06-Layer 2—LAN Switching Command Reference
HomeSupportSecurityH3C SecCenter CSAP-NTAReference GuidesCommand ReferencesH3C SecCenter CSAP-NTA Probe Appliance Series Comware 7 Command References-6W60006-Layer 2—LAN Switching Command Reference
01-MAC address table commands
01-MAC address table commands 90.28 KB
display mac-address
Use display mac-address to display MAC address entries.
display mac-address [ mac-address [ vlan vlan-id ] | [ [ dynamic | static ] [ interface interface-type interface-number ] | blackhole ] [ vlan vlan-id ] [ count ] ]
mac-address: Specifies a MAC address in the format of H-H-H. When entering a MAC address, you can omit the leading zeros in each H section. For example, enter f-e2-1 for 000f-00e2-0001.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
dynamic: Displays dynamic MAC address entries.
static: Displays static MAC address entries.
blackhole: Displays blackhole MAC address entries.
count: Displays only the number of MAC address entries that match all entry attributes you specify in the command. Detailed information about MAC address entries is not displayed. For example, you can use the display mac-address vlan 20 dynamic count command to display the number of dynamic entries for VLAN 20. If you do not specify an entry attribute, the command displays the number of entries in the MAC address table. If you do not specify this keyword, the command displays detailed information about the specified MAC address entries.
Use this command to display static, dynamic, or blackhole MAC address entries. A MAC address entry includes a destination MAC address, an outgoing interface, and a VLAN ID.
If you do not specify any parameters, the command displays all MAC address entries.
This command displays dynamic MAC address entries for an aggregate interface only when the aggregate interface has a minimum of one Selected member port.
# Display MAC address entries for VLAN 100.
<Sysname> display mac-address vlan 100
MAC Address      VLAN ID    State            Port/Nickname            Aging
0033-0033-0033   100        Blackhole        N/A                      N
0000-0000-0002   100        Static           GE1/0/3                  N
00e0-fc00-5829   100        Learned          GE1/0/4                  Y
# Display the number of MAC address entries.
<Sysname> display mac-address count
1 mac address(es) found.
VLAN ID
ID of the VLAN to which the outgoing interface of the MAC address entry belongs.
MAC address entry state:
·     Static—Static MAC address entry.
·     Learned—Dynamic MAC address entry. Dynamic entries can be learned or manually configured.
·     Blackhole—Blackhole MAC address entry.
·     Drop aging—MAC address entry that can age out. Packets from this MAC address are dropped.
·     Drop no-aging—MAC address entry that cannot age out. Packets from this MAC address are dropped.
·     Vlan-interface—MAC address entry of a VLAN interface.
Port/Nickname
When the field displays an interface name, the field indicates the outgoing interface for packets that are destined for the MAC address. This field displays N/A for a blackhole MAC address entry.
The Nickname field is not supported in the current software version.
Aging
Whether the entry can age out:
·     Y—The entry can age out.
·     N—The entry never ages out.
Number of matching MAC address entries.
mac-address
mac-address timer
display mac-address aging-time
Use display mac-address aging-time to display the aging timer for dynamic MAC address entries.
# Display the aging timer for dynamic MAC address entries.
<Sysname> display mac-address aging-time
MAC address aging time: 300s.
mac-address timer
display mac-address mac-learning
Use display mac-address mac-learning to display the global MAC address learning status and the MAC learning status of the specified interface or all interfaces.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, the command displays the global MAC address learning status and the MAC address learning status of all interfaces.
# Display the global MAC address learning status and the MAC learning status of all interfaces.
<Sysname> display mac-address mac-learning
Global MAC address learning status: Enabled.
Port                         Learning Status
GE1/0/1                     Enabled
GE1/0/2                     Enabled
·     Enabled.
·     Disabled.
Learning Status
MAC address learning status of an interface:
·     Enabled.
·     Disabled.
mac-address mac-learning enable
mac-address (interface view)
Use mac-address to add or modify a MAC address entry on an interface.
Use undo mac-address to delete a MAC address entry on an interface.
Layer 2 Ethernet interface view and Layer 2 aggregate interface view:
mac-address { dynamic | static } mac-address vlan vlan-id
undo mac-address { dynamic | static } mac-address vlan vlan-id
An interface is not configured with MAC address entries.
dynamic: Specifies dynamic MAC address entries.
static: Specifies static MAC address entries.
mac-address: Specifies a MAC address in the format of H-H-H, excluding multicast, all-zero, and all-F MAC addresses. When entering a MAC address, you can omit the leading zeros in each H section. For example, enter f-e2-1 for 000f-00e2-0001.
vlan vlan-id: Specifies an existing VLAN to which the specified interface belongs. The value range for the vlan-id argument is 1 to 4094.
Typically, the device automatically builds the MAC address table by learning the source MAC addresses of incoming frames on each interface. However, you can manually configure static MAC address entries. For a MAC address, a manually configured static entry takes precedence over a dynamically learned entry. To improve the security for the user device connected to an interface, manually configure a static entry to bind the user device to the interface. Then, the frames destined for the user device (for example, Host A) are always sent out of the interface. Other hosts using the forged MAC address of Host A cannot obtain the frames destined for Host A.
The MAC address entry configuration cannot survive a reboot unless you save it. The dynamic MAC address entries, however, are lost upon reboot whether or not you save the configuration.
# Add a static entry for MAC address 000f-e201-0101 on GigabitEthernet 1/0/1 that belongs to VLAN 2.
[Sysname-GigabitEthernet1/0/1] mac-address static 000f-e201-0101 vlan 2
# Add a static entry for MAC address 000f-e201-0101 on Bridge-Aggregation 1 that belongs to VLAN 1.
[Sysname-Bridge-Aggregation1] mac-address static 000f-e201-0102 vlan 1
display mac-address
mac-address (system view)
Use mac-address to add or modify a MAC address entry.
Use undo mac-address to delete one or all MAC address entries.
undo mac-address [ [ dynamic | static ] mac-address interface interface-type interface-number vlan vlan-id ]
undo mac-address [ blackhole | dynamic | static ] [ mac-address ] vlan vlan-id
undo mac-address [ dynamic | static ] interface interface-type interface-number
The system is not configured with MAC address entries.
blackhole: Specifies blackhole MAC address entries. Packets whose source or destination MAC addresses match blackhole MAC address entries are dropped.
vlan vlan-id: Specifies an existing VLAN to which the interface belongs. The value range for the vlan-id argument is 1 to 4094.
interface interface-type interface-number: Specifies an outgoing interface by its type and number.
You can use this command to configure the following types of MAC address entries:
·     Dynamic entries.
Dynamic entries include manually configured dynamic entries and automatically learned dynamic entries.
·     Static entries.
For a MAC address, a manually configured static entry takes precedence over a dynamic entry. To improve the security for the user device connected to an interface, manually configure a static entry to bind the user device to the interface. Then, the frames destined for the user device (for example, Host A) are always sent out of the interface. Other hosts using the forged MAC address of Host A cannot obtain the frames destined for Host A.
·     Blackhole entries.
To drop frames with the specified source MAC addresses or destination MAC addresses, you can configure blackhole entries.
A static or blackhole entry can overwrite a dynamic entry, but not vice versa.
If you execute the undo mac-address command without specifying any parameters, this command deletes all unicast MAC address entries and static multicast MAC address entries.
You can delete all the MAC address entries (including unicast and static multicast MAC address entries) from the specified VLAN. You can also delete only one type (dynamic, static, or blackhole) of MAC address entries. You can single out an interface and delete the unicast MAC address entries on it, but not the static multicast MAC address entries.
# Add a static entry for MAC address 000f-e201-0101. Then, all frames that are destined for this MAC address are sent out of GigabitEthernet 1/0/1, which belongs to VLAN 2.
[Sysname] mac-address static 000f-e201-0101 interface gigabitethernet 1/0/1 vlan 2
display mac-address
Use mac-address mac-learning enable to enable MAC address learning globally, on an interface, or on a VLAN.
Use undo mac-address mac-learning enable to disable MAC address learning globally, on an interface, or on a VLAN.
MAC address learning is enabled.
VLAN view
To prevent the MAC address table from becoming saturated, you can disable MAC address learning.
For example, a number of packets with different source MAC addresses reaching a device can affect the MAC address table update. To avoid such attacks, you can disable MAC address learning by following these guidelines:
·     You can disable MAC address learning on a per-interface basis. If you disable MAC address learning globally, MAC address learning is disabled for all interfaces. The device then stops learning MAC addresses and cannot dynamically update the MAC address table.
·     Because disabling MAC address learning can result in broadcast storms, enable broadcast storm suppression after you disable MAC address learning on an interface. For more information about broadcast storm suppression, see Interface Configuration Guide.
·     With MAC address learning enabled globally, you can disable MAC address learning for an interface.
·     After MAC address learning is disabled, existing dynamic MAC address entries can age out.
# Disable MAC address learning globally.
[Sysname] undo mac-address mac-learning enable
# Disable MAC address learning on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] undo mac-address mac-learning enable
mac-address mac-learning priority
Use mac-address mac-learning priority to assign MAC learning priority to an interface.
Use undo mac-address mac-learning priority to restore the default.
mac-address mac-learning priority { high | low }
Low MAC address learning priority is used.
high: Assigns high MAC learning priority.
low: Assigns low MAC learning priority.
The MAC address learning priority values can be high and low. An interface with high MAC address learning priority can learn any MAC address. An interface with low MAC address learning priority can learn only the MAC addresses that have not been learned by high-priority interfaces.
The MAC learning priority mechanism can help defend your network against MAC address spoofing attacks. To prevent the downlink interface from learning the MAC address of an upper layer device (for example, the gateway), you can perform the following tasks:
·     Assign high MAC learning priority to an uplink interface.
·     Assign low MAC learning priority to a downlink interface.
# Assign high MAC learning priority to GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] mac-address mac-learning priority high
# Assign high MAC learning priority to Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] mac-address mac-learning priority high
mac-address max-mac-count (interface view)
Use mac-address max-mac-count to set the MAC learning limit on an interface.
Use undo mac-address max-mac-count to restore the default.
The maximum number of MAC addresses that an interface can learn is restricted by hardware capability of the device.
count: Specifies the maximum number of MAC addresses that can be learned on an interface. When the argument is set to 0, the interface is not allowed to learn MAC addresses.
The following compatibility matrix shows the value ranges for this argument:
Model
Value range
CSAP-NTA-100, CSAP-NTA-200, CSAP-NTA-AK375
0 to 4096
CSAP-NTA-300, CSAP-NTA-400, CSAP-NTA-500, CSAP-NTA-600
0 to 4096
CSAP-NTA-V200, CSAP-NTA-V1000
0 to 1024
This command helps limit the MAC address table size. When the number of MAC address entries learned by an interface reaches the limit, the interface stops learning MAC address entries.
# Configure GigabitEthernet 1/0/1 to learn a maximum of 200 MAC address entries.
[Sysname-GigabitEthernet1/0/1] mac-address max-mac-count 200
mac-address
mac-address max-mac-count enable-forwarding (interface view)
Use mac-address max-mac-count enable-forwarding to enable the device to forward unknown frames received on an interface after the MAC learning limit on the interface is reached. Unknown frames refer to frames whose source MAC addresses are not in the MAC address table.
Use undo mac-address max-mac-count enable-forwarding to disable the device from forwarding unknown frames received on an interface after the MAC learning limit on the interface is reached.
When the MAC learning limit on an interface is reached, the device can forward unknown frames received on the interface.
# Disable the device from forwarding unknown frames received on GigabitEthernet 1/0/1 after the MAC learning limit on GigabitEthernet 1/0/1 is reached.
[Sysname-GigabitEthernet1/0/1] undo mac-address max-mac-count enable-forwarding
mac-address
mac-address timer
Use mac-address timer to set the aging timer for dynamic MAC address entries.
Use undo mac-address timer to restore the default.
The aging timer is 300 seconds for dynamic MAC address entries.
aging seconds: Specifies an aging timer for dynamic MAC address entries, in seconds. The value range for the seconds argument is 10 to 1400.
no-aging: Configures dynamic MAC address entries not to age.
To set the aging timer appropriately, follow these guidelines:
·     A long aging interval causes the MAC address table to retain outdated entries and fail to accommodate the most recent network changes.
·     A short aging interval results in removal of valid entries. Then, unnecessary broadcast packets appear and affect device performance.
# Set the aging time to 500 seconds for dynamic MAC address entries.
snmp-agent trap enable mac-address
Use snmp-agent trap enable mac-address to enable SNMP notifications for the MAC address table.
Use undo snmp-agent trap enable mac-address to disable SNMP notifications for the MAC address table.
SNMP notifications are enabled for the MAC address table.
To report critical MAC address move events to an NMS, enable SNMP notifications for the MAC address table. For MAC address move event notifications to be sent correctly, you must also configure SNMP on the device.
When SNMP notifications are disabled for the MAC address table, the device sends the generated logs to the information center. To display the logs, configure the log destination and output rule configuration in the information center.
For information about SNMP and information center configuration, see the network management and monitoring configuration guide for the device.
The MAC address table supports only SNMP notifications about MAC address moves. When you enable or disable SNMP notifications about MAC address moves, you enable or disable all types of SNMP notifications for the MAC address table.
# Disable SNMP notifications for the MAC address table.
[Sysname] undo snmp-agent trap enable mac-address
