03-Interface Configuration Guide
HomeSupportSwitchesS12500R SeriesConfigure & DeployConfiguration GuidesH3C S12500R Switch Router Series Configuration Guides(R51xx)-6W10103-Interface Configuration Guide
02-Ethernet interface configuration
02-Ethernet interface configuration 214.21 KB
Configuring Ethernet interfaces· 1
About Ethernet interface· 1
Configuring a management Ethernet interface· 1
Ethernet interface naming conventions· 1
Restrictions and guidelines: Ethernet interface configuration· 2
Configuring common Ethernet interface settings· 2
Splitting a 100-GE interface and combining 10-GE breakout interfaces· 2
Splitting a 400-GE interface and combining 100-GE breakout interfaces· 3
Configuring basic settings of an Ethernet interface· 4
Configuring basic settings of an Ethernet subinterface· 4
Configuring the link mode of an Ethernet interface· 5
Forcibly bringing up a fiber port 5
Configuring jumbo frame support 6
Configuring physical state change suppression on an Ethernet interface· 7
Configuring dampening on an Ethernet interface· 8
Enabling link flapping protection on an interface· 9
Configuring storm suppression· 10
Configuring generic flow control on an Ethernet interface· 11
Configuring PFC on an Ethernet interface· 11
Setting the statistics polling interval 12
Enabling subinterface rate statistics collection on an Ethernet interface· 12
Enabling loopback testing on an Ethernet interface· 12
Configuring interface alarm functions· 13
Restoring the default settings for an interface· 17
Configuring a Layer 2 Ethernet interface· 17
Configuring storm control on an Ethernet interface· 17
Configuring a Layer 3 Ethernet interface or subinterface· 18
Setting the MTU for an Ethernet interface or subinterface· 18
Setting the MAC address of an Ethernet interface or subinterface· 19
Verifying and maintaining Ethernet interfaces· 19
Displaying the configuration and running status of Ethernet interfaces· 19
Displaying and clearing Ethernet interface statistics· 20
Displaying and clearing Ethernet module statistics· 20
The Switch Series supports Ethernet interfaces, management Ethernet interfaces, and Console interfaces. For the interface types and the number of interfaces supported by a switch model, see the installation guide.
This chapter describes how to configure management Ethernet interfaces and Ethernet interfaces.
A management interface uses an RJ-45/LC connector. You can connect the interface to a PC for software loading and system debugging, or connect it to a remote NMS for remote system management.
To avoid traffic interruption after active/standby MPU switchover, make sure the management Ethernet interface on the active MPU is correctly connected to the management Ethernet interface numbered the same on the standby MPU.
2.     Enter management Ethernet interface view.
interface M-GigabitEthernet interface-number
3.     (Optional.) Set the interface description.
The default setting is M-GigabitEthernet0/0/0 Interface.
4.     (Optional.) Set the duplex mode for the management Ethernet interface.
duplex { auto | full | half }
By default, the duplex mode is auto for a management Ethernet interface.
5.     (Optional.)_Set the speed for the management Ethernet interface.
speed { 10 | 100 | 1000 | auto }
By default, the speed is auto for a management Ethernet interface.
6.      (Optional.) Shut down the interface.
shutdown
By default, the management Ethernet interface is up.
The Ethernet interfaces are named in the format of interface type A/B/C. The letters that follow the interface type represent the following elements:
·     A—Card slot number.
·     B—Subcard slot number.
·     C—Port index.
A breakout interface is named in the format of interface type A/B/C:D. A/B/C is the interface number of the original interface before split. D is the number of the breakout interface, which is in the range of 1 to 4.
Do not preprovision modules when they are operating unstably. Otherwise, some interfaces might fail to be split.
This section describes the settings common to Layer 2 Ethernet interfaces, Layer 3 Ethernet interfaces, and Layer 3 Ethernet subinterfaces. For more information about the settings specific to Layer 2 Ethernet interfaces, see "Configuring a Layer 2 Ethernet interface." For more information about the settings specific to Layer 3 Ethernet interfaces or subinterfaces, see "Configuring a Layer 3 Ethernet interface or subinterface."
You can use a 100-GE interface as a single interface. To improve port density, reduce costs, and improve network flexibility, you can split a 100-GE interface into four 10-GE breakout interfaces. The 10-GE breakout interfaces support the same configuration and attributes as common 10-GE interfaces, except that they are numbered differently. For example, you can split 100-GE interface HundredGigE 1/0/1 into four 10-GE breakout interfaces Ten-GigabitEthernet 1/0/1:1 through Ten-GigabitEthernet 1/0/1:4.
If you need higher bandwidth on a single interface, you can combine the multiple 10-GE breakout interfaces into a 100-GE interface.
Restrictions and guidelines for 100-GE interface splitting and 10-GE breakout interface combining
·     For this feature to take effect stably, as a best practice, reboot the card where the related interface resides after executing this command. To view the split or combined interfaces, execute the display interface brief command.
·     For the breakout or combination operation to succeed, do not split or combine interfaces during the active/standby switchover process.
Splitting a 100-GE interface into multiple 10-GE breakout interfaces
2.     Enter 100-GE interface view.
interface hundredgige interface-number
3.     Split the 100-GE interface into multiple 10-GE breakout interfaces.
using tengige
By default, a 100-GE interface is not split and operates as a single interface.
Combining multiple 10-GE breakout interfaces into a 100-GE interface
2.     Enter the view of any 10-GE breakout interface.
interface ten-gigabitethernet interface-number
3.     Combine the multiple 10-GE breakout interfaces into a 100-GE interface.
using hundredgige
By default, a 10-GE breakout interface operates as a single interface.
You can use a 400-GE interface as a single interface. To improve port density, reduce costs, and improve network flexibility, you can also split a 400-GE interface into multiple 100-GE breakout interfaces. The 100-GE breakout interfaces support the same configuration and attributes as common 100-GE interfaces, except that they are numbered differently.
For example, you can split 400-GE interface FourHundredGigE 1/0/1 into four 100-GE breakout interfaces HundredGigE 1/0/1:1 and HundredGigE 1/0/1:4.
If you need higher bandwidth on a single interface, you can combine the  100-GE breakout interfaces into a 400-GE interface.
Restrictions and guidelines for 400-GE interface splitting and 100-GE breakout interface combining
·     To ensure that the breakout function works stably, as a best practice, reboot the slot of the interface after executing this command. To view the breakout or combined interfaces, execute the display interface brief command.
·     After a 400-GE interface is split into breakout interfaces, the breakout interfaces might go down and come up. Wait until the breakout interfaces are stable, and then use them to process user services.
Splitting a 400-GE interface into multiple 100-GE breakout interfaces
2.     Enter 400-GE interface view.
interface fourhundredgige interface-number
3.     Split the 400-GE interface into multiple 100-GE breakout interfaces.
using hundredgige [ mode 2-channel ]
By default, a 400-GE interface is not split and operates as a single interface.
The mode 2-channel keyword is supported in only R5111 and later.
Combining multiple 100-GE breakout interfaces into a 400-GE interface
2.     Enter the view of any 100-GE breakout interface.
3.     Combine these 100-GE breakout interfaces into a 400-GE interface.
using fourhundredgige
By default, a 100-GE breakout interface operates as a single interface.
You can configure an Ethernet interface to operate in one of the following duplex modes:
·     Full-duplex mode—The interface can send and receive packets simultaneously.
·     Autonegotiation mode—The interface negotiates a duplex mode with its peer.
You can set the speed of an Ethernet interface or enable it to automatically negotiate a speed with its peer.
The shutdown and port up-mode commands are mutually exclusive.
For information about the bandwidth, description, and shutdown commands, see Interface Command Reference.
2.     Enter Ethernet interface view.
3.     Set the description for the Ethernet interface.
The default setting is interface-name Interface. For example, HundredGigE1/0/1 Interface.
4.     Set the duplex mode for the Ethernet interface.
duplex { auto | full }
By default, the duplex mode is auto for Ethernet interfaces.
5.     Set the speed for the Ethernet interface.
speed { 10000 | 40000 | 100000 | 400000 | auto }
By default, the speed of an Ethernet interface is autonegotiated.
6.     Set the expected bandwidth for the Ethernet interface.
bandwidth bandwidth-value
By default, the expected bandwidth (in kbps) is the interface baud rate divided by 1000.
7.     Bring up the Ethernet interface.
By default, an Ethernet interface is down.
Restrictions and guidelines for Ethernet subinterface basic settings
·     The shutdown, port up-mode, and loopback commands are mutually exclusive.
·     The shutdown command cannot be configured on an Ethernet interface in a loopback test.
·     For information about the bandwidth, description, and shutdown commands, see Interface Command Reference.
2.     Create an Ethernet subinterface.
interface interface-type interface-number.subnumber
3.     Set the description for the Ethernet subinterface.
The default setting is interface-name Interface. For example, HundredGigE1/0/1.1 Interface.
4.     Set the expected bandwidth for the Ethernet subinterface.
5.     Bring up the Ethernet subinterface.
By default, an Ethernet subinterface is up.
Ethernet interfaces can operate either as Layer 2 or Layer 3 Ethernet interfaces. You can set the link mode to bridge (Layer 2) or route (Layer 3) for these Ethernet interfaces.
3.     Configure the link mode of the Ethernet interface.
By default, an Ethernet interface operates in Layer 3 mode.
CAUTION
CAUTION:
Changing the link mode of an Ethernet interface also restores all commands (except shutdown) on the Ethernet interface to their defaults in the new link mode.
As shown in Figure 1, a fiber port uses separate fibers for transmitting and receiving packets. The physical state of the fiber port is up only when both transmit and receive fibers are physically connected. If one of the fibers is disconnected, the fiber port does not work.
To enable a fiber port to forward traffic over a single link, you can use the port up-mode command. This command forcibly brings up a fiber port, even when no fiber links or transceiver modules are present for the fiber port. When one fiber link is present and up, the fiber port can forward packets over the link unidirectionally.
Figure 1 Forcibly bring up a fiber port
·     The port up-mode and shutdown commands are mutually exclusive.
·     A fiber port forcibly brought up stays physically up whether or not a transceiver module or a fiber link is present for the port.
3.     Forcibly bring up the fiber port.
port up-mode
By default, a fiber port is not forcibly brought up, and the physical state of a fiber port depends on the physical state of the fibers.
Jumbo frames are frames larger than 1536 bytes and are typically received by an Ethernet interface during high-throughput data exchanges, such as file transfers.
The Ethernet interface processes jumbo frames in the following ways:
·     When the Ethernet interface is configured to deny jumbo frames (by using the undo jumboframe enable command), the Ethernet interface discards jumbo frames.
·     When the Ethernet interface is configured with jumbo frame support, the Ethernet interface performs the following operations:
¡     Processes jumbo frames within the specified length.
¡     Discards jumbo frames that exceed the specified length.
3.     Configure jumbo frame support.
jumboframe enable [ size ]
By default, the device allows jumbo frames within 9964 bytes to pass through all Layer 2 Ethernet interfaces.
If you set the size argument multiple times, the most recent configuration takes effect.
The physical link state of an Ethernet interface is either up or down. Each time the physical link of an interface comes up or goes down, the interface immediately reports the change to the CPU. The CPU then performs the following operations:
·     Notifies the upper-layer protocol modules (such as routing and forwarding modules) of the change for guiding packet forwarding.
·     Automatically generates traps and logs to inform users to take the correct actions.
To prevent frequent physical link flapping from affecting system performance, configure physical state change suppression. You can configure this feature to suppress only link-down events, only link-up events, or both. If an event of the specified type still exists when the suppression interval expires, the system reports the event to the CPU.
Do not enable this feature on an interface that has spanning tree protocols or Smart Link enabled.
The link-delay and port link-flap protect enable commands are mutually exclusive on an Ethernet interface.
On an interface, you can configure different suppression intervals for link-up and link-down events. If you execute the link-delay command multiple times on an interface, the following rules apply:
·     You can configure the suppression intervals for link-up and link-down events separately.
·     If you configure the suppression interval multiple times for link-up or link-down events, the most recent configuration takes effect.
3.     Configure physical state change suppression.
By default, physical state change suppression is disabled.
The interface dampening feature uses an exponential decay mechanism to prevent excessive interface flapping events from adversely affecting routing protocols and routing tables in the network. Suppressing interface state change events protects the system resources.
If an interface is not dampened, its state changes are reported. For each state change, the system also generates an SNMP trap and log message.
After a flapping interface is dampened, it does not report its state changes to the CPU. For state change events, the interface only generates SNMP trap and log messages.
·     Penalty—The interface has an initial penalty of 0. When the interface flaps, the penalty increases by 1000 for each down event until the ceiling is reached. It does not increase for up events. When the interface stops flapping, the penalty decreases by half each time the half-life timer expires until the penalty drops to the reuse threshold.
·     Ceiling—The penalty stops increasing when it reaches the ceiling.
·     Suppress-limit—The accumulated penalty that triggers the device to dampen the interface. In dampened state, the interface does not report its state changes to the CPU. For state change events, the interface only generates SNMP traps and log messages.
·     Reuse-limit—When the accumulated penalty decreases to this reuse threshold, the interface is not dampened. Interface state changes are reported to the upper layers. For each state change, the system also generates an SNMP trap and log message.
·     Decay—The amount of time (in seconds) after which a penalty is decreased.
·     Max-suppress-time—The maximum amount of time the interface can be dampened. If the penalty is still higher than the reuse threshold when this timer expires, the penalty stops increasing for down events. The penalty starts to decrease until it drops below the reuse threshold.
·     When configuring the dampening command, follow these rules to set the values mentioned above:
·     The ceiling is equal to 2(Max-suppress-time/Decay)  × reuse-limit. It is not user configurable.
·     The configured suppress limit is lower than or equal to the ceiling.
·     The ceiling is lower than or equal to the maximum suppress limit supported.
Figure 2 shows the change rule of the penalty value. The lines t0 and t2 indicate the start time and end time of the suppression, respectively. The period from t0 to t2 indicates the suppression period, t0 to t1 indicates the max-suppress-time, and t1 to t2 indicates the complete decay period.
Figure 2 Change rule of the penalty value
·     The dampening, link-delay, and port link-flap protect enable commands are mutually exclusive on an interface.
·     The dampening command does not take effect on the administratively down events. When you execute the shutdown command, the penalty restores to 0, and the interface reports the down event to the upper-layer protocols.
·     Do not enable the dampening feature on an interface with MSTP or Smart Link enabled.
3.     Enable dampening on the interface.
By default, interface dampening is disabled on Ethernet interfaces.
Link flapping on an interface changes network topology and increases the system overhead. For example, in an active/standby link scenario, when interface status on the active link changes between UP and DOWN, traffic switches between active and standby links. To solve this problem, configure this feature on the interface.
With this feature enabled on an interface, when the interface goes down, the system enables link flapping detection. During the link flapping detection interval, if the number of detected flaps reaches or exceeds the link flapping detection threshold, the system shuts down the interface.
This feature takes effect only if it is configured in both the system view and interface view.
To bring up an interface that has been shut down by link flapping protection, execute the undo shutdown command.
In the display interface command output, the Link-Flap DOWN value of the Current state field indicates that the interface has been shut down by link flapping protection.
2.     Enable link flapping protection on all interfaces.
By default, link flapping protection is disabled on all interfaces.
3.     Enter Ethernet interface view.
4.     Enable link flapping protection on the Ethernet interface.
port link-flap protect enable [ interval interval | threshold threshold ] *
By default, link flapping protection is disabled on an Ethernet interface.
The storm suppression feature ensures that the size of a particular type of traffic (broadcast, multicast, or unknown unicast traffic) does not exceed the threshold on an interface. When the broadcast, multicast, or unknown unicast traffic on the interface exceeds this threshold, the system discards packets until the traffic drops below this threshold.
Both storm suppression and storm control can suppress storms on an interface. Storm suppression uses the chip to suppress traffic. Storm suppression has less impact on the device performance than storm control, which uses software to suppress traffic.
·     For the traffic suppression result to be determined, do not configure storm control together with storm suppression for the same type of traffic. For more information about storm control, see "Configuring storm control on an Ethernet interface."
3.     Enable broadcast suppression and set the broadcast suppression threshold.
By default, broadcast suppression is disabled.
4.     Enable multicast suppression and set the multicast suppression threshold.
By default, multicast suppression is disabled.
5.     Enable unknown unicast suppression and set the unknown unicast suppression threshold.
By default, unknown unicast suppression is disabled.
To avoid dropping packets on a link, you can enable generic flow control at both ends of the link. When traffic congestion occurs at the receiving end, the receiving end sends a flow control (Pause) frame to ask the sending end to suspend sending packets. Generic flow control includes the following types:
·     TxRx-mode generic flow control—Enabled by using the flow-control command. With TxRx-mode generic flow control enabled, an interface can both send and receive flow control frames:
¡     When congestion occurs, the interface sends a flow control frame to its peer.
¡     When the interface receives a flow control frame from its peer, it suspends sending packets to its peer.
·     Rx-mode generic flow control—Enabled by using the flow-control receive enable command. With Rx-mode generic flow control enabled, an interface can receive flow control frames, but it cannot send flow control frames:
¡     When congestion occurs, the interface cannot send flow control frames to its peer.
To handle unidirectional traffic congestion on a link, configure the flow-control receive enable command at one end and the flow-control command at the other end. To enable both ends of a link to handle traffic congestion, configure the flow-control command at both ends.
3.     Enable generic flow control.
¡     Enable TxRx-mode generic flow control.
flow-control
¡     Enable Rx-mode generic flow control.
By default, generic flow control is disabled on an Ethernet interface.
Priority-based flow control (PFC) provides a finer flow control mechanism to implement lossless packet transmission on Ethernet. For more information about PFC, see PFC configuration in Layer 2—LAN Switching Configuration Guide.
To display the interface statistics collected in the last statistics polling interval, use the display interface command. To clear the interface statistics, use the reset counters interface command..
Setting the statistics polling interval in Ethernet interface view
3.     Set the statistics polling interval for the Ethernet interface.
flow-interval interval
By default, the statistics polling interval for an Ethernet interface is 300 seconds.
After you enable subinterface rate statistics collection on an Ethernet interface, the device periodically refreshes the rate statistics on the subinterfaces of this Ethernet interface.
3.     Enable subinterface rate statistics collection on the Ethernet interface.
sub-interface rate-statistic
By default, subinterface rate statistics collection is disabled on an Ethernet interface.
4.     (Optional.) View the subinterface rate statistics.
display interface
Perform this task to determine whether an Ethernet link works correctly.
Internal loopback testing tests the device where the Ethernet interface resides. The Ethernet interface sends outgoing packets back to the local device. If the device fails to receive the packets, the device fails.
·     After you enable this feature on an Ethernet interface, the interface does not forward data traffic.
·     After you enable this feature on an Ethernet interface, the Ethernet interface switches to full duplex mode. After you disable this feature, the Ethernet interface restores to its duplex setting.
3.     Enable loopback testing.
loopback internal
By default, loopback testing is disabled on an interface.
With the interface alarm functions enabled, when the number of error packets on an interface in normal state within the specified interval exceeds the upper threshold, the interface generates an upper threshold exceeding alarm and enters the alarm state. When the number of error packets on an interface in the alarm state within the specified interval drops below the lower threshold, the interface generates a recovery alarm and restores to the normal state.
You can configure the interface alarm parameters in system view and interface view.
·     The configuration in system view takes effect on all interfaces of the specified slot. The configuration in interface view takes effect only on the current interface.
·     For an interface, the configuration in interface view takes priority, and the configuration in system view is used only when no configuration is made in interface view.
An interface that is shut down because of error packet alarms cannot automatically recover. To bring up the interface, execute the undo shutdown command on the interface.
Enabling interface alarm functions
2.     Enable alarm functions for the interface monitoring module.
snmp-agent trap enable ifmonitor [ crc-error | input-error | input-usage | output-error | output-usage | rx-pause | sdh-b1-error | sdh-b2-error | sdh-error | tx-pause ] *
By default, all alarm functions are enabled for interfaces.
Configuring CRC error packet parameters
2.     Configure global CRC error packet alarm parameters.
ifmonitor crc-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
By default, the upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for CRC error packets.
4.     Configure CRC error packet alarm parameters for the interface.
By default, an interface uses the global CRC error packet alarm parameters.
Configuring input error packet alarm parameters
2.     Configure global input error packet alarm parameters.
ifmonitor input-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
By default, the upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for input error packets.
4.     Configure input error packet alarm parameters for the interface.
By default, an interface uses the global input error packet alarm parameters.
Configuring output error packet alarm parameters
2.     Configure global output error packet alarm parameters.
ifmonitor output-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
By default, the upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for output error packets.
4.     Configure output error packet alarm parameters.
By default, an interface uses the global output error packet alarm parameters.
Configuring input bandwidth usage alarm parameters
2.     Configure global input bandwidth usage alarm parameters.
ifmonitor input-usage slot slot-number high-threshold high-value low-threshold low-value
By default, the upper threshold is 90 and the lower threshold is 80 for input bandwidth usage alarms.
4.     Configure input bandwidth usage alarm parameters.
By default, an interface uses the global input bandwidth usage alarm parameters.
Configuring output bandwidth usage alarm parameters
2.     Configure global output bandwidth usage alarm parameters.
ifmonitor output-usage slot slot-number high-threshold high-value low-threshold low-value
By default, the upper threshold is 90 and the lower threshold is 80 for output bandwidth usage alarms.
4.     Configure output bandwidth usage alarm parameters.
By default, an interface uses the global output bandwidth usage alarm parameters.
Configuring received pause frame alarm parameters
2.     Configure global received pause frame alarm parameters.
ifmonitor rx-pause slot slot-number high-threshold high-value low-threshold low-value interval interval
By default, the upper threshold is 500, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for received pause frames.
4.     Configure received pause frame alarm parameters.
port ifmonitor rx-pause high-threshold high-value low-threshold low-value interval interval
By default, an interface uses the global received pause frame alarm parameters.
Configuring sent pause frame alarm parameters
2.     Configure global sent pause frame alarm parameters.
ifmonitor tx-pause slot slot-number high-threshold high-value low-threshold low-value interval interval
By default, the upper threshold is 500, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for sent pause frames.
4.     Configure sent pause frame alarm parameters.
port ifmonitor tx-pause high-threshold high-value low-threshold low-value interval interval
By default, an interface uses the global sent pause frame alarm parameters.
Configuring SDH error packet alarm parameters
2.     Configure global SDH error packet alarm parameters.
ifmonitor sdh-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
By default, the upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for SDH error packets.
4.     Configure SDH error packet alarm parameters for the interface.
port ifmonitor sdh-error high-threshold high-value low-threshold low-value interval interval [ shutdown ]
By default, an interface uses the global SDH error packet alarm parameters.
Configuring SDH-B1 error packet alarm parameters
2.     Configure global SDH-B1 error packet alarm parameters.
ifmonitor sdh-b1-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
By default, the upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for SDH-B1 error packets.
4.     Configure SDH-B1 error packet alarm parameters for the interface.
port ifmonitor sdh-b1-error high-threshold high-value low-threshold low-value interval interval [ shutdown ]
By default, an interface uses the global SDH-B1 error packet alarm parameters.
Configuring SDH-B2 error packet alarm parameters
2.     Configure global SDH-B2 error packet alarm parameters.
ifmonitor sdh-b2-error slot slot-number high-threshold high-value low-threshold low-value interval interval [ shutdown ]
By default, the upper threshold is 1000, the lower threshold is 100, and the statistics collection and comparison interval is 10 seconds for SDH-B2 error packets.
4.     Configure SDH-B2 error packet alarm parameters for the interface.
port ifmonitor sdh-b2-error high-threshold high-value low-threshold low-value interval interval [ shutdown ]
By default, an interface uses the global SDH-B2 error packet alarm parameters.
CAUTION
CAUTION:
This feature might interrupt ongoing network services. Make sure you are fully aware of the impacts of this feature when you use it in a live network.
This feature might fail to restore the default settings for some commands because of command dependencies or system restrictions. You can use the display this command in interface view to check for these commands and perform their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message to resolve the problem.
For information about the default command, see Interface Command Reference.
2.     Enter Ethernet interface view or Ethernet subinterface view.
3.     Restore the default settings for the interface.
default
Storm control compares broadcast, multicast, and unknown unicast traffic regularly with their respective traffic thresholds on an Ethernet interface. For each type of traffic, storm control provides a lower threshold and an upper threshold.
Depending on your configuration, when a particular type of traffic exceeds its upper threshold, the interface performs either of the following operations:
·     Blocks this type of traffic and forwards other types of traffic—Even though the interface does not forward the blocked traffic, it still counts the traffic. When the blocked traffic drops below the lower threshold, the interface begins to forward the traffic.
·     Goes down automatically—The interface goes down automatically and stops forwarding any traffic. When the blocked traffic drops below the lower threshold, the interface does not automatically come up. To bring up the interface, use the undo shutdown command or disable the storm control feature.
You can configure an Ethernet interface to output threshold event traps and log messages when monitored traffic meets one of the following conditions:
·     Exceeds the upper threshold.
·     Drops below the lower threshold.
Both storm suppression and storm control can suppress storms on an interface. Storm suppression uses the chip to suppress traffic. Storm suppression has less impact on the device performance than storm control, which uses software to suppress traffic. For more information about storm suppression, see "Configuring storm suppression."
Storm control uses a complete polling cycle to collect traffic data, and analyzes the data in the next cycle. An interface takes one to two polling intervals to take a storm control action.
2.     (Optional.) Set the statistics polling interval of the storm control module.
storm-constrain interval interval
The default setting is 10 seconds.
For network stability, use the default or set a longer statistics polling interval.
4.     Enable storm control, and set the lower and upper thresholds for broadcast or unknown unicast traffic.
storm-constrain { broadcast | multicast | unicast } { pps | kbps | ratio } upperlimit lowerlimit
By default, storm control is disabled.
5.     Set the control action to take when monitored traffic exceeds the upper threshold.
6.     Enable the Ethernet interface to output log messages when it detects storm control threshold events.
storm-constrain enable log
By default, the Ethernet interface outputs log messages when monitored traffic exceeds the upper threshold or drops below the lower threshold from a value above the upper threshold.
7.     Enable the Ethernet interface to send storm control threshold event traps.
storm-constrain enable trap
By default, the Ethernet interface sends traps when monitored traffic exceeds the upper threshold or drops below the lower threshold from the upper threshold from a value above the upper threshold.
The maximum transmission unit (MTU) of an Ethernet interface affects the fragmentation and reassembly of IP packets on the interface. Typically, you do not need to modify the MTU of an interface.
2.     Enter interface view.
3.     Set the interface MTU.
mtu size
The default setting is 1500 bytes.
In a network, when the Layer 3 Ethernet interfaces or subinterfaces of different devices have the same MAC address, the devices might fail to communicate correctly. To eliminate the MAC address conflicts, use the mac-address command to modify the MAC addresses of Layer 3 Ethernet interfaces or subinterfaces.
Additionally, when a Layer 3 Ethernet subinterface is created, it uses the MAC address of its main interface by default. As a result, all Layer 3 Ethernet subinterfaces of a Layer 3 Ethernet interface share the same MAC address. To set a different MAC address for a Layer 3 Ethernet subinterface, use the mac-address command.
When you set a MAC address, make sure the following requirements are met:
·     The MAC address must have the same highest 36 bits as the base MAC address.
·     The MAC address must be no lower than the base MAC address plus 160 (decimal).
For more information about base MAC address, see MAC address table in Layer 2—LAN Switching Configuration Guide.
3.     Set the interface MAC address.
mac-address mac-address
By default, no MAC address is configured for an Ethernet interface.
As a best practice, do not set a MAC address in the VRRP-reserved MAC address range for a Layer 3 Ethernet subinterface.
Perform all display tasks in any view.
·     Display the running status and related information of the specified interfaces.
display interface [ interface-type [ interface-number | interface-number.subnumber ] ] [ brief [ description | down ] ]
·     Display interfaces that can be split.
display interface split-capable [ slot slot-number ]
·     Display link flapping protection information on the specified interfaces.
display link-flap protection [ interface interface-type [ interface-number ] ]
·     Display PFC information on the specified interfaces.
display priority-flow-control interface [ interface-type [ interface-number ] ]
·     Display storm control information on the specified interfaces.
display storm-constrain [ broadcast | multicast | unicast ] [ interface interface-type interface-number ]
Displaying Ethernet interface statistics
·     Display interface traffic statistics.
display counters { inbound | outbound } interface [ interface-type [ interface-number | interface-number.subnumber ] ]
For information about this command, see common interface commands in Interface Command Reference.
·     Display traffic rate statistics of interfaces in up state over the last statistics polling interval.
display counters rate { inbound | outbound } interface [ interface-type [ interface-number | interface-number.subnumber ] ]
·     Display information about packets dropped on an interface.
display packet-drop { interface [ interface-type [ interface-number ] ] | summary }
Clearing Ethernet interface statistics
Perform all clear tasks in user view.
·     Clear Ethernet interface statistics.
reset counters interface [ interface-type [ interface-number | interface-number.subnumber ] ]
·     Clear the dropped packet statistics for an interface.
reset packet-drop interface [ interface-type [ interface-number ] ]
Displaying Ethernet module statistics
To display the Ethernet module statistics, execute the following command in any view:
display ethernet statistics slot slot-number
Clearing Ethernet module statistics
To clear the Ethernet module statistics, execute the following command in user view:
reset ethernet statistics [ slot slot-number ]
