05-Objects
HomeSupportConfigure & DeployConfiguration GuidesH3C Firewall Products Comware 7 Web Configuration Guide-6W60005-Objects
05-WAF
05-WAF 121.54 KB
WAF
This help contains the following topics:
·     Introduction
¡     WAF profiles
¡     WAF actions
¡     WAF mechanism
¡     CC defense
·     Restrictions and guidelines
·     Configure WAF
¡     Configure a WAF profile
¡     Configure a CC defense profile
¡     Create and delete user-defined signatures
Introduction
The Web application firewall (WAF) feature enables devices to monitor HTTP and HTTPS traffic to and from Web applications for malicious activity and to proactively take prevention actions.
WAF profiles
WAF is implemented based on WAF profiles. A WAF profile contains a set of WAF signatures to match packets and the actions for the matching packets.
WAF signatures
The device compares packets with WAF signatures to detect, classify, and prevent network attacks.
Each WAF signature contains multiple attributes, including attack category, action, protected target, severity level, and direction. You can set criteria to filter WAF signatures that a WAF profile uses based on the signature attributes.
Signature exceptions
WAF signatures have default signature actions and enabling status.
To change the enabling status or action for a WAF signature in a WAF profile, specify the WAF signature as a signature exception in the WAF profile. The action specified for the signature exception takes precedence over the global signature action.
WAF actions
When the device detects a packet matching a WAF signature, it takes the global action for the signature on the packet.
The device supports the following WAF actions:
·     Blacklist—Drops matching packets and adds the sources of the packets to the IP blacklist. If the IP blacklist feature is enabled, packets from the blacklisted sources will be blocked for the blacklist period. If the IP blacklist feature is not enabled, packets from the blacklisted sources are not blocked.
For more information about the IP blacklist feature, see attack defense online help.
·     Drop—Drops matching packets.
·     Permit—Permits matching packets to pass.
·     Reset—Closes the TCP or UDP connections for matching packets by sending TCP reset messages or ICMP port unreachable messages.
·     Redirect—Redirects matching packets to a webpage.
·     Default—Uses the default signature action.
·     Capture—Captures matching packets.
·     Logging—Logs matching packets.
WAF mechanism
As shown in Figure 1, upon receiving a packet, the device performs the following operations:
1.     The device compares the packet with the security policies.
If the packet matches a security policy that is associated with a WAF profile, the device identifies the packet application layer protocol and extracts the packet signatures.
2.     The device determines the actions for the packet by comparing the extracted packet signatures with the WAF signatures in the WAF profile:
¡     If the packet does not match any WAF signatures, the device permits the packet to pass.
¡     If the packet matches only one WAF signature, the device takes the signature actions.
¡     If the packet matches multiple WAF signatures, the device uses the following rules to select the actions:
-     If the matching WAF signatures have two or more actions, including redirect, drop, permit, and reset, the device takes the action of the highest priority. The actions in descending order of priority are reset, redirect, drop, and permit.
-     The device will execute the blacklist, capture, and logging actions if they are in the matching WAF signatures.
Figure 1 WAF mechanism
CC defense
The Challenge Collapsar (CC) defense feature blocks malicious HTTP and HTTPS traffic from Web applications by performing content inspection, rule matching, and statistics collection.
The CC defense feature is implemented in a WAF profile that is associated with a security policy.
As shown in Figure 2, upon receiving a packet, the device performs the following operations:
1.     The device compares the packet with IP exceptions.
¡     If an IP exception is found, the device permits the packet to pass through.
¡     If no IP exception is found, the device goes to step 2.
2.     The device identifies the packet application layer protocol, and extracts the URL and other related information.
3.     The device compares the extracted packet information with the CC defense rules and determines the action for the packet.
¡     If the packet does not match any CC defense rules, the device permits the packet to pass through.
¡     If the packet matches one CC defense rule, the device stops the matching process and goes to step 4.
4.     The device determines the actions for the packet based on the detection interval:
¡     For a packet within the detection interval, the device performs the following actions after collecting statistics from the packet and compares the statistics with the thresholds of detection items:
-     The device executes the permit, blacklist, and logging actions as needed if a threshold is reached.
-     The device permits the packet to pass through if no threshold is reached.
¡     For a packet out of the detection interval, the device does not collect statistics from the packet and permits the packet to pass through.
Figure 2 CC defense mechanism
·     After you create, edit, or delete a WAF profile or user-defined signature, the configuration must be activated to take effect. You can click Submit to activate the configuration immediately, or the configuration will be activated automatically after 40 seconds by default. Activating configuration causes transient DPI service interruption. DPI-based services might also be interrupted. For example, security policies cannot control access to applications.
·     The WAF module requires a license to run on the device. If the license expires, you can still use the WAF functions but you can no longer upgrade the WAF signature library on the device. For more information about licenses, see license online help.
·     A user-defined signature of the number type supports only one detection item.
Configure WAF
Configure WAF as shown in Figure 3.
Figure 3 WAF configuration procedure
The device provides a predefined WAF profile named default. The default WAF profile uses all enabled WAF signatures on the device and cannot be modified or deleted.
You can also create WAF profiles on the device as needed.
You can configure global action for a WAF profile or change the action for individual WAF signatures in the profile.
The system selects the actions for packets matching a WAF signature in the following order:
1.     Actions configured for the WAF signature as a signature exception in the WAF profile.
2.     Global action configured for the WAF profile.
3.     Default action of the WAF signature.
1.     Click the Objects tab.
2.     In the navigation pane, select APP Security > WAF > Profiles.
The WAF Profiles page opens.
3.     Click Create.
The Create WAF Profile page opens.
4.     Create a WAF profile.
Table 1 WAF profile configuration items
Item
Name
Specify a WAF profile name.
CC Defense Profile
Select a CC defense profile for the WAF module.
Signature filtering criteria
In the Signature filtering criteria area, set the criteria to filter the WAF signatures used in the WAF profile based signature attributes including the protected target, attack category, direction, default signature action, and severity level.
By default, no signature filtering criteria are set and a WAF profile uses all enabled WAF signatures on the device.
A WAF profile uses a WAF signature only if the signature matches all the configured criteria.
For each attribute-based criterion, you can specify multiple attribute values. A WAF signature matches the criterion if it matches any of the specified attribute values.
To view the signatures filtered out by using the criteria, click View matching signatures.
Protected target
Select the protected targets for the protected target criterion.
Attack category
Select the attack categories for the attack category criterion.
Direction
Select the traffic directions for the direction criterion. Options are:
·     To-server—Client to server direction.
·     To-client—Server to client direction.
Default action
Select the actions for the default signature action criterion.
Options are Drop, Permit, Reset, and Blacklist.
Severity level
Select the severity levels for the severity levels criterion.
Options are Critical, High, Medium, and Low.
Global profile action
Apply the selected action to all traffic matching the signatures used by the profile. To apply the default signature-specific action to matching traffic, select Default.
Action
Select the global action for the WAF profile.
Options are Default, Blacklist, Drop, Permit, Reset, and Redirect.
The global action applies to all packets matching the signatures in the WAF profile.
By default, the Default option is used. For packets matching a signature in the profile, the default signature action will be applied.
Logging
Select whether to enable logging for matching packets. Options are Enable and Disable.
Capture
Select whether to enable capture matching packets. Options are Enable and Disable.
The capture action enables the device to capture packets and export the captured packets to the specified URL at the scheduled export time. For more information about configuring the capture action, see security actions online help.
Add signature exceptions
To specify WAF signatures as signature exceptions in a WAF profile, use either of the following methods:
·     In the Signature exceptions area of the Create WAF Profile page, enter the ID of the WAF signature and click Add.
·     On the Create WAF Profile page, click View matching signatures. On the View Signatures page that opens, select the signatures you want to specify as signature exceptions, and then click Add to signature exception list. The Edit Exception Rule window opens. Configure the following settings as needed, and then click OK.
¡     Select the action for the signatures.
¡     Enable or disable the signatures.
¡     Select whether to enable packet capture and logging for packets matching the signatures.
Edit Exception Rule
On the signature exception list, click the Edit icon  for a signature exception. On the Edit Signature Exception window that opens, configure the following settings, and then click OK.
·     Select the action for the signature.
·     Enable or disable the signature.
·     Select whether to enable packet capture and logging for packets matching the signature.
5.     Click OK.
The WAF profile is displayed on the WAF Profiles page.
6.     Use the WAF profile in a security policy. For more information about security policies, see security policy online help.
7.     To have the configuration take effect immediately, click Submit. Or, wait 40 seconds for the configuration to take effect automatically.
A CC defense profile takes effect only after it is specified in the WAF module. The device processes HTTP attack packets based on CC defense profiles.
You can configure filtering criteria and detection items as needed.
2.     In the navigation pane, select APP Security > WAF > CC Defense Profiles.
3.     On the page that opens, click Create.
4.     Configure basic settings for the CC defense profile.
Table 2 Basic configuration items for CC defense profile
Item
Name
Specify a CC defense profile name.
Enter a description for easy identification.
Source IP address exceptions
Specify exceptional source IP addresses. The device permits an HTTP packet to pass through if the source IP address of the HTTP packet matches an IP address exception. If no match is found, the device continues the CC attack detection.
Detection interval
Set the detection timer for CC attack detection. The timer starts when a CC defense rule is first matched.
5.     In the CC defense rules area, click Create.
6.     Create a CC defense rule.
Table 3 CC defense rule configuration items
Item
Rule name
Specify a CC defense rule name.
Destination IPv4 addresses
Specify destination IPv4 addresses as filtering criteria in the CC defense rule.
Destination IPv6 addresses
Destination ports
Specify destination ports as filtering criteria in the CC defense rule.
Request methods
Select request methods as filtering criteria in the CC defense rule.
Protected path
Specify the protected paths to the website resources.
X-Forwarded-For detection
Select whether to enable X-Forwarded-For detection for the device to obtain the true source IP address from HTTP packets. Options are Enable and Disable.
This field is applicable to scenarios where a client uses a proxy to access the server.
Detection items
Select detection items to determine whether CC attacks are present. Options include Request rate and Request concentration ratio.
·     Request rate—Identifies whether a client is accessing a website too frequently. Set Request rate threshold to define the maximum number of requests allowed to access a protected path within the detection interval.
·     Request concentration ratio—Identifies whether a website is most frequently visited.
¡     Min requests—Defines the number of requests to protected paths within the detection interval for triggering the request concentration detection.
¡     Request concentration ratio threshold—Defines the request concentration ratio threshold (percentage of the requests to the most frequently visited protected path to total requests to all protected paths) to determine that a CC attack occurs.
Action
Select the action for the CC defense rule. Options are Permit and Blacklist.
If you select Blacklist, you must set the blacklist period.
Logging
Select whether to enable logging when CC attacks are detected. Options are Enable and Disable.
7.     Click OK.
The CC defense rule is displayed on the CC defense rules list.
8.     Click OK.
The CC defense profile is displayed on the CC Defense Profiles page.
9.     Click the Objects tab.
10.     In the navigation pane, select APP Security > WAF > Profiles.
11.     Use the CC defense profile in a WAF profile. For more information about WAF profiles, see "Configure a WAF profile."
12.     To have the configuration take effect, click Submit.
You can create user-defined signatures that do not exist in the current signature library.
A user-defined signature contains basic settings and rules.
A user-defined signature can contain multiple rules. The logical operators between rules are as follows:
·     Logical AND—A packet matches a signature when it matches all rules in the signature.
·     Logical OR—A packet matches a signature when the packet matches any rule in the signature.
In a user-defined signature rule, you can configure the match criteria of source IPv4 address, destination IPv4 address, source port, destination port, and request method, the detection items, and the detection trigger items.
A user-defined signature can be one of the following types:
·     Keyword—A keyword type requires configuring both the detection items and detection trigger conditions. The device continues to compare a packet with detection items only after the packet matches all detection trigger conditions. A packet matches a rule only when the packet matches all detection items in the rule.
·     Number—A number type requires configuring the detection items. A packet matches a rule only when the packet matches all detection items in the rule.
Create a user-defined signature
2.     In the navigation pane, select APP Security > WAF > Signatures.
3.     Click Create user-defined signature.
4.     On the page that opens, configure basic settings for a user-defined signature.
Table 4 Basic configuration items for a user-defined signature
Item
Name
Enter the name of the user-defined signature.
Severity level
Select the severity level of the risk impacts that the matching packets might bring to the network.
Direction
Select the traffic direction for the direction criterion. Options are:
·     To-client, To-server—Both client-to-server and server-to-client directions.
Action
Select the action for packets matching the signature.
Options are Blacklist, Drop, Permit, and Reset.
Logging
Capture
5.     In the Rules area, select a logical operator before you configure rules for the signature.
6.     Click Create.
7.     On the page that opens, configure basic settings for the rule.
Table 5 Basic configuration items for a user-defined signature rule
Item
ID
Enter the rule ID.
Match pattern type
Select the type of the match pattern. Options are Keyword and Number.
Request methods
Select an HTTP request method, such as GET and POST.
Source IPv4 address
Enter a source IPv4 address as the match criterion.
Source port range
Enter a source port range as the match criterion.
Enter a destination IPv4 address as the match criterion.
Destination port range
·     Enter a destination port range as the match criterion.
8.     In the Detection trigger conditions area, click Create.
This area is available only when Keyword has been selected as the match pattern type.
9.     Create a detection trigger condition.
Table 6 Detection trigger condition configuration items
Item
Protocol filed
Select a protocol field to inspect.
Match pattern type
Select the type of the match pattern. Options are Text and Hex.
Match pattern
Enter the content of the match pattern.
Depth
Specify the number of bytes to be inspected after an offset.
Offset
Enter an offset in bytes after which the inspection starts. The offset is counted from the beginning of the protocol filed.
10.     Click OK.
The detection trigger condition is displayed on the Detection trigger conditions list.
11.     In the Detection items area, click Create.
12.     Create a detection item.
Table 7 Detection item configuration items
Item
ID
Enter a detection item ID.
Protocol field
Select a protocol field.
Operator
Select an operator to define the match operation in the detection item.
Options vary by the match pattern type selected in the Create Rule page:
·     If Keyword has been selected, the options are Contain and Not contain.
·     If Number has been selected, the options are Greater than, Equal to, Not equal to, Less than, Greater than or equal to, and Less than or equal to.
Match pattern type
Select the type of the match pattern. Options are Text, Regular expression, and Hex.
Match pattern
Depth
Specify the number of bytes to be inspected.
Offset
Relative depth
Relative offset
Enter an offset after which the inspection starts. The offset is counted from the beginning of the protocol filed.
13.     Click OK.
The detection item is displayed on the Detection items list.
14.     Click OK.
The rule is displayed on the Rules list.
15.     Click OK.
The signature is displayed on the WAF Signatures page.
16.     To have the configuration take effect, click Submit.
Delete user-defined signatures
3.     On the page that opens, select the user-defined signatures that you want to delete.
4.     Click Delete.
