05-Objects
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath IPS Comware 7 Web-Based Configuration Guide(R8X60)-6W60005-Objects
06-Data filtering
06-Data filtering 145.99 KB
Data filtering
This help contains the following topics:
·     Introduction
¡     Basic concepts
¡     Data filtering mechanism
·     Restrictions and guidelines
¡     Restrictions and guidelines: Profile activation
¡     Restrictions and guidelines: Regular expression-based keyword match pattern configuration
·     Configure data filtering
¡     Configure a keyword group
¡     Configure a data filtering profile
Introduction
Data filtering filters packets based on application layer information. You can use data filtering to effectively prevent leakage of internal information, distribution of illegal information, and unauthorized access to the Internet.
Data filtering supports filtering packets of the following protocols:
·     HTTP.
·     FTP.
·     SMTP.
·     IMAP.
·     NFS.
·     POP3.
·     RTMP.
·     SMB.
Basic concepts
Keyword
The device provides a list of predefined keywords and allows you to create user-defined keywords in a keyword group.
·     Predefined keywordIncludes Phone, Bank card, Credit card, and ID card. These keywords can be used to identify packets that contain phone numbers, bank card numbers, credit card numbers, and ID card numbers.
·     User-defined keywordA text- or regular expression-based string to identify patterns in the application layer data of packets.
Keyword group
A keyword group is a group of up to 32 keywords. A packet matches a keyword group if it matches a keyword in the group. You can enable or disable predefined keywords and create new keywords in a keyword group.
Data filtering rule
A data filtering rule contains a set of packet filtering criteria and the actions for matching packets. The packet filtering criteria include keyword group, direction (Upload, Download, or Both), and applications. The packet processing actions include Drop, Permit, and Logging. A packet must match all the filtering criteria for the actions specified for the rule to apply.
Upon receiving a packet of a protocol that data filtering supports, the device performs the following operations:
1.     Compares the packet with the security policies.
If the packet matches a security policy that is associated with a data filtering profile, the device extracts the application layer information from the packet.
2.     Determines the actions to take on the packet by comparing the extracted application layer information with the data filtering rules in the data filtering policy:
¡     If the packet does not match any data filtering rules in the policy, the device permits the packet to pass.
¡     If the packet matches only one rule, the device takes the actions specified for the rule.
¡     If the packet matches multiple rules, the device determines the actions as follows:
-     If the matching rules have both the permit and drop actions, the device takes the drop action.
-     If the logging action is specified for any of the matching rules, the device logs the packet.
After you create, edit, or delete a data filtering profile, the configuration must be activated to take effect. You can click Submit to activate the configuration immediately or the configuration will be activated automatically 40 seconds later by default. Activating the configuration causes transient DPI service interruption. DPI-based services might also be interrupted. For example, security policies cannot control access to applications.
·     The regular expression pattern can contain a maximum of four branches. For example, 'abc(c|d|e|\x3D)' is valid, and 'abc(c|onreset|onselect|onchange|style\x3D)' is invalid.
·     Nested braces are not allowed. For example, 'ab((abcs*?))' is invalid.
·     A branch cannot be specified after another branch. For example, 'ab(a|b)(c|d)^\\r\\n]+?' is invalid.
·     A minimum of four non-wildcard characters must exist before an asterisk (*) or question mark (?). For example, 'abc*' is invalid and 'abcd*DoS\x2d\d{5}\x20\x2bxi\\r\\nJOIN' is valid.
Configure data filtering as shown in Figure 1.
Figure 1 Data filtering configuration procedure
Perform this task to create a keyword group and configure keywords in the keyword group.
1.     Click the Objects tab.
2.     In the navigation pane, select APPSecurity > Data Filtering > Keyword Groups.
3.     On the page that appears, click Create.
4.     Create a keyword group.
Table 1 Keyword group configuration items
Item
Name
Enter a name for the keyword group.
Enter a description for the keyword group.
5.     In the Predefined keyword list area, select Enable for a predefined keyword. For example, to identify packets that contain phone numbers, select Enable for Phone.
6.     In the User-defined keyword list area, click Create.
7.     Create a keyword.
Table 2 Keyword configuration items
Item
Name
Enter a name for the keyword.
Select the type of the keyword match pattern. Options are:
·     Text—Select this option to configure a text-based match pattern for exact match.
·     Regular expression—Select this option to configure a regular expression-based match pattern for fuzzy match.
Match pattern
Enter the content of the keyword match pattern.
8.     Click OK.
The keyword is displayed on the user-defined keyword list.
You can add a maximum of 32 more keywords to the keyword group.
9.     Click OK.
The keyword group is displayed on the Keyword Groups page.
Perform this task to create a data filtering profile and configure data filtering rules in the profile.
2.     In the navigation pane, select APPSecurity > Data Filtering > Profiles.
4.     Create a data filtering profile.
Table 3 Data filtering profile configuration items
Item
Name
Enter a name for the data filtering profile.
Enter a description for the data filtering profile.
5.     In the Data filtering rules area, click Create.
6.     Create a data filtering rule.
Table 4 Data filtering rule configuration items
Item
Name
Enter a name for the data filtering rule.
Keyword group
Select an existing keyword group or create a keyword group.
Applications
Select the application layer protocols of the applications to which the rule applies. Supported application layer protocols are FTP, HTTP, IMAP, NFS, POP3, RTMP, SMB, and SMTP.
Direction
Select the traffic direction to which the rule applies. Options are Upload, Download, and Both.
Action
Select the action for matching packets. Options are Permit and Drop.
Logging
Select whether to enable logging for matching packets. Options are Enable and Disable.
7.     Click OK.
The data filtering rule is displayed on the data filtering rule list of the data filtering profile.
8.     Click OK.
The data filtering profile is displayed on the Data Filtering Profiles page.
9.     Use the data filtering profile in a security policy. For more information about security policies, see security policy online help.
10.     Click Submit to activate the configuration immediately or wait 40 seconds for the configuration to be activated automatically.
After you create a data filtering profile, the configuration must be activated to take effect. By default, the configuration will be activated automatically 40 seconds later.
