- 11-Network Management and Monitoring Configuration Guide
- 01-Information center configuration
- 02-Fast log output configuration
- 03-NetStream configuration
- 04-Mirroring configuration
- 05-Packet capture configuration
- 06-NQA configuration
- 07-Track configuration
- 08-BFD configuration
- 09-Interface backup configuration
- 10-System maintenance and debugging configuration
- 11-NTP configuration
- 12-EAA configuration
- 13-Process monitoring and maintenance configuration
- 14-NETCONF configuration
- 15-CWMP configuration
- 16-SNMP configuration
- 17-RMON configuration
- 18-Event MIB configuration
13-Process monitoring and maintenance configuration | 92.99 KB |
Monitoring and maintaining processes
About monitoring and maintaining processes
Process monitoring and maintenance tasks at a glance
Monitoring and maintaining user processes
About monitoring and maintaining user processes
Display and maintenance commands for user processes
Monitoring and maintaining kernel threads
Configuring kernel thread deadloop detection
Configuring kernel thread starvation detection
Display and maintenance commands for kernel threads
The system software of the device is a full-featured, modular, and scalable network operating system based on the Linux kernel. The system software features run the following types of independent processes:
· User process—Runs in user space. Most system software features run user processes. Each process runs in an independent space so the failure of a process does not affect other processes. The system automatically monitors user processes. The system supports preemptive multithreading. A process can run multiple threads to support multiple activities. Whether a process supports multithreading depends on the software implementation.
· Kernel thread—Runs in kernel space. A kernel thread executes kernel code. It has a higher security level than a user process. If a kernel thread fails, the system breaks down. You can monitor the running status of kernel threads.
To monitor and maintain processes, perform the following tasks:
· Monitoring and maintaining user processes
¡ Monitoring and maintaining processes
The commands in this section apply to both user processes and kernel threads.
¡ Monitoring and maintaining user processes
The commands in this section apply only to user processes.
· Monitoring and maintaining kernel threads
¡ Monitoring and maintaining kernel threads
The commands in this section apply only to kernel threads.
The commands in this section apply to both user processes and kernel threads. You can use the commands for the following purposes:
· Display the overall memory usage.
· Display the running processes and their memory and CPU usage.
· Locate abnormal processes.
If a process consumes excessive memory or CPU resources, the system identifies the process as an abnormal process.
· If an abnormal process is a user process, troubleshoot the process as described in "Monitoring and maintaining user processes."
· If an abnormal process is a kernel thread, troubleshoot the process as described in "Monitoring and maintaining kernel threads."
Execute the following commands in any view.
Task |
Command |
Display memory usage. (For more information about this command, see Fundamentals Command Reference.) |
CSAP-NTA-V200[V1000]: display memory [ summary ] CSAP-NTA-100[200][300][400][500][600][AK375]: display memory [ summary ] [ slot slot-number [ cpu cpu-number ] ] |
Display process state information. |
CSAP-NTA-V200[V1000]: display process [ all | job job-id | name process-name ] CSAP-NTA-100[200][300][400][500][600][AK375]: display process [ all | job job-id | name process-name ] [ slot slot-number [ cpu cpu-number ] ] |
Display CPU usage for all processes. |
CSAP-NTA-V200[V1000]: display process cpu CSAP-NTA-100[200][300][400][500][600][AK375]: display process cpu [ slot slot-number [ cpu cpu-number ] ] |
Monitor process running state. |
CSAP-NTA-V200[V1000]: monitor process [ dumbtty ] [ iteration number ] CSAP-NTA-100[200][300][400][500][600][AK375]: monitor process [ dumbtty ] [ iteration number ] [ slot slot-number [ cpu cpu-number ] ] |
Monitor thread running state. |
CSAP-NTA-V200[V1000]: monitor thread [ dumbtty ] [ iteration number ] CSAP-NTA-100[200][300][400][500][600][AK375]: monitor thread [ dumbtty ] [ iteration number ] [ slot slot-number [ cpu cpu-number ] ] |
Use this feature to monitor abnormal user processes and locate problems.
Configuring core dump
The core dump feature enables the system to generate a core dump file each time a process crashes until the maximum number of core dump files is reached. A core dump file stores information about the process. You can send the core dump files to H3C Support to troubleshoot the problems.
Core dump files consume storage resources. Enable core dump only for processes that might have problems.
Execute the following commands in user view:
1. (Optional.) Specify the directory for saving core dump files.
exception filepath directory
The directory for saving core dump files is the root directory of the default file system. For more information about the default file system, see file system management in Fundamentals Configuration Guide.
2. Enable core dump for a process and specify the maximum number of core dump files, or disable core dump for a process.
process core { maxcore value | off } { job job-id | name process-name }
By default, a process generates a core dump file for the first exception and does not generate any core dump files for subsequent exceptions.
Execute display commands in any view and other commands in user view.
Task |
Command |
Display context information for process exceptions. |
CSAP-NTA-V200[V1000]: display exception context [ count value ] CSAP-NTA-100[200][300][400][500][600][AK375]: display exception context [ count value ] [ slot slot-number [ cpu cpu-number ] ] |
Display the core dump file directory. |
CSAP-NTA-V200[V1000]: display exception filepath
display exception filepath [ slot slot-number [ cpu cpu-number ] ] |
Display log information for all user processes. |
CSAP-NTA-V200[V1000]: display process log CSAP-NTA-100[200][300][400][500][600][AK375]: display process log [ slot slot-number [ cpu cpu-number ] ] |
Display memory usage for all user processes. |
CSAP-NTA-V200[V1000]: display process memory CSAP-NTA-100[200][300][400][500][600][AK375]: display process memory [ slot slot-number [ cpu cpu-number ] ] |
Display heap memory usage for a user process. |
CSAP-NTA-V200[V1000]: display process memory heap job job-id [ verbose ] CSAP-NTA-100[200][300][400][500][600][AK375]: display process memory heap job job-id [ verbose ] [ slot slot-number [ cpu cpu-number ] ] |
Display memory content starting from a specified memory block for a user process. |
CSAP-NTA-V200[V1000]: display process memory heap job job-id address starting-address length memory-length CSAP-NTA-100[200][300][400][500][600][AK375]: display process memory heap job job-id address starting-address length memory-length [ slot slot-number [ cpu cpu-number ] ] |
Display the addresses of memory blocks with a specified size used by a user process. |
CSAP-NTA-V200[V1000]: display process memory heap job job-id size memory-size [ offset offset-size ] CSAP-NTA-100[200][300][400][500][600][AK375]: display process memory heap job job-id size memory-size [ offset offset-size ] [ slot slot-number [ cpu cpu-number ] ] |
Clear context information for process exceptions. |
CSAP-NTA-V200[V1000]: reset exception context CSAP-NTA-100[200][300][400][500][600][AK375]: reset exception context [ slot slot-number [ cpu cpu-number ] ] |
Kernel threads share resources. If a kernel thread monopolizes the CPU, other threads cannot run, resulting in a deadloop.
This feature enables the device to detect deadloops. If a thread occupies the CPU for a specific interval, the device determines that a deadloop has occurred, logs the event, and reboots to remove the deadloop.
Change kernel thread deadloop detection settings only under the guidance of H3C Support. Inappropriate configuration can cause system breakdown. As a best practice, leave the default unchanged.
1. Enter system view.
2. Enable kernel thread deadloop detection.
monitor kernel deadloop enable [ cpu cpu-number [ core core-number&<1-64> ] ]
monitor kernel deadloop enable [ slot slot-number [ cpu cpu-number [ core core-number&<1-64> ] ] ]
By default, kernel thread deadloop detection is enabled.
3. (Optional.) Set the interval for identifying a kernel thread deadloop.
monitor kernel deadloop time time
monitor kernel deadloop time time [ slot slot-number [ cpu cpu-number ] ]
By default, the threshold for identifying a kernel thread deadloop is 28 seconds.
4. (Optional.) Exclude a kernel thread from kernel thread deadloop detection.
monitor kernel deadloop exclude-thread tid
monitor kernel deadloop exclude-thread tid [ slot slot-number [ cpu cpu-number ] ]
When enabled, kernel thread deadloop detection monitors all kernel threads by default.
5. Set kernel thread deadloop protection thresholds.
monitor kernel deadloop action threshold threshold
monitor kernel deadloop action threshold threshold [ slot slot-number [ cpu cpu-number ] ]
By default, the kernel thread deadloop protection threshold is 1. The device takes protection actions immediately after detecting a kernel thread deadloop.
When the number of detected kernel thread deadloops reaches the kernel thread deadloop protection threshold, the device takes protection actions to remove the deadloops.
Starvation occurs when a thread is unable to access shared resources.
Kernel thread starvation detection enables the system to detect and report thread starvation. If a thread is not executed within a specific interval, the system determines that a starvation has occurred and generates a starvation message.
Thread starvation does not impact system operation. A starved thread can automatically run when certain conditions are met.
Configure kernel thread starvation detection only under the guidance of H3C Support. Inappropriate configuration can cause system breakdown. As a best practice, leave the default unchanged.
2. Enable kernel thread starvation detection.
monitor kernel starvation enable
monitor kernel starvation enable [ slot slot-number [ cpu cpu-number ] ]
By default, kernel thread starvation detection is disabled.
3. (Optional.) Set the interval for identifying a kernel thread starvation.
monitor kernel starvation time time
monitor kernel starvation time time [ slot slot-number [ cpu cpu-number ] ]
By default, the threshold for identifying a kernel thread starvation is 120 seconds.
4. (Optional.) Exclude a kernel thread from kernel thread starvation detection.
monitor kernel starvation exclude-thread tid
monitor kernel starvation exclude-thread tid [ slot slot-number [ cpu cpu-number ] ]
When enabled, kernel thread starvation detection monitors all kernel threads by default.
Task |
Command |
Display kernel thread deadloop detection configuration. |
CSAP-NTA-V200[V1000]: display kernel deadloop configuration CSAP-NTA-100[200][300][400][500][600][AK375]: display kernel deadloop configuration [ slot slot-number [ cpu cpu-number ] ] |
Display kernel thread deadloop information. |
CSAP-NTA-V200[V1000]: display kernel deadloop show-number [ offset ] [ verbose ] CSAP-NTA-100[200][300][400][500][600][AK375]: display kernel deadloop show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ] |
Display kernel thread exception information. |
CSAP-NTA-V200[V1000]: display kernel exception show-number [ offset ] [ verbose ] CSAP-NTA-100[200][300][400][500][600][AK375]: display kernel exception show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ] |
Display kernel thread reboot information. |
CSAP-NTA-V200[V1000]: display kernel reboot show-number [ offset ] [ verbose ] CSAP-NTA-100[200][300][400][500][600][AK375]: display kernel reboot show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ] |
Display kernel thread starvation detection configuration. |
CSAP-NTA-V200[V1000]: display kernel starvation configuration CSAP-NTA-100[200][300][400][500][600][AK375]: display kernel starvation configuration [ slot slot-number [ cpu cpu-number ] ] |
Display kernel thread starvation information. |
CSAP-NTA-V200[V1000]: display kernel starvation show-number [ offset ] [ verbose ] CSAP-NTA-100[200][300][400][500][600][AK375]: display kernel starvation show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ] |
Clear kernel thread deadloop information. |
CSAP-NTA-V200[V1000]: reset kernel deadloop CSAP-NTA-100[200][300][400][500][600][AK375]: reset kernel deadloop [ slot slot-number [ cpu cpu-number ] ] |
Clear kernel thread exception information. |
CSAP-NTA-V200[V1000]: reset kernel exception CSAP-NTA-100[200][300][400][500][600][AK375]: reset kernel exception [ slot slot-number [ cpu cpu-number ] ] |
Clear kernel thread reboot information. |
CSAP-NTA-V200[V1000]: reset kernel reboot CSAP-NTA-100[200][300][400][500][600][AK375]: reset kernel reboot [ slot slot-number [ cpu cpu-number ] ] |
Clear kernel thread starvation information. |
CSAP-NTA-V200[V1000]: reset kernel starvation CSAP-NTA-100[200][300][400][500][600][AK375]: reset kernel starvation [ slot slot-number [ cpu cpu-number ] ] |
