H3C WBC Series Multservice Access Controllers Web-Based Configuration Guide(E5448)-6W100
HomeSupportWirelessWBC Series Multiservice Access ControllersConfigure & DeployUser ManualsH3C WBC Series Multservice Access Controllers Web-Based Configuration Guide(E5448)-6W100
03-Feature navigator
03-Feature navigator 145.95 KB
Feature navigator
Menu items and icons available to you depend on the user roles you have. By default, you can use any user roles to display information. To configure features, you must have the network-admin user role. This chapter describes all menus available for the network-admin user role.
Top-level menus differ in system view and in network view. You can toggle between these two views by clicking the view tab at the bottom of the page. For each top menu, a navigator table is provided. Use the navigator tables to navigate to the pages for the tasks you want to perform.
For example:
·     To change the default device name, perform the following tasks:
a.     Click the system view tab at the bottom of the page.
b.     From the navigation tree, select System > Management. You are placed on the Settings tab.
·     To delete an IPv4 ACL, perform the following tasks:
b.     From the navigation tree, select System > Resource. You are placed on the IPv4 ACL tab.
In the navigator tables, a menu is in boldface if it has submenus.
Feature navigator in system view
Top-level menus in system view include Dashboard, Network Configuration, Network Security, System, and Tools.
Available features in system view vary by device model. For more information, see System features.
Dashboard menu
The dashboard menu provides an overview of the system and its running status, including the following information:
·     Event logs.
·     AP statistics.
·     System utilization information.
·     Wireless service statistics.
·     Client statistics.
·     Traffic monitoring statistics.
This menu does not contain submenus.
Network configuration menu
Use Table 1 to navigate to the tasks you can perform from the Network Configuration menu.
Table 1 Network configuration menu navigator
Menus
Tasks
Mobility Domain
Roaming
·     Display WLAN client roaming information and roaming group information.
·     Configure WLAN client roaming settings.
Roaming Centers
WLAN Roaming Center
·     Enable or disable WLAN roaming center
·     Configure a UDP port number, wait timer for user offline notification responses, maximum transmission attempts for user offline notification requests, and portal roaming center IP addresses.
Portal Roaming Center
·     Configure WLAN roaming center IP address, UDP port number, wait timer for responses from the WLAN roaming center, and maximum number of attempts to transmit a packet to the WLAN roaming center.
Network Interfaces
Interfaces
·     Display interfaces and their attributes, including:
¡     Interface status.
¡     IP address.
¡     Speed and duplex mode.
¡     Interface description.
·     Delete logical interfaces.
·     Modify interfaces.
Link Aggregation
Create, modify, or delete Layer 2 aggregation groups.
VLAN
VLAN
·     Configure port-based VLANs.
·     Create VLAN-interfaces.
MAC
·     Create or delete static MAC entries, dynamic MAC entries, and blackhole MAC entries.
·     Display existing MAC entries.
STP
·     Enable or disable STP globally.
·     Enable or disable STP on interfaces.
·     Configure the STP operating mode as STP, RSTP, PVST, or MSTP.
·     Configure instance priorities.
·     Configure MST regions.
Network Routing
Routing Table
Display IPv4 and IPv6 routing table information, including brief routing table information and route statistics.
Static Routing
·     Display IPv4 and IPv6 static routing entries.
·     Create, modify, or delete IPv4 and IPv6 static routing entries.
Network Services-IP Services
IP
·     Configure the method to obtain an IP address (DHCP or static).
·     Configure the IP address or MTU of an interface.
·     Create a loopback interface.
IPv6
·     Configure the method to obtain an IPv6 address (manual assignment, dynamic assignment, or auto generation).
·     Configure the IPv6 address of an interface.
Network Services-DHCP/DNS
DHCP
·     Configure DHCP server functions, including:
¡     Configure DHCP services.
¡     Configure the interface to operate in the DHCP server mode.
¡     Configure DHCP address pools.
¡     Configure IP address conflict detection.
·     Configure DHCP relay agent functions, including:
¡     Configure the DHCP relay agent mode.
¡     Configure the IP address of the DHCP server.
·     Configure settings for DHCP relay entry, include:
¡     Recording of DHCP relay entries.
¡     Periodic refreshing of DHCP relay entries.
¡     Interval for refreshing DHCP relay entries.
DHCP Snooping
·     Configure a port as a trusted or untrusted port.
·     Record and back up DHCP snooping entries.
·     Configure the following features for DHCP snooping ports:
¡     MAC address check.
¡     DHCP-REQUEST check.
¡     DHCP packet rate limit.
¡     Max DHCP snooping entries.
·     Enable support for Option 82. If Option 82 is enabled, you can configure the handling strategy, the padding format, and the padding contents for Option 82.
IPv4 DNS
·     Configure IPv4 static domain name resolution.
·     Configure IPv4 dynamic domain name resolution.
·     Configure the DNS proxy.
·     Configure IPv4 domain name suffixes.
IPv6 DNS
·     Configure static and dynamic IPv6 domain name resolution.
·     Configure the IPv6 DNS proxy.
·     Configure IPv6 domain name suffixes.
Network Services-Multicast
IGMP Snooping
Configure IGMP snooping functions, including:
·     Enable or disable IGMP snooping in a VLAN.
·     Query IGMP snooping entries.
·     Enable dropping unknown multicast data.
·     Configure the IGMP snooping querier.
·     Enable fast-leave processing.
·     Set the maximum number of multicast groups on a port.
MLD Snooping
Configure MLD snooping functions, including:
·     Enable or disable MLD snooping in a VLAN.
·     Query MLD snooping entries.
·     Enable dropping unknown IPv6 multicast data.
·     Configure the MLD snooping querier.
·     Set the maximum number of IPv6 multicast groups on a port.
Network Services-ARP
ARP
·     Add static ARP entries.
·     Delete dynamic ARP entries and static ARP entries.
·     Configure the ARP proxy.
·     Configure gratuitous ARP.
·     Configure ARP attack protection.
Network Services-ND
ND
·     Add static ND entries.
·     Delete dynamic ND entries and static ND entries.
·     Configure the aging time for stale ND entries.
·     Enable or disable link local ND entry minimization.
·     Configure hop limit.
·     Configure RA prefix attributes, including:
¡     Address prefix.
¡     Prefix length.
¡     Valid lifetime.
¡     Preferred lifetime.
·     Configure RA settings for an interface, including:
¡     RA message suppression.
¡     Maximum and minimum intervals for sending RA messages.
¡     M-flag.
¡     MTU option.
¡     Hop limit.
¡     O-flag.
¡     Router lifetime.
¡     NS message retransmit interval.
¡     Router preference.
¡     Neighbor reachable time.
·     Enable common and local ND proxy on an interface.
·     Configure ND rules for the interface, including:
¡     Maximum number of dynamic neighbor entries.
¡     Maximum number of DAD attempts.
Network Services-NAT
NAT
·     Configure dynamic and static NAT, internal servers, and dynamic and static NAT444.
·     Configure NAT address groups, NAT444 address groups, port block groups, and server groups.
·     Configure PAT mode, DNS mappings, and NAT hairpin.
·     Enable NAT ALG.
·     Display NAT logs.
Management Protocols
HTTP/HTTPS
·     Enable or disable HTTP service.
·     Enable or disable HTTPS service.
·     Set the Web connection timeout.
·     Set the HTTP service port number.
·     Set the HTTPS service port number.
·     Specify Web access control ACLs.
FTP
·     Enable or disable FTP service.
·     Set the DSCP value for the device to use for outgoing FTP packets.
·     Specify FTP access control ACLs.
·     Set the FTP connection idle timeout.
·     Configure SSL service policies.
Telnet
·     Enable or disable Telnet service.
·     Set the DSCP values for the device to use for outgoing IPv4 or IPv6 Telnet packets.
·     Specify Telnet access control ACLs.
SSH
·     Enable or disable the Stelnet, SFTP, and SCP services.
·     Configure SSH parameters.
NTP
·     Enable or disable the NTP service.
·     Configure the IP address and stratum level of the local clock.
·     Set an NTP authentication key.
LLDP
·     Enable or disable LLDP.
·     Enable or disable CDP compatibility.
·     Configure LLDP parameters.
·     Display interface status.
·     Configure the interface status.
·     Display LLDP neighbors.
·     Configure LLDP to advertise the specified TLVs.
Settings
·     Enable or disable log output to the log buffer, and configure the maximum number of logs in the log buffer.
·     Configure the address and port number of log hosts.
Network security menu
Use Table 2 to navigate to the tasks you can perform from the Network Security menu.
Table 2 Network security menu navigator
Menus
Tasks
Packet Filter
Packet Filter
·     Create, modify, or delete a packet filter for an interface.
·     Configure the default action for the packet filter.
Traffic Policy
QoS Policies
Create, modify, or delete interface QoS policies.
Priority Mapping
·     Query or configure the port priority.
·     Configure the priority mapping table.
Access Control
802.1X
·     Enable or disable 802.1X.
·     Configure the 802.1X authentication method.
·     Configure the port access control method.
·     Configure the maximum number of concurrent 802.1X users on the port.
·     Configure advanced 802.1X features.
Authentication
ISP Domains
·     Add, modify, or delete ISP domains.
·     Configure the domain name, state, access method, and advanced settings for an IPS domain.
·     Configure the default ISP domain.
RADIUS
·     Add, modify, or delete RADIUS schemes.
·     Configure the scheme name, authentication server, accounting server, shared key, and advanced settings.
·     Enable or disable receiving of session control packets.
User Management
Local Users
·     Add, modify, or delete local users.
·     Add, modify, or delete local user groups.
System menu
Use Table 3 to navigate to the tasks you can perform from the System menu.
Table 3 System menu navigator
Menus
Tasks
Event Logs
Event Logs
Query, collect, or delete log information.
Resource
IPv4 ACL
·     Create, modify, or delete an IPv4 basic ACL.
·     Create, modify, or delete an IPv4 advanced ACL.
IPv6 ACL
·     Create, modify, or delete an IPv6 basic ACL.
·     Create, modify, or delete an IPv6 advanced ACL.
Layer 2 ACLs
Create, modify, or delete an Ethernet frame header ACL.
Time range
Create, modify, or delete a time range.
File Systems
File System Management
Upload, download, or delete files.
License Management
License configuration
Display or install licenses.
Obtain DID
Export DID files.
Licenses and features
Display licenses and features.
Compress
Compress the license storage path.
Administrators
Administrators
·     Create, modify, or delete roles.
·     Create, modify, or delete administrators.
·     Configure the role of administrators.
·     Control administrator access authority.
·     Manage passwords.
Management
Settings
·     Set the name, location, and contact information of the device.
·     Set the system time.
Configuration
·     Save or export the running configuration.
·     Import configuration.
·     Display the running configuration.
·     Restore the settings to the factory defaults.
Upgrade
·     Upgrade system software.
·     Display system software lists, including:
¡     List of software enabled at the current system startup.
¡     List of main software to be enabled at the next system startup.
Reboot
Reboot the device.
About
Display basic device information, including device name, serial number, model, description, location, contact information, version, electronic label, and statement.
Tools menu
Use Table 4 to navigate to the tasks you can perform from the Tools menu.
Table 4 Tools menu navigator
Menus
Tasks
Debug
Diagnostics
Collect diagnostic information for locating problems.
Ping
IPv4 Ping
Identify whether an IPv4 address is reachable.
IPv6 Ping
Identify whether an IPv6 address is reachable.
Tracert
IPv4 Tracert
Trace the path of IPv4 packets from source to destination.
IPv6 Tracert
Trace the path of IPv6 packets from source to destination.
Feature navigator in network view
Top-level menus in network view include Dashboard, Quick Start, Monitoring, Wireless Configuration, Network Security, System , Tools, and Reporting.
Dashboard menu
·     Event logs.
·     AP statistics.
Quick start menu
Use Table 5 to navigate to the tasks you can perform from the Quick Start menu.
Table 5 Quick start menu navigator
Menus
Tasks
Add New AP
Add New AP
Add new APs manually.
Add New SSID
Add New SSID
·     Configure wireless services.
·     Configure link layer authentication.
·     Enable or disable authorization.
·     Enable or disable intrusion detection.
·     Configure key management.
·     Bind APs.
Add New User
Add New User
Add new users.
Monitoring menu
Use Table 6 to navigate to the tasks you can perform from the Monitoring menu.
Table 6 Monitoring menu navigator
Menus
Tasks
Wireless Networks
Wireless Services
Display wireless services.
Access Points
APs
Display AP statistics.
AP Groups
Display AP groups.
Clients
Clients
Display client statistics.
Wireless Security
WIPS
Display WIPS statistics.
RRM
RF Optimization
Display channel and power adjustment information.
Spectrum Analysis
Display detailed information about spectrum analysis.
Client Proximity Sensor
Display client proximity sensor information.
DPI
IPv4
Display IPv4 traffic and application statistics.
IPv6
Display IPv6 traffic and application statistics.
Application Monitoring
Bonjour
·     Display Bonjour service information discovered by Bonjour gateways.
·     Clear Bonjour service resource information.
Multicast Optimization
Display IPv4 and IPv6 multicast statistics.
Wireless configuration menu
Use Table 7 to navigate to the tasks you can perform from the Wireless Configuration menu.
Table 7 Wireless configuration menu navigator
Menus
Tasks
Wireless Networks
Wireless Networks
·     Display wireless services.
·     Add, delete, or modify wireless services.
·     Enable or disable authorization and intrusion detection.
·     Manage keys.
·     Bind APs.
·     Configure access control.
AP Management
AP
Add, modify, delete, or query APs.
AP Groups
Create, query, modify, or delete AP groups.
AP Global Settings
·     Configure AP region codes.
·     Enable or disable region code lock.
·     Enable or disable AP software upgrade.
·     Enable or disable auto AP.
·     Enable or disable auto-AP persistence.
AP Provisioning
Display or modify AP preprovisioned settings.
AP Group Provisioning
Display or modify AP group preprovisioned settings.
Wireless QoS
Client Rate Limiting
·     Display detailed information about client rate limit.
·     Configure client-type-based client rate limit.
·     Configure service-based client rate limit.
·     Configure AP radio or AP group radio-based client rate limit.
Bandwidth Guaranteeing
·     Display detailed information about intelligent bandwidth guarantee.
·     Set the maximum radio bandwidth.
·     Configure intelligent bandwidth guarantee for an AP or AP group.
Wi-Fi Multimedia
·     Display wireless QoS status and information.
·     Display radio EDCA parameters.
·     Display radio and client negotiation parameters.
·     Display WMM statistics for clients.
·     Display transport stream information.
Wireless Security
WIPS
·     Display detailed WIPS information.
·     Enable WIPS.
·     Configure VSDs.
·     Configure classification policies.
·     Configure attack detection policies.
·     Configure signature policies.
·     Configure countermeasure policies.
·     Configure AP classification rules.
·     Configure signatures.
·     Add MAC addresses to the alarm-ignored device list.
Whitelist and blacklist
·     Configure whitelists.
·     Configure static and dynamic blacklists.
Radio Management
Radio Configuration
Display detailed model and radio information for all APs in an AP group.
RRM
·     Display channel and power adjustment information.
·     One-key channel and power optimization.
·     Configure RRM for APs and AP groups:
¡     Configure RRM holddown groups.
¡     Configure radio baselines.
·     Display RRM adjustment history.
Spectrum Analysis
·     Enable spectrum analysis.
·     Configure interference device type.
·     Import feature database files.
·     Configure the alarming feature.
Load Balancing
·     Enable load balancing.
·     Configure the load balancing mode.
·     Configure load balancing groups.
·     Configure load balancing parameters.
Band Navigation
·     Enable or disable global band navigation.
·     Enable or disable band navigation for APs and AP groups.
·     Configure band navigation parameters.
·     Enable or disable client proximity sensor.
·     Display client proximity sensor information.
Applications
Mesh Service
View mesh configuration.
·     Display IPv4 multicast optimization.
·     Configure IPv4 multicast optimization.
·     Display IPv6 multicast optimization.
·     Configure IPv6 multicast optimization.
Location Aware
·     Configure global packet rate limit, packet filtering, and packet dilution.
·     Configure Aeroscout locating, bluetooth locating, CUPID locating, fingerprinting, and Internet of Things (IoT) locating.
Bonjour
·     Enable or disable the Bonjour gateway feature.
·     Create and activate Bonjour service types.
·     Change the Bonjour gateway mode.
·     Configure Bonjour policies.
Use Table 8 to navigate to the tasks you can perform from the Network Security menu.
Table 8 Network security menu navigator
Menus
Tasks
Packet Filter
Packet Filter
Traffic Policy
QoS Policies
Priority Mapping
·     Query and configure the port priority.
Access Control
802.1X
Authentication
ISP Domains
·     Configure the domain name, state, access method, and advanced settings of an IPS domain.
RADIUS
BYOD
BYOD DB
·     Display DHCP rules, HTTP rules, and MAC rules.
·     Configure DHCP rules, HTTP rules, and MAC rules.
BYOD Authorization
Query or modify BYOD authorization.
User Management
Local Users
·     Add or modify local user groups.
Guest Management
Guest List
Query, add, or export guests.
Import Guests
Import guests.
Generate Guest Accounts
Generate guests in bulk.
Approve Guest
Approve guests.
Guest Configuration
Configure guest parameters.
Access Control
MAC Authentication
·     Enable or disable MAC authentication.
·     Enable MAC authentication for an interface and set the maximum number of concurrent MAC authentication users on a port.
·     Configure the quiet timer.
·     Configure advanced MAC authentication settings.
Port Security
·     Enable or disable port security.
·     Specify the port security mode.
·     Configure advanced port security settings.
Portal
·     Configure the portal authentication server.
·     Configure the portal Web server.
·     Configure the local portal Web server.
·     Configure portal-free rules.
·     Configure interface policies.
·     Configure online user information.
System menu
Use Table 9 to navigate to the tasks you can perform from the System menu.
Table 9 System menu navigator
Menus
Tasks
Resource
IPv4 ACL
·     Create basic or advanced IPv4 ACLs.
·     Modify or delete ACLs on this page and other service module pages, such as the packet filtering page.
IPv6 ACL
·     Create basic or advanced IPv6 ACLs.
Layer 2 ACLs
·     Create Ethernet ACLs.
Time range
Create, modify, or delete time ranges.
VLAN group
Create, modify, or delete VLAN groups.
Tools menu
Use Table 10 to navigate to the tasks you can perform from the Tools menu.
Table 10 Tools menu navigator
Menus
Tasks
Wireless Capture
Wireless Capture
Display captured wireless packets.
RF Ping
RF Ping
Perform wireless link quality detection.
Debug
Diagnostics
Reporting menu
Use Table 11 to navigate to the tasks you can perform from the Reporting menu.
Table 11 Reporting menu navigator
Menus
Tasks
Client Statistics
AC Frame
Display transmitted/received/dropped AC frames.
AC Bytes
Display transmitted/received/dropped AC bytes.
Total Frame
Display total transmitted, received, and dropped frames.
Total Bytes
Display total transmitted, received, and dropped bytes.
AP Statistics
AP Statistics
Wireless Service Statistics
Display wireless service statistics.
