12-VPN Instance Command Reference
HomeSupportSecurityH3C SecCenter CSAP-NTAReference GuidesCommand ReferencesH3C SecCenter CSAP-NTA Probe Appliance Series Comware 7 Command References-6W60012-VPN Instance Command Reference
01-VPN instance commands
01-VPN instance commands 43.52 KB
description (VPN instance view)
Use description to configure a description for a VPN instance.
No description is configured for a VPN instance.
VPN instance view
context-admin
text: Configures the description for the VPN instance, a case-sensitive string of 1 to 79 characters.
# Set the description for VPN instance vpn1 to This is vpn1.
[Sysname-vpn-instance-vpn1] description This is vpn1
display ip vpn-instance
Use display ip vpn-instance to display VPN instance information.
display ip vpn-instance [ instance-name vpn-instance-name ]
context-admin
context-operator
instance-name vpn-instance-name: Specifies a VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays brief information about all VPN instances.
# Display brief information about all VPN instances.
<Sysname> display ip vpn-instance
  VPN-Instance Name               RD                     Create time
  management                      1000000000:1           2016/10/31
VPN-Instance Name
Name of the VPN instance.
RD
Route distinguisher of the VPN instance.
Create time
Time when the VPN instance was created.
ip binding vpn-instance
Use ip binding vpn-instance to associate an interface with a VPN instance.
Use undo ip binding vpn-instance to restore the default.
An interface is not associated with a VPN instance and belongs to the public network.
Interface view
context-admin
This command or its undo form clears the IP address and routing protocol configuration on the interface. You must reconfigure the IP address and routing protocol for the interface after executing this command. To view the configuration of an interface, execute the display this command in interface view.
The specified VPN instance must have been created by using the ip vpn-instance command in system view.
To associate a new VPN instance with an interface, first execute the undo ip binding vpn-instance command to remove the existing association.
# Associate interface GigabitEthernet 1/0/1 with VPN instance vpn1.
[Sysname-GigabitEthernet1/0/1] ip binding vpn-instance vpn1
ip vpn-instance (system view)
Use ip vpn-instance to create a VPN instance and enter its view, or enter the view of an existing VPN instance.
Use undo ip vpn-instance to delete a VPN instance.
No VPN instances exist.
context-admin
vpn-instance-name: Specifies a name for the VPN instance, a case-sensitive string of 1 to 31 characters.
# Create VPN instance vpn1 and enter its view.
