10-EVPN Command Reference
HomeSupportSwitchesS12500R SeriesReference GuidesCommand ReferencesH3C S12500R Switch Router Series Command References(R51xx)-6W10110-EVPN Command Reference
01-EVPN commands
01-EVPN commands 169.69 KB
Basic EVPN commands
address-family evpn (public instance view)
Use address-family evpn to enter public instance EVPN view.
Use undo address-family evpn to delete all settings in public instance EVPN view.
address-family evpn
Public instance view
You can configure EVPN settings such as route targets in public instance EVPN view.
# Enter public instance EVPN view.
[Sysname] ip public-instance
[Sysname-public-instance] address-family evpn
[Sysname-public-instance-evpn]
address-family evpn (VPN instance view)
Use address-family evpn to enter VPN instance EVPN view.
Use undo address-family evpn to delete all settings in VPN instance EVPN view.
address-family evpn
VPN instance view
You can configure EVPN settings such as route targets and routing policies in VPN instance EVPN view.
# Enter EVPN view of VPN instance tenant.
[Sysname] ip vpn-instance tenant
[Sysname-vpn-instance-tenant] address-family evpn
[Sysname-vpn-evpn-tenant]
address-family ipv4 (public instance view)
Use address-family ipv4 to enter public instance IPv4 address family view.
Use undo address-family ipv4 to delete all settings in public instance IPv4 address family view.
address-family ipv4
# Enter public instance IPv4 address family view.
[Sysname-public-instance] address-family ipv4
[Sysname-public-instance-ipv4]
address-family l2vpn evpn
Use address-family l2vpn evpn to create the BGP EVPN address family and enter its view, or enter the view of the existing BGP EVPN address family.
Use undo address-family l2vpn evpn to delete the BGP EVPN address family and all settings in BGP EVPN address family view.
The BGP EVPN address family does not exist.
BGP instance view
Configuration made in BGP EVPN address family view takes effect only on routes and peers of the BGP EVPN address family that are on the public network.
# Create the BGP EVPN address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn evpn
[Sysname-bgp-default-evpn]
advertise l2vpn evpn
Use advertise l2vpn evpn to enable BGP EVPN route advertisement to the local site.
Use undo advertise l2vpn evpn to disable BGP EVPN route advertisement to the local site.
BGP EVPN route advertisement to the local site is enabled.
BGP-VPN IPv4 unicast address family view
This command enables the device to advertise private BGP EVPN routes to the local site after the device adds the routes to the routing table of a VPN instance.
# Enable BGP EVPN route advertisement to the local site for VPN instance vpn1.
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv4
[Sysname-bgp-default-ipv4-vpn1] advertise l2vpn evpn
arp mac-learning disable
Use arp mac-learning disable to disable an EVPN instance from learning MAC addresses from ARP information.
Use undo arp mac-learning disable to restore the default.
An EVPN instance learns MAC addresses from ARP information.
EVPN instance view
The MAC information and ARP information advertised by a remote VTEP overlap. To avoid duplication, use this command to disable the learning of MAC addresses from ARP information. EVPN will learn remote MAC addresses only from the MAC information advertised from remote sites.
# Disable an EVPN instance from learning MAC addresses from ARP information.
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation vxlan
[Sysname-vsi-aaa-evpn-vxlan] arp mac-learning disable
arp-advertising disable
Use arp-advertising disable to disable ARP information advertisement for an EVPN instance.
Use undo arp-advertising disable to restore the default.
ARP information advertisement is enabled for an EVPN instance.
EVPN instance view
In an EVPN network with distributed gateways, you can disable ARP information advertisement for a VXLAN to save resources if all its user terminals use the same EVPN gateway device. The EVPN instance of the VXLAN will stop advertising ARP information through MAC/IP advertisement routes and withdraw advertised ARP information. When ARP information advertisement is disabled, user terminals in other VXLANs still can communicate with that VXLAN through IP prefix advertisement routes.
# Disable ARP information advertisement for an EVPN instance.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] arp-advertising disable
display bgp l2vpn evpn
Use display bgp l2vpn evpn to display BGP EVPN routes.
display bgp [ instance instance-name ] l2vpn evpn [ peer ipv4-address { advertised-routes | received-routes } [ statistics ] | [ route-distinguisher route-distinguisher | route-type { imet | ip-prefix | mac-ip } ] * [ { evpn-route route-length | evpn-prefix } [ advertise-info ] | ipv4-address | mac-address ] | statistics ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP EVPN routes for the default BGP instance.
peer ipv4-address: Specifies a peer by its IPv4 address.
advertised-routes: Specifies the routes advertised to the specified peer.
received-routes: Specifies the routes received from the specified peer.
statistics: Displays BGP EVPN route statistics.
route-distinguisher route-distinguisher: Specifies a route distinguisher (RD), a string of 3 to 21 characters. The RD can use one of the following formats:
·     16-bit AS number:32-bit user-defined number. For example, 101:3.
·     32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
·     32-bit AS number:16-bit user-defined number. For example, 65536:1. The AS number must be equal to or greater than 65536.
route-type: Specifies a route type.
imet: Specifies inclusive multicast Ethernet tag (IMET) routes.
ip-prefix: Specifies IP prefix advertisement routes.
mac-ip: Specifies MAC/IP advertisement routes.
evpn-route: Specifies a BGP EVPN route, a case-insensitive string of 1 to 512 characters.
route-length: Specifies the route length in bits, in the range of 0 to 65535.
evpn-prefix: Specifies a BGP EVPN route in the format of evpn-route/route-length, a case-insensitive string of 1 to 512 characters.
advertise-info: Displays advertisement information for BGP EVPN routes.
ipv4-address: Specifies an IPv4 address.
mac-address: Specifies a MAC address in MAC/IP advertisement routes. If you specify the route-type keyword, to use this argument, you must also specify the mac-ip keyword.
If you do not specify any parameter, this command displays brief information about all BGP EVPN routes.
# Display brief information about all BGP EVPN routes.
<Sysname> display bgp l2vpn evpn
 BGP local router ID is 1.1.1.9
                a – additional-path
 Total number of routes from all PEs: 6
 Route distinguisher: 100:1
 Total number of routes: 3
* >  [2][0][48][00aa.00bb.00cc][4][0.0.0.0]/136
                       10.1.1.2        0                   32768   ?
*  e                   10.1.1.1        0                   0       65410?
* >  [3][300][16][::ffff:1.1.1.1]/176
                       127.0.0.1       0                   32768   ?
 Route distinguisher: 200:1
 Total number of routes: 2
* >i [2][0][48][00aa.00cc.00dd][4][1.1.1.1]/136
                       3.3.3.9         0         100       0       ?
* >i [3][300][16][::ffff:2.2.2.2]/176
                       3.3.3.9         0         100       0       65420?
Route distinguisher of public instance: 1:15
Total number of routes: 1
* >e [2][0][48][0011.0022.0033][32][11.22.33.55]/136
                        30.30.1.2       0                     0       100i
Status codes
Route status codes:
·     * - valid—Valid route.
·     > - best—Optimal route.
·     d - dampened—Dampened route.
·     h - history—History route.
·     i - internal—Internal route.
·     e - external—External route.
·     s - suppressed—Suppressed route.
·     S - stale—Stale route.
·     a - additional-path—Add-Path optimal route.
Origin
Origin of the route:
·     i – IGP—Originated in the AS. The origin of routes advertised by using the network command is IGP.
·     e – EGP—Learned through EGP.
·     ? – incomplete—Unknown origin. The origin of routes redistributed from IGP protocols is incomplete.
Network
BGP EVPN route/route length. BGP EVPN routes are as follows:
·     [2][EthernetTagID][MACLength][MAC][IPAddressLength][IPAddress]
¡     2—MAC/IP advertisement route.
¡     EthernetTagID—Ethernet tag ID.
¡     MACLength—MAC address length.
¡     MAC—MAC address.
¡     IPAddressLength—IP address length.
¡     IPAddress—IP address.
·     [3][EthernetTagID][IPAddressLength][IPAddress]
¡     3—IMET route.
¡     IPAddress—IP address of the originating router.
·     [5][EthernetTagID][IPAddressLength][IPAddress]
¡     5—IP prefix advertisement route.
NextHop
Next hop IP address.
MED
Multi-Exit Discriminator (MED) attribute.
LocPrf
Local precedence.
PrefVal
Preferred value.
Path/Ogn
AS_PATH and ORIGIN attributes of the route.
# Display detailed information about BGP EVPN route [2][5][48][0001-0203-0405][32][4.5.5.5]/136 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [2][5][48][0001-0203-0405][32][5.5.5.5] 136
 BGP local router ID: 172.16.250.133
 Local AS number: 100
 Route distinguisher: 1.1.1.1:100
 Paths:   1 available, 1 best
 BGP routing table information of [2][5][48][0001-0203-0405][32][5.5.5.5]/136:
 Rely nexthop    : 10.1.1.2
 Original nexthop: 10.1.1.2
 OutLabel        : 0
 Ext-Community   : <RT: 1:2>, <RT: 1:3>, <RT: 1:4>, <RT: 1:5>, <RT: 1:6>, <RT: 1:7
                   >, <Encapsulation Type: VXLAN>, <Router's Mac: 0006-0708-0910
                   >, <MAC Mobility: Flag 0, SeqNum 2>, <Default GateWay>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : MAC/IP advertisement route
 ESI             : 00:01:02:03:04:05:06:07:08:09
 Ethernet tag ID : 5
 MAC address     : 0001-0203-0405
 IP address      : 5.5.5.5/32
 MPLS label1     : 10
 MPLS label2     : 0
Paths
Number of routes:
·     available—Number of valid routes.
·     best—Number of optimal routes.
From
IP address of the BGP peer that advertised the route.
Rely nexthop
Next hop after route recursion. If no next hop is found, this field displays not resolved.
Original nexthop
Original next hop of the route. If the route was obtained from a BGP update message, the original next hop is the next hop IP address in the message.
OutLabel
Outgoing label of the route.
Ext-Community
Extended community attributes:
·     RT.
·     Encapsulation Type.
·     Router's Mac.
·     MAC Mobility—MAC mobility.
¡     Flag—Indicates whether the MAC address can move. A value of 1 indicates that the MAC address cannot move, and a value of 0 indicates that the MAC address can move.
¡     SeqNum—Identifies the most recent move of the MAC address.
·     Default GateWay—Route for the default gateway.
RxPathID
Add-Path ID value of the received route.
This field is not supported by the BGP EVPN address family.
TxPathID
Add-Path ID value of the sent route.
AS-path
AS_PATH attribute of the route. This attribute records the ASs the route has passed and avoids routing loops.
Origin
·     igp—Originated in the AS. The origin of routes advertised by using the network command is IGP.
·     egp—Learned through EGP.
·     incomplete—Unknown origin. The origin of routes redistributed from IGP protocols is incomplete.
Attribute value
Attributes of the route:
·     MED—MED value for the destination network.
·     localpref—Local preference value.
·     pref-val—Preferred value.
·     pre—Route preference value.
Current state of the route:
·     valid.
·     internal.
·     external.
·     local.
·     synchronize.
·     best.
IP precedence
IP precedence in the range of 0 to 7. N/A indicates that the IP precedence is invalid.
QoS local ID
QoS local ID in the range of 1 to 4095. N/A indicates that the QoS local ID is invalid.
Traffic index
Traffic index in the range of 1 to 64. N/A indicates that the traffic index is invalid.
MPLS label1
VXLAN ID used for Layer 2 forwarding.
MPLS label2
L3 VXLAN ID used for Layer 3 forwarding.
# Display detailed information about BGP EVPN route [3][0][32][5.5.5.5]/80 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [3][0][32][4.5.5.5] 80
 BGP routing table information of [3][0][32][4.5.5.5]/80:
 OutLabel        : 0
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: VXLAN>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 Attribute value : MED 0,pref-val 0
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : Inclusive multicast Ethernet tag route
 Ethernet tag ID : 0
 Origin address  : 5.5.5.5/32
Ext-Community
·     RT.
Origin address
# Display detailed information about BGP EVPN route [5][10][32][4.5.5.5]/80 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [5][10][32][4.5.5.5] 80
 BGP routing table information of [5][10][32][4.5.5.5]/80:
 OutLabel        : 0
 Ext-Community   : <RT: 1:2>, <Encapsulation Type: VXLAN>, <Router's Mac:
                   0006-0708-0910>
 RxPathID        : 0x0
 TxPathID        : 0x0
 AS-path         : 200
 Origin          : igp
 IP precedence   : N/A
 QoS local ID    : N/A
 Traffic index   : N/A
 EVPN route type : IP prefix advertisement route
 ESI             : 00:00:00:00:00:00:00:00:00:0a
 Ethernet tag ID : 10
 IP address      : 4.5.5.5/32
 Gateway address : 0.0.0.0
 MPLS Label      : 1
Ext-Community
·     RT.
·     Router's Mac.
IP address
IP address and prefix length.
MPLS Label
# Display detailed information about BGP EVPN route [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:0a] [32][4.5.5.5] 128 advertise-info
 Paths:   1 best
 BGP routing table information of [4][00:00:00:00:00:00:00:00:00:0a][32][4.5.5.5]/128:
    10.2.1.2
Table 5 Command output
Paths
Peers to whom the route has been advertised and the number of the peers.
display evpn auto-discovery
Use display evpn auto-discovery to display information about peers that are automatically discovered through BGP.
display evpn auto-discovery { imet [ peer ip-address] [ vsi vsi-name ] | macip-prefix [ nexthop next-hop ] [ count ] }
imet: Specifies peers discovered through IMET routes.
peer ip-address: Specifies a peer by its IP address. If you do not specify this option, the command displays information about all automatically discovered peers.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays peer information for all VSIs.
macip-prefix: Specifies peers discovered through MAC/IP advertisement routes and IP prefix advertisement routes.
nexthop next-hop: Specifies a next hop. If you do not specify this option, the command displays peer information for all next hops.
count: Displays the number of peers. If you do not specify this keyword, the command displays detailed peer information.
# Display information about peers discovered through IMET routes.
<Sysname> display evpn auto-discovery imet
Total number of automatically discovered peers: 2
VSI name: vpna
RD                    PE_address      Tunnel_address  Tunnel mode VXLAN ID
1:10                  2.2.2.2         2.2.2.2         VXLAN       10
2:100                 3.3.3.3         3.3.3.3         VXLAN       10
Table 6 Command output
PE_address
Identifier of the remote VTEP on the VSI.
Tunnel_address
Tunnel destination IP address.
Tunnel mode
Tunnel mode:
·     VXLAN.
·     VXLAN-DCI.
# Display information about peers discovered through MAC/IP advertisement routes and IP prefix advertisement routes.
<Sysname> display evpn auto-discovery macip-prefix
Destination IP  Source IP       L3VNI           Tunnel mode Outgoing interface
1.1.1.1         3.3.3.3         200             VXLAN       Vsi-interface3
2.2.2.2         3.3.3.3         200             VXLAN       Vsi-interface3
# Display the total number of peers discovered through MAC/IP advertisement routes and IP prefix advertisement routes.
<Sysname> display evpn auto-discovery macip-prefix count
Total number of entries: 2
Table 7 Command output
Destination IP
Source IP
Tunnel source IP address.
L3VNI
Tunnel mode
Tunnel mode:
·     VXLAN.
·     VXLAN-DCI.
Outgoing interface
VSI interface associated with the L3 VXLAN ID.
display evpn route arp
Use display evpn route arp to display EVPN ARP entries.
display evpn route arp [ local | remote ] [ public-instance | vpn-instance vpn-instance-name ] [ count ]
local: Specifies local ARP entries.
remote: Specifies remote ARP entries.
public-instance: Specifies the public instance.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
count: Displays the number of ARP entries. If you do not specify this keyword, the command displays detailed information about ARP entries.
If you do not specify the local or remote keyword, this command displays both local and remote EVPN ARP entries.
If you do not specify the public-instance keyword or the vpn-instance vpn-instance-name option, this command displays EVPN ARP entries for the public instance and all VPN instances.
# Display all EVPN ARP entries.
<Sysname> display evpn route arp
Flags: D - Dynamic   B - BGP      L - Local active
       G - Gateway   S - Static   M - Mapping
VPN instance: vpn1                            Interface: Vsi-interface1
IP address      MAC address     Router MAC      VSI index   Flags
10.1.1.1        0003-0003-0003  a0ce-7e40-0400  0           GL
10.1.1.11       0001-0001-0001  a0ce-7e40-0400  0           DL
10.1.1.12       0001-0001-0011  a0ce-7e41-0401  0           B
10.1.1.13       0001-0001-0021  a0ce-7e42-0402  0           B
Public instance                               Interface: Vsi-interface2
11.1.1.1        0033-0033-0033  a0ce-7e40-0400  0           GL
11.1.1.11       0011-0011-0011  a0ce-7e40-0400  0           DL
# Display the total number of EVPN ARP entries.
<Sysname> display evpn route arp count
Total number of entries: 6
Table 8 Command output
VSI interface.
Flags
ARP entry type:
·     D—The entry is dynamically learned.
·     B—The entry is learned from BGP EVPN routes.
·     L—The local entry is active. If this flag is not set and the B flag is set, the entry learned from BGP EVPN routes is active.
·     G—The entry for the gateway is active.
·     S—The static entry is active.
·     M—The entry from a remote VXLAN mapped to a local VXLAN is active.
display evpn route arp suppression
Use display evpn route arp suppression to display EVPN ARP flood suppression entries.
display evpn route arp suppression [ local | remote ] [ vsi vsi-name ] [ count ]
local: Specifies local ARP flood suppression entries.
remote: Specifies remote ARP flood suppression entries.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays ARP flood suppression entries for all VSIs.
count: Displays the number of ARP flood suppression entries. If you do not specify this keyword, the command displays detailed information about ARP flood suppression entries.
If you do not specify the local or remote keyword, this command displays both local and remote EVPN ARP flood suppression entries.
# Display all EVPN ARP flood suppression entries.
<Sysname> display evpn route arp suppression
VSI name: vpna
IP address      MAC address     Flags
10.1.1.12       0002-0002-0002  B
# Display the total number of ARP flood suppression entries.
<Sysname> display evpn route arp suppression count
Total number of entries: 1
Table 9 Command output
Flags
ARP flood suppression entry type:
display evpn route mac
Use display evpn route mac to display EVPN MAC address entries.
display evpn route mac [ local | remote ] [ vsi vsi-name ] [ count ]
local: Specifies local MAC address entries.
remote: Specifies remote MAC address entries.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays MAC address entries for all VSIs.
count: Displays the number of MAC address entries. If you do not specify this keyword, the command displays detailed information about MAC address entries.
If you do not specify the local or remote keyword, this command displays both local and remote EVPN MAC address entries.
# Display all EVPN MAC address entries.
<Sysname> display evpn route mac
VSI name: bbb
MAC address     Link ID/Name    Flags   Next hop
0000-0000-000a  1               DL      -
0000-0000-0009  Tunnel1         B       2.2.2.2
# Display the total number of EVPN MAC address entries.
<Sysname> display evpn route mac count
Table 10 Command output
Link ID/Name
For a local MAC address, this field displays the AC's link ID on the VSI.
For a remote MAC address, this field displays the tunnel interface name.
Flags
MAC address entry type:
Next hop
IP address of the remote VTEP. If the MAC address entry is a local entry, a hyphen (-) is displayed.
display evpn routing-table
Use display evpn routing-table to display EVPN routing table information.
display evpn routing-table { public-instance | vpn-instance vpn-instance-name } [ count ]
count: Displays the number of entries in the routing table. If you do not specify this keyword, the command displays detailed information about the routing table.
# Display the EVPN IPv4 routing table for VPN instance vpn1.
<Sysname> display evpn routing-table vpn-instance vpn1
VPN instance name: vpn1                             Local L3VNI: 7
IP address         Nexthop            Outgoing interface       NibID
10.1.1.11          1.1.1.1            Vsi-interface3           0x18000000
10.1.1.12          2.2.2.2            Vsi-interface3           0x18000001
# Display the EVPN IPv4 routing table for the public instance.
<Sysname> display evpn routing-table public-instance
Public instance                                     Local L3VNI: 3900
# Display the number of EVPN route entries in the IPv4 routing table for VPN instance vpn1.
<Sysname> display evpn routing-table vpn-instance vpn1 count
Table 11 Command output
Local L3VNI
L3 VXLAN ID associated with the VPN instance or the public instance.
NibID
Next hop ID.
evpn encapsulation
Use evpn encapsulation to create an EVPN instance and enter its view, or enter the view of an existing EVPN instance.
Use undo evpn encapsulation to restore the default.
No EVPN instance exists.
VSI view
vxlan: Specifies VXLAN encapsulation.
Before you can configure EVPN settings, you must create an EVPN instance.
# Create an EVPN instance and enter its view.
[Sysname] vsi aaa
export route-policy
Use export route-policy to apply an export routing policy to EVPN on a VPN instance.
Use undo export route-policy to restore the default.
No export routing policy is applied to EVPN on a VPN instance.
route-policy: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
You can specify an export routing policy to filter advertised routes or modify their route attributes for EVPN.
EVPN can use an export routing policy specified in VPN instance view or VPN instance EVPN view. Export routing policy configuration in VPN instance EVPN view takes precedence over that in VPN instance view.
# Apply export routing policy poly-1 to EVPN on VPN instance vpn1.
[Sysname-vpn-instance-vpn1] address-family evpn
[Sysname-vpn-evpn-vpn1] export route-policy poly-1
route-policy (Layer 3—IP Routing Command Reference)
import evpn mac-ip
Use import evpn mac-ip to enable the device to redistribute received MAC/IP advertisement routes that contain ARP information into a BGP unicast routing table.
Use undo import evpn mac-ip to disable the device from redistributing received MAC/IP advertisement routes that contain ARP information into a BGP unicast routing table.
import evpn mac-ip
MAC/IP advertisement routes that contain ARP information are not redistributed into any BGP unicast routing table.
BGP IPv4 unicast address family view
This command enables the device to redistribute received MAC/IP advertisement routes that contain ARP information into a BGP unicast routing table.
·     If you use this command in BGP IPv4 unicast address family view, the device will redistribute the routes into the BGP IPv4 unicast routing table. In addition, the device will advertise the routes to the local site.
·     If you use this command in BGP-VPN IPv4 unicast address family view, the device will redistribute the routes into the BGP-VPN IPv4 unicast routing table of the corresponding VPN instance. To advertise the routes to the local site, you must configure the advertise l2vpn evpn command.
# Redistribute received MAC/IP advertisement routes into the BGP-VPN IPv4 unicast routing table of VPN instance vpna.
[Sysname] bgp 100
[Sysname-bgp-default] ip vpn-instance vpna
[Sysname-bgp-default-vpna] address-family ipv4
[Sysname-bgp-default-ipv4-vpna] import evpn mac-ip
import route-policy
Use import route-policy to apply an import routing policy to EVPN on a VPN instance.
Use undo import route-policy to restore the default.
No import routing policy is applied to EVPN on a VPN instance. The VPN instance accepts a route when the export route targets of the route match local import route targets.
You can specify an import routing policy to filter received routes or modify their route attributes for EVPN.
EVPN can use an import routing policy specified in VPN instance view or VPN instance EVPN view. Import routing policy configuration in VPN instance EVPN view takes precedence over that in VPN instance view.
# Apply import routing policy poly-1 to EVPN on VPN instance vpn1.
[Sysname-vpn-evpn-vpn1] import route-policy poly-1
ip public-instance
Use ip public-instance to create the public instance and enter its view, or enter the view of the existing public instance.
Use undo ip public-instance to delete the public instance.
ip public-instance
The public instance does not exist.
A distributed EVPN gateway uses the public instance to perform Layer 3 forwarding for the public network and to enable communication between private and public networks. The public instance is similar to a VPN instance. A distributed EVPN gateway processes traffic of the public instance in the same way it does for a VPN instance.
# Create the public instance and enter its view.
l3-vni
Use l3-vni to configure an L3 VXLAN ID for a VSI interface or for the public instance.
Use undo l3-vni to remove the L3 VXLAN ID for a VSI interface or for the public instance.
l3-vni vxlan-id
undo l3-vni
No L3 VXLAN ID is configured for a VSI interface or for the public instance.
VSI interface view
vxlan-id: Specifies a VXLAN ID in the range of 0 to 16777215.
On distributed EVPN gateways, you must configure L3 VXLAN IDs for the gateways to differentiate traffic of different VPN instances.
To forward Layer 3 traffic of a VPN instance, you must assign an L3 VXLAN ID to the VSI interface of the VPN instance. To forward Layer 3 traffic of the public network, you must assign the same L3 VXLAN ID to the public instance and the VSI interface of the public instance.
To modify the L3 VXLAN ID for the public instance, you must first delete the original L3 VXLAN ID.
The L3 VXLAN ID specified by using this command cannot be the same as any VXLAN ID specified by using the mapping vni command.
# Configure the L3 VXLAN ID as 1000 for VSI-interface 100.
[Sysname] interface vsi-interface 100
[Sysname-Vsi-interface100] l3-vni 1000
mac-advertising disable
Use mac-advertising disable to disable MAC address advertisement and withdraw advertised MAC addresses.
Use undo mac-advertising disable to restore the default.
MAC address advertisement is enabled.
EVPN instance view
The MAC information and ARP information advertised by the VTEP overlap. To avoid duplication, use this command to disable MAC address advertisement and withdraw the MAC addresses advertised to remote VTEPs.
# Disable MAC address advertisement and withdraw advertised MAC addresses for an EVPN instance.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] mac-advertising disable
peer advertise vpn-reoriginate ibgp
Use peer advertise vpn-reoriginate ibgp to enable advertising the IP prefix advertisement routes reoriginated for a VPN instance to an IBGP peer or peer group.
Use undo peer advertise vpn-reoriginate ibgp to restore the default.
peer { group-name | ipv4-address [ mask-length ] } advertise vpn-reoriginate ibgp
undo { group-name | ipv4-address [ mask-length ] } peer advertise vpn-reoriginate ibgp
The device does not advertise the IP prefix advertisement routes reoriginated for a VPN instance to IBGP peers or peer groups.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The peer group must exist.
ipv4-address: Specifies a peer by its IPv4 address. The peer must exist.
mask-length: Specifies a mask length in the range of 0 to 32. To specify a subnet, you must specify both the ipv4-address and mask-length arguments.
For this command to take effect, you must also execute the advertise route-reoriginate command.
This command enables the device to advertise the IP prefix advertisement routes reoriginated for VPN instances to IBGP peers after the advertise route-reoriginate command is executed for the VPN instances.
# Enable advertising the IP prefix advertisement routes reoriginated for VPN instances to IBGP peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 advertise vpn-reoriginate ibgp
advertise route-reoriginate (MPLS Command Reference)
peer next-hop-invariable
Use peer next-hop-invariable to configure the device to not change the next hop of routes advertised to an EBGP peer or peer group.
Use undo peer next-hop-invariable to configure the device to use its address as the next hop of routes advertised to an EBGP peer or peer group.
undo peer { group-name | ipv4-address [ mask-length ] } next-hop-invariable
The device uses its address as the next hop of routes advertised to EBGP peers or peer groups.
This command is exclusive with the peer next-hop-local command.
The next hop in BGP EVPN routes is the IP address of the originating VTEP. By default, the device replaces the next hop of IBGP routes with its address when advertising the routes to an EBGP peer. If the device is a transport network device, it will modify the next hop of BGP EVPN routes. For VTEPs to learn one another's IP address, you must configure the device to not change the next hop of routes advertised to EBGP peers.
# Configure the device to not change the next hop of routes advertised to EBGP peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 next-hop-invariable
peer next-hop-local (Layer 3—IP Routing Command Reference)
policy vpn-target
Use policy vpn-target to enable route target filtering for BGP EVPN routes.
Use undo policy vpn-target to disable route target filtering for BGP EVPN routes.
policy vpn-target
Route target filtering is enabled for BGP EVPN routes.
When route target filtering is enabled for BGP EVPN routes, the EVPN routing table accepts only BGP EVPN routes of which the export route targets match the local import route targets. If the device must save all BGP EVPN routes, use the undo policy vpn-target command to disable route target filtering for BGP EVPN routes.
# Disable route target filtering for BGP EVPN routes.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] undo policy vpn-target
route-distinguisher (EVPN instance view)
Use route-distinguisher to configure an RD for an EVPN instance.
Use undo route-distinguisher to restore the default.
route-distinguisher { route-distinguisher | auto }
No RD is configured for an EVPN instance.
EVPN instance view
route-distinguisher: Specifies an RD, a string of 3 to 21 characters. The RD cannot be all zeros and can use one of the following formats:
auto: Automatically generates an RD in the N:VXLAN ID format. The initial value of N is 1. If N:VXLAN ID is already in use, the system increases the value of N by 1 until the RD is available.
EVPN uses MP-BGP to advertise BGP EVPN routes for automatic VTEP discovery, MAC reachability information advertisement, and host route advertisement. MP-BGP uses the RD to differentiate BGP EVPN routes of different EVPN instances.
# Configure 22:1 as the RD of an EVPN instance.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] route-distinguisher 22:1
route-distinguisher (public instance view)
Use route-distinguisher to configure an RD for the public instance.
No RD is configured for the public instance.
route-distinguisher: Specifies an RD, a string of 3 to 21 characters. The RD can use one of the following formats:
To modify the RD of the public instance, first execute the undo route-distinguisher command to remove the original RD.
# Configure 22:1 as the RD of the public instance.
[Sysname-public-instance] route-distinguisher 22:1
rr-filter
Use rr-filter to create a route reflector (RR) reflection policy.
Use undo rr-filter to restore the default.
rr-filter { ext-comm-list-number | ext-comm-list-name }
undo rr-filter
An RR does not filter reflected BGP EVPN routes.
ext-comm-list-number: Specifies an extended community attribute list by its number in the range of 1 to 65535.
ext-comm-list-name: Specifies an extended community attribute list by its name, a case-sensitive string of 1 to 63 characters. The name string cannot contain only digits.
This command enables an RR to reflect only received BGP EVPN routes that match the attributes in the specified extended community attribute list.
If a cluster contains multiple RRs, you can configure different reflection policies on the RRs for load sharing among the RRs.
For more information about the extended community attribute list, see Layer 3—IP Routing Configuration Guide.
# Configure a reflection policy for the device to reflect BGP EVPN routes that match extended community attribute list 10.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] rr-filter 10
ip extcommunity-list (Layer 3—IP Routing Command Reference)
vpn-route cross multipath
Use vpn-route cross multipath to enable ECMP VPN route redistribution.
Use undo vpn-route cross multipath to disable ECMP VPN route redistribution.
ECMP VPN route redistribution is disabled. If multiple routes have the same prefix and RD, BGP only imports the optimal route into the EVPN routing table.
ECMP VPN route redistribution enables BGP to import all routes that have the same prefix and RD into the EVPN routing table.
# Enable ECMP VPN route redistribution.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] vpn-route cross multipath
vpn-target
Use vpn-target to configure route targets for EVPN.
Use undo vpn-target to delete route targets for EVPN.
In EVPN instance view:
vpn-target { vpn-target&<1-8> | auto } [ both | export-extcommunity | import-extcommunity ]
undo vpn-target { vpn-target&<1-8> | auto | all } [ both | export-extcommunity | import-extcommunity ]
VPN instance EVPN view, public instance IPv4 address family view, or public instance EVPN view:
EVPN does not have route targets.
EVPN instance view
Public instance EVPN view
Public instance IPv4 address family view
vpn-target&<1-8>: Specifies a space-separated list of up to eight route targets. Each route target is a string of 3 to 21 characters in one of the following formats:
auto: Automatically generates a route target in the format of BGP AS number:VXLAN ID.
both: Uses the specified route targets as both import and export targets. If you do not specify the both, export-extcommunity, or import-extcommunity keyword, the both keyword applies.
export-extcommunity: Uses the specified route targets as export targets.
import-extcommunity: Uses the specified route targets as import targets.
all: Specifies all route targets.
EVPN uses MP-BGP to advertise BGP EVPN routes for automatic VTEP discovery, MAC reachability information advertisement, and host route advertisement. MP-BGP uses route targets to control the advertisement and acceptance of BGP EVPN routes.
A VTEP sets the export targets for BGP EVPN routes before advertising the routes to remote VTEPs. The VTEP checks the export targets of BGP EVPN routes from remote VTEPs and imports only BGP EVPN routes of which the export targets match the local import targets.
If you execute this command multiple times, all configured route targets take effect.
# Configure import route targets 10:1, 100:1, and 1000:1 for an EVPN instance.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] vpn-target 10:1 100:1 1000:1 import-extcommunity
