H3C UniServer R6700 G3 Server User Guide-6W101
HomeSupportServerH3C UniServer R6700 G3Install & UpgradeInstallation GuidesH3C UniServer R6700 G3 Server User Guide-6W101
02-Appendix
Appendix A  Server specifications· 1
Server models and chassis view· 1
Technical specifications· 2
Components· 3
Front panel 4
Front panel view· 4
LEDs and buttons· 5
Ports· 6
Rear panel 7
Rear panel view· 7
LEDs· 7
Ports· 9
System board· 10
System board components· 10
System maintenance switches· 11
Processor mezzanine board components· 12
DIMM slots· 12
Appendix B  Component specifications· 1
About component model names· 1
DIMMs· 1
DRAM DIMM rank classification label 1
HDDs and SSDs· 2
Drive LEDs· 2
Drive configurations and numbering· 3
PCIe modules· 6
Storage controllers· 6
Riser cards· 6
Riser card guidelines· 7
RC-2*FHHL-G3· 7
RC-2LP-2U-G3-2· 8
RC-2LP-2U-G3-3· 9
RC-3*FHHL-G3· 9
RC-3FHHL-2U-G3-1· 10
RC-4*NVME-3*FHHL-G3· 11
RC-8*NVME-1*FHHL-G3· 12
B/D/F information· 13
Viewing B/D/F information· 13
Obtaining B/D/F information· 15
Fans· 15
Fan layout 15
Power supplies· 16
800 W Platinum power supply· 16
800 W 336 V high-voltage power supply· 16
850 W Titanium power supply· 17
1200 W Platinum power supply· 17
1600 W Platinum power supply PSR1600-12A· 18
1600 W Platinum power supply DPS-1600AB-13 R· 18
1600W 336V high-voltage DC· 19
Expander modules· 19
Diagnostic panels· 19
Diagnostic panel view· 19
LEDs· 20
Storage options other than HDDs and SDDs· 24
NVMe VROC modules· 24
Appendix C  Hot removal and managed hot removal of NVMe drives· 1
Performing a managed hot removal in Windows· 1
Prerequisites· 1
Procedure· 1
Performing a managed hot removal in Linux· 2
Prerequisites· 2
Performing a managed hot removal from the CLI 2
Appendix D  Environment requirements· 1
About environment requirements· 1
General environment requirements· 1
Operating temperature requirements· 1
General guidelines· 1
8SFF front drive configuration· 1
16SFF front drive configuration· 2
24SFF front drive configuration· 3
Appendix E  Product recycling· 1
Appendix F  Glossary· 1
Appendix G  Acronyms· 1
The information in this document might differ from your product if it contains custom configuration options or features.
H3C UniServer R6700 G3 servers are 2U rack servers with four Intel Purley or Jintide-C series processors. The servers are suitable for compute-intensive scenarios, such as virtualization, high-performance computing (HPC), cloud computing, memory computing, databases, and SAP HANA. They can be deployed to support business applications of service providers, finance companies, governments, enterprise clouds, and research institutes. The servers feature high computing performance, low power consumption, strong expandability, and high availability, allowing for simple deployment and management.
Figure 1 Chassis view
The servers come in the models listed in Table 1. These models support different drive configurations. For more information about drive configuration and compatible storage controller configuration, see "Drive configurations and numbering."
Table 1 R6700 G3 server models
Model
Maximum drive configuration
8SFF SAS/SATA
24 SFF drives at the front + 2 SFF drives at the rear.
8SFF UniBay
A UniBay drive slot supports both SAS/SATA drives and NVMe drives. For more information about drive slots, see "Front panel view."
Item
Specifications
Dimensions (H × W × D)
·     Without a security bezel: 87.5 × 445.4 × 748 mm (3.44 × 17.54 × 29.45 in)
·     With a security bezel: 87.5 × 445.4 × 769 mm (3.44 × 17.54 × 30.28 in)
Max. weight
29.5 kg (65.04 lb)
Processors
4 × Intel Purley processors or Jintide-C series processors
(Up to 3.8 GHz base frequency, maximum 205 W power consumption, and 38.5 MB cache per processor)
Memory
A maximum of 48 DIMMs (support mixture of DCPMMs and DRAM DIMMs)
Chipset
Intel C621 Lewisburg chipset
Network connection
·     1 × onboard 1 Gbps HDM dedicated network port
·     2 × onboard 1 Gbps network adapter ports
·     1 × sLOM network adapter connector
I/O connectors
·     6 × USB connectors:
¡     5 × USB 3.0 connectors (two on the system board, two at the server rear, and one at the server front)
¡     1 × USB 2.0 connector at the server front
·     9 SATA connectors in total:
¡     1 × onboard mini-SAS-HD connector (×8 SATA connectors)
¡     1 × onboard ×1 SATA connector
·     1 × RJ-45 HDM dedicated port at the server rear
·     2 × 1 Gbps network adapter ports at the server rear
·     2 × VGA connectors (one at the server rear and one at the server front)
·     1 × BIOS serial port at the server rear
Expansion slots
A maximum of 11 × PCIe 3.0 slots (Up to 10 standard PCIe modules and one sLOM network adapter)
Optical drives
External USB optical drives
Power supplies
2 × hot-swappable power supplies in redundancy
800 W Platinum, 800W 336V high-voltage DC, 850W Titanium, 1200 W Platinum, 1600 W Platinum, and 1600W 336V high-voltage DC power supplies
Components
Figure 2 R6700 G3 server components
Table 2 R6700 G3 server components
Item
(1) Power supply
Supplies power to the server. It supports hot swapping and 1+1 redundancy.
(2) sLOM network adapter
Installed on the sLOM network adapter connector of the system board for network expansion.
(3) Riser card
Installed in the server to provide additional slots for PCIe modules.
(4) Processor heatsink
Cools the processor.
(5) Processor retaining bracket
Attaches a processor to the heatsink.
(6) Processor
Integrates a memory processing unit and a PCIe controller to provide data processing capabilities for the server.
(7) Riser card blank
Installed on an empty riser card connector to ensure good ventilation.
(8) Fan
Supports hot swapping and N+1 redundancy.
(9) Supercapacitor
Supplies power to the flash card of the power fail safeguard module, which enables the storage controller to back up data to the flash card for protection when power outage occurs.
(10) Chassis-open alarm module
Generates a chassis open alarm every time the access panel is removed. The alarms can be displayed from the HDM Web interface.
(11) NVMe VROC module
Works with VMD to provide RAID capability for the server to virtualize storage resources of NVMe drives.
(12) System battery
Supplies power to the system clock.
(13) Multifunctional rack mount ears
Attach the server to the rack. The right ear is integrated with the front I/O component. The left ear is integrated with VGA and USB 2.0 connectors.
(14) Drive cage
Encloses drives.
(15) Drive
Drive for data storage, which is hot swappable.
(16) Diagnostic panel
Displays information about faulty components for quick diagnosis.
(17) Fan cage
Used for holding fans.
(18) Memory
Stores computing data and data exchanged with external storage.
(19) TPM or TCM module
Provides encryption services to enhance data security.
(20) Access panel
N/A
(21) Drive backplane
Provides power and data channels for drives.
(22) System board
One of the most important parts of a server, on which multiple components are installed, such as processor, memory, and fan. It is integrated with basic server components, including the BIOS chip, HDM chip, and PCIe connectors.
(23) Chassis
N/A
(24) Processor mezzanine board
Installed over the system board to provide additional processor connectors and DIMM slots.
Front panel
Front panel view
Figure 3 shows the front panel view of the server.
Figure 3 Front panel
(1) VGA connector
(2) USB 2.0 connector
(3) Drive cage bay 1 for 8SFF SAS/SATA drives (optional)
(4) Drive cage bay 2 for 8SFF SAS/SATA drives or 8SFF UniBay drives
(5) Serial label pull tab module
(6) Drive cage bay 3 for 8SFF SAS/SATA drives or 8SFF UniBay drives (optional)
(7) Diagnostic panel or LCD module (optional)
(8) USB 3.0 connector
(9) UniBay drives (for the 4SFF UniBay + 4 SFF SAS/SATA drive configuration)
(10) SAS/SATA drives (for the 4SFF UniBay + 4 SFF SAS/SATA drive configuration)
LEDs and buttons
Figure 4 shows the front panel LEDs and buttons. Table 3 describes the status of the front panel LEDs.
Figure 4 Front panel LEDs and buttons
(1) Power on/standby button and system power LED
(2) Health LED
(3) sLOM or embedded network adapter Ethernet port LED
(4) UID button LED
Table 3 LEDs and buttons on the front panel
Button/LED
Status
·     Steady green—The system has started.
·     Flashing green (1 Hz)—The system is starting.
·     Steady amber—The system is in Standby state.
·     Off—No power is present. Possible reasons:
¡     No power source is connected.
¡     No power supplies are present.
¡     The installed power supplies are faulty.
¡     The system power cords are not connected correctly.
Health LED
·     Steady green—The system is operating correctly or a minor alarm has occurred.
·     Flashing green (4 Hz)—HDM is initializing.
·     Flashing amber (1 Hz)—A major alarm has occurred.
·     Flashing red (1 Hz)—A critical alarm has occurred.
If a system alarm is present, log in to HDM to obtain more information about the system running status.
·     Steady green—A link is present on the port.
·     Flashing green (1 Hz)—The port is receiving or sending data.
·     Off—No link is present on the port.
UID button LED
·     Steady blue—UID LED is activated. The UID LED can be activated by using the following methods:
¡     Press the UID button LED.
¡     Activate the UID LED from HDM.
·     Flashing blue:
¡     1 Hz—The firmware is being upgraded or the system is being managed from HDM.
¡     4 Hz—HDM is restarting. To restart HDM, press the UID button LED for a minimum of 8 seconds.
·     Off—UID LED is not activated.
Ports
The server provides fixed USB 3.0/2.0 and VGA connectors on its front panel.
Table 4 Ports on the front panel
Port
VGA connector
DB-15
Connects a display terminal, such as a monitor or KVM device.
USB connector
USB 3.0/2.0
Connects the following devices:
·     USB flash drive.
·     USB keyboard or mouse.
·     USB optical drive for operating system installation.
Rear panel
Rear panel view
Figure 5 shows the rear panel view.
Figure 5 Rear panel components
(1) PCIe slots 1 through 3
(2) PCIe slots 4 through 6
(3) PCIe slots 7 and 8
(4*) 2SFF UniBay drive cage or PCIe riser card (optional)
(5) Power supply 2
(6) Power supply 1
(7) VGA connector
(8) BIOS serial port
(9) USB 3.0 connectors
(10) Ethernet ports (1 Gbps, RJ-45)
(11) HDM dedicated network port (1 Gbps, RJ-45, default IP address 192.168.1.2/24)
(12) sLOM network adapter in slot 11 (optional)
·     The asterisk (*) indicates that if a PCIe riser card is installed, PCIe slots are numbered 9 to 10 from the top down.
·     A UniBay drive slot supports both SAS/SATA drives and NVMe drives.
LEDs
Figure 6 shows the rear panel LEDs. Table 5 describes the status of the rear panel LEDs.
Figure 6 Rear panel LEDs
(1, 4, and 6) Link LEDs of the Ethernet ports
(2, 5, and 7) Activity LEDs of the Ethernet ports
(3) UID LED
(8) Power supply 1 LED
(9) Power supply 2 LED
Table 5 LEDs on the rear panel
LED
Status
Link LED of an Ethernet port
Activity LED of an Ethernet port
·     Off—The port is not receiving or sending data.
UID LED
¡     Enable UID LED from HDM.
·     Flashing blue:
¡     1 Hz—The firmware is being updated or the system is being managed by HDM.
Power supply LED
·     Steady green—The power supply is operating correctly.
·     Flashing green (1 Hz)—Power is being input correctly but the system is not powered on.
·     Flashing green (0.33 Hz)—The power supply is in standby state and does not output power.
·     Flashing green (2 Hz)—The power supply is updating its firmware.
·     Steady amber—Either of the following conditions exists:
¡     The power supply is faulty.
¡     The power supply does not have power input, but the other power supply has correct power input.
·     Flashing amber (1 Hz)—An alarm has occurred on the power supply.
·     Off—No power supplies have power input, which can be caused by an incorrect power cord connection or power source shutdown.
Ports
Table 6 Ports on the rear panel
Port
VGA connector
DB-15
BIOS serial port
RJ-45
The BIOS serial port is used for the following purposes:
·     Log in to the server when the remote network connection to the server has failed.
·     Establish a GSM modem or encryption lock connection.
USB connector
USB 3.0
·     USB flash drive.
Ethernet port
RJ-45
Establishes a network connection for interaction with external devices.
RJ-45
Establishes a network connection to manage HDM from its Web interface.
Power receptacle
Standard single-phase
Connects the power supply to the power source.
System board
Figure 7 System board components
(1) TPM/TCM connector
(2) System maintenance switches (below the riser card support bracket)
(3) PCIe riser connector 1
(4) sLOM network adapter connector (slot 11)
(5) System battery
(6) Mini-SAS-HD port (×8 SATA ports)
(7) Front I/O connector
(8) NVMe VROC module connector
(9) SATA port
(10) LCD module connector
(11) Diagnostic panel connector
(12) Front drive backplane power connector 1
(13) Front drive backplane AUX connector 1
(14) Front drive backplane power connector 2
(15) Front drive backplane AUX connector 2
(16) Front drive backplane power connector 3
(17) Front drive backplane AUX connector 3
(18) Rear drive backplane power connector
(19) Chassis-open alarm module, front VGA, and USB 2.0 connector
(20) Rear drive backplane AUX connector
(21) Dual internal USB 3.0 connectors
(22) PCIe riser connector 4
(23) Processor mezzanine board connector
(24) PCIe riser connector 3
(25) Dual SD card extended module connector
(26) PCIe riser connector 2
Use the system maintenance switches as shown in Figure 8, if you forget HDM username, HDM password, or BIOS password, or need to restore default BIOS settings, as described in Table 7. To identify the location of the switches on the system board, see Figure 7.
Figure 8 System maintenance switches
To use the system maintenance switches, remove the riser card support bracket installed over the switches.
Table 7 System maintenance switches
Item
Remarks
Switch 1
·     OFF (default)HDM login requires the username and password of a valid HDM user account.
·     ON—HDM login requires the default username and password.
For security purposes, turn off the switch after you complete tasks with the default username and password as a best practice.
Switch 5
·     OFF (default)—Normal server startup.
·     ON—Restores the default BIOS settings.
To restore the default BIOS settings, turn on and then turn off the switch. The server starts up with the default BIOS settings at the next startup.
CAUTION:
The server cannot start up when the switch is turned on.
Switch 6
·     ON—Clears all passwords from the BIOS at server startup.
To clear all passwords from the BIOS, turn on the switch and then start the server. All the passwords will be cleared from the BIOS. Before the next server startup, turn off the switch to perform a normal server startup.
Switches 2, 3, 4, 7, and 8
Reserved.
N/A
Figure 9 Processor mezzanine board components
(1) SlimSAS connector 4A (×8 SlimSAS port, for processor 4)
(2) SlimSAS connector 4B (×8 SlimSAS port, for processor 4)
(3) SlimSAS connector 3B (×8 SlimSAS port, for processor 4)
(4) SlimSAS connector 3A (×8 SlimSAS port, for processor 4)
(5) SlimSAS connector 2B (×8 SlimSAS port, for processor 3)
(6) SlimSAS connector 2A (×8 SlimSAS port, for processor 3)
(7) SlimSAS connector 1A (×8 SlimSAS port, for processor 3)
(8) SlimSAS connector 1B (×8 SlimSAS port, for processor 3)
DIMM slots
The system board and processor mezzanine board each provide 6 DIMM channels per processor, 12 channels in total. Each channel contains one white-coded slot and one black-coded slot, as shown in Table 8.
Table 8 DIMM slot numbering and color-coding scheme
Processor
DlMM slots
Processor 1
A1 through A6 (white coded)
A7 through A12 (black coded)
Processor 2
B1 through B6 (white coded)
B7 through B12 (black coded)
Processor 3
Processor 4
Figure 10 and Figure 11 shows the physical layout of the DIMM slots on the system board and the processor mezzanine board, respectively. For more information about the DIMM slot population rules, see the guidelines in "Installing DIMMs."
Figure 10 DIMM physical layout on the system board
Figure 11 DIMM physical layout on the processor mezzanine board
For components compatible with the server and detailed component information, visit the query tool at http://www.h3c.com/cn/Service/Document_Software/Document_Center/Server/.
The model name of a hardware option in this document might differ slightly from its model name label.
A model name label might add a prefix or suffix to the hardware-coded model name for purposes such as identifying the matching server brand or applicable region. For example, the DDR4-2666-8G-1Rx8-R memory model represents memory module labels including DDR4-2666-8G-1Rx8-R, DDR4-2666-8G-1Rx8-R-F, and DDR4-2666-8G-1Rx8-R-S, which have different suffixes.
DIMMs
A DIMM rank is a set of memory chips that the system accesses while writing or reading from the memory. On a multi-rank DIMM, only one rank is accessible at a time.
To determine the rank classification of a DRAM DIMM, use the label attached to the DIMM, as shown in Figure 12.
Figure 12 DRAM DIMM rank classification label
Table 9 DIMM rank classification label description
Callout
Remarks
1
Capacity
·     8GB.
·     16GB.
·     32GB.
2
Number of ranks
·     1R—One rank.
·     2R—Two ranks.
·     4R—Four ranks.
·     8R—Eight ranks.
3
Data width
·     ×4—4 bits.
·     ×8—8 bits.
4
DIMM generation
Only DDR4 is supported.
5
Data rate
·     2133P—2133 MHz.
·     2400T—2400 MHz.
·     2666V—2666 MHz.
·     2933Y—2933 MHz.
6
DIMM type
·     L—LRDIMM.
·     R—RDIMM.
HDDs and SSDs
Drive LEDs
The server supports SAS, SATA, and NVMe drives, of which SAS and SATA drives support hot swapping. You can use the LEDs on a drive to identify its status after it is connected to a storage controller.
Figure 13 shows the location of the LEDs on a drive.
Figure 13 Drive LEDs
(1) Fault/UID LED
(2) Present/Active LED
To identify the status of a SAS or SATA drive, use Table 10. To identify the status of an NVMe drive, use Table 11.
Table 10 SAS/SATA drive LED description
Fault/UID LED status
Present/Active LED status
Flashing amber (0.5 Hz)
Steady green/Flashing green (4.0 Hz)
A drive failure is predicted. As a best practice, replace the drive before it fails.
Steady amber
The drive is faulty. Replace the drive immediately.
Steady blue
The drive is operating correctly and is selected by the storage controller.
Off
The drive is performing a RAID migration or rebuilding, or the system is reading or writing data to the drive.
Off
Steady green
The drive is present but no data is being read or written to the drive.
Off
Off
The drive is not securely installed.
Table 11 NVMe drive LED description
Off
The managed hot removal process is completed. You can remove the drive safely.
Flashing amber (4.0 Hz)
Off
The drive is in hot insertion process.
Steady amber
Steady blue
The drive is operating correctly and selected by the storage controller.
Off
Off
Steady green
Off
Off
The RSTe embedded RAID controller supports only SATA drives and the standard storage controllers support both SAS and SATA drives.
Table 12 presents the required storage controllers and riser cards for different front drive configurations and Table 13 presents the used drive cage bays and drive numbering schemes.
Table 12 Drive, storage controller, and riser card configurations
Server model
Front drive configuration
Storage controller
Riser card
8SFF SAS/SATA server
8SFF
(8 front SFF SAS/SATA drives)
·     Embedded RSTe RAID controller
·     1 × standard storage controller with 8 internal SAS ports
Any
16SFF
(16 front SFF SAS/SATA drives)
·     2 × standard storage controllers with 8 internal SAS ports
·     1 × RAID-LSI-9460-16i(4G) or RAID-LSI-9560-LP-16i-8GB standard storage controller
Any
16SFF
(8 front SFF SAS/SATA drives + 8 front SFF UniBay drives)
1 × RC-8*NVME-1*FHHL-G3 riser card
16SFF
(8 front SFF SAS/SATA drives + 8 front SFF NVMe drives)
24SFF
(24 SFF SAS/SATA drives)
·     3 × standard storage controllers with 8 internal SAS ports
·     2 × standard storage controllers with 8 internal SAS ports + 1 × RAID-LSI-9460-16i(4G) standard storage controller
Any
24SFF
(16 front SFF SAS/SATA drives + 8 front SFF UniBay drives)
·     1 × standard storage controllers with 8 internal SAS ports + 1 × RAID-LSI-9460-16i(4G) standard storage controller
24SFF
(16 front SFF SAS/SATA drives + 8 front SFF NVMe drives)
·     1 × RAID-LSI-9460-16i(4G) standard storage controller
8SFF UniBay server
8SFF
(4 front SFF UniBay drives in drive slots 4 through 7 + 4 front SFF SAS/SATA drives in drive slots 0 through 3)
·     1 × embedded RSTe storage controller
1 × RC-4*NVME-3*FHHL-G3 riser card for the UniBay drives
8SFF
(8 front SFF UniBay drives)
·     1 × standard storage controller with 16 internal SAS ports
1 × RC-8*NVME-1*FHHL-G3 riser card for the UniBay drives
16SFF
(16 front SFF NVMe drives)
N/A
2 × RC-8*NVME-1*FHHL-G3 riser cards
16SFF
(16 front SFF UniBay drives)
2 × RC-8*NVME-1*FHHL-G3 riser cards for the UniBay drives
24SFF
(8 front SFF SAS/SATA drives + 16 front SFF UniBay drives)
·     1 × RAID-LSI-9460-16i(4G) standard storage controller + 1 × standard storage controllers with 8 internal SAS ports
2 × RC-8*NVME-1*FHHL-G3 riser card for the UniBay drives
To install 2SFF drives at the server rear, connect the rear drives to the embedded RSTe RAID controller and connect the front drives to the standard controllers as described in Table 12.
Table 13 Drive population and drive numbering schemes
Drive configuration
Drive numbering
8SFF front drives
See Figure 14.
16SFF front drives
See Figure 15.
24SFF front drives
See Figure 16.
2SFF rear drives
See Figure 17.
For the location of the drive cage bays on the front panel of the server, see "Front panel view."
Figure 14 Drive numbering for 8SFF drive configurations
Figure 15 Drive numbering for 16SFF drive configurations
Figure 16 Drive numbering for the 24SFF drive configuration
Figure 17 Drive numbering for the 2SFF drives at the server rear
PCIe modules
Typically, the PCIe modules are available in the following standard form factors:
·     LP—Low profile.
·     FHHL—Full height and half length.
·     FHFL—Full height and full length.
·     HHHL—Half height and half length.
·     HHFL—Half height and full length.
Storage controllers
The server supports the following types of storage controllers depending on their form factors:
·     Embedded RSTe RAID controllerEmbedded in the server and does not require installation.
·     Standard storage controllerComes in a standard PCIe form factor and typically requires a riser card for installation.
For some storage controllers, you can order a power fail safeguard module to prevent data loss from power outages. This module provides a flash card and a supercapacitor. When a system power failure occurs, the supercapacitor provides power for a minimum of 20 seconds. During this interval, the storage controller can transfer data from DDR memory to the flash card, where the data remains indefinitely or until the controller retrieves the data. If the storage controller contains a built-in flash card, you can order only a supercapacitor.
Item
Specifications
Embedded in PCH of the system board
Connectors
·     One onboard ×8 mini-SAS-HD connector
·     One onboard ×1 SATA connector
Number of internal ports
9 internal SATA ports
Drive interface
6 Gbps SATA 3.0
PCIe interface
PCIe2.0 ×4
RAID levels
0, 1, 5, 10
Built-in cache memory
N/A
Power fail safeguard module
Not supported
Firmware upgrade
Upgraded with the BIOS
Other storage controllers
For more information, visit the query tool at http://www.h3c.com/cn/Service/Document_Software/Document_Center/Server/.
Riser cards
To expand the server with PCIe modules, you can install riser cards on the PCIe riser connectors.
Each PCIe slot in a riser card can supply a maximum of 75 W power to the PCIe module. You must connect a separate power cord to the PCIe module only if it requires more than 75 W power.
If a processor is faulty or absent, the corresponding PCIe slots are unavailable.
The slot number of a PCIe slot varies by the PCIe riser connector that holds the riser card. For example, slot 1/4 represents PCIe slot 1 if the riser card is installed on connector 1 and represents PCIe slot 4 if the riser card is installed on connector 2.
For information about PCIe riser connector locations, see "Rear panel."
RC-2*FHHL-G3
Item
Specifications
Connector 3
PCIe slots
·     Slot 7: PCIe3.0 ×8 (8, 4, 2, 1) for processor 2
·     Slot 8: PCIe3.0 ×8 (8, 4, 2, 1) for processor 2
The numbers in parentheses represent link widths.
Form factors of supported PCIe modules
LP
Maximum power supplied per PCIe slot
75 W
Figure 18 PCIe slots on the RC-2*FHHL-G3 riser card
(1) PCIe slot 8
(2) PCIe slot 7
RC-2LP-2U-G3-2
Item
Specifications
Connector 3
PCIe slots
·     Slot 7: PCIe3.0 ×16 (16, 8, 4, 2, 1) for processor 4
·     Slot 8: PCIe3.0 ×16 (16, 8, 4, 2, 1) for processor 2
SlimSAS connectors
·     Connectors A and B (×8 SlimSAS port, for processor 4), providing x8 PCIe link for slot 7.
·     The number in parentheses represents link widths.
·     For the standard storage controller held by the riser card to manage NVMe drives, connect the SlimSAS connectors to the front NVMe drive backplane.
·     The riser card supports control of up to four NVMe drives.
LP
75 W
Figure 19 PCIe slots and SlimSAS connectors on the RC-2LP-2U-G3-2 riser card
(1) PCIe slot 8
(2) PCIe slot 7
(3) SlimSAS connector B
(4) SlimSAS connector A
RC-2LP-2U-G3-3
Item
Specifications
Connector 4
PCIe slots
·     Slot 9: PCIe3.0 ×8 (8, 4, 2, 1) for processor 4
·     Slot 10: PCIe3.0 ×8 (8, 4, 2, 1) for processor 4
SlimSAS connectors
·     Connector A (×8 SlimSAS port, for processor 4), providing x8 PCIe link for slot 9.
·     Connector B (×8 SlimSAS port, for processor 4), providing x8 PCIe link for slot 10.
LP
75 W
Figure 20 PCIe slots and SlimSAS connectors on the RC-2LP-2U-G3-3 riser card
(1) SlimSAS connector B
(2) SlimSAS connector A
(3) PCIe slot 10
(4) PCIe slot 9
RC-3*FHHL-G3
Item
Specifications
·     Connector 1
·     Connector 2
PCIe slots
·     PCIe riser connector 1:
¡     Slot 1: PCIe3.0 ×16 (16, 8, 4, 2, 1) for processor 1
¡     Slot 2: PCIe3.0 ×16 (16, 8, 4, 2, 1) for processor 1
¡     Slot 3: PCIe3.0 ×8 (8, 4, 2, 1) for processor 3
·     PCIe riser connector 2:
¡     Slot 4: PCIe3.0 ×16 (16, 8, 4, 2, 1) for processor 2
¡     Slot 5: PCIe3.0 ×16 (16, 8, 4, 2, 1) for processor 2
¡     Slot 6: PCIe3.0 ×8 (8, 4, 2, 1) for processor 4
FHHL
75 W
Figure 21 PCIe slots on the RC-3*FHHL-G3 riser card
(1) PCIe slot 3/6
(2) PCIe slot 2/5
(3) PCIe slot 1/4
(4) GPU power connector
RC-3FHHL-2U-G3-1
Item
Specifications
·     Connector 1
·     Connector 2
PCIe slots
¡     Slot 1: PCIe3.0 ×16 (16, 8, 4, 2, 1) for processor 3
¡     Slot 3: PCIe3.0 ×16 (16, 8, 4, 2, 1) for processor 1
¡     Slot 4: PCIe3.0 ×16 (16, 8, 4, 2, 1) for processor 3
¡     Slot 6: PCIe3.0 ×16 (16, 8, 4, 2, 1) for processor 2
SlimSAS connectors
·     PCIe riser connector 1: Connectors A and B (×8 SlimSAS port, for processor 3), providing x8 PCIe link for slot 1.
·     PCIe riser connector 2: Connectors A and B (×8 SlimSAS port, for processor 3), providing x8 PCIe link for slot 4.
FHHL
75 W
Figure 22 PCIe slots and SlimSAS connectors on the RC-3FHHL-2U-G3-1 riser card
(1) PCIe slot 3/6
(2) PCIe slot 2/5
(3) PCIe slot 1/4
(4) SlimSAS connector B
(5) SlimSAS connector A
RC-4*NVME-3*FHHL-G3
Item
Specifications
·     Connector 1
·     Connector 2
PCIe slots
¡     Slot 1: PCIe3.0 ×8 (8, 4, 2, 1) for processor 1
¡     Slot 2: PCIe3.0 ×8 (8, 4, 2, 1) for processor 1
¡     Slot 4: PCIe3.0 ×8 (8, 4, 2, 1) for processor 3
¡     Slot 5: PCIe3.0 ×8 (8, 4, 2, 1) for processor 3
SlimSAS connectors
Connectors A1 and A3 (×8 SlimSAS port, for processor 1)
FHHL
75 W
Figure 23 PCIe slots and SlimSAS connectors on the RC-4*NVME-3*FHHL-G3 riser card
(1) PCIe slot 3/6
(2) PCIe slot 2/5
(3) PCIe slot 1/4
(4) SlimSAS connector A3
(5) SlimSAS connector A1
RC-8*NVME-1*FHHL-G3
Item
Specifications
·     Connector 1
·     Connector 2
PCIe slots
¡     Slot 1: PCIe3.0 ×8 (8, 4, 2, 1) for processor 3
¡     Slot 4: PCIe3.0 ×8 (8, 4, 2, 1) for processor 4
The numbers in parentheses represent link widths. Both slots support single-slot wide GPUs.
SlimSAS connectors
Connectors A1, A3, B1, and B3 (×8 SlimSAS port)
The connectors are managed by processor 1 and processor 2 if the card is installed over PCIe riser connector 1 and connector 2, respectively.
·     The riser card supports control of up to eight NVMe drives.
FHHL
75 W
Figure 24 PCIe slots and SlimSAS connectors on the RC-8*NVME-1*FHHL-G3 riser card
(1) SlimSAS connector B3
(2) SlimSAS connector B1
(3) SlimSAS connector A3
(4) SlimSAS connector A1
(5) PCIe slot 1/4
B/D/F information
Table 14 lists the default Bus/Device/Function numbers (B/D/F) when the following conditions are all met:
·     All processors are installed.
·     All PCIe riser connectors are installed with riser cards.
·     All PCIe slots in riser cards are installed with PCIe modules.
·     The sLOM network adapter is installed in slot 11.
B/D/F information in Table 14 might change if any of the above conditions is not met or a PCIe module with a PCIe bridge is installed.
For more information about riser cards, see "Riser cards" and "Replacing riser cards and PCIe modules." For more information the locations of slot 11, see "System board components."
For information about how to obtain B/D/F information, see "Obtaining B/D/F information."
Table 14 PCIe modules and the corresponding Bus/Device/Function numbers
Riser card model
PCIe slot
Processor
Port number
Root port (B/D/F)
End point (B/D/F)
RC-8*NVME-1*FHHL-G3
Connector 1
slot 1
Processor 3
Port 3C
ac:02.00
ad:00.00
Connector 2
slot 4
Processor 4
Port 2A
d8:00.00
d9:00.00
RC-3*FHHL-G3
Connector 1
slot 1
Processor 1
Port 1A
16:00.00
17:00.00
slot 2
Processor 1
Port 3A
32:00.00
33:00.00
slot 3
Processor 3
Port 3C
ac:02.00
ad:00.00
Connector 2
slot 4
Processor 2
Port 1A
44:00.00
45:00.00
slot 5
Processor 2
Port 2A
58:00.00
59:00.00
slot 6
Processor 4
Port 2A
d8:00.00
d9:00.00
RC-4*NVME-3*FHHL-G3
Connector 1
slot 1
Processor 1
Port 3A
32:00.00
33:00.00
slot 2
Processor 1
Port 3C
32:02.00
34:00.00
slot 3
Processor 3
Port 3C
ac:02.00
ad:00.00
Connector 2
slot 4
Processor 2
Port 2A
58:00.00
59:00.00
slot 5
Processor 2
Port 2C
58:02.00
5a:00.00
slot 6
Processor 4
Port 2A
d8:00.00
d9:00.00
RC-3FHHL-2U-G3-1
Connector 1
slot 1
Processor 3
Port 2A
98:00.00
99:00.00
slot 2
Processor 1
Port 3A
32:00.00
33:00.00
slot 3
Processor 1
Port 1A
16:00.00
17:00.00
Connector 2
slot 4
Processor 3
Port 1A
84:00.00
85:00.00
slot 5
Processor 2
Port 2A
58:00.00
59:00.00
slot 6
Processor 2
Port 1A
44:00.00
45:00.00
RC-2*FHHL-G3
Connector 3
slot 7
Processor 2
Port 3C
6c:02.00
6d:00.00
slot 8
Processor 2
Port 3A
6c:00.00
6e:00.00
RC-2LP-2U-G3-2
Connector 3
slot 7
Processor 4
Port 1A
c4:00.00
c5:00.00
slot 8
Processor 2
Port 3A
6c:00.00
6d:00.00
RC-2LP-2U-G3-3
Connector 4
slot 9
Processor 4
Port 3A
ec:00.00
ed:00.00
slot 10
Processor 4
Port 3C
ec:02.00
ef:00.00
N/A
N/A
slot 11 (for sLOM network adapter)
Processor 1
Port 2A
24:00.00
25:00 .00
·     The root port (B/D/F) indicates the bus number of the PCIe root node in the processor.
·     The end point (B/D/F) indicates the bus number of a PCIe module in the operating system.
You can obtain B/D/F information by using one of the following methods:
·     BIOS log—Search the dumpiio keyword in the BIOS log.
·     UEFI shell—Execute the pci command. For information about how to execute the command, execute the help pci command.
·     Operating system—The obtaining method varies by OS.
¡     For Linux, execute the lspci command.
If Linux does not support the lspci command by default, you must execute the yum command to install the pci-utils package.
¡     For Windows, install the pciutils package, and then execute the lspci command.
¡     For VMware, execute the lspci command.
Fans
Fan layout
Figure 25 shows the layout of the fans in the chassis.
Figure 25 Fan layout
Power supplies
The power supplies have an overtemperature protection mechanism. A power supply stops working when an overtemperature occurs and automatically recovers when the overtemperature condition is removed.
Item
Specifications
Model
PSR800-12A
Rated input voltage range
·     100 VAC to 240 VAC @ 50/60 Hz
·     192 VDC to 288 VDC (240 HVDC power source)
Maximum rated input current
·     10.0 A @ 100 VAC to 240 VAC
·     4.0 A @ 240 VDC
Maximum rated output power
800 W
Efficiency at 50 % load
94%, 80 Plus Platinum level
Temperature requirements
·     Operating temperature: 0°C to 50°C (32°F to 122°F)
·     Storage temperature: –40°C to +70°C (–40°F to +158°F)
Operating humidity
5% to 90%
Maximum altitude
5000 m (16404.20 ft)
Redundancy
1+1 redundancy
Hot swappable
Yes
Cold backup
Yes
Item
Specifications
Model
PSR800-12AHD
·     180 VDC to 400 VDC (240 to 336 HVDC power source)
·     3.8 A @ 240 VDC
800 W
94%
Operating humidity
5% to 90%
Maximum altitude
Redundancy
1+1 redundancy
Hot swappable
Yes
Cold backup
Yes
Item
Specifications
Model
PSR850-12A
·     11.0 A @ 100 VAC to 240 VAC
·     4.0 A @ 240 VDC
850 W
96%, 80 Plus Titanium level
Operating humidity
5% to 85%
Maximum altitude
Redundancy
1+1 redundancy
Hot swappable
Yes
Cold backup
Yes
Item
Specifications
Model
PSR1200-12A
·     100 VAC to 127 VAC @ 50/60 Hz (1000 W)
·     200 VAC to 240 VAC @ 50/60 Hz (1200 W)
·     192 VDC to 288 VDC (240 HVDC power source) (1200 W)
·     12.0 A @ 100 VAC to 240 VAC
·     6.0 A @ 240 VDC
1200 W
Operating humidity
5% to 90%
Maximum altitude
Redundancy
1+1 redundancy
Hot swappable
Yes
Cold backup
Yes
Item
Specifications
Model
PSR1600-12A
·     9.5 A @ 200 VAC to 240 VAC
·     8.0 A @ 240 VDC
1600 W
94%, 80 Plus platinum level
Operating humidity
5% to 90%
Maximum altitude
Redundancy
1+1 redundancy
Hot swappable
Yes
Cold backup
Yes
Item
Specifications
Model
DPS-1600AB-13 R
·     13.8 A @ 100 VAC to 127 VAC
·     9.6 A @ 200 VAC to 240 VAC
1600 W
Operating humidity
5% to 85%
Maximum altitude
Redundancy
1+1 redundancy
Hot swappable
Yes
Cold backup
Yes
Item
Specifications
Model
FSP1600-20FH
·     192 VDC to 400 VDC (240 or 336 HVDC power source)
·     6.0 A @ 336 VDC
1600 W
·     Operating temperature: 0°C to 55°C (32°F to 131°F)
Operating humidity
5% to 90%
Maximum altitude
Redundancy
1+1 redundancy
Hot swappable
Yes
Cold backup
Yes
Expander modules
Model
Specifications
HDDCage-8UniBay
Used in the 8SFF UniBay server.
Cage-8SFF-BAY1
Used in the 8SFF UniBay and 8SFF SAS/SATA servers.
Cage-8SFF-BAY3
Used in the 8SFF SAS/SATA server.
Diagnostic panels
Diagnostic panels provide diagnostics and troubleshooting capabilities. You can locate and troubleshoot component failures by using the diagnostic panels in conjunction with the event log generated in HDM.
A diagnostic panel displays only one component failure at a time. When multiple component failures exist, the diagnostic panel displays all these failures one by one at intervals of 4 seconds.
Figure 26 shows the error code and LEDs on a diagnostic panel.
Figure 26 Diagnostic panel view
(1) Error code
(2) LEDs
For more information about the LEDs and error codes, see "LEDs."
LEDs
The server is operating correctly when the error code is 00 and all LEDs are off.
POST LED
LED status
Error code
Steady green
Code for the current POST phase (in the range of 00 to 99)
The server is performing POST without detecting any error.
Flashing red (1 Hz)
The POST process encountered an error and stopped in the displayed phase.
TEMP LED
LED status
Error code
Temperature sensor ID
A major temperature warning is present on the component monitored by the sensor.
This warning might occur because the temperature of the component has exceeded the upper major threshold or dropped below the lower major threshold.
Flashing red (1 Hz)
A critical temperature warning is present on the component monitored by the sensor.
This warning might occur because the temperature of the component has exceeded the upper critical threshold or dropped below the lower critical threshold.
CAP LED
LED status
Error code
Flashing amber
01
The system power consumption has exceeded the power cap value.
Component LEDs
An alarm is present if a component LED has one of the following behaviors:
Use Table 15 to identify the faulty item if a component LED has one of those behaviors. To obtain records of component status changes, use the event log in HDM. For information about using the event log, see HDM online help.
Table 15 LED, error code and faulty item matrix
LED
Error code
Faulty item
BRD
01
System board
02
03
Drive backplane for front drive cage bay 1
04
Drive backplane for front drive cage bay 2
05
Drive backplane for front drive cage bay 3
11
91
CPU (processor)
01
Processor 1
02
Processor 2
03
Processor 3
04
Processor 4
DIMM
A1 through A9, AA, Ab, or AC
DIMM slots for processor 1:
·     A1 through A9—DIMMs in slots A1 through A9
·     AA—DIMM in slot A10
·     Ab—DIMM in slot A11
·     AC—DIMM in slot A12
b1 through b9, bA, bb, or bC
DIMM slots for processor 2:
·     b1 through b9—DIMMs in slots B1 through B9
·     bA—DIMM in slot B10
·     bb—DIMM in slot B11
·     bC—DIMM in slot B12
C1 through C9, CA, Cb, or CC
DIMM slots for processor 3:
·     C1 through C9—DIMMs in slots A1 through A9
·     CA—DIMM in slot A10
·     Cb—DIMM in slot A11
·     CC—DIMM in slot A12
d1 through d9, dA, db, or dC
DIMM slots for processor 4:
·     d1 through d9—DIMMs in slots B1 through B9
·     dA—DIMM in slot B10
·     db—DIMM in slot B11
·     dC—DIMM in slot B12
HDD
00 through 07
Drives in slots 0 through 7 in bay 1
08 through 15
Drives in slots 0 through 7 in bay 2
16 through 23
Drives in slots 0 through 7 in bay 3
32 and 33
·     32—Drive in slot 9 at the rear
·     33—Drive in slot 9 at the rear
PCIE
01 through 10
PCIe modules in PCIe slots 1 to 10 of a riser card
If a storage controller is installed in a PCIe slot, the RAID LED displays the storage controller status.
PSU
01
Power supply 1
02
Power supply 2
FAN
01 through 06
Fan 1 through Fan 6
VRD
01
P5V_STBY voltage on the system board
02
P3V3_STBY voltage on the system board
03
P1V05_PCH_STBY voltage on the system board
04
PVNN_PCH_STBY voltage on the system board
05
P1V8_PCH_STBY voltage on the system board
06
P5V voltage on the system board
07
P3V3 voltage on the system board
09
Primary power supply of the sLOM network adapter
10
Secondary power supply of the sLOM network adapter
11
Power supply of drive backplane 4 for rear 2SFF drives
12
Power supply of drive backplane 3 for front drive cage bay 1
13
Power supply of drive backplane 2 for front drive cage bay 2
14
Power supply of drive backplane 2 for front drive cage bay 3
21
Power supply of the riser card over riser connector 1
23
Power supply of the riser card over riser connector 2
26
Power supply of the riser card over riser connector 3
28
Power supply of the riser card over riser connector 4
40
Power supply fault summary
42
System board P12V overcurrent
44
Internal VR fault on processor 1 (fivr_fault)
45
Internal VR fault on processor 2 (fivr_fault)
50
Power supply of the processor mezzanine board
52
Processor mezzanine board P12V overcurrent
54
Internal VR fault on processor 3 (fivr_fault)
55
Internal VR fault on processor 4 (fivr_fault)
60
PVCCIO_CPU1 voltage on the system board
61
PVCCIN_CPU1 voltage on the system board
62
PVCCSA_CPU1 voltage on the system board
63
VDDQ_CPU1_ABC voltage on the system board
64
VDDQ_CPU1_DEF voltage on the system board
65
VPP_CPU1_ABC voltage on the system board
66
VPP_CPU1_DEF voltage on the system board
67
VTT_CPU1_ABC voltage on the system board
68
VTT_CPU1_DEF voltage on the system board
69
P1V0_CPU1 voltage on the system board
6A
PVMCP_CPU1 voltage on the system board
70
PVCCIO_CPU2 voltage on the system board
71
PVCCIN_CPU2 voltage on the system board
72
PVCCSA_CPU2 voltage on the system board
73
VDDQ_CPU2_ABC voltage on the system board
74
VDDQ_CPU2_DEF voltage on the system board
75
VPP_CPU2_ABC voltage on the system board
76
VPP_CPU2_DEF voltage on the system board
77
VTT_CPU2_ABC voltage on the system board
78
VTT_CPU2_DEF voltage on the system board
79
P1V0_CPU2 voltage on the system board
7A
PVMCP_CPU2 voltage on the system board
80
PVCCIO_CPU3 voltage on the processor mezzanine board
81
PVCCIN_CPU3 voltage on the processor mezzanine board
82
PVCCSA_CPU3 voltage on the processor mezzanine board
83
VDDQ_CPU3_ABC voltage on the processor mezzanine board
84
VDDQ_CPU3_DEF voltage on the processor mezzanine board
85
VPP_CPU3_ABC voltage on the processor mezzanine board
86
VPP_CPU3_DEF voltage on the processor mezzanine board
87
VTT_CPU3_ABC voltage on the processor mezzanine board
88
VTT_CPU3_DEF voltage on the processor mezzanine board
89
P1V0_CPU3 voltage on the processor mezzanine board
90
PVCCIO_CPU4 voltage on the processor mezzanine board
91
PVCCIN_CPU4 voltage on the processor mezzanine board
92
PVCCSA_CPU4 voltage on the processor mezzanine board
93
VDDQ_CPU4_ABC voltage on the processor mezzanine board
94
VDDQ_CPU4_DEF voltage on the processor mezzanine board
95
VPP_CPU4_ABC voltage on the processor mezzanine board
96
VPP_CPU4_DEF voltage on the processor mezzanine board
97
VTT_CPU4_ABC voltage on the processor mezzanine board
98
VTT_CPU4_DEF voltage on the processor mezzanine board
99
P1V0_CPU4 voltage on the processor mezzanine board
Model
Specifications
DVD-RW-Mobile-USB-A
Removable USB DVDRW drive module
IMPORTANT IMPORTANT:
For this module to work correctly, you must connect it to a USB 3.0 connector.
NVMe VROC modules
Model
RAID levels
Compatible NVMe drives
NVMe-VROC-Key-S
NVMe VROC module standard edition
0, 1, 10
All NVMe drives
NVMe-VROC-Key-P
NVMe VROC module premium edition
0, 1, 5, 10
All NVMe drives
NVMe-VROC-Key-i
NVMe VROC module Intel edition
0, 1, 5, 10
Intel NVMe drives
The server supports hot removal and managed hot removal of NVMe drives.
Managed hot removal of NVMe drives enables you to remove NVMe drives safely while the server is operating.
For information about operating systems that support hot removal and managed hot removal of NVMe drives, visit the query tool at http://www.h3c.com/cn/Service/Document_Software/Document_Center/Server/.
Use Table 16 to determine the managed hot removal method depending on the VMD status and the operating system type. For more information about VMD, see the BIOS user guide for the server.
Table 16 Managed hot removal methods
VMD status
Operating system
Auto/Enabled
Windows
Performing a managed hot removal in Windows.
Linux
Performing a managed hot removal in Linux.
Disabled
N/A
Contact the support.
Install Intel® Rapid Storage Technology enterprise (Intel® RSTe).
To obtain Intel® RSTe, use one of the following methods:
·     Go to https://platformsw.intel.com/KitSearch.aspx to download the software.
·     Contact Intel Support.
1.     Stop reading data from or writing data to the NVMe drive to be removed.
2.     Identify the location of the NVMe drive. For more information, see "Drive configurations and numbering."
3.     Run Intel® RSTe.
4.     Unmount the NVMe drive from the operating system, as shown in Figure 27:
¡     Select the NVMe drive to be removed from the Devices list.
¡     Click Activate LED to turn on the Fault/UID LED on the drive.
¡     Click Remove Disk.
Figure 27 Removing an NVMe drive
5.     Observe the Fault/UID LED on the drive. If the Fault/UID LED turns steady blue and the drive is removed from the Devices list, remove the drive from the server.
For more information about the removal procedure, see "Replacing an NVMe drive."
Identify that your operating system is a non-SLES Linux operating system. SLES operating systems do not support hot removal of NVMe drives.
3.     Access the CLI of the server.
4.     Execute the lsblk | grep nvme command to identify the drive letter of the NVMe drive, as shown in Figure 28.
Figure 28 Identifying the drive letter of the NVMe drive to be removed
5.     Execute the ledctl locate=/dev/drive_letter command to turn on the Fault/UID LED on the drive. The drive_letter argument represents the drive letter, nvme0n1 for example.
6.     Execute the echo 1 > /sys/block/drive_letter/device/device/remove command to unmount the drive from the operating system. The drive_letter argument represents the drive letter, nvme0n1 for example.
7.     Observe the Fault/UID LED on the drive. If the Fault/UID LED turns steady amber, remove the drive from the server.
The operating temperature requirements for the server vary depending on the server model and hardware configuration. When the general and component-based requirements conflict, use the component-based requirement.
Be aware that the actual maximum operating temperature of the server might be lower than what is stated because of poor site cooling performance. In a real data center, the server cooling performance might decrease because of adverse external factors, including poor cabinet cooling performance, high power density inside the cabinet, or insufficient spacing between devices.
Item
Specifications
Minimum: 5°C (41°F)
Maximum: Varies depending on the power consumed by the processors and presence of expansion modules. For more information, see "Operating temperature requirements."
Storage temperature
Operating humidity
8% to 90%, noncondensing
Storage humidity
5% to 95%, noncondensing
Operating altitude
–60 m to +3000 m (–196.85 ft to +9842.52 ft)
The allowed maximum temperature decreases by 0.33 °C (32.59°F) as the altitude increases by 100 m (328.08 ft) from 900 m (2952.76 ft)
Storage altitude
–60 m to +5000 m (–196.85 ft to +16404.20 ft)
General guidelines
The server supports N+1 fan redundancy. If a fan fails, server performance might degrade.
The DPS-1600AB-13 R power supply operates correctly only at 30°C (86°F).
Table 17 Operating temperature requirements
Maximum server operating temperature
Processor configuration
Hardware option configuration
30°C (86°F)
N/A
To use a GPU-T4 module, install the module to PCIe slot 1, 4, 6, or 7.
35°C (95°F)
N/A
To use a GPU-T4 module, install the module to PCIe slot 6 or 7.
40°C (104°F)
Processors with a TDP of 150 W or lower are supported (excluding processors 6240Y and 6252N).
The following hardware options are not supported:
·     DCPMMs.
·     GPUs.
·     NVMe drives.
45°C (113°F)
Processors with a TDP of 130 W or lower are supported.
·     DCPMMs.
·     NVMe SSD PCIe accelerator modules.
·     NVMe drives.
·     SATA M.2 SSDs.
·     GPU modules.
·     Rear SFF drives.
Table 18 Operating temperature requirements
30°C (86°F)
N/A
GPU-T4 module is not supported.
35°C (95°F)
When a GPU-P4 module is used, only processors with a TDP of 160 W or lower are supported.
40°C (104°F)
N/A
·     DCPMMs.
·     GPU modules.
·     NVMe drives.
45°C (113°F)
N/A
·     NVMe drives.
·     SATA M.2 SSDs.
·     GPU modules.
·     Rear SFF drives.
Table 19 Operating temperature requirements
30°C (86°F)
When a GPU-P4 module is used, only processors with a TDP of 165 W or lower are supported.
35°C (95°F)
N/A
GPU modules and rear NVMe drives are not supported.
40°C (104°F)
·     DCPMMs.
·     GPU modules.
·     NVMe drives.
·     SATA M.2 SSDs.
·     Rear SFF drives.
45°C (113°F)
Processors with a TDP of 105 W or lower are supported.
·     DCPMMs.
·     GPU modules.
·     NVMe drives.
·     SATA M.2 SSDs.
·     Rear SFF drives.
New H3C Technologies Co., Ltd. provides product recycling services for its customers to ensure that hardware at the end of its life is recycled. Vendors with product recycling qualification are contracted to New H3C to process the recycled hardware in an environmentally responsible way.
For product recycling services, contact New H3C at
·     Tel: 400-810-0504
·     E-mail: [email protected]
·     Website: http://www.h3c.com
Appendix F  Glossary
Item
B
BIOS
Basic input/output system is non-volatile firmware pre-installed in a ROM chip on a server's system board. The BIOS stores basic input/output, power-on self-test, and auto startup programs to provide the most basic hardware initialization, setup and control functionality.
C
CPLD
Complex programmable logic device is an integrated circuit used to build reconfigurable digital circuits.
F
FIST
Fast Intelligent Scalable Toolkit provided by H3C for easy and extensible server management. It can guide users to configure a server quickly with ease and provide an API interface to allow users to develop their own management tools.
G
GPU
Graphics processing unit module converts digital signals to analog signals for output to a display device and assists processors with image processing to improve overall system performance.
H
HDM
Hardware Device Management is the server management control unit with which administrators can configure server settings, view component information, monitor server health status, and remotely manage the server.
Hot swapping
A module that supports hot swapping (a hot-swappable module) can be installed or removed while the server is running without affecting the system operation.
K
KVM
A device that allows remote users to use their local video display, keyboard, and mouse to monitor and control remote servers.
N
Network adapter
A network adapter, also called a network interface card (NIC), connects the server to the network.
NVMe VROC module
A module that works with VMD to provide RAID capability for the server to virtualize storage resources of NVMe drives.
R
RAID
Redundant array of independent disks (RAID) is a data storage virtualization technology that combines multiple physical hard drives into a single logical unit to improve storage and security performance.
Redundancy
A mechanism that ensures high availability and business continuity by providing backup modules. In redundancy mode, a backup or standby module takes over when the primary module fails.
T
Temperature sensors
A temperature sensor detects changes in temperature at the location where it is installed and reports the temperature data to the server system.
U
U
A unit of measure defined as 44.45 mm (1.75 in) in IEC 60297-1. It is used as a measurement of the overall height of racks, as well as equipment mounted in the racks.
V
VMD
VMD provides hot removal, management, and fault-tolerance functions for NVMe drives to increase availability, reliability, and serviceability.
Appendix G  Acronyms
Acronym
Full name
B
BIOS
Basic Input/Output System
C
CMA
Cable Management Arm
CPLD
Complex Programmable Logic Device
D
DCPMM
Data Center Persistent Memory Module
DDR
Double Data Rate
DIMM
Dual Inline Memory Module
DRAM
Dynamic Random Access Memory
F
FIST
G
GPU
Graphics Processing Unit
H
HBA
Host Bus Adapter
HDD
Hard Disk Drive
HDM
I
IDC
Internet Data Center
K
KVM
Keyboard, Video, Mouse
L
LRDIMM
Load Reduced Dual Inline Memory Module
N
NCSI
Network Controller Sideband Interface
NVMe
Non-Volatile Memory Express
P
PCIe
Peripheral Component Interconnect Express
POST
Power-On Self-Test
R
RAID
Redundant Array of Independent Disks
RDIMM
Registered Dual Inline Memory Module
S
SAS
Serial Attached Small Computer System Interface
SATA
Serial ATA
SD
Secure Digital
SDS
Secure Diagnosis System
SFF
Small Form Factor
sLOM
Small form factor Local Area Network on Motherboard
SSD
Solid State Drive
T
TCM
Trusted Cryptography Module
TDP
Thermal Design Power
TPM
Trusted Platform Module
U
UID
Unit Identification
UPI
Ultra Path Interconnect
UPS
Uninterruptible Power Supply
USB
Universal Serial Bus
V
VROC
Virtual RAID on CPU
VMD
Volume Management Device
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
