07-Layer 3—IP Services Command Reference
HomeSupportSecurityH3C SecCenter CSAP-NTAReference GuidesCommand ReferencesH3C SecCenter CSAP-NTA Probe Appliance Series Comware 7 Command References-6W60007-Layer 3—IP Services Command Reference
12-Adjacency table commands
12-Adjacency table commands 58.14 KB
IPv4 adjacency table commands
display adjacent-table
Use display adjacent-table to display IPv4 adjacency entries.
CSAP-NTA-V200[V1000]:
display adjacent-table { all | physical-interface interface-type interface-number | routing-interface interface-type interface-number } [ count | verbose ]
CSAP-NTA-100[200][300][400][500][600][AK375]:
display adjacent-table { all | physical-interface interface-type interface-number | routing-interface interface-type interface-number | slot slot-number } [ count | verbose ]
View
all: Displays all IPv4 adjacency entries.
physical-interface interface-type interface-number: Displays IPv4 adjacency entries about the specified physical interface.
routing-interface interface-type interface-number: Displays IPv4 adjacency entries about the specified routing interface.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv4 adjacency entries for all member devices. (CSAP-NTA-100[200][300][400][500][600][AK375])
count: Displays the number of IPv4 adjacency entries.
verbose: Displays detailed information about IPv4 adjacency entries.
# Display detailed information about all IPv4 adjacency entries.
<Sysname> display adjacent-table all verbose
   IP address                        : 0.0.0.0
   Routing interface                : Tunnel1
   Physical interface               : Tunnel1
   Logical interface                : N/A
   Service type                      : Tunnel
   Action type                       : Forwarding
   Link media type                  : P2P
   Slot                               : 0
   Cpu                                : 0
   VPN index                         : 0
   Virtual circuit information   : N/A
   Link head information(IP)      : 4500000000000000ff2f000002020201020202020000
                                   0800
   Link head information(MPLS)   : 4500000000000000ff2f000002020201020202020000
                                   0800
# Display IPv4 adjacency entries for the specified slot.
<Sysname> display adjacent-table slot 1
IP address        Routing interface         Physical interface      Type
0.0.0.0           Tun1                         Tun1                       Tunnel
# Display the number of IPv4 adjacency entries for the specified slot.
<Sysname> display adjacent-table slot 1 count
 Total entries on slot 1: 1
IP address
IP address of the next hop.
·     For a P2P link, the IP address of the next hop is not needed. This field displays 0.0.0.0.
·     For an NBMA link, the value 0.0.0.0 indicates the default adjacency entry. Packets are forwarded through the default virtual circuit.
Routing interface
Output interface of the matching route entry.
Physical interface
Physical interface of which the outgoing packets are sent out.
Logical interface
Logical interface for sending the packets. If the entry has no logical interface, this field displays N/A.
Service type/Type
Link layer protocol type.
Action type
Packet processing type, Forwarding or Drop.
Link media type
Link media type:
·     P2P—Point-to-point link.
·     NBMA—Non-broadcast multi-access link.
Cpu
Number of the CPU.
VPN index
Index of the VPN.
Information about the virtual circuit, such as PVC or DLCI. If the entry has no virtual circuit, this field displays N/A.
Link layer header for IPv4.
Link layer header for MPLS.
IPv6 adjacency table commands
display ipv6 adjacent-table
Use display ipv6 adjacent-table to display IPv6 adjacency entries.
display ipv6 adjacent-table { all | physical-interface interface-type interface-number | routing-interface interface-type interface-number } [ count | verbose ]
display ipv6 adjacent-table { all | physical-interface interface-type interface-number | routing-interface interface-type interface-number | slot slot-number } [ count | verbose ]
all: Displays all IPv6 adjacency entries.
physical-interface interface-type interface-number: Displays IPv6 adjacency entries about the specified physical interface.
routing-interface interface-type interface-number: Displays IPv6 adjacency entries about the specified routing interface.
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6 adjacency entries for all member devices. (CSAP-NTA-100[200][300][400][500][600][AK375])
count: Displays the number of IPv6 adjacency entries.
verbose: Displays detailed information about IPv6 adjacency entries.
# Display detailed information about all IPv6 adjacency entries.
<Sysname> display ipv6 adjacent-table all verbose
   IPv6 address                    : N/A
   Slot                              : 1
   Cpu                                : 0
   VPN index                         : 0
   Link head information(IPv6)   : 4500000000000000ff2f000002020201020202020000
                                   86dd
                                   86dd
# Display IPv6 adjacency entries for the specified slot.
<Sysname> display ipv6 adjacent-table slot 1
IPv6 address          Routing interface     Physical interface    Type
N/A                     Tun1                     Tun1                    Tunnel
# Display the number of IPv6 adjacency entries for the specified slot.
<Sysname> display ipv6 adjacent-table slot 1 count
IPv6 address
IPv6 address of the next hop.
·     For a P2P link, the IPv6 address of the next hop is not needed. This field has the value 0::0, and displays N/A.
·     For an NBMA link, the value 0.0.0.0 indicates a default adjacency table. Packets are forwarded through the default virtual circuit.
Routing interface
Physical interface
Logical interface
Logical interface that sends the packets. If the entry has no logical interface, this field displays N/A.
Service type/Type
Action type
Link media type
Link media type:
Cpu
Number of the CPU.
VPN index
Index of the VPN.
Link layer header for IPv6.
