- 06-Network
- 01-Scanner
- 02-VRF
- 03-Interface
- 04-Interface pairs
- 05-Interface collaboration
- 06-Security zones
- 07-VLAN
- 08-MAC
- 09-DNS
- 10-ARP
- 11-ND
- 12-Forwarding advanced settings
- 13-Routing table
- 14-Static routing
- 15-Policy-based routing
- 16-OSPF
- 17-RIP
- 18-HTTP
- 19-SSH
- 20-NTP
- 21-FTP
- 22-Telnet
- 23-MAC authentication
- 24-MAC address whitelist
- 25-MAC access silent MAC info
- 26-MAC access advanced settings
- 27-IP authentication
- 28-IPv4 whitelist
- 29-IPv6 whitelist
| 14-Static routing | 12.80 KB |
Static routing
Introduction
Static routes are manually configured. If a network's topology is simple, you only need to configure static routes for the network to work correctly.
Static routes cannot adapt to network topology changes. If a fault or a topological change occurs in the network, the network administrator must modify the static routes manually.
A default route is used to forward packets that do not match any specific routing entry in the routing table. You can configure a default IPv4 route with destination address 0.0.0.0/0 and configure a default IPv6 route with destination address ::/0.
