16-Security Command Reference
HomeSupportWirelessWBC Series Multiservice Access ControllersReference GuidesCommand ReferencesH3C WBC Series Multservice Access Controllers Command References(E5448)-6W10016-Security Command Reference
18-Protocol packet rate limit commands
18-Protocol packet rate limit commands 91.20 KB
The following compatibility matrix shows the support of hardware platforms for protocol packet rate limit:
Hardware series
Model
Product code
Protocol packet rate limit compatibility
WBC series
WBC560
WBC580 G2-Standard Edition
WBC580 G2-Healthcare Edition
EWP-WBC560
EWP-WBC580-G2-BASE
EWP-WBC580-G2-HOSP
No
Access controller modules
LSQM1WBCZ720X
LSUM1WBCZ720XRT
LSQM1WBCZ720X
LSUM1WBCZ720XRT
Yes
anti-attack enable
Use anti-attack enable to enable packet rate limit.
Use undo anti-attack enable to disable packet rate limit.
anti-attack enable
Packet rate limit is disabled.
To implement packet rate limit for a protocol, you must complete the following tasks:
·     Execute the anti-attack enable command to enable packet rate limit.
·     Execute the anti-attack protocol enable command to enable packet rate limit for the protocol.
# Enable packet rate limit.
[Sysname] anti-attack enable
Use anti-attack protocol enable to enable packet rate limit for protocols.
Use undo anti-attack protocol enable to disable packet rate limit for protocols.
anti-attack protocol { all | protocol } enable
undo anti-attack protocol { all | protocol } enable
Packet rate limit is disabled for all protocols.
all: Specifies all protocols.
protocol: Specifies a protocol. This argument can be a case-insensitive string of 1 to 31 characters. Supported protocol values are shown in Table 1.
Table 1 Supported protocols
Protocol value
acsei
ACSEI protocol packets
arp
ARP protocol packets
capwap_ctrl
CAPWAP control packets
capwap_data
CAPWAP data packets
dhcp
DHCP protocol packets
dot11_action
802.11 ACK packets
dot11_assoc
802.11 association request packets
dot11_auth
802.11 authentication packets
dot11_ctrl
Other types of 802.11 protocol packets
dot11_deauth
802.11 deauthentication packets
dot11_disassoc
802.11 disassociation request packets
dot11_null
802.11 null data packets
dot11_reassoc
802.11 reassociation request packets
dot1x
802.1X authentication packets
ethernet
Packets that are not identified as packets of specific protocols
http
HTTP protocol packets
iactp
IACTP protocol packets
icmp
ICMP protocol packets
icmpv6_nd
ICMPv6 neighbor discovery protocol packets
icmpv6_other
ICMPv6 protocol packets except for neighbor discovery protocol packets
igmp
IGMP protocol packets
ip
IPv4 protocol packets
ipv6
IPv6 protocol packets
ntp
NTP protocol packets
portal_syn
Portal redirect packets
radius
RADIUS protocol packets
snmp
SNMP protocol packets
tcp
TCP protocol packets
telnet
Telnet protocol packets
udp
UDP protocol packets
vrrp
VRRP protocol packets
# Enable packet rate limit for ARP.
[Sysname] anti-attack protocol arp enable
anti-attack enable
anti-attack protocol flow-threshold
Use anti-attack protocol flow-threshold to enable flow-based packet rate limit for a protocol and set the maximum transmission rate per flow.
Use undo anti-attack protocol flow-threshold to disable flow-based packet rate limit for a protocol.
anti-attack protocol protocol flow-threshold flow-rate-limit
undo anti-attack protocol protocol flow-threshold
Flow-based packet rate limit is disabled for all protocols.
protocol: Specifies a protocol. This argument can be a case-insensitive string of 1 to 31 characters. For information about supported protocol values, see Table 1.
flow-rate-limit: Specifies the maximum transmission rate per flow for the protocol in packets per second. The value range is 0 to 102400.
The device identifies flows of a protocol by source IP or MAC address. Protocol packets that are sourced from the same IP address or MAC address belong to the same flow.
You can configure both protocol-based and flow-based protocol packet rate limit for the same protocol. The device first performs flow-based protocol packet rate limit and then performs protocol-based packet rate limit. Excessive protocol packets are dropped.
# Enable flow-based packet rate limit for ARP and set the maximum transmission rate per flow to 50 packets per second.
[Sysname] anti-attack protocol arp flow-threshold 50
anti-attack protocol threshold
Use anti-attack protocol threshold to set the maximum transmission rate for a protocol.
Use undo anti-attack protocol threshold to restore the default for a protocol.
anti-attack protocol protocol threshold rate-limit
undo anti-attack protocol protocol threshold
The default settings vary by device model. To display the default setting for a protocol, execute the undo anti-attack protocol threshold and display anti-attack protocol commands in turn.
rate-limit: Specifies the maximum transmission rate for the protocol in packets per second. The value range is 0 to 102400.
Excessive packets are dropped.
# Set the maximum transmission rate to 1000 packets per second for ARP.
[Sysname] anti-attack protocol arp threshold 1000
Use display anti-attack protocol to display packet rate limit information about protocols.
display anti-attack protocol [ protocol ]
protocol: Specifies a protocol. This argument can be a case-insensitive string of 1 to 31 characters. If you do not specify a protocol, the command displays information about all protocols. For information about supported protocol values, see Table 1.
# Display packet rate limit information about all protocols. Only protocol-based protocol packet rate limit is enabled in this example.
<Sysname> display anti-attack protocol
                        Anti-attack statistics
Protocol       anti-attack Limit(pps)  Rate(pps) Passed    Dropped
dot1x          disable     1024        0         0         0
dhcp           disable     2000        0         0         0
igmp           disable     1024        0         0         0
ntp            disable     512         0         0         0
arp            disable     20000       0         0         0
snmp           disable     1024        0         0         0
telnet         disable     1024        0         0         0
icmp           disable     1024        0         0         0
icmpv6_nd      disable     1024        0         0         0
icmpv6_other   disable     1024        0         0         0
iactp          disable     2560        0         0         0
acsei          disable     512         0         0         0
http           disable     1024        0         0         0
https          disable     1024        0         0         0
openflow       disable     1024        0         0         0
portal         disable     1024        0         0         0
udp            disable     2048        0         0         0
tcp            disable     1024        0         0         0
ip             disable     2560        0         0         0
ipv6           disable     512         0         0         0
ethernet       disable     512         0         0         0
radius         disable     2048        0         0         0
vrrp           disable     2048        0         0         0
capwap_ctrl    disable     5120        0         0         0
capwap_ctrl_disdisable     2048        0         0         0
capwap_data    disable     51200       0         0         0
dot11_auth     disable     512         0         0         0
dot11_assoc    disable     512         0         0         0
dot11_reassoc  disable     512         0         0         0
dot11_null     disable     1024        0         0         0
dot11_disassoc disable     512         0         0         0
dot11_deauth   disable     512         0         0         0
dot11_action   disable     512         0         0         0
dot11_ctrl     disable     512         0         0         0
lacp           disable     512         0         0         0
Anti-attack
Status of protocol-based packet rate limit for the protocol:
·     EnabledThe feature is enabled.
·     DisabledThe feature is disabled.
Limit(pps)
Maximum packet transmission rate of the protocol, in packets per second.
Rate(pps)
Current packet transmission rate of the protocol, in packets per second.
Passed
Number of protocol packets sent to the CPU.
Dropped
Number of dropped protocol packets.
# Display packet rate limit information about ARP. Both protocol-based protocol packet rate limit and flow-based protocol packet rate limit are enabled in this example.
<Sysname> display anti-attack protocol arp
arp            enable      1024        0         17907     0
FlowSource              FlowLimit(pps)    FlowRate(pps)   Passed    Dropped
00e0-fc12-7723          1000              0               2         0
0011-e212-8801          1000              0               17905     0
FlowSource
Source IP or MAC address of the flow.
FlowLimit(pps)
Maximum transmission rate for the flow, in packets per second.
FlowRate(pps)
Current transmission rate of the flow, in packets per second.
