-time 600
address-security enable
Use address-security enable to enable address security.
Use undo address-security enable to disable address security.
address-security enable [ alarm-only ]
Address security is disabled.
Service template view
alarm-only: Configures address security to generate alarms only and not to limit client access.
This feature enables the WLAN roaming center to check clients coming online from the specified service template for MAC address or IP address spoofing attacks. If a MAC or IP address spoofing attack is detected, the AC adds the attacker to the blacklist, and logs off both the attacker and the client whose address is spoofed.
For WLAN address security to take effect, configure 802.1X authentication.
WLAN address security takes effect only on clients that come online afterwards.
# Enable address security on service template 1.
[Sysname] wlan service-template 1
[Sysname-wlan-st-1] address-security enable
client ip-cache aging-time
Use client ip-cache aging-time to set the aging time for client IP address cache entries.
Use undo client ip-cache aging-time to restore the default.
client ip-cache aging-time aging-time
The aging time is 1800 seconds for client IP address cache entries.
aging-time: Specifies the aging time for client IP address cache entries, in the range of 600 to 86400 seconds.
With IP address recovery enabled for reassociated clients, the WLAN roaming center maintains IP and MAC binding entries for clients that leave an AP. When the aging time of such a cache entry expires, the WLAN roaming center deletes the entry.
# Set the aging time for client IP address cache entries to 600 seconds.
[Sysname-wlan-roaming-center] client ip-cache aging-time 600
client ip-snooping ip-recover enable (User Access and Authentication Command Reference)
control-access
Use control-access to specify a portal roaming center or client roaming center permitted by the WLAN roaming center.
Use undo control-access to restore the default.
control-access { bas-ip ipv4-address | bas-ipv6 ipv6-address }
undo control-access { bas-ip ipv4-address | bas-ipv6 ipv6-address }
No permitted portal roaming center or client roaming center is specified.
bas-ip ipv4-address: Specifies the IPv4 address of a portal roaming center or client roaming center.
bas-ipv6 ipv6-address: Specifies the IPv6 address of a portal roaming center or client roaming center.
This feature enables the WLAN roaming center to process packets from only the permitted portal or client roaming centers, enhancing network security. If no permitted portal roaming centers are specified, the WLAN roaming center processes packets from all portal roaming centers.
In inter-AC roaming of portal users, you can execute this command multiple times to specify multiple portal or client roaming centers. You can specify both IPv4 addresses and IPv6 addresses of portal or client roaming centers.
# Specify the AC with an IP address of 111.8.33.72 as a portal or client roaming center permitted by the WLAN roaming center.
[Sysname-wlan-roaming-center] control-access bas-ip 111.8.33.72
display wlan roaming-center history user
Use display wlan roaming-center history user to display offline client history on the WLAN roaming center.
display wlan roaming-center history user { all | ip ipv4-address | ipv6 ipv6-address | mac mac-address }
all: Specifies all offline clients.
ip ipv4-address: Specifies an offline client by its IPv4 address.
ipv6 ipv6-address: Specifies an offline client by its IPv6 address.
mac mac-address: Specifies an offline client by its MAC address.
# Display the history of all offline clients on the WLAN roaming center.
<Sysname> display wlan roaming-center history user all
MAC address: 000d-88f8-0eac
   IP address: 192.168.0.123
   Online BAS IP: 192.168.0.100
   Online time: 12:01:12 01/02 2018
   Offline time: 12:26:12 01/02 2018
   Roaming information:
     Roaming count: 3
       BAS-IP                         Roam-in time
       192.168.0.10                   12:20:12 01/02 2018 UTC
       192.168.0.11                   12:18:12 01/02 2018 UTC
       192.168.0.12                   12:16:12 01/02 2018 UTC
MAC address: 000d-88f8-0ead
     Roaming count: 3
     BAS-IP                           Roam-in time
MAC address
Client MAC address.
IP address
Client IPv4 or IPv6 address.
Online BAS IP
IP address of the AC from which the client first came online.
Online time
Time at which the client came online.
Offline time
Time at which the client went offline.
Roaming information
Client roaming entries. This field can display a maximum of ten entries, with the most recent one coming the first in the output.
Roaming count
Number of roamings performed by the client.
BAS-IP
IP address of the portal roaming center.
Roam-in time
Time at which the client roamed to the portal roaming center.
reset wlan roaming-center history user
wlan roaming-center enable
display wlan roaming-center statistics packet
Use display wlan roaming-center statistics packet to display packet statistics on the WLAN roaming center.
display wlan roaming-center statistics packet [ bas-ip ipv4-address | bas-ipv6 ipv6-address ]
bas-ip ipv4-address: Specifies a portal roaming center by its IPv4 address.
bas-ipv6 ipv6-address: Specifies a portal roaming center by its IPv6 address.
If you do not specify the bas-ip ipv4-address or bas-ipv6 ipv6-address option, the command displays packet statistics about all portal roaming centers.
# Display packet statistics about the portal roaming center with an IP address of 192.168.0.100.
<Sysname> display wlan roaming-center statistics packet bas-ip 192.168.0.100
BAS-IP192.168.0.100
Total sent packets: 100
Total received packets: 101
Total invalid packets: 0
Pkt-Type                   Success                  Error              Timeout
RC_REQ_INFO                1                        1                  0
RC_ACK_INFO                1                        2                  0
RC_REQ_ONLINE              1                        2                  0
RC_ACK_ONLINE              1                        1                  1
RC_REQ_OFFLINE             1                        1                  0
RC_ACK_OFFLINE             1                        1                  1
RC_REQ_DHCPINFO            1                        1                  1
RC_ACK_DHCPINFO            1                        1                  1
RC_REQ_NTY_OFFLINE         1                        1                  0
RC_ACK_NTY_OFFLINE         1                        1                  1
BAS-IP
Pkt-Type
Type of the packet:
·     RC_REQ_INFO—User query request that the portal roaming center sends to the WLAN roaming center.
·     RC_ACK_INFO—User query response that the WLAN roaming center sends to the portal roaming center.
·     RC_REQ_ONLINE—User online request that the portal roaming center sends to the WLAN roaming center.
·     RC_ACK_ONLINE—User online response that the WLAN roaming center sends to the portal roaming center.
·     RC_REQ_OFFLINE—User offline request that the portal roaming center sends to the WLAN roaming center.
·     RC_ACK_OFFLINE—User offline response that the WLAN roaming center sends to the portal roaming center.
·     RC_REQ_DHCPINFO—User DHCP information request that the portal roaming center sends to the WLAN roaming center.
·     RC_ACK_DHCPINFO—User DHCP information response that the WLAN roaming center sends to the portal roaming center.
·     RC_REQ_NTY_OFFLINE—User offline notification request that the WLAN roaming center sends to the portal roaming center.
·     RC_ACK_NTY_OFFLINE—User offline notification response that the portal roaming center sends to the WLAN roaming center.
Success
Number of packets that have been transmitted successfully.
Error
Number of packets that failed to be transmitted.
Timeout
Number of packet transmission timeouts.
display wlan roaming-center user
Use display wlan roaming-center user to display client information on the WLAN roaming center.
display wlan roaming-center user { all | bas-ip ipv4-address | bas-ipv6 ipv6-address | ip ipv4-address | ipv6 ipv6-address | mac mac-address } [ verbose ]
all: Specifies all clients.
ip ipv4-address: Specifies a client by its IPv4 address.
ipv6 ipv6-address: Specifies a client by its IPv6 address.
mac mac-address: Specifies a client by its MAC address.
verbose: Displays detailed client information. If you do not specify this keyword, the command displays brief client information.
# Display brief client information on the WLAN roaming center.
<Sysname> display wlan roaming-center user all
Total user: 5
MAC address               IP address
000d-88f8-0eac            122.122.111.100
000d-88f8-0eaa            122.122.111.101
000d-88f8-0eab            122.122.111.102
000d-88f8-0eae            10::4
000d-88f8-0eaf            1002:1002:1002:1002:1002:
1002:1002:1002
# Display brief information about the client with an IP address of 122.122.111.100 on the WLAN roaming center.
<Sysname> display wlan roaming-center user ip 122.122.111.100
# Display brief information about the client with an IPv6 address of 10::4 on the WLAN roaming center.
<Sysname> display wlan roaming-center user ipv6 10::4
# Display brief information about the client with a MAC address of 000d-88f8-0eac on the WLAN roaming center.
<Sysname> display wlan roaming-center user mac 000d-88f8-0eac
# Display detailed information about the client with a MAC address of 000d-88f8-0eac on the WLAN roaming center.
<Sysname> display wlan roaming-center user mac 000d-88f8-0eac verbose
  IP address: 2::1:21
  Username: 1
  Authorization information:
    User profile: abc
    ACL number/name: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
    Session timeout period: N/A
    Idle cut traffic threshold: N/A
    Web URL: N/A
    Online time: 12:01:12 01/02 2018 UTC
    Roaming count: 3
      BAS-IP                          Roam-in time
MAC address
Client MAC address.
IP address
Client IP address.
User profile
Authorized user profile. This field displays N/A if no user profile is authorized to the client.
ACL number/name
Number or name of the authorized ACL. This field displays N/A if no ACL is authorized to the client.
Inbound CAR
Authorized inbound CAR information:
·     CIR—Committed information rate in bps.
·     PIR—Peak information rate in bps.
·     CBS—Committed burst size in bits.
If no inbound CAR is authorized, this field displays N/A.
Outbound CAR
Authorized outbound CAR information:
If no outbound CAR is authorized, this field displays N/A.
Session timeout in seconds. This field displays N/A if no session timeout is authorized.
Session idle timeout in seconds and minimum traffic threshold in bytes. This field displays only the session idle timeout if the minimum traffic threshold failed to be obtained from the user online request.
Web URL
Authorized Web URL of the client. This field displays N/A if no Web URL is authorized.
Online BAS IP
Online time
Time at which the client first came online.
Roaming count
port
Use port to specify the port used by the WLAN roaming center to communicate with portal roaming centers and client roaming centers.
Use undo port to restore the default.
port port-number
undo port
The WLAN roaming center uses port 1088 to communicate with portal roaming centers and client roaming centers.
port-number: Specifies a port number in the range of 1 to 65534. Make sure the specified port is not in use and does not use a well-known port number.
Make sure the port specified for the WLAN roaming center is the same as the port specified for portal roaming centers and client roaming centers.
Changing the port number when portal clients are online might cause information synchronization failure between the WLAN roaming center and portal roaming centers. Portal clients might fail to roam and must be reauthenticated.
As a best practice to avoid data residual, disable the WLAN roaming center before you change the port number.
# Configure the WLAN roaming center to use port 60015 to communicate with portal roaming centers and client roaming centers.
[sysname] wlan roaming-center
[Sysname-wlan-roaming-center] port 60015
Use reset wlan roaming-center history user to clear client history information on the WLAN roaming center.
reset wlan roaming-center history user { all | ip ipv4-address | ipv6 ipv6-address | mac mac-address }
# Clear history information about all clients on the WLAN roaming center.
<Sysname> reset wlan roaming-center history user all
reset wlan roaming-center statistics packet
Use reset wlan roaming-center statistics packet to clear packet statistics on the WLAN roaming center.
reset wlan roaming-center statistics packet [ bas-ip ipv4-address | bas-ipv6 ipv6-address ]
If you do not specify the bas-ip ipv4-address or the bas-ipv6 ipv6-address option, the command clears all packet statistics on the WLAN roaming center.
# Clear all packet statistics on the WLAN roaming center.
<Sysname> reset wlan roaming-center statistics packet
reset wlan roaming-center user
Use reset wlan roaming-center user to clear client information on the WLAN roaming center.
reset wlan roaming-center user { all | bas-ip ipv4-address | bas-ipv6 ipv6-address | ip ipv4-address | ipv6 ipv6-address | mac mac-address }
# Clear information about all clients on the WLAN roaming center.
<Sysname> reset wlan roaming-center user all
response-timeout
Use response-timeout to set the response timeout timer for packets to portal or client roaming centers.
Use undo response-timeout to restore the default.
response-timeout timeout
The response timeout timer is 3 seconds.
timeout: Specifies the timeout timer in the range of 1 to 10 seconds.
In inter-AC roaming, when a portal user goes offline, it informs the associated portal roaming center, which then informs the WLAN roaming center. Then, the WLAN roaming center informs the other portal roaming centers. If the WLAN roaming center fails to receive a response from a portal roaming center before the response timeout timer expires, it retransmits the packet. If it fails to receive any response from a portal roaming center after the last retransmission attempt, it deletes the timeout timer.
In a WLAN configured with WLAN address security, the WLAN roaming center sends requests to client roaming centers to query the aging time of MAC address and IP address entries. If it fails to receive a response before the response timeout timer expires, it deletes the specific MAC address and IP address entry.
# Set the response timeout timer to 2 seconds for packets to portal or client roaming centers.
[Sysname-wlan-roaming-center] response-timeout 2
retry
Use retry to set the maximum transmission attempts for user offline notification requests.
Use undo retry to restore the default.
retry retries
undo retry
The maximum number of transmission attempts for user offline notification requests is 5.
retries: Specifies the maximum number of packet transmission attempts in the range of 1 to 10.
After sending a user offline notification request to an AC, the WLAN roaming center resends the request if it fails to receive a response before the wait timer expires. If it fails to receive any response after the maximum transmission attempt limit is reached, the WLAN roaming center deletes the timeout timer and removes the AC from the access device list of the client.
# Set the maximum transmission attempts for user offline notification requests to 4.
[Sysname-wlan-roaming-center] retry 4
response-timeout
Use roaming-center enable to enable the WLAN roaming center.
Use undo roaming-center enable to disable the WLAN roaming center.
The WLAN roaming center feature is disabled.
For portal users to roam between ACs, you must enable portal roaming center on both ACs.
You can enable the WLAN roaming center on only one AC in a network.
Disabling the WLAN roaming center feature deletes all portal client information.
To use WLAN address security, you must enable the WLAN roaming center.
# Enable the WLAN roaming center.
[Sysname-wlan-roaming-center] roaming-center enable
spoofing-attack blacklist
Use spoofing-attack blacklist to add a client to the spoofing attack blacklist by username.
Use undo spoofing-attack blacklist to delete a client from the spoofing attack blacklist.
spoofing-attack blacklist username username
undo spoofing-attack blacklist username username
No clients exist in the spoofing attack blacklist.
Address security view
username username: Specifies the username of a user, a case-sensitive string of 1 to 55 characters. The name cannot be a, al, or all, and cannot contain domain names or the following special characters: \ | / : * ? < > @
With address security configured, the WLAN roaming center logs off both the detected MAC or IP address spoofing attackers and the spoofed clients, and adds the attackers to the blacklist. This prevents attackers from coming online again.
You can add a maximum of 5000 clients to the spoofing attack blacklist.
The spoofing attack blacklist takes effect only on the WLAN roaming center.
# Add the client with username user1 to the spoofing attack blacklist.
[Sysname] wlan address-security
[Sysname-wlan-address-security] spoofing-attack blacklist username user1
Use wlan address-security to create the address security view and enter the view.
Use undo wlan address-security to delete the address security view.
The address security view does not exist.
# Enter address security view.
wlan roaming-center
Use wlan roaming-center to create a WLAN roaming center and enter its view, or enter the view of an existing WLAN roaming center.
Use undo wlan roaming-center to delete the WLAN roaming center.
wlan roaming-center
No WLAN roaming center exists.
In inter-AC roaming of portal users, the WLAN roaming center stores and updates client information and provides query services for the information. Deleting the WLAN roaming center deletes all client roaming information.
In address security application, the WLAN roaming center checks online clients for MAC address and IP address spoofing and prevents attackers from coming online to enhance network security.
# Create a WLAN roaming center and enter its view.
