07-Layer 3—IP Services Command Reference
HomeSupportSecurityH3C SecCenter CSAP-NTAReference GuidesCommand ReferencesH3C SecCenter CSAP-NTA Probe Appliance Series Comware 7 Command References-6W60007-Layer 3—IP Services Command Reference
11-Multi-CPU packet distribution commands
11-Multi-CPU packet distribution commands 40.79 KB
The following compatibility matrix shows the support of hardware platforms for multi-CPU packet distribution:
Hardware
Multi-CPU packet distribution compatibility
CSAP-NTA-100, CSAP-NTA-200, CSAP-NTA-AK375
No
CSAP-NTA-300, CSAP-NTA-400, CSAP-NTA-500, CSAP-NTA-600
Yes
CSAP-NTA-V200, CSAP-NTA-V1000
Yes
forwarding policy
Use forwarding policy to specify a multi-CPU packet distribution policy.
Use undo forwarding policy to restore the default.
forwarding policy { per-flow [ three-tuple | mode { source-ip | destination-ip | source-port | destination-port } ] | per-packet }
The device uses the flow-based policy that identifies a flow by source IP address, destination IP address, source port number, destination port number, and protocol number.
per-flow: Specifies the flow-based forwarding. The device forwards packets of the same flow to the same CPU. The device identifies a data flow by source IP address, destination IP address, source port number, destination port number, and protocol number. The CPU processes flow packets by following the first-in first-out rule.
three-tuple: Identifies a data flow by the three-tuple (source IP address, destination IP address, and protocol number). If you do not specify this keyword, the device identifies a data flow by the five-tuple.
The following compatibility matrixes show the support of hardware platforms for this keyword:
Hardware
Parameter compatibility
No
Yes
No
mode: Specifies a flow-based forwarding mode.
source-ip: Identifies a flow by source IP address.
destination-ip: Identifies a flow by destination IP address.
source-port: Identifies a flow by source port.
destination-port: Identifies a flow by destination port.
The following compatibility matrixes show the support of hardware platforms for the mode keyword:
Hardware
No
Yes
No
per-packet: Specifies the packet-based forwarding. The device forwards packets in sequence to different CPUs, even though they are the same flow. This policy does not ensure packet order.
If you do not specify any keyword for flow identification, the device identifies a flow by source IP address, destination IP address, source port number, destination port number, and protocol number.
# Specify the flow-based policy.
[Sysname] forwarding policy per-flow
