| 01-Text | 1.95 MB |
About the SeerEngine-DC controller
Hardware requirements for deployment on physical servers
Hardware requirements for deployment on VMs
Deployment procedure at a glance
Installing the Unified Platform
(Optional.) Configuring HugePages
Deploying the Unified Platform
Registering and installing licenses
Registering and installing licenses for the Unified Platform
Registering and installing licenses for the controller
Installing the activation file on the license server
Backing up and restoring the controller configuration
Upgrading the controller and DTN
Uninstalling SeerEngine-DC and DTN
Uninstalling the DTN component only
RDRS deployment procedure at a glance
Deploying the primary and backup sites
Configuring the RDRS settings for the controllers at the primary and backup sites
Deploying the third-party arbitration service
Uninstalling the third-party arbitration service
Upgrading the third-party arbitration service
Upgrading SeerEngine-DC to support RDRS
Cluster deployment over a Layer 3 network
Deploying the SeerEngine-DC controller at Layer 3
About cluster 2+1+1 deployment
SeerEngine-DC is a data center controller. Similar to a network operating system, the SeerEngine-DC controller drives SDN application development and allows operation of various SDN applications. It can control various resources on the network and provide interfaces for applications to enable specific network forwarding.
The controller has the following features:
· It supports OpenFlow 1.3 and provides built-in services and a device driver framework.
· It is a distributed platform with high availability and scalability.
· It provides extensible REST APIs and GUI.
· It can operate in standalone or cluster mode.
Preparing for installation
Server requirements
CAUTION: · To avoid unrecoverable system failures caused by unexpected power failures, use a storage controller that supports power fail protection on the servers and make sure a supercapacitor is in place. · The DTN component does not support RDRS. · In the RDRS mode, the primary and backup sites each require three servers. |
Controller cluster + DTN physical host deployment (x86, Intel64/AMD64 architecture)
Table 1 Hardware requirements for controller cluster + DTN physical host deployment (x86, Intel64/AMD64 architecture)
Item |
Requirements |
Controller node (standard configuration), 3 |
CPU |
16 cores, 2.0 GHz or above |
Memory |
128 GB or above |
Drive |
Select either of the following drive options: · Drive configuration option 1: ¡ System drive: 4 × 960 GB SSDs or 8 × 480 GB SSDs, RAID 10 (1920 GB or higher after RAID setup). ¡ etcd drive: 2 × 480 GB SSDs, RAID 1 (50 GB or higher after RAID setup). (Installation path: /var/lib/etcd.) ¡ Storage controller: 1 GB cache, installed with a power fail safeguard module. · Drive configuration option 2: ¡ System drive: 4 × 1200 GB or 8 × 600 GB 7.2K RPM or above HDDs, RAID 10 (1920 GB or higher after RAID setup). ¡ etcd drive: 2 × 600 GB 7.2K RPM or above HDDs configured in RAID 1 (50 GB or higher after RAID setup). (Installation path: /var/lib/etcd.) ¡ Storage controller: 1 GB cache, installed with a power fail safeguard module. |
Network interface |
· Non-bonding mode: 1 × 10 Gbps Ethernet port. To deploy vBGP, 3+3 RDRS system, or DTN, add a network interface separately for each of them. · Bonding mode: 2 × 10 Gbps Linux bonding interfaces. To deploy vBGP, 3+3 RDRS system, or DTN, add two network interfaces separately for each of them. |
Managed devices and servers |
Device: A maximum of 100. Server: A maximum of 2000. |
Controller node (high-end configuration), 3 |
CPU |
20 cores, 2.2 GHz or above |
Memory |
256 GB or above |
Drive |
Select either of the following drive options: · Drive configuration option 1: ¡ System drive: 4 × 960 GB SSDs or 8 × 480 GB SSDs, RAID 10 (1920 GB or higher after RAID setup). ¡ etcd drive: 2 × 480 GB SSDs, RAID 1 (50 GB or higher after RAID setup). (Installation path: /var/lib/etcd.) ¡ Storage controller: 1GB cache, installed with a power fail safeguard module. · Drive configuration option 2: ¡ System drive: 4 × 1200 GB or 8 × 600 GB 7.2K RPM or above HDDs, RAID 10 (1920 GB or higher after RAID setup). ¡ etcd drive: 2 × 600 GB 7.2K RPM or above HDDs configured in RAID 1 (50 GB or higher after RAID setup). (Installation path: /var/lib/etcd.) ¡ Storage controller: 1GB cache, installed with a power fail safeguard module. |
Network interface |
Device: A maximum of 300. Server: A maximum of 6000. |
DTN physical host (high-end configuration), number of simulated devices/80 |
CPU |
x86, Intel64/AMD64 20 cores 2.2 GHz or above Support for VX-T/VX-D |
Memory |
256 GB or above |
Drive |
Select either of the following drive options. · 2 × 960 GB SSDs + RAID 1 or 4 × 480 GB SSDs + RAID 10 (600 GB or higher after RAID setup). · 2 × 600 GB 7.2K RPM or above HDDs + RAID 1 (600 GB or higher after RAID setup). |
Network interface |
A minimum of 3, 1 to 10 Gbps. |
Simulated devices |
A maximum of 80 per server. |
DTN physical host (standard configuration), number of simulated devices/30 |
CPU |
x86, Intel64/AMD64 16 cores 2.0 GHz or above Support for VX-T/VX-D |
Memory |
128 GB or above |
Drive |
Select either of the following drive options: · 2 × 960 GB SSDs + RAID 1 or 4 × 480 GB SSDs + RAID 10 (600 GB or higher after RAID setup). · 2 × 600 GB 7.2K RPM or above HDDs + RAID 1 (600 GB or higher after RAID setup). |
Network interface |
Simulated devices |
A maximum of 30 per server. |
Remarks · To use the simulation feature, add 100GB or above memory for the server where the DTN component is deployed. · Deploy a DTN physical host only if you are to use the simulation feature. · To deploy the general_PLAT_kernel-region application package, one more CPU core and 6GB more memory are required. · To deploy the general_PLAT_network application package, three more CPU cores and 16GB more memory are required. |
Table 2 Hardware requirements for a controller in standalone mode + DTN physical host deployment (x86-Intel64/AMD64)
Item |
Requirements |
CPU |
Memory |
128 GB or above |
Drive |
Network interface |
· Non-bonding mode: 1 × 10 Gbps Ethernet port. To deploy the DTN component, add a network interface. · Bonding mode: 2 × 10 Gbps Linux bonding interfaces. To deploy the DTN component, add two network interfaces. |
· Device: A maximum of 36. · Server: A maximum of 600. |
CPU |
Memory |
256 GB or above |
Drive |
Network interface |
Simulated devices |
A maximum of 80 per sever. |
CPU |
Memory |
128 GB or above |
Drive |
Network interface |
Simulated devices |
A maximum of 30 per sever. |
CAUTION: · If a failure occurs on a controller in standalone mode, the services might be interrupted. As a best practice, configure a remote backup server for a controller in standalone mode. · A controller in standalone mode cannot be upgraded to operate in cluster mode, and does not support hybrid overlay, multi-fabric, security groups, QoS, or interoperation with CloudOS. |
Controller cluster deployment + DTN physical host deployment (Haiguang x86-64 server)
Table 3 Hardware requirements for controller cluster deployment (Haiguang x86-64 server)
Item |
Requirements |
CPU |
2 × Hygon C86 7265s 24 cores 2.2 GHz |
Memory |
128 GB or above |
Drive |
Select either of the following drive options: · Drive configuration option 1: ¡ System drive: 4 × 960 GB SSDs or 8 × 480 GB SSDs, RAID 10 (1920 GB or higher after RAID setup). ¡ etcd drive: 2 × 480 GB SSDs configured in RAID 1 (50 GB or higher after RAID setup). (Installation path: /var/lib/etcd.) ¡ Storage controller: 1GB cache, installed with a power fail safeguard module. · Drive configuration option 2: ¡ System drive: 4 × 1200 GB or 8 × 600 GB 7.2K RPM or above HDDs, RAID 10 (1920 GB or higher after RAID setup). ¡ etcd drive: 2 × 600 GB 7.2K RPM or above HDDs, RAID 1 (50 GB or higher after RAID setup). (Installation path: /var/lib/etcd.) ¡ Storage controller: 1GB cache, installed with a power fail safeguard module. |
Network interface |
· Non-bonding mode: 1 × 10 Gbps Ethernet port. To deploy vBGP or 3+3 RDRS system, add a network interface separately for each of them. · Bonding mode: 2 × 10 Gbps Linux bonding interfaces. To deploy vBGP or 3+3 RDRS system, add two network interfaces separately for each of them. |
· Device: A maximum of 100. · Server: A maximum of 2000. |
CPU |
2 × Hygon C86 7280s 32 cores 2.0 GHz |
Memory size |
256 GB or above |
Drive |
Select either of the following drive options: · Drive configuration option 1: ¡ System drive: 4 × 960 GB SSDs or 8 × 480 GB SSDs, RAID 10 (1920 GB or higher after RAID setup). ¡ etcd drive: 2 × 480 GB SSDs, RAID 1 (50 GB or higher after RAID setup). (Installation path: /var/lib/etcd.) ¡ Storage controller: 1GB cache, installed with a power fail safeguard module. · Drive configuration option 2: ¡ System drive: 4 × 1200 GB or 8 × 600 GB 7.2K RPM or above HDDs, RAID 10 (1920 GB or higher after RAID setup). ¡ etcd drive: 2 × 600 GB 7.2K RPM or above HDDs, RAID 1 (50 GB or higher after RAID setup). (Installation path: /var/lib/etcd.) ¡ Storage controller: 1GB cache, installed with a power fail safeguard module. |
Network interface |
· Device: A maximum of 300. · Server: A maximum of 6000. |
CPU |
x86, Intel64/AMD64 2*Hygon C86 7280 32 cores 2.0 GHz or above Support for VX-T/VX-D |
Memory |
256 GB or above |
Drive |
Network interface |
Simulated devices |
CPU |
x86, Intel64/AMD64 2*Hygon C86 7265 24 cores 2.2 GHz or above Support for VX-T/VX-D |
Memory |
128 GB or above |
Drive |
Network interface |
Simulated devices |
Controller cluster deployment (Kunpeng ARM server)
Kunpeng servers do not support DTN deployment.
Table 4 Hardware requirements for controller cluster deployment (Kunpeng ARM server)
Item |
Requirements |
CPU |
2 × Kunpeng 920s, 24 cores, 2.6 GHz |
Memory |
128 GB or above |
Drive |
Select one of the following drive options: · Drive configuration option 1: ¡ System drive: 4 × 960 GB SSDs or 8 × 480 GB SSDs, RAID 10 (1920 GB or higher after RAID setup). ¡ etcd drive: 2 × 480 GB SSDs, RAID 1 (50 GB or higher after RAID setup). (Installation path: /var/lib/etcd.) ¡ Storage controller: 1GB cache, installed with a power fail safeguard module. · Drive configuration option 2: ¡ System drive: 4 × 1200 GB or 8 × 600 GB 7.2K RPM or above HDDs, RAID 10 (1920 GB or higher after RAID setup). ¡ etcd drive: 2 × 600 GB 7.2K RPM or above HDDs, RAID 1 (50 GB or higher after RAID setup). (Installation path: /var/lib/etcd.) ¡ Storage controller: 1GB cache, installed with a power fail safeguard module. |
Network interface |
Controller node (high-end configuration), 3 in total |
CPU |
2 × Kunpeng 920s, 48 cores, 2.6 GHz |
Memory |
384 GB (12 × 32 GB) |
Drive |
Select one of the following drive options: · Drive configuration option 1: ¡ System drive: 4 × 960 GB SSDs or 8 × 480 GB SSDs, RAID 10 (1920 GB or higher after RAID setup). ¡ etcd drive: 2 × 480 GB SSDs, RAID 1 (50 GB or higher after RAID setup). (Installation path: /var/lib/etcd.) ¡ Storage controller: 1GB cache, installed with a power fail safeguard module. · Drive configuration option 2: ¡ System drive: 4 × 1200 GB or 8 × 600 GB 7.2K RPM or above HDDs, RAID 10 (1920 GB or higher after RAID setup). ¡ etcd drive: 2 × 600 GB 7.2K RPM or above HDDs, RAID 1 (50 GB or higher after RAID setup) (Installation path: /var/lib/etcd.) ¡ Storage controller: 1GB cache, installed with a power fail safeguard module. |
Network interface |
Remarks · To deploy the general_PLAT_kernel-region application package, one more CPU core and 6GB more memory are required. · To deploy the general_PLAT_network application package, three more CPU cores and 16GB more memory are required. |
Controller cluster deployment (FeiTeng ARM server)
FeiTeng servers do not support DTN deployment.
Table 5 Hardware requirements for controller cluster deployment (FeiTeng ARM server)
Item |
Requirements |
CPU |
2 × FeiTeng S2500, 64 cores, 2.1 GHz |
Memory |
128 GB or above |
Drive |
Network interface |
CPU |
2 × Feiteng S2500, 64 cores, 2.1 GHz |
Memory |
384 GB |
Drive |
Network interface |
The controller can also be installed on a VM deployed on the following virtualization platforms, and the virtualized environment provides the CPU, memory, and disk resources required by the controller:
· VMware ESXi 6.7.0
· H3C_CAS-E0706
The number of vCPU cores required for deploying the controller on a VM is twice the number of CPU cores required for deploying the controller on a physical server if hyper-threading is enabled on the server where the virtualization platform is deployed. If hyper-threading is disabled, the required number of vCPU cores is the same as that of CPU cores, and memory and disks can also be configured as required for deployment on a physical server.
This section uses a server enabled with hyper-threading as an example to describe the requirements for deploying the controller on a VM.
CAUTION: · You can deploy the controller on a VM only in scenarios where the controller will not interoperate with CloudOS. · To ensure system environment stability, make sure the CPUs, memory, and disks allocated to the VM meet the recommended capacity requirements and there are physical resources with corresponding capacity. Make sure VM resources are not overcommitted, and reserve resources for the VM. · Make sure etcd has an exclusive use of a physical disk. · To deploy the controller on a VMware-managed VM, enable the network card hybrid mode and pseudo transmission on the host where the VM resides. · Do not deploy DTN on a VM. · Do not deploy vBGP on a VM. · To ensure high reliability, deploy the three VM nodes of the controller cluster on three different physical hosts. · Deploy the controllers on physical servers in medium and large-scale (leaf number greater than 30) scenarios. |
Table 6 Hardware requirements for controller cluster deployment
Item |
Requirements |
Number of controller nodes |
3 |
vCPU |
32 cores, 2.0 GHz |
Memory |
128 GB or above |
Drive |
· System drive: 2.4 TB · etcd drive: 50 GB |
Network interface |
1 × 10 Gbps Ethernet port. To deploy vBGP or 3+3 RDRS system, add a network interface separately for each of them. |
· Device: A maximum of 30. · Server: A maximum of 600. |
Remarks · To use the simulation feature, add 100GB or above memory for the server where the DTN component is deployed. · To deploy the general_PLAT_kernel-region application package, 2 more CPU cores and 6GB more memory are required. · To deploy the general_PLAT_network application package, 3 more CPU cores and 16GB more memory are required. |
Software requirements
SeerEngine-DC runs on the Unified Platform as a component. Before deploying SeerEngine-DC, first install the Unified Platform.
Client requirements
You can access the Unified Platform from a Web browser without installing any client. As a best practice, use Google Chrome 70 or a later version.
Pre-installation checklist
Table 7 Pre-installation checklist
Item |
Requirements |
Server |
Hardware |
· The CPUs, memory, drives, and network interfaces meet the requirements. · The server supports the Unified Platform. |
Software |
The system time settings are configured correctly. As a best practice, configure NTP for time synchronization and make sure the devices synchronize to the same clock source. |
Client |
You can access the Unified Platform from a Web browser without installing any client. As a best practice, use Google Chrome 70 or a later version. |
Use the following procedure to deploy the controller:
1. Prepare for installation.
Prepare a minimum of three physical servers. Make sure the physical servers meet the hardware and software requirements as described in "Server requirements."
2. Deploy the Unified Platform.
For the deployment procedure, see H3C Unified Platform Deployment Guide.
3. Deploy SeerEngine-DC components.
4. Deploy the DTN component.
For the deployment procedure, see H3C SeerEngine-DC Simulation Network Deployment Guide.
5. Deploy simulated services.
For the deployment procedure, see H3C SeerEngine-DC Simulation Network Environment Deployment Guide.
SeerEngine-DC runs on the Unified Platform as a component. Before deploying SeerEngine-DC, first install the Unified Platform. For the detailed procedure, see H3C Unified Platform Deployment Guide.
To run SeerEngine-DC on Unified Platform, you are required to partition the drive, configure HugePages, and deploy the application packages required by SeerEngine-DC.
Partitioning the system drive
Before installing the Unified Platform, partition the system drive as described in Table 8.
Table 8 Drive partition settings (2400GB partition)
RAID configuration |
Partition |
Mount point |
Min. capacity |
Remarks |
2400 GB or higher after RAID 10 setup |
/dev/sda1 |
/boot/efi |
200 MiB |
EFI System Partition type. This partition is required only in UEFI mode. |
/dev/sda2 |
/boot |
1024 MiB |
N/A |
/dev/sda3 |
1000 GiB |
Expandable when the drive space is sufficient. |
/dev/sda4 |
/var/lib/docker |
500 GiB |
/dev/sda6 |
swap |
1024 MiB |
Swap type. |
/dev/sda7 |
/var/lib/ssdata |
550 GiB |
/dev/sda8 |
N/A |
300 GiB |
Reserved for GlusterFS. Not required when the operating system is installed. |
50 GB or higher after RAID 1 setup |
/dev/sdb |
/var/lib/etcd |
50 GiB |
Required to be mounted on a separate drive. |
Table 9 Drive partition settings (1920GB partition)
Partition |
Mount point |
Min. capacity |
Remarks |
1920 GB or higher after RAID 10 setup |
/dev/sda1 |
/boot/efi |
200 MiB |
/dev/sda2 |
/boot |
1024 MiB |
N/A |
/dev/sda3 |
700 GiB |
/dev/sda4 |
/var/lib/docker |
450 GiB |
/dev/sda6 |
swap |
1024 MiB |
Swap type. |
/dev/sda7 |
/var/lib/ssdata |
500 GiB |
/dev/sda8 |
N/A |
220 GiB |
/dev/sdb |
/var/lib/etcd |
50 GiB |
ARM hosts do not support multi-vBGP cluster.
To use the vBGP component, you must enable and configure HugePages. To deploy multiple vBGP clusters on a server, plan the HugePages configuration in advance to ensure adequate HugePages resources.
You are not required to configure HugePages if the vBGP component is not to be deployed. If SeerAnalyzer is to be deployed, you are not allowed to configure HugePages. After you enable or disable HugePages, restart the server for the configuration to take effect. HugePages are enabled on a server by default.
H3Linux operating system
H3Linux operating system supports two huge page sizes. Table 10 describes HugePages parameter settings for different page sizes.
Table 10 HugePages parameter settings for different page sizes
Huge page size |
Number of huge pages |
Remarks |
1 G |
8 + (n-1) |
· N is the number of vBGP clusters. · A single vBGP node uses 1 GB of HugePages memory. |
2 M |
4096 + 400 × (n-1) |
· N is the number of vBGP clusters. · A single vBGP node uses 400 MB of HugePages memory. |
You must configure HugePages on each node, and reboot the system for the configuration to take effect.
IMPORTANT: To deploy the Unified Platform on an H3C CAS-managed VM, enable HugePages for the host and VM on the CAS platform and set the CPU operating mode for the VM to straight-through before issuing the HugePages configuration. |
To configure HugePages on the H3Linux operating system:
1. Execute the hugepage.sh script.
[root@node1 ~]# cd /etc
[root@node1 etc]# ./hugepage.sh
2. Set the memory size and number of pages for HugePages during the script execution process.
The default parametersr ae set as follows: default_hugepagesz=1G hugepagesz=1G hugepages=8 }
Do you want to reset these parameters? [Y/n] Y
Please enter the value of [ default_hugepagesz ],Optional units: M or G >> 2M
Please enter the value of [ hugepagesz ],Optional units: M or G >> 2M
Please enter the value of [ hugepages ], Unitless >> 4096
3. Reboot the server as promoted.
GRUB_CMDLINE_LINUX="crashkernel=auto rhgb quiet default_hugepagesz=2M hugepagesz=2M hugepages=4096 "
Legacy update grub.cfg
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-3.10.0-957.27.2.el7.x86_64
Found initrd image: /boot/initramfs-3.10.0-957.27.2.el7.x86_64.img
Found linux image: /boot/vmlinuz-0-rescue-664108661c92423bb0402df71ce0e6cc
Found initrd image: /boot/initramfs-0-rescue-664108661c92423bb0402df71ce0e6cc.img
done
update grub.cfg success,reboot now...
GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="$(sed 's, release .*$,,g' /etc/system-release)"
GRUB_DEFAULT=saved
GRUB_DISABLE_SUBMENU=true
GRUB_TERMINAL_OUTPUT="console"
GRUB_DISABLE_RECOVERY="true"
Reboot to complete the configuration? [Y/n] Y
4. Verify that HugePages is configured correctly. If the configuration result is displayed as configured, the configuration is successful.
[root@node1 ~]# cat /proc/cmdline
BOOT_IMAGE=/vmlinuz-3.10.0-957.27.2.el7.x86_64 root=UUID=6b5a31a2-7e55-437c-a6f9-e3bc711d3683 ro crashkernel=auto rhgb quiet default_hugepagesz=2M hugepagesz=2M hugepages=4096
Galaxy Kylin operating system
Galaxy Kylin operating system supports one huge page size. Table 11 describes HugePages parameter settings.
Table 11 HugePages parameter settings
Huge page size |
Remarks |
2 M |
1. Open the grub file.
vim /etc/default/grub
2. Edit the values of the default_hugepagesz, hugepagesz, and hugepages parameters at the line starting with GRUB_CMDLINE_LINUX.
GRUB_CMDLINE_LINUX="default_hugepagesz=2M hugepagesz=2M hugepages=4096
3. Update the configuration file.
¡ If the system boots in UEFI mode, execute the following command:
grub2-mkconfig -o /boot/efi/EFI/kylin/grub.cfg
¡ If the system boots in Legacy mode, execute the following command:
grub2-mkconfig -o /boot/grub2/grub.cfg
4. Restart the server for the configuration to take effect.
5. Execute the cat/proc/cmdline command to view the configuration result. If the result is consistent with your configuration, the configuration succeeds.
The Unified Platform can be installed on x86 or ARM servers. Select the installation packages specific to the server type and install the selected packages in sequence as described in Table 12.
For the installation procedures of the packages, see H3C Unified Platform Deployment Guide.
The following installation packages must be deployed when you deploy the Unified Platform:
· common_PLAT_GlusterFS_2.0
· general_PLAT_portal_2.0
· general_PLAT_kernel_2.0
The following installation packages are deployed automatically when you deploy SeerEngine-DC components:
· general_PLAT_kernel-base_2.0
· general_PLAT_Dashboard_2.0
· general_PLAT_widget_2.0
To use the general_PLAT_network_2.0 and syslog packages, deploy them after SeerEngine-DC components are deployed.
Table 12 Installation packages required by the controller
Installation package |
· x86: common_PLAT_GlusterFS_2.0_version.zip · ARM: common_PLAT_GlusterFS_2.0_version_arm.zip |
Provides local shared storage functionalities. |
· x86: general_PLAT_portal_2.0_version.zip · ARM: general_PLAT_portal_2.0_version_arm.zip |
Provides portal, unified authentication, user management, service gateway, and help center functionalities. |
· x86: general_PLAT_kernel_2.0_version.zip · ARM: general_PLAT_kernel_2.0_version_arm.zip |
Provides access control, resource identification, license, configuration center, resource group, and log functionalities. |
· x86: general_PLAT_kernel-base_2.0_version.zip · ARM: general_PLAT_kernel-base_2.0_version_arm.zip |
Provides alarm, access parameter template, monitoring template, report, email, and SMS forwarding functionalities. |
· x86: general_PLAT_kernel-region_2.0_version.zip · ARM: general_PLAT_kernel-region_2.0_version_arm.zip |
(Optional.) Provides the hierarchical management functionality. If you are to use hierarchical management, install the general_PLAT_network_2.0 application and use it together with the super controller component for the super controller to manage DC networks. |
· x86: general_PLAT_network_2.0_version.zip · ARM: general_PLAT_network_2.0_version_arm.zip |
(Optional.) Provides basic management of network resources, network performance, network topology, and iCC. Install this application if you are to check match of the software versions with the solution. |
· x86: common_PLAT_Dashboard_2.0_version.zip · ARM: common_PLAT_Dashboard _2.0_version_arm.zip |
Provides the dashboard framework. |
· x86: general_PLAT_widget_2.0_version.zip · ARM: general_PLAT_widget_2.0_version_arm.zip |
Provides dashboard widget management. |
· x86: Syslog-version_x86.zip · ARM: Syslog-version_arm.zip |
(Optional.) Provides syslog management (log viewing, alarm upgrade rules, log parsing) Install this application package if you are to use syslog management. |
NOTE: · To deploy the general_PLAT_kernel-region application package on a physical server, one more CPU core and 6GB more memory are required. To deploy the general_PLAT_network application package on a physical server, three more CPU cores and 16GB more memory are required. · To deploy the general_PLAT_kernel-region application package on a VM, two more vCPU cores and 6G more memory are required. To deploy the general_PLAT_network application package on a VM, six more vCPU cores and 16GB more memory are required. |
Deploying the controller
IMPORTANT: · The controller runs on the Unified Platform. You can deploy, upgrade, and uninstall it only on the Unified Platform. · Before deploying the controller, make sure the required applications have been deployed. · To deploy RDRS for the controller, see "RDRS" for network planning and component deployment. |
Preparing for deployment
Enabling network interfaces
If the server uses multiple network interfaces for connecting to the network, enable the network interfaces before deployment.
The procedure is the same for all network interfaces. The following procedure enables network interface ens34.
To enable a network interface:
1. Access the server that hosts the Unified Platform.
2. Access the network interface configuration file.
[root@node1 /]# vi /etc/sysconfig/network-scripts/ifcfg-ens34
3. Set the BOOTPROTO field to none to not specify a boot-up protocol and set the ONBOOT field to yes to activate the network interface at system startup.
Figure 1 Modifying the configuration file for a network interface
4. Execute the ifdown and ifup commands in sequence to reboot the network interface.
[root@node1 /]# ifdown ens34
[root@node1 /]# ifup ens34
5. Execute the ifconfig command to verify that the network interface is in up state.
Planning the networks
Network planning
Plan for the following three types of networks:
· Calico network
Calico is an open source networking and network security solution for containers, Vims, and native host-based workloads. The Calico network is an internal network used for container interactions. The network segment of the Calico network is the IP address pool set for containers when the cluster is deployed. The default network segment is 177.177.0.0. You do not need to configure an address pool for the Calico network when installing and deploying the controller. The Calico network and MACVLAN network can use the same network interface.
· MACVLAN network
The MACVLAN network is used as a management network.
The MACVLAN virtual network technology allows you to bind multiple IPs and MAC addresses to a physical network interface. Some applications, especially legacy applications or applications that monitor network traffic, require a direct connection to the physical network. You can use the MACVLAN network driver program to assign a MAC address to the virtual network interface of each container, making the virtual network interface seem to be a physical network interface directly connected to the physical network. The physical network interface must be able to handle "promiscuous mode", supporting bundling of multiple MAC addresses to a physical interface.
· OVS-DPDK network
The OVS-DPDK type network is used as a management network.
Open vSwitch is a multi-layer virtual switch that supports SDN control semantics through the OpenFlow protocol and its OVSDB management interface. DPDK has a set of user space libraries and enables faster development of high speed data packet networking applications. Integrating DPDK and Open vSwitch, the OVS-DPDK network architecture can accelerate OVS data stream forwarding.
The required management networks depend on the deployed components and application scenarios. Before deployment, plan the network address pools in advance.
Table 13 Network types and numbers used by components in the non-RDRS scenario
Component |
Network type |
Number of networks |
Remarks |
SeerEngine-DC |
MACVLAN (management network) |
1 |
N/A |
vBGP |
Management network and service network converged |
OVS-DPDK (management network) |
1*Number of vBGP clusters |
· Used for communication between the vBGP and SeerEngine-DC components and service traffic transmission. · Each vBGP cluster requires a separate OVS-DPDK management network. |
Management network and service network separated |
· Used for communication between the vBGP and SeerEngine-DC components. · Each vBGP cluster requires a separate OVS-DPDK management network. |
OVS-DPDK (service network) |
· Used for service traffic transmission. · Each vBGP cluster requires a separate OVS-DPDK service network. |
Digital Twin Network (DTN) |
MACVLAN (simulation management network) |
1 |
Used for simulation services. A separate network interface is required. |
Figure 3 Cloud data center networks in the non-RDRS scenario (only DTN deployed)
IMPORTANT: · The MACVLAN and OVS-DPDK subnets are on different network segments. You must configure routing entries on the switches connected to the network interfaces to enable Layer 3 communication between the SeerEngine-DC management network and vBGP management network. · DTN does not support RDRS. · If the simulation management network and the controller management network are connected to the same switch, you must configure VPN instances. If the simulation management network and the controller management network are connected to different switches, make sure the switches are physically isolated. · Make sure the simulation management IP and the simulated device management IP are reachable to each other. |
IP address planning
Use Table 14 as a best practice to calculate IP addresses required for the networks.
Table 14 IP addresses required for the networks in the non-RDRS scenario
Component |
Network type |
Maximum team members |
Default team members |
Number of IP addresses |
Remarks |
SeerEngine-DC |
32 |
3 |
Number of team members + 1 (team IP) |
N/A |
vDHCP |
2 |
2 |
Number of vBGP clusters* team members + number of vBGP clusters (team IP) |
same MACVLAN management network. |
vBGP |
2 |
2 |
N/A |
2 |
2 |
N/A |
2 |
2 |
Number of team members |
N/A |
DTN |
1 |
1 |
1 (team IP) |
A separate network interface is required. For management IP address assignment for DTN hosts, see H3C SeerEngine-DC Simulation Network Deployment Guide. |
Table 15 shows an example of IP address planning for a single vBGP cluster in a non-RDRS scenario where the management network and service network are converged .
Table 15 IP address planning for the non-RDRS scenario
Component |
Network type |
IP addresses |
Remarks |
SeerEngine-DC |
Subnet: 192.168.12.0/24 (gateway 192.168.12.1) |
N/A |
Network address pool: 192.168.12.101 to 192.168.12.132 |
vBGP |
Subnet: 192.168.13.0/24 (gateway 192.168.13.1) |
Management network and service network are converged. |
Network address pool: 192.168.13.101 to 192.168.13.132 |
DTN |
Network address pool: 192.168.12.133 to 192.168.12.133 |
1. Log in to the Unified Platform. Click System > Deployment.
2. Obtain the SeerEngine-DC installation packages. Table 16 provides the names of the installation packages. Make sure you select installation packages specific to your server type, x86 or ARM.
Table 16 Installation packages
Component |
Installation package name |
Remarks |
SeerEngine-DC |
· x86: SeerEngine_DC-version-MATRIX.zip · ARM: SeerEngine_DC-version-ARM64.zip |
Required |
vBGP |
· x86: vBGP-version.zip · ARM: vBGP-version-ARM64.zip |
Optional |
DTN |
· x86: SeerEngine_DC_DTN-version.zip · ARM: SeerEngine_DC_DTN-version-ARM64.zip |
Optional, for providing simulation services |
IMPORTANT: · For some controller versions, the installation packages are released only for one server architecture, x86 or ARM. · The DTN version must be consistent with the SeerEngine-DC version. |
3. Click Upload to upload the installation package and then click Next.
4. Select Cloud Data Center and then select DC Controller. To deploy the vBGP component simultaneously, select vBGP and select a network scheme for vBGP deployment. To deploy the DTN component simultaneously, select Simulation. Then click Next.
Figure 4 Selecting components
CAUTION: To avoid malfunction of simulation services, do not delete the worker node on which DTN has been deployed on the Matrix cluster deployment page. |
5. Configure the MACVLAN and OVS-DPDK networks and add the uplink interfaces according to the network plan in "Planning the network." If you are not to deploy vBGP, you only need to configure MACVLAN networks.
To use simulation services, configure the network settings as follows:
¡ Configure a separate MACVLAN network for the DTN component. Be sure that the subnet IP address pool for the network contains a minimum of one IP address.
¡ If the servers are in standard configuration, the DTN component must have an exclusive use of a worker node server. If the servers are in high-end configuration, the DTN component can have an exclusive use of a worker node server or be deployed on the same master node with a controller. In this example, the DTN component is deployed on a worker node residing on a high-end server.
Figure 5 Configuring a MACVLAN management network for the SeerEngine-DC component
Figure 6 Configuring a MACVLAN management network for the DTN component
Figure 7 Configuring an OVS-DPDK network
6. (Optional.) On the Bind to Nodes page, select whether to enable node binding. If you enable node binding, select a minimum of three master nodes to host and run microservice pods.
If a resource-intensive component such as SeerAnalyzer is required to be deployed simultaneously with the controller, enable node binding and bind the components to different nodes for better use of server resources.
Figure 8 Enabling node binding
7. Bind networks to the components, assign IP address to the components, specify a network node for the service simulation network, and then click Next.
Figure 9 Binding networks
8. On the Confirm Parameters tab, verify network information and specify a VRRP group ID for the components.
A component automatically obtains an IP address from the IP address pool of the subnet bound to it. To modify the IP address, click Modify and then specify another IP address for the component. The IP address specified must be in the IP address range of the subnet bound to the component.
If vBGP is to be deployed, you are required to specify a VRRP group ID in the range of 1 to 255 for the components. The VRRP group ID must be unique within the same network.
Figure 10 Confirming parameters (SeerEngine-DC)
Figure 11 Confirming parameters (DTN)
9. Click Deploy.
Figure 12 Deployment in progress
Accessing the controller
After the controller is deployed on the Unified Platform, the controller menu items will be loaded on the Unified Platform. Then you can access the Unified Platform to control and manage the controller.
To access the controller:
1. Enter the address for accessing the Unified Platform in the address bar and then press Enter.
By default, the login address is http://ip_address:30000/central/index.html.
¡ ip_address represents the northbound virtual IP address of the Unified Platform.
¡ 30000 is the port number.
Figure 13 Unified Platform login page
2. Enter the username and password, and then click Log in.
The default username is admin and the default password is Pwd@12345.
Figure 14 Unified Platform dashboard
For the Unified Platform license registration and installation procedure, see H3C Unified Platform Deployment Guide.
After you install the controller, you can use its complete features and functions for a 180-day trial period. After the trial period expires, you must get the controller licensed.
For the activation file request and installation procedure, see H3C Software Products Remote Licensing Guide.
Obtaining licenses
1. Log in to the Unified Platform and then click System > License Management > DC license.
2. Configure the parameters for the license server as described in Table 18.
Table 17 License server parameters
Item |
IP address |
Specify the IP address configured on the license server used for internal communication in the cluster. |
Port number |
Specify the service port number of the license server. The default value is 5555. |
Username |
Specify the client username configured on the license server. |
Password |
Specify the client password configured on the license server. |
3. Click Connect to connect the controller to the license server.
The controller will automatically obtain licensing information after connecting to the license server.
You can back up and restore the controller configuration on the Unified Platform. For the procedures, see H3C Unified Platform Deployment Guide.
CAUTION: · If both SeerEngine-DC and DTN require an upgrade, upgrade SeerEngine-DC before DTN. The DTN version must be consistent with the SeerEngine-DC version after the upgrade. · The upgrade might cause service interruption. Be cautious when you perform this operation. · Before upgrading or scaling out the Unified Platform or the controller, specify the manual switchover mode for the RDRS if the RDRS has been created. · Do not upgrade the controllers on the primary and backup sites simultaneously if the RDRS has been created. Upgrade the controller on a site first, and upgrade the controller on another site after data is synchronized between the two sites. · If the simulation network construction page has a display issue after the DTN component is upgraded, clear the browser cache and log in again. · After upgrading the DTN component from E6102 or earlier to E6103 or later, you must reinstall the operating system and reconfigure settings for DTN hosts and delete the original hosts from the simulation network and then reincorporate the hosts. For how to install the operating system and configure settings for DTN hosts, see H3C SeerEngine-DC Simulation Network Environment Deployment Guide. · After upgrading the DTN component from E6202 or earlier to E6203 or later, you must uninstall and reconfigure the DTN hosts and delete the original hosts from the simulation network and then reincorporate the hosts. For how to uninstall and configure DTN hosts, see H3C SeerEngine-DC Simulation Network Environment Deployment Guide. |
This section describes the procedure for upgrading and uninstalling the controller and DTN. For the upgrading and uninstallation procedure for the Unified Platform, see H3C Unified Platform Deployment Guide.
The components can be upgraded on the Unified Platform with the configuration retained.
To upgrade the controller and DTN:
Figure 15 Deployment page
2. Click the left chevron button
for Cloud DC to
expand component information. Then upgrade SeerEngine-DC and DTN.
a. Click the
icon for the
SeerEngine-DC component to upgrade the SeerEngine-DC component.
- If the controller already supports RDRS, the upgrade page is displayed.
# Upload and select the installation package.
# Select whether to enable Add Master Node-Component Bindings. The nodes that have been selected during controller deployment cannot be modified or deleted.
# Click Upgrade.
# If the upgrade fails, click Roll Back to roll back to the previous version.
- If the controller does not support RDRS, the system displays a confirmation dialog box with a Support RDRS option.
If you leave the Support RDRS option unselected, the upgrade page is displayed. Proceed with the upgrade.
If you select the Support RDRS option, the system will guide you to upgrade the component to support RDRS. For the upgrade procedure, see "Upgrading SeerEngine-DC to support RDRS."
b. Click the
icon for the DTN
component to upgrade the DTN component.
# Click Upgrade.
Hot patching the controller
CAUTION: · Hot patching the controller might cause service interruption. To minimize service interruption, select the time to hot patch the controller carefully. · You cannot upgrade the controller to support RDRS through hot patching. · If you are to hot patch the controller after the RDRS is created, first specify the manual switchover mode for the RDRS. · Do not hot patch the controllers at the primary and standby sites at the same time after the RDRS is created. Only after the controller at a site is upgraded and data is synchronized, you can upgrade the controller at the other site. |
On the United Platform, you can hot patch the controller with the configuration retained.
To hot patch the controller:
Figure 16 Deployment page
of the controller to
expand controller information, and then click the hot patching icon
3. Upload the patch package and select the patch of the required version, and then click Upgrade.
Figure 17 Hot patching page
4. If the upgrade fails, click Roll Back to roll back to the previous version or click Terminate to terminate the upgrade.
When you uninstall the SeerEngine-DC controller, DTN will be uninstalled simultaneously.
To uninstall SeerEngine-DC and DTN:
2. Click the
icon to the left of the controller name and then
click Uninstall.
Figure 18 Uninstalling the controller and DTN
The DTN component can be uninstalled separately.
To uninstall the DTN component only:
2. Click the
icon to the left of the DTN
component and then click Uninstall.
Figure 19 Uninstalling the DTN component
Uninstalling a hot patch
2. Select a patch, and then click Uninstall.
Figure 20 Uninstalling a hot patch
RDRS
About RDRS
A remote disaster recovery system (RDRS) provides disaster recovery services between the primary and backup sites. The controllers at the primary and backup sites back up each other. When the RDRS is operating correctly, data is synchronized between the site providing services and the peer site in real time. When the service-providing site becomes faulty because of power, network, or external link failure, the peer site immediately takes over to ensure service continuity.
The RDRS supports the following switchover modes:
· Manual switchover—In this mode, the RDRS does not automatically monitor state of the controllers on the primary or backup site. You must manually control the controller state on the primary and backup sites by specifying the Switch to Primary or Switch to Backup actions. This mode requires deploying the Unified Platform of the same version on the primary and backup sites.
· Auto switchover with arbitration—In this mode, the RDRS automatically monitors state of the controllers. Upon detecting a controller or Unified Platform failure (because of site power or network failure), the RDRS automatically switches controller state at both sites by using the arbitration service. This mode also supports manual switchover. To use this mode, you must deploy the Unified Platform of the same version at the primary and backup sites and the arbitration service as a third-party site.
The arbitration service can be deployed on the same server as the primary or backup site. However, when the server is faulty, the arbitration service might stop working. As a result, RDRS auto switchover will fail. As a best practice, configure the arbitration service on a separate server.
1. Deploy the primary and backup sites.
2. Configure the RDRS settings for the controllers at the primary and backup sites.
3. Deploy the third-party arbitration service.
4. Create an RDRS.
CAUTION: · To use vBGP, make sure the primary and backup sites have a consistent OVS-DPDK network scheme and the same number of vBGP clusters. · In an RDRS scenario, if you configure DHCP relay on the management switch for automated underlay network deployment, you must specify the controller clusters' IPs of both the primary and backup sites as relay servers. · To deploy RDRS for the controllers, make sure the primary and backup sites uses different IP addresses for the RDRS networks. |
Table 18 Network types and numbers used by components at the primary/ backup site in the RDRS scenario
Component |
Network type |
Remarks |
SeerEngine-DC |
1 |
N/A |
MACVLAN (RDRS network) |
1 |
· Used for carrying traffic for real-time data synchronization between the primary and backup sites. · Used for communication between the RDRS networks at the primary and backup sites · As a best practice, use a separate network interface. |
vBGP |
1*number of vBGP clusters |
Figure 21 Cloud DC networks in an RDRS scenario (vBGP deployed)
Table 19 IP addresses required for the networks at the primary/backup site in the RDRS scenario
Component |
Network type |
Remarks |
SeerEngine-DC |
32 |
3 |
Number of cluster nodes + 1 (cluster IP) |
N/A |
32 |
3 |
Number of cluster nodes |
vBGP |
2 |
2 |
Number of vBGP clusters*number of cluster nodes + Number of vBGP clusters (cluster IP) |
2 |
2 |
2 |
2 |
Number of vBGP clusters*number of cluster nodes |
Table 21 shows an example of IP address planning for a single vBGP cluster in an RDRS scenario where the management network and service network are converged.
Table 20 IP address planning for the RDRS scenario
Site |
Component |
Network |
IP address |
Remarks |
Primary site |
SeerEngine-DC |
Make sure the primary and backup sites use different IP addresses for the RDRS networks and controllers. |
Address pool: 192.168.12.101 to 192.168.12.132 |
Subnet: 192.168.16.0/24 (gateway 192.168.16.1) |
Address pool: 192.168.16.101 to 192.168.16.132 |
vBGP |
N/A |
Address pool: 192.168.13.101 to 192.168.13.132 |
Backup site |
SeerEngine-DC |
Subnet: 192.168.12.0/24 (gateway 10.0.234.254) |
Address pool: 192.168.12.133 to 192.168.12.164 |
Address pool: 192.168.16.133 to 192.168.16.164 |
vBGP |
N/A |
Address pool: 192.168.13.133 to 192.168.13.164 |
Follow these restrictions and guidelines when you deploy the primary and backup sites and a site:
· The Unified Platform version, transfer protocol (HTTP or HTTPS), username and password, and IP version of the primary and backup sites must be the same.
· The arbitration service package on the site must match the Unified Platform version on the primary and backup sites.
· To use the auto switchover with arbitration mode, you must deploy a standalone Unified Platform as the site, and deploy arbitration services on the site.
· To use the allowlist feature in an RDRS scenario, you must add the IP addresses of all nodes on the backup site to the allowlist on the primary site, and add the IP addresses of all nodes on the primary site to the allowlist on the backup site.
This procedure uses a separate server as the site and deploys the Unified Platform in standalone mode on this site.
To deploy the primary and backup sites and a site:
1. Deploy Matrix on primary and backup sites and the site. For the deployment procedure, see H3C Unified Platform Deployment Guide.
2. Deploy the Unified Platform on primary and backup sites. Specify the same NTP server for the primary and backup sites. For the deployment procedure, see H3C Unified Platform Deployment Guide.
If the controller installed on the specified backup site does not support disaster recovery or is not in backup state, remove the controller and install it again.
2. Obtain the SeerEngine-DC installation package.
The SeerEngine-DC installation packages used for the primary and backup sites must be consistent in version and name.
4. Select Cloud DC and DC controller. Then select the Support for RDRS network scheme. To deploy the vBGP component simultaneously, select vBGP and select the Management and service network converged network scheme for the vBGP component. Then click Next.
Figure 22 Selecting components
5. Configure the networks required by the components and add the uplink interfaces according to the network plan in "Planning the network."
¡ Configure a separate MACVLAN as the RDRS network.
¡ To deploy vBGP, configure an OVS-DPDK network. Make sure the network solutions are the same at the primary and backup sites.
The following shows network configurations at the primary site.
Figure 23 Configuring a MACVLAN management network for the SeerEngine-DC controller
Figure 24 Configuring an RDRS network
Figure 25 Configuring an OVS-DPDK network
6. (Optional.) On the Bind Node page, select whether to enable node binding. If you enable node binding, select a minimum of three master nodes to host and run microservice pods.
7. Bind networks to the components and assign IP address to the components. Then click Next.
Figure 26 Binding networks (1)
8. On the Confirm Parameters page, verify network information and specify the RDRS status and a VRRP group ID for the components.
Configure the RDRS status for the controllers:
¡ Select Primary from the Status in RDRS list for a controller at the primary site.
¡ Select Backup from the Status in RDRS list for a controller at the backup site.
9. Click Deploy.
Figure 27 Deployment in progress
The third-party site can be deployed on a physical server. Table 22 describes the hardware requirements for a server to host the third-party site.
Table 21 Hardware requirements for a server to host the third-party site
CPU |
Memory size |
Drive |
Network interface |
x86-64 (Intel64/AMD64) 2 cores 2.0 GHz or above |
16 GB or above |
The drives must be configured in RAID 1. · Drive configuration option 1: ¡ System drive: 2 × 480 GB SSDs configured in RAID1 that provides a minimum total drive size of 256 GB. ¡ ETCD drive: 2 × 480 GB SSDs, configured in RAID1 that provides a minimum total drive size of 20 GB. (Installation path: /var/lib/etcd.) · Drive configuration option 2: ¡ System drive: 2 × 600 GB 7.2K RPM or above HDDs configured in RAID 1 that provides a minimum total drive size of 256 GB ¡ ETCD drive: 2 × 600 GB 7.2K RPM or above HDDs that provides a minimum total drive size of 20 GB ¡ Storage controller: 1 GB cache, power fail protected with a supercapacitor installed |
1 × 10 Gbps or above |
As a best practice, deploy the third-party arbitration service on the CentOS 7.0 system. The correct operation of the third-party arbitration service requires installation of the CentOS 7.0 software dependencies described in Table 23.
Table 22 CentOS 7.0 software dependencies and their versions
Software dependency name |
Version |
java openjdk |
1.8.0 |
Zip |
3.0 |
Unzip |
6.0 |
docker-ce |
18.09.6 |
Containerd |
1.2.13 |
Make sure the application software package at the third-party site matches the SNA Center version at the primary and backup sites.
To avoid service failure, do not change the system time after the deployment.
Execution of the ifconfig command on network interfaces might cause loss of default routes. For correct deployment and operation of the third-party arbitration service, use the ifup and ifdown commands to configure network interfaces.
If multiple network interfaces exist on the node that hosts the third-party arbitration service, make sure all other network interfaces except the network interface used for the third-party arbitration service are down. If such a network interface is up, use the ifdown command to shut down it.
Before deploying the third-party arbitration service, check the environment against the checklist described in Table 24 to be sure that all requirements are met.
Table 23 Pre-installation checklist
Item |
Requirements |
Server |
Hardware |
The hardware of the server, including CPUs, memory, disks, and network interfaces, meets the requirements. |
Software |
· The version of the operating system is as required. · The system time settings are configured correctly. As a best practice, configure NTP for time synchronization and make sure the devices on the network synchronize to the same clock source. · Network settings, including IP addresses, have been configured correctly. |
Whether the third-party arbitration service has been installed in the system |
If the third-party arbitration service has been installed in the system, uninstall and reinstall the service again. |
Network interface |
Make sure the service has an exclusive use of a network interface. No subinterfaces or subnet IPs have been configured on the network interface. |
IP address |
The IP addresses of other interfaces on the node that hosts the third-party arbitration service must not be on the same network segment with the IP address used for the third-party arbitration service. |
Time zone |
For the arbitration service to function correctly, make sure the third-party arbitration service and the primary and backup sites are in the same time zone. You can use the timedatectl command to view the system time zone of each node. |
Power supply |
To protect the file system from irreversible damages (such as damage of the configuration file of the docker.service, etcd.service, or chrony.conf component), do not restart the node, power off the node forcibly, or reset the VM during the deployment and operation of the third-party arbitration service. |
Uploading the third-party arbitration service installation package
Obtain and copy the third-party arbitration service installation package to the installation directory on the server, or upload the installation package to the installation directory by using a file transfer protocol such as FTP.
The installation package is named in the SeerEngine_DC_ARBITRATOR-version.zip (applicable to a x86 system) or SeerEngine_DC_ARBITRATOR-version-ARM64.zip (applicable to an ARM system) format.
For some controller versions, the installation package is released only for one server architecture, x86 or ARM.
CAUTION: To avoid installation package damage, select the binary code if you use FTP or TFTP to upload or download the installation package. |
Installing the third-party arbitration service
The system supports the use of the root user or a non-root user to install the third-party arbitration service. As a best practice, use the root user for the installation. To use a non-root user to install the software package, you must use the root user to modify the configuration file by using the visudo command and assign installation permission to the non-root user by adding the following configuration items at the end of the configuration file:
[root@rdr01 ~]# visudo
<username> ALL=(root) NOPASSWD:/bin/bash
The following procedure uses the root user for the installation. To use a non-root user for the installation, execute the sudo ./install.sh command.
1. Access the directory where the third-party arbitration service installation package is saved and install the third-party arbitration service.
[root@rdr01 ~]# unzip SeerEngine_DC_ARBITRATOR-E3611.zip
[root@rdr01 ~]# cd SeerEngine_DC_ARBITRATOR-E3611/
[root@rdr01 SeerEngine_DC_ARBITRATOR-E3611]# ./install.sh
Installing...
2021-03-04 16:42:52 [info] -----------------------------------
2021-03-04 16:42:52 [info] SeerEngine_DC_ARBITRATOR-E3611
2021-03-04 16:42:52 [info] H3Linux Release 1.1.2
2021-03-04 16:42:52 [info] Linux 3.10.0-957.27.2.el7.x86_64
2021-03-04 16:42:53 [warn] To avoid unknown error, do not interrupt this installation procedure.
2021-03-04 16:42:57 [info] Checking environment...
2021-03-04 16:42:57 [info] Decompressing rdrArbitrator package...
Complete!
2. Verify that the installation is successful. If the installation succeeds, the result is displayed as follows:
[root@rdr01 SeerEngine_DC_ARBITRATOR-E3611]# jps |grep rdr
19761 rdrs3rd-1.0.0.jar
[root@rdr01 SeerEngine_DC_ARBITRATOR-E3611]# docker ps |grep etcd
31b40e2d521d rdr-arbitrator/etcd3rd:1.0.0 "/entrypoint.sh" 5 minutes ago Up 5 minutes etcd3rd
1. Access the CLI of the operating system and execute the following commands to uninstall the third-party arbitration service.
[root@rdr01 ~]# cd SeerEngine_DC_ARBITRATOR-E3611 //Directory where the third-party arbitration service package is decompressed
[root@rdr01 SeerEngine_DC_ARBITRATOR-E3611]# ./uninstall.sh
Uninstalling…
Uninstalling...
2021-03-04 16:50:09 [info] Stopping rdrArbitrator service...
2021-03-04 16:50:09 [info] stop container 31b40e2d521d in docker daemon
2021-03-04 16:50:20 [info] stop container 31b40e2d521d in docker daemon success
2021-03-04 16:50:20 [info] Deleting image rdr-arbitrator/etcd3rd:1.0.0 in docker daemon
2021-03-04 16:50:20 [info] Delete image rdr-arbitrator/etcd3rd:1.0.0 in docker daemon success
2021-03-04 16:50:20 [info] Deleting rdrArbitrator dir...
Complete!
2. Verify that the uninstallation is successful.
CAUTION: Specify the manual switchover mode for the RDRS before the upgrade. |
To upgrade the third-party arbitration service, you must first uninstall the old version of third-party arbitration service and then upload and install the new version of third-party arbitration service installation package.
To upgrade the third-party arbitration service:
1. Access the primary site of the RDRS and specify the manual switchover mode.
2. Access the command line interface of the operating system and uninstall the third-party arbitration service. For the uninstallation procedure, see "Uninstalling the third-party arbitration service."
3. Obtain the new version of the third-party arbitration service installation package, and copy the package to the installation directory or upload the software package to the directory by using a file transfer protocol such as FTP. Then reinstall the third-party arbitration service. For the installation procedure, see "Installing the third-party arbitration service."
4. Log in to the primary site of the RDRS and change the switchover mode to automatic switchover with arbitration.
Creating an RDRS
Do not create an RDRS at the primary and backup sites simultaneously.
Ensure network connectivity between the primary and standby sites during the RDRS creation process. If the RDRS fails to be created, first check the network connectivity.
You cannot back up or restore data on the RDRS configuration page, including the primary or backup site name, primary or backup site IP address, backup site username and password, and site IP address.
After an RDRS is created, you cannot change the internal virtual IP of the cluster at the primary and backup sites and the node IPs.
1. Log in to SeerEngine-DC. Click System on the top navigation bar and then select RDRS from the navigation pane.
2. In the Site Settings area, configure the primary, backup, and site settings, and specify the switchover mode.
3. Click Connect.
If the heartbeat link is successfully set up, the RDRS site settings have been configured successfully.
After the sites are built successfully, the backup site will automatically synchronize its user, log, and backup and restore settings to the primary site, with the exception of the log content.
4. In the Disaster Recovery Components area, click Add to configure disaster recovery components.
If SeerEngine-DC at the primary site does not support RDRS, you can upgrade it to support RDRS on the Unified Platform with the configuration retained.
The upgrade might cause service interruption. Be cautious when you perform the upgrade.
Only SeerEngine-DC at the primary site can be upgraded to support RDRS. If SeerEngine-DC installed at the standby site does not support RDRS or its RDRS status is not backup, uninstall and reinstall it.
Figure 28 Deployment page
for the component to
expand component information. Then click the
icon.
3. Select the Support RDRS option in the dialog box that opens and then click OK.
Figure 29 Support RDRS option
4. On the Configure Network page, create a MACVLAN network as the RDRS network. Make sure the RDRS network and the management network are on different network segments.
Figure 30 Configure Network page
5. On the Bind Network page, bind the controller to the corresponding RDRS network and subnet, and then click Next.
Figure 31 Bind Network page
6. On the Confirm Parameters tab, verify that the IP addresses assigned to the RDRS network are correct, and then click Next.
7. On the Upgrade tab, upload and select the installation package, and then click Deploy.
8. If the upgrade fails, click Roll Back to roll back to the previous version.
If the master nodes in a cluster are on different subnets, you deploy the cluster over a Layer 3 network.
In cluster deployment over a Layer 3 network, RDRS deployment, simulation and vBGP component deployment, and underlay IPv6 deployment are not supported.
Network planning
As shown in Figure 31, Master 1 and Master 2 are on the management network of Fabric 1, Master 3 is on the management network of Fabric 2. The management networks of Fabric 1 and Fabric 2 are on different subnets and communicate with each other at Layer 3. Plan the IP addresses as shown in Table 25 to deploy the cluster.
Component |
IP type |
IP address |
Remarks |
Unified Platform cluster |
IP address of Master node 1 |
192.168.10.102/24 |
The default gateway is 192.168.10.1 on management switch 1. |
IP address of Master node 2 |
192.168.10.103/24 |
IP address of Master node 3 |
192.168.110.104/24 |
The default gateway is 192.168.110.1 on management switch 2. |
Cluster internal virtual IP |
192.168.10.101/32 |
N/A |
Northbound service VIP |
192.168.10.100/32 |
N/A |
SeerEngine-DC |
Management network 1 (bound to master 1 and master 2) |
Subnet: 192.168.12.0/24 Network address pool: 192.168.12.101-192.168.12.132 |
MACVLAN network. The default gateway is 192.168.12.1 on management switch 1. |
Management network 2 (bound to master 3) |
Subnet: 192.168.112.0/24 Network address pool: 192.168.112.101-192.168.112.132 |
MACVLAN network. The default gateway is 192.168.112.1 on management switch 2. |
Management network 3 (cluster VIP) |
Subnet: 8.8.8.0/24 Network address pool: 8.8.8.8-8.8.8.8 |
You do not need to specify a gateway address on the switch. |
Before cluster deployment, complete routing settings for the underlay to make sure the nodes can communicate with each other at Layer 3.
Deploying a Matrix cluster
This section describes only settings different from Layer 2 deployment. For other procedures, see H3C Unified Platform Deployment Guide.
1. Set the cluster network mode to multisubnet.
Figure 33 Configuring cluster parameters
2. Configure BGP parameters for the nodes.
Table 25 Configuring BGP parameters for the nodes
Node |
IP address |
Local/Router ID |
Local/AS Number |
Peers/IP |
Peers/AS Number |
Master 1 |
192.168.10.102 |
192.168.10.102 |
100 |
192.168.10.1 |
100 |
Master 2 |
192.168.10.103 |
192.168.10.103 |
100 |
192.168.10.1 |
100 |
Master 3 |
192.168.110.104 |
192.168.110.104 |
200 |
192.168.110.1 |
200 |
Figure 34 Adding a node
3. Configure BGP on the switches connected to the cluster.
On management switch 1:
[device1] bgp 100
[device1-bgp] peer 192.168.10.102 as-number 100
[device1-bgp] peer 192.168.10.102 connect-interface Vlan-interface 10
[device1-bgp] peer 192.168.10.103 as-number 100
[device1-bgp] peer 192.168.10.103 connect-interface Vlan-interface 10
[device1-bgp] peer 192.168.110.1 as-number 200
[device1-bgp] peer 192.168.110.1 connect-interface Vlan-interface 10
[device1-bgp] address-family ipv4 unicast
[device1-bgp-ipv4] peer 192.168.10.102 enable
[device1-bgp-ipv4] peer 192.168.10.103 enable
[device1-bgp-ipv4] peer 192.168.110.1 enable
On management switch 2:
[device2] bgp 200
[device2-bgp] peer 192.168.110.104 as-number 200
[device2-bgp] peer 192.168.110.104 connect-interface Vlan-interface 10
[device1-bgp] peer 192.168.10.1 as-number 100
[device1-bgp] peer 192.168.10.1 connect-interface Vlan-interface 10
[device2-bgp] address-family ipv4 unicast
[device2-bgp-ipv4] peer 192.168.110.104 enable
[device1-bgp-ipv4] peer 192.168.10.1 enable
Deploying the SeerEngine-DC controller at Layer 3
This section describes only settings different from Layer 2 deployment. For other procedures, see "Deploying the controller."
1. Create a MACVLAN network based on the IP address planning in Table 25.
Figure 35 Configuring network settings
2. Select networks.
Figure 36 Network bindings
3. After the controller is deployed successfully, configure routing settings for each node. You can configure OSPF and BGP. In this example, BGP is configured.
Table 26 Routing settings on the nodes
Node |
BGP instance settings |
Network |
Neighbor settings |
Router ID |
AS Number |
Neighbor |
Remote AS |
Master 1 |
192.168.12.101 |
100 |
8.8.8.8/32 |
192.168.10.1 |
100 |
Master 2 |
192.168.12.102 |
100 |
8.8.8.8/32 |
192.168.10.1 |
100 |
Master 3 |
192.168.112.101 |
200 |
8.8.8.8/32 |
192.168.110.1 |
200 |
Figure 37 Routing settings on Master 1
4. Configure routing settings on the management switches.
[device1] bgp 100
[device1-bgp] peer 192.168.12.101 as-number 100
[device1-bgp] peer 192.168.12.101 connect-interface Vlan-interface 10
[device1-bgp] peer 192.168.12.102 as-number 100
[device1-bgp] peer 192.168.12.102 connect-interface Vlan-interface 10
[device1-bgp-ipv4] peer 192.168.12.101 enable
[device1-bgp-ipv4] peer 192.168.12.102 enable
[device2] bgp 200
[device2-bgp] peer 192.168.112.101 as-number 200
[device2-bgp] peer 192.168.112.101 connect-interface Vlan-interface 10
[device2-bgp-ipv4] peer 192.168.112.101 enable
Cluster 2+1+1 deployment
About cluster 2+1+1 deployment
The cluster 2+1+1 mode is a low-cost failure recovery solution. To set up this solution, deploy the three nodes for setting up the DC controller cluster in two different cabinets or equipment rooms and reserve a standby node outside the cluster as a redundant node. When the cluster is operating correctly, leave the standby node unpowered. If two master nodes in the cluster fail at the same time, power on the standby node. The standby node will join the cluster quickly and the cluster service will have a fast recovery.
Figure 38 Cluster disaster recovery deployment
Deployment process
1. Prepare four servers: three used for setting up the Unified Platform cluster and one used as the standby server.
2. Install the four servers at different locations. As a best practice, install two of the servers for setting up the cluster in one cabinet (or equipment room), and the other server for setting up the cluster and the standby server in another cabinet (or equipment room).
3. Install the Unified Platform on the three servers for setting up the cluster. For the installation procedure, see H3C Unified Platform Deployment Guide. As a best practice, assign IP addresses in the same network segment to the three servers and make sure they are reachable to each other.
4. Deploy the SeerEngine-DC controller in the cluster. For the deployment procedure, see "Deploying the controller."
5. Install the Matrix platform on the standby server. Make sure the Matrix version is consistent with that installed on the three cluster servers. You are not required to deploy the Unified Platform on the standby server.
Preparing for disaster recovery
1. Record the host name, NIC name, IP address, and username and password of the three nodes in the cluster.
2. Install Matrix on the standby node. The Matrix platform must be the same version as that installed on the cluster nodes.
IMPORTANT: The drive letter and partitioning scheme of the standby node must be consistent with those of the cluster nodes. |
Two node-failure recovery
In a cluster with three leader nodes as shown in Figure 38, if two nodes (for example, DC controllers 1 and 2) fail at the same time, the cluster cannot operate correctly. Only DC controller 3 is accessible and will automatically enter emergency mode. In emergency mode, you can only view configuration data on the controller.
Figure 39 Failure of two nodes
To recover the cluster, perform the following steps:
1. Power on the standby node (without connecting it to the management network) and verify that Matrix has been installed on it. If not installed, see H3C Unified Platform Deployment Guide to install Matrix.
Do not configure any cluster-related settings on the standby node after Matrix is installed on it.
2. Verify that the host name, NIC name, IP address, and username and password of the standby node are exactly the same as those of the failed nodes, DC controller 1 in this example.
3. Disconnect the network connections of the failed controllers 1 and 2, and connect the standby node to the management network.
4. Log in to the Matrix Web interface of controller 3, and then click Deploy > Cluster. Click
the
button for
controller 1 and select Rebuild
from the list. Then use one of the following methods to rebuild the node:
¡ Select and upload the same version of software package as installed on the current code. Then click Apply.
¡ Select the original software package version and then click Apply.
5. Log out to quit emergency mode. Then log in to the system again. As a best practice, use the VIP to access Matrix.
6. Repair or recover DC controller 2.
After the cluster resumes services, you can repair or recover DC controller 2.
¡ To use a new physical server to replace controller 2, you are required to log in to the Matrix page to perform repair operations.
¡ If the file system of the original controller 2 can be restored and started correctly, the controller can automatically join the cluster after you power on it. Then the cluster will have three correctly operating controllers.
CAUTION: · After the nodes are rebuilt, the standby node will join the cluster as controller 1. The original controller 1 cannot join the cluster directly after failure recovery. As a best practice, format the drive on the original controller 1, install Matrix on it, and use it as the new standby node. · If two controllers in the cluster are abnormal, you are not allowed to restart the only normal node. If the normal node is restarted, the cluster cannot be recovered through 2+1+1 disaster recovery. |
