06-Network
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath IPS Comware 7 Web-Based Configuration Guide(R8X60)-6W60006-Network
29-IPv6 whitelist
29-IPv6 whitelist 17.86 KB
IPv6 whitelist
Introduction
The IPv6 whitelist is used during the IP authentication. When the IPv6 address of a user is on the IPv6 whitelist, the user can directly pass authentication without being authenticated by the authentication server.
Configure the IPv6 whitelist
1.     Click the Network tab.
2.     In the navigation pane, select Security Access > IP Access > IPv6 Whitelist.
3.     Click Create. The Create IPv6 Whitelist page opens.
4.     Add an IPv6 whitelist user to the IPv6 whitelist.
Table 1 IPv6 whitelist user configuration items
Item
Select a device interface through the whitelist user accesses the network.
IPv6 address
Configure the IPv6 address of the whitelist user.
ISP domain
Configure the ISP domain used by the whitelist user. The authentication server must be set to none for the ISP domain.
Configure the description of the whitelist user.
5.     Click OK.
