00-Preface | 27.14 KB |
Preface
· Audience.
· Conventions.
Audience
· Network planners.
· Server administrators working with the server.
Conventions
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Documentation feedback
We appreciate your comments.
