H3C UniServer R6700 G3 Server User Guide-6W101
HomeSupportServerH3C UniServer R6700 G3Install & UpgradeInstallation GuidesH3C UniServer R6700 G3 Server User Guide-6W101
01-Text
Safety information· 1
Safety sign conventions· 1
Power source recommendations· 1
Installation safety recommendations· 2
General operating safety· 2
Electrical safety· 2
Rack mounting recommendations· 2
ESD prevention· 3
Cooling performance· 3
Battery safety· 3
Preparing for installation· 1
Rack requirements· 1
Installation site requirements· 3
Airflow directions· 3
Temperature, humidity, and altitude requirements· 3
Cleanliness requirements· 3
Grounding requirements· 4
Storage requirements· 4
Installation tools· 4
Installing or removing the server 1
Installing the server 1
Installing rails· 1
Rack-mounting the server 1
(Optional) Installing the CMA· 2
Connecting external cables· 2
Cabling guidelines· 2
Connecting a mouse, keyboard, and monitor 2
Connecting an Ethernet cable· 4
Connecting the power cord· 5
Securing cables· 7
Removing the server from a rack· 8
Powering on and powering off the server 1
Important information· 1
Powering on the server 1
Prerequisites· 1
Procedure· 1
Powering off the server 2
Prerequisites· 2
Procedure· 2
Configuring the server 1
Configuration flowchart 1
Configuring basic BIOS settings· 2
Setting the server boot order 2
Setting the BIOS passwords· 2
Configuring RAID·· 2
Installing the operating system and hardware drivers· 2
Installing the operating system·· 2
Installing hardware drivers· 2
Updating firmware· 3
Installing and removing hardware options· 1
General guidelines· 1
General prerequisites· 1
Replacing the security bezel 1
Removing the security bezel 1
Installing the security bezel 1
Installing the diagnostic panel 2
Replacing the diagnostic panel 2
Installing the LCD smart management module· 3
Replacing the LCD smart management module· 4
Installing front drive cages· 4
Prerequisites· 4
Procedure· 5
Installing the rear 2SFF UniBay drive cage· 6
Replacing a SAS/SATA drive· 6
Guidelines· 6
Prerequisites· 6
Removing a SAS/SATA drive· 7
Installing a SAS/SATA drive· 7
Verifying the replacement 7
Replacing an NVMe drive· 7
Guidelines· 7
Prerequisites· 8
Procedure· 8
Verifying the replacement 8
Replacing the NVMe VROC module· 8
Removing the NVMe VROC module· 8
Installing the NVMe VROC module· 9
Replacing a power supply· 9
Guidelines· 9
Removing a power supply· 9
Installing a power supply· 9
Replacing riser cards and PCIe modules· 10
Guidelines· 10
Removing a riser card and a PCIe module· 11
Installing a riser card and a PCIe module on PCIe riser connector 1 or 2· 11
Installing PCIe modules and a riser card on PCIe riser connector 3 or 4· 11
Replacing a SATA M.2 SSD·· 12
Guidelines· 12
Removing a SATA M.2 SSD·· 12
Installing a SATA M.2 SSD·· 13
Replacing the M.2 transfer module· 13
Removing the M.2 transfer module· 13
Installing the M.2 transfer module· 13
Replacing an SD card· 14
Guidelines· 14
Removing an SD card· 14
Installing an SD card· 14
Replacing the dual SD card extended module· 15
Removing the dual SD card extended module· 15
Installing the dual SD card extended module· 15
Replacing a standard storage controller and a power fail safeguard module· 15
Guidelines· 16
Preparing for replacement 17
Removing a standard storage controller and a power fail safeguard module· 17
Installing a storage controller and a power fail safeguard module· 18
Replacing a GPU module· 19
Guidelines· 19
Removing a GPU module· 19
Installing a GPU module· 20
Replacing a network adapter 20
Guidelines· 20
Replacing the sLOM network adapter 20
Replacing a standard PCIe network adapter 21
Replacing a drive backplane· 21
Removing a drive backplane· 21
Installing a drive backplane· 22
Replacing the processor mezzanine board or mezzanine air baffle kit 22
Removing the processor mezzanine board· 22
Installing the processor mezzanine board· 22
Replacing a DIMM·· 23
Guidelines· 23
Removing a DIMM·· 26
Installing a DIMM·· 26
Replacing a fan· 27
Replacing a processor 27
Guidelines· 27
Removing a processor 28
Installing a processor 28
Verifying the replacement 29
Installing and setting up a TCM or TPM·· 29
Installation and setup flowchart 30
Installing a TCM or TPM·· 30
Enabling the TCM or TPM in the BIOS· 31
Configuring encryption in the operating system·· 31
Replacing the system battery· 32
Removing the system battery· 32
Installing the system battery· 32
Replacing the system board· 33
Guidelines· 33
Removing the system board· 33
Installing the system board· 33
Connecting internal cables· 1
Guidelines· 1
Connecting drive cables for 8SFF SAS/SATA server 1
Front 16SFF SAS/SATA drive cabling· 1
Front hybrid 8SFF SAS/SATA and 8SFF UniBay drive cabling· 5
Front hybrid 8SFF SAS/SATA and 8SFF NVMe drive cabling· 6
Front 24SFF SAS/SATA drive cabling· 8
Front hybrid 16SFF SAS/SATA and 8SFF UniBay drive cabling· 12
Front hybrid 16SFF SAS/SATA and 8SFF NVMe drive cabling· 17
Connecting drive cables for 8SFF UniBay server 19
Front hybrid 4SFF UniBay and 4SFF SAS/SATA drive cabling· 19
Front 8SFF UniBay drive cabling· 23
Front 16SFF NVMe drive cabling· 26
Front 16SFF UniBay drive cabling· 27
Front hybrid 8SFF SAS/SATA and 16SFF UniBay drive cabling· 32
Connecting drive cables for the rear 2SFF UniBay drives· 36
Connecting the NVMe data cable· 36
Connecting the SATA data cable· 37
Connecting the AUX signal cable and the power cord· 38
Connecting the SATA M.2 SSD cable· 38
Connecting PCIe signal cables· 39
Maintenance· 41
Guidelines· 41
Maintenance tools· 41
Maintenance tasks· 41
Observing LED status· 41
Monitoring the temperature and humidity in the equipment room·· 41
Examining cable connections· 41
Technical support 42
Safety information
To avoid bodily injury or damage to the server or its components, make sure you are familiar with the safety signs on the server chassis or its components.
Table 1 Safety signs
Sign
Circuit or electricity hazards are present. Only H3C authorized or professional server engineers are allowed to service, repair, or upgrade the server.
WARNING WARNING!
To avoid bodily injury or damage to circuits, do not open any components marked with the electrical hazard sign unless you have authorization to do so.
Electrical hazards are present. Field servicing or repair is not allowed.
WARNING WARNING!
To avoid bodily injury, do not open any components with the field-servicing forbidden sign in any circumstances.
The RJ-45 port is used for network connection.
WARNING WARNING!
To avoid electrical shock, fire, or damage to hardware, do not connect a telephone or any other communication equipment to this port.
The surface or component might be hot and present burn hazards.
WARNING WARNING!
To avoid being burnt, allow hot surfaces or components to cool before touching them.
The server or component is heavy and requires more than one people to carry or move.
WARNING WARNING!
To avoid bodily injury or damage to hardware, do not move a heavy component alone. In addition, observe local occupational health and safety requirements and guidelines for manual material handling.
The server is powered by multiple power supplies.
WARNING WARNING!
To avoid bodily injury from electrical shocks, make sure you disconnect all power supplies if you are performing offline servicing.
Power instability or outage might cause data loss, service disruption, or damage to the server in the worst case.
To protect the server from unstable power or power outage, use uninterrupted power supplies (UPSs) to provide power for the server.
To avoid bodily injury or damage to the server, read the following information carefully before you operate the server.
To avoid bodily injury or damage to the server, follow these guidelines when you operate the server:
·     Only H3C authorized or professional server engineers are allowed to install, service, repair, operate, or upgrade the server.
·     Make sure all cables are correctly connected before you power on the server.
·     Place the server on a clean, stable table or floor for servicing.
·     To avoid being burnt, allow the server and its internal modules to cool before touching them.
Electrical safety
WARNING
WARNING!
If you put the server in standby mode (system power LED in amber) with the power on/standby button on the front panel, the power supplies continue to supply power to some circuits in the server. To remove all power for servicing safety, you must first press the button until the system power LED turns into steady amber, and then remove all power cords from the server.
To avoid bodily injury or damage to the server, follow these guidelines:
·     Always use the power cords that came with the server.
·     Do not use the power cords that came with the server for any other devices.
·     Power off the server when installing or removing any components that are not hot swappable.
To avoid bodily injury or damage to the equipment, follow these guidelines when you rack mount a server:
·     Mount the server in a standard 19-inch rack.
·     Make sure the leveling jacks are extended to the floor and the full weight of the rack rests on the leveling jacks.
·     Couple the racks together in multi-rack installations.
·     Load the rack from the bottom to the top, with the heaviest hardware unit at the bottom of the rack.
·     Get help to lift and stabilize the server during installation or removal, especially when the server is not fastened to the rails. As a best practice, a minimum of two people are required to safely load or unload a rack. A third person might be required to help align the server if the server is installed higher than check level.
·     For rack stability, make sure only one unit is extended at a time. A rack might get unstable if more than one server unit is extended.
·     Make sure the rack is stable when you operate a server in the rack.
·     To maintain correct airflow and avoid thermal damage to the server, use blanks to fill empty rack units.
ESD prevention
Electrostatic charges that build up on people and tools might damage or shorten the lifespan of the system board and electrostatic-sensitive components.
Preventing electrostatic discharge
To prevent electrostatic damage, follow these guidelines:
·     Transport or store the server with the components in antistatic bags.
·     Keep the electrostatic-sensitive components in the antistatic bags until they arrive at an ESD-protected area.
·     Place the components on a grounded surface before removing them from their antistatic bags.
·     Avoid touching pins, leads, or circuitry.
·     Make sure you are reliably grounded when touching an electrostatic-sensitive component or assembly.
Grounding methods to prevent electrostatic discharge
The following are grounding methods that you can use to prevent electrostatic discharge:
·     Wear an ESD wrist strap and make sure it makes good skin contact and is reliably grounded.
·     Take adequate personal grounding measures, including wearing antistatic clothing, static dissipative shoes, and antistatic gloves.
·     Use conductive field service tools.
·     Use a portable field service kit with a folding static-dissipating work mat.
Cooling performance
Poor cooling performance might result from improper airflow and poor ventilation and might cause damage to the server.
To ensure good ventilation and proper airflow, follow these guidelines:
·     Install blanks over empty module slots, including drive slots, rear PCIe slots, and power supply slots.
·     Do not block the ventilation openings in the server chassis.
·     To avoid thermal damage to the server, do not operate the server for long periods in any of the following conditions:
¡     Access panel open or uninstalled.
¡     Air baffles uninstalled.
¡     PCIe slots, drive slots, or power supply slots empty.
·     If the server is stacked in a rack with other devices, make sure there is a minimum clearance of 2 mm (0.08 in) below and above the server.
Battery safety
The server's system board contains a system battery, which is designed with a lifespan of 5 to 10 years.
If the server no longer automatically displays the correct date and time, you might need to replace the battery. When you replace the battery, follow these safety guidelines:
·     Do not attempt to recharge the battery.
·     Do not expose the battery to a temperature higher than 60°C (140°F).
·     Do not disassemble, crush, puncture, short external contacts, or dispose of the battery in fire or water.
·     Dispose of the battery at a designated facility. Do not throw the battery away together with other wastes.
Prepare a rack that meets the rack requirements and plan an installation site that meets the requirements of space and airflow, temperature, humidity, equipment room height, cleanliness, and grounding.
Rack requirements
IMPORTANT
IMPORTANT:
As a best practice to avoid affecting the server chassis, install power distribution units (PDUs) with the outputs facing backwards. If you install PDUs with the outputs facing the inside of the server, please perform an onsite survey to make sure the cables won't affect the server rear.
The server is 2U high. The rack for installing the server must meet the following requirements:
·     A standard 19-inch rack.
·     A clearance of more than 50 mm (1.97 in) between the rack front posts and the front rack door.
·     A minimum of 1200 mm (47.24 in) in depth as a best practice.
The installation limits for a rack vary by rack depth. For more information, see Table 2. As a best practice to avoid potential issues, contact H3C support for on-site surveys.
Table 2 Installation limits for different rack depths
Rack depth
Installation limits
1000 mm (39.37 in)
·     The H3C cable management arm (CMA) is not supported.
·     A clearance of 60 mm (2.36 in) is reserved from the server rear to the rear rack door for cabling.
·     The slide rails and PDUs might hinder each other. As a best practice, contact H3C Support to determine the installation site of PDUs or change PDU size. If the slide rails cannot be installed, use trays or other tools to support the server.
1100 mm (43.31 in)
Make sure the CMA does not hinder PDUs at the server rear before installing the H3C CMA. If the CMA hinders PDU installation, change a rack with larger depth or adjust the installation site of PDUs.
1200 mm (47.24 in)
Make sure the CMA does not hinder PDUs or the cabling. If the CMA hinders PDU installation or cabling, change the installation site of PDUs.
For detailed installation suggestions, see Figure 1.
Figure 1 Installation suggestions for a 1200 mm deep rack (top view)
(1) Rack depth 1200 mm (47.24 in)
(2) More than 50 mm (1.97 in) between the rack front posts and the front rack door
(3) 780 mm (30.71 in) between the rack front posts and the rear of the chassis, with handles of the power supplies not shown
(4) Server depth with chassis ears, 800 mm (31.50 in)
(5) 960 mm (37.80 in) between the front rack posts and CMA
(6) 860 mm (33.86 in) between the front rack posts and the rear of the slide rails
Airflow directions
Figure 2 Airflow through the server
(1) to (4) Directions of the airflow into the chassis and power supplies
(5) Direction of the airflow out of the power supplies
(6) to (8) Directions of the airflow out of the chassis
To ensure correct operation of the server, make sure the room temperature, humidity, and altitude meet the requirements as described in "Appendix D  Environment requirements."
Mechanically active substances buildup on the chassis might result in electrostatic adsorption, which causes poor contact of metal components and contact points. In the worst case, electrostatic adsorption can cause communication failure.
Table 3 Mechanically active substance concentration limit in the equipment room
Substance
Particle diameter
Concentration limit
Dust particles
≥ 5 µm
≤ 3 × 104 particles/m3
(No visible dust on desk in three days)
Dust (suspension)
≤ 75 µm
≤ 0.2 mg/m3
Dust (sedimentation)
75 µm to 150 µm
≤ 1.5 mg/(m2h)
Sand
≥ 150 µm
≤ 30 mg/m3
The equipment room must also meet limits on salts, acids, and sulfides to eliminate corrosion and premature aging of components, as shown in Table 4.
Table 4 Harmful gas limits in an equipment room
Gas
Maximum concentration (mg/m3)
SO2
0.2
H2S
0.006
NO2
0.04
NH3
0.05
Cl2
0.01
Correctly connecting the server grounding cable is crucial to lightning protection, anti-interference, and ESD prevention. The server can be grounded through the grounding wire of the power supply system and no external grounding cable is required.
To store the server, an HDD, or an SSD for 3 months or longer without power supply, power on the server, HDD, or SSD at least once every 3 months as a best practice. Make sure the power-on operation time is not less than 2 hours. For more information about powering on or off the server, see "Powering on and powering off the server."
As a best practice to avoid data loss, make sure the power-off storage time is less than 180 days for an HDD and less than 90 days for an SSD, M.2 SSD, or SD card.
Installation tools
Table 5 lists the tools that you might use during installation.
Table 5 Installation tools
Name
T25 Torx screwdriver
For captive screws inside chassis ears.
T30 Torx screwdriver
For captive screws on processor heatsinks.
T15 Torx screwdriver (shipped with the server)
For screws on the system board.
T10 Torx screwdriver (shipped with the server)
For screws on riser cards.
Flat-head screwdriver
For replacing the system battery.
Phillips screwdriver
For screws on drive brackets.
Cage nut insertion/extraction tool
For insertion and extraction of cage nuts in rack posts.
Diagonal pliers
For clipping insulating sleeves.
Paper knife
For unwrapping the server.
Tape measure
For distance measurement.
Multimeter
For resistance and voltage measurement.
ESD wrist strap
For ESD prevention when you operate the server.
Antistatic gloves
Antistatic clothing
Ladder
For high-place operations.
Interface cable (such as an Ethernet cable or optical fiber)
For connecting the server to an external network.
Monitor
For displaying the output from the server.
As a best practice, install hardware options to the server (if needed) before installing the server in the rack. For more information about how to install hardware options, see "Installing and removing hardware options."
Installing rails
Install the inner rails and the outer rails in the rack mounting rail kit to the server and the rack, respectively. For information about installing the rails, see the document shipped with the rails.
1.     Slide the server into the rack. For more information about how to slide the server into the rack, see the document shipped with the rails.
Figure 3 Rack-mounting the server
2.     Secure the server as shown in Figure 4:
a.     Push the server until the chassis ears are flush against the rack front posts, as shown by callout 1.
b.     Unlock the latches of the chassis ears, as shown by callout 2.
c.     Fasten the captive screws inside the chassis ears and lock the latches, as shown by callout 3.
Figure 4 Securing the server
Install the CMA if the server is shipped with a CMA. For information about how to install the CMA, see the installation guide shipped with the CMA.
Cabling guidelines
WARNING
WARNING!
To avoid electric shock, fire, or damage to the equipment, do not connect communication equipment to RJ-45 Ethernet ports on the server.
·     For heat dissipation, make sure no cables block the inlet or outlet air vents of the server.
·     To easily identify ports and connect/disconnect cables, make sure the cables do not cross.
·     Label the cables for easy identification of the cables.
·     Wrap unused cables onto an appropriate position on the rack.
·     To avoid damage to cables when extending the server out of the rack, do not route the cables too tight if you use the CMA.
Perform this task before you configure the BIOS, HDM, FIST, or RAID on the server or enter the operating system of the server.
The server provides two VGA connectors for connecting a monitor, one on the front panel and one on the rear panel.
The server is not shipped with a standard PS2 mouse and keyboard. To connect a PS2 mouse and keyboard, you must prepare a USB-to-PS2 adapter.
1.     Connect one plug of a VGA cable to a VGA connector on the server, and fasten the screws on the plug.
Figure 5 Connecting a VGA cable
2.     Connect the other plug of the VGA cable to the VGA connector on the monitor, and fasten the screws on the plug.
3.     Connect the mouse and keyboard.
¡     For a USB mouse and keyboard, directly connect the USB connectors of the mouse and keyboard to the USB connectors on the server.
¡     For a PS2 mouse and keyboard, insert the USB connector of the USB-to-PS2 adapter to a USB connector on the server. Then, insert the PS2 connectors of the mouse and keyboard into the PS2 receptacles of the adapter.
Figure 6 Connecting a PS2 mouse and keyboard by using a USB-to-PS2 adapter
Perform this task before you set up a network environment or log in to the HDM management interface through the HDM network port to manage the server.
1.     Determine the network port on the server.
¡     To connect the server to the external network, use the Ethernet port on the network adapter.
¡     To log in to the HDM management interface, use either of the following HDM network ports:
-     HDM dedicated network port on the server. For the position of the HDM dedicated network port, see rear panel view in "Appendix A  Server specifications."
-     HDM shared network port on the sLOM network adapter (if any). For the position of the HDM shared network port, see "Replacing the sLOM network adapter."
2.     Determine the type of the Ethernet cable.
Verify the connectivity of the cable by using a link tester.
If you are replacing the Ethernet cable, make sure the new cable is of the same type with the old cable or compatible with the old cable.
3.     Label the Ethernet cable by filling in the names and numbers of the server and the peer device on the label.
As a best practice, use labels of the same kind for all cables.
If you are replacing the Ethernet cable, label the new cable with the same number as the number of the old cable.
4.     Connect one end of the Ethernet cable to the network port on the server and the other end to the peer device.
Figure 7 Connecting an Ethernet cable
5.     Verify network connectivity.
After powering on the server, use the ping command to test the network connectivity. If the connection between the server and the peer device fails, make sure the Ethernet cable is correctly connected.
6.     Secure the Ethernet cable. For information about how to secure cables, see "Securing cables."
Guidelines
WARNING
WARNING!
To avoid damage to the equipment or even bodily injury, use the power cord that ships with the server.
Before connecting the power cord, make sure the server and components are installed correctly.
1.     Insert the power cord plug into the power receptacle of a power supply at the rear panel, as shown in Figure 8.
Figure 8 Connecting the power cord
2.     Connect the other end of the power cord to the power source, for example, the power strip on the rack.
3.     Secure the power cord to avoid unexpected disconnection of the power cord.
a.     (Optional.) If the cable clamp is positioned too near the power cord that it blocks the power cord plug connection, press down the tab on the cable mount and slide the clip backward.
Figure 9 Sliding the cable clamp backward
b.     Open the cable clamp, place the power cord through the opening in the cable clamp, and then close the cable clamp, as shown by callouts 1, 2, 3, and 4 in Figure 10.
Figure 10 Securing the power cord
c.     Slide the cable clamp forward until it is flush against the edge of the power cord plug, as shown in Figure 11.
Figure 11 Sliding the cable clamp forward
Securing cables
Securing cables to the CMA
For information about how to secure cables to the CMA, see the installation guide shipped with the CMA.
Securing cables to slide rails by using cable straps
You can secure cables to either left slide rails or right slide rails. As a best practice for cable management, secure cables to left slide rails.
When multiple cable straps are used in the same rack, stagger the strap location, so that the straps are adjacent to each other when viewed from top to bottom. This positioning will enable the slide rails to slide easily in and out of the rack.
To secure cables to slide rails by using cable straps:
1.     Hold the cables against a slide rail.
2.     Wrap the strap around the slide rail and loop the end of the cable strap through the buckle.
3.     Dress the cable strap to ensure that the extra length and buckle part of the strap are facing outside of the slide rail.
Figure 12 Securing cables to a slide rail
1.     Power down the server. For more information, see "Powering off the server."
2.     Disconnect all peripheral cables from the server.
3.     Extend the server from the rack, as shown in Figure 13.
a.     Open the latches of the chassis ears.
b.     Loosen the captive screws.
c.     Slide the server out of the rack.
Figure 13 Extending the server from the rack
4.     Place the server on a clean, stable surface.
If the server is connected to external storage devices, make sure the server is the first device to power off and then the last device to power on. This restriction prevents the server from mistakenly identifying the external storage devices as faulty devices.
Before you power on the server, you must complete the following tasks:
·     Install the server and internal components correctly.
·     Connect the server to a power source.
Powering on the server by pressing the power on/standby button
Press the power on/standby button to power on the server.
The server exits standby mode and supplies power to the system. The system power LED changes from steady amber to flashing green and then to steady green. For information about the position of the system power LED, see LEDs and buttons in "Appendix A  Server specifications."
Powering on the server from the HDM Web interface
1.     Log in to the HDM.
For information about how to log in to HDM, see the firmware update guide for the server.
2.     In the navigation pane, select Power & Thermal > Power Control.
The power control configuration page opens.
3.     Select Power on and then click Execute.
Powering on the server from the remote console interface
1.     Log in to HDM.
2.     Log in to a remote console and then power on the server.
For information about how to log in to a remote console, see H3C Servers HDM online help.
Configuring automatic power-on
You can configure automatic power-on from HDM or the BIOS.
To configure automatic power-on from HDM:
1.     Log in to HDM.
The meter power configuration page opens.
3.     Click the Automatic power-on tab and then select Always power on.
4.     Click Save.
To configure automatic power-on from the BIOS:
1.     Enter the BIOS.
For information about how to enter the BIOS, see the BIOS user guide for the server.
2.     Select Server Mgmt > AC Restore Settings, and then press Enter.
3.     Select Always Power On, and then press Enter.
4.     Press F4 to save the configuration.
Before powering off the server, you must complete the following tasks:
·     Backup all critical data.
·     Make sure all services have stopped or have been migrated to other servers.
Powering off the server from its operating system
1.     Connect a monitor, mouse, and keyboard to the server.
2.     Shut down the operating system of the server.
3.     Disconnect all power cords from the server.
Powering off the server by pressing the power on/standby button
1.     Press the power on/standby button and wait for the system power LED to turn into steady amber.
2.     Disconnect all power cords from the server.
Powering off the server forcedly by pressing the power on/standby button
IMPORTANT
IMPORTANT:
This method forces the server to enter standby mode without properly exiting applications and the operating system. Use this method only when the server system crashes. For example, a process gets stuck.
1.     Press and hold the power on/standby button until the system power LED turns into steady amber.
Powering off the server from the HDM Web interface
1.     Log in to HDM, and then power off the server. For more information, see H3C Servers HDM online help.
Powering off the server from the remote console interface
1.     Log in to a remote console, and then power off the server. For more information, see H3C Servers HDM online help.
The following information describes the procedures to configure the server after the server installation is complete.
Figure 14 Configuration flowchart
1.     Power on the server. For information about the procedures, see "Powering on the server."
2.     Verify that the health LED on the front panel is steady green, which indicates that the system is operating correctly. For more information about the health LED status, see LEDs and buttons in "Appendix A  Server specifications."
You can set the server boot order and the BIOS user and administrator passwords from the BIOS setup utility of the server.
The BIOS menu screenshots used in this document are for illustration only and might differ from your products.
You can change the server boot order from the BIOS. For information about the default boot order and the order change method, see the BIOS user guide for the server.
By default, no BIOS user password or BIOS administrator password is set. All people have full access to the BIOS.
To prevent unauthorized access to the BIOS settings, set BIOS administrator and user passwords. To perform access control based on user roles, make sure the BIOS user password and the BIOS administrator password are different.
For more information about setting passwords and privileges for the BIOS user and administrator, see the BIOS user guide for the server.
Configuring RAID
Configure physical and logical drives (RAID arrays) for the server.
The supported RAID levels and RAID configuration methods vary by storage controller model. For more information, see the storage controller user guide for the server.
Install a compatible operating system on the server by following the procedures described in the operating system installation guide for the server.
For information about the operating system compatibility, visit the OS compatibility query tool at http://www.h3c.com/cn/Service/Document_Software/Document_Center/Server/.
IMPORTANT
IMPORTANT:
In case an update failure causes hardware unavailability, always back up the drivers before you update them.
For newly installed hardware to operate correctly, the operating system must have the required hardware drivers.
To install a hardware driver, see the operating system installation guide for the server.
Updating firmware
IMPORTANT
IMPORTANT:
Verify the hardware and software compatibility before firmware upgrade. For information about the hardware and software compatibility, see the software release notes.
You can update the following firmware from FIST or HDM:
·     HDM.
·     BIOS.
·     CPLD.
·     DBCPLD.
·     STBCPLD.
For information about the update procedures, see the firmware update guide for the server.
If you are installing or replacing multiple hardware options, read their installation or replacement procedures and identify similar steps to streamline the entire procedure.
For more information about hardware installation and replacement videos, acess the official website at http://www.h3c.com/cn/home/qr/default.htm?id=543.
General guidelines
To remove the access panel for the first time, first remove the screws on both sides at the server rear.
Before you install or replace any hardware options except the security bezel, make sure the following conditions are met:
·     Wear the antistatic clothing.
·     Do not wear any conductive objects, such as jewelry and watches.
·     Examine the slot and connector for damages before you install a hardware option. Make sure the pins are not damaged (bent for example) and do not contain any foreign objects.
1.     Insert the key provided with the bezel into the lock on the bezel. Hold down and turn the key 90 degree clockwise to unlock the security bezel.
CAUTION
CAUTION:
To avoid damage to the lock, hold down the key while you are turning the key.
2.     Press the latch at one end of the bezel, open the security bezel, and then release the latch.
3.     Pull the other edge of the security bezel out of the groove in the chassis ear to remove the security bezel.
1.     Press the right edge of the security bezel into the groove in the right chassis ear on the server.
2.     Press the latch at the other end, close the security bezel, and then release the latch to secure the security bezel into place.
3.     Insert the key provided with the bezel into the lock on the bezel. Hold down and turn the key 90 degree counterclockwise to lock the security bezel. Then, pull out the key and keep it safe.
CAUTION
CAUTION:
WARNING
WARNING!
To avoid bodily injury from hot surfaces, allow the server and its internal modules to cool before touching them.
To install the diagnostic panel:
1.     Identify the location of the diagnostic panel. For more information, see system board components in "Appendix A  Server specifications."
2.     Power off the server. For more information, see "Powering off the server."
3.     Remove the server from the rack. For more information, see "Removing the server from a rack."
4.     Remove the security bezel, if any. For more information, see "Removing the security bezel."
5.     Remove the access panel. Pressing the two unlock buttons on the access panel, slide the panel toward the server rear, and then lift the panel to remove it.
6.     Remove the fan cage. Open the locking levers at the two ends of the fan cage, and then lift the fan cage out of the chassis.
7.     To install the diagnostic panel for the first time, remove the blank and install the 1SFF cage:
a.     Remove the blank from the slot in which the diagnostic panel will be installed. Remove the screw that secures the blank and then push the blank from the inside of the chassis to remove it.
b.     Insert the 1SFF cage provided with the diagnostic panel into the slot and secure the 1SFF cage with the fastening screw.
8.     Install the diagnostic panel:
a.     Connect the diagnostic panel cable to the diagnostic panel.
b.     Push the diagnostic panel into the slot until it snaps into place.
c.     Connect the other end of the diagnostic panel cable to the diagnostic panel connector on the system board. For more information about the location of the diagnostic panel connector, see system board components in "Appendix A  Server specifications."
9.     Install the fan cage. Place the fan cage in the chassis and then close the locking levers at the two ends of the fan cage.
10.     Install the access panel. Place the access panel on top of the server chassis and slide the access panel toward the server front until it snaps into place.
11.     Install the removed security bezel. For more information, see "Installing the security bezel."
12.     Rack-mount the server. For more information, see "Rack-mounting the server."
13.     Connect the power cord. For more information, see "Connecting the power cord."
14.     Power on the server. For more information, see "Powering on the server."
WARNING
WARNING!
To replace the diagnostic panel:
1.     Power off the server. For more information, see "Powering off the server."
2.     Remove the server from the rack. For more information, see "Removing the server from a rack."
3.     Remove the security bezel, if any. For more information, see "Removing the security bezel."
4.     Remove the access panel. Pressing the two unlock buttons on the access panel, slide the panel toward the server rear, and then lift the panel to remove it.
5.     Remove the fan cage. Open the locking levers at the two ends of the fan cage, and then lift the fan cage out of the chassis.
6.     Disconnect the diagnostic panel cable from the system board.
7.     Remove the diagnostic panel:
a.     Press the release button on the diagnostic panel. The ejector lever pops out.
b.     Hold the ejector lever to pull the diagnostic panel out of the slot.
8.     Install a new diagnostic panel. For more information, see "Installing the diagnostic panel."
WARNING
WARNING!
To install the LCD smart management module:
1.     Identify the location of the LCD smart management module. For more information, see system board components in "Appendix A  Server specifications."
7.     Remove the blank from the slot in which the LCD smart management module will be installed. Remove the screw that secures the blank and then push the blank from the inside of the chassis to remove it.
8.     Install the 1SFF cage. Insert the 1SFF cage into the slot and use the fastening screw to secure it into place.
9.     Install the LCD smart management module:
a.     Connect the extension cable of the LCD smart management module.
b.     Push the LCD smart management module into the slot until you cannot push it further.
c.     Connect the extension cable to the LCD smart management module connector on the system board. For more information about the location of the LCD smart management module connector, see system board components in "Appendix A  Server specifications."
10.     Install the fan cage. Place the fan cage in the chassis and then close the locking levers at the two ends of the fan cage.
11.     Install the access panel. Place the access panel on top of the server chassis and slide the access panel toward the server front until it snaps into place.
12.     Install the removed security bezel. For more information, see "Installing the security bezel."
13.     Rack-mount the server. For more information, see "Rack-mounting the server."
14.     Connect the power cord. For more information, see "Connecting the power cord."
15.     Power on the server. For more information, see "Powering on the server."
WARNING
WARNING!
To replace the LCD smart management module:
6.     Remove the LCD smart management module:
a.     Disconnect the extension cable of the LCD smart management module from the system board.
b.     Press the pull tab on the LCD smart management module with a T10 Torx screwdriver or a pair of tweezers, and then pull the LCD smart management module out of the slot.
7.     Install a new LCD smart management module. For more information, see "Installing the LCD smart management module."
8.     Install the fan cage. Place the fan cage in the chassis and then close the locking levers at the two ends of the fan cage.
9.     Install the access panel. Place the access panel on top of the server chassis and slide the access panel toward the server front until it snaps into place.
10.     Install the removed security bezel. For more information, see "Installing the security bezel."
11.     Rack-mount the server. For more information, see "Rack-mounting the server."
12.     Connect the power cord. For more information, see "Connecting the power cord."
13.     Power on the server. For more information, see "Powering on the server."
Use Table 6 to determine the location of the front drive cage you are installing depending on the type of the drive cage. For information about the installation locations of the front drive cages, see front panel view in "Appendix A  Server specifications."
Table 6 Drive cage installation locations
Drive cage model
Installation locations
HDDCage-8UniBay
Drive cage bay 3 for the 8SFF UniBay server
Cage-8SFF-BAY1
·     Drive cage bay 1 for the 8SFF UniBay server
·     Drive cage bay 1 for the 8SFF SAS/SATA server
Cage-8SFF-BAY3
Drive cage bay 3 for the 8SFF SAS/SATA server
6.     Remove the processor mezzanine board or mezzanine air baffle kit. For more information, see "Removing the processor mezzanine board."
7.     Install a front drive cage:
a.     Remove the blank (if any) from the slot for the diagnostic panel slot. Remove the screw that secures the blank and then push the blank from the inside of the chassis to remove it.
b.     Remove the blank from the bay in which the drive cage will be installed. Remove the screws that secure the blank and then push the blank from the inside of the chassis to remove it.
c.     Insert the drive cage to the drive cage bay and then use screws to secure it into place.
8.     (Optional.) Install standard storage controllers for drives to be installed in the drive cage. For more information, see "Installing a storage controller and a power fail safeguard module."
IMPORTANT
IMPORTANT:
Make sure the vendor of the new storage controllers are the same with that of the existing storage controllers. For more information, visit the query tool at http://www.h3c.com/cn/Service/Document_Software/Document_Center/Server/.
9.     Connect all cables to the drive backplane. For more information, see "Connecting drive cables for 8SFF SAS/SATA server" and "Connecting drive cables for 8SFF UniBay server."
10.     Install the processor mezzanine board. For more information, see "Installing the processor mezzanine board."
11.     Install the fan cage. Place the fan cage in the chassis and then close the locking levers at the two ends of the fan cage.
12.     Install the access panel. Place the access panel on top of the server chassis and slide the access panel toward the server front until it snaps into place.
13.     Install drives in the drive cage.
14.     Paste the drive label on the top of the server above the drive cage bay.
15.     Install the removed security bezel. For more information, see "Installing the security bezel."
16.     Rack-mount the server. For more information, see "Rack-mounting the server."
17.     Connect the power cord. For more information, see "Connecting the power cord."
18.     Power on the server. For more information, see "Powering on the server."
3.     Remove the access panel. Pressing the two unlock buttons on the access panel, slide the panel toward the server rear, and then lift the panel to remove it.
4.     Remove the rear 2SFF drive cage blank over the power supplies. Lift the drive cage bay out of the chassis.
5.     Install the riser card bracket. Align the guide pins on the bracket with the guide holes in the chassis, and then use screws to secure the bracket into place.
6.     Install the rear 2SFF drive cage. Place the drive cage in the chassis and use screws to secure the drive cage into place.
7.     Connect cables to the backplane of the 2SFF drive cage. For more information, see "Connecting drive cables for the rear 2SFF UniBay drives."
8.     Install a blank over the empty PCIe riser connector 3. Place the blank over the chassis, with the standouts of the blank aligned with the notches on the chassis edges, and then insert the blank into the chassis.
10.     Rack-mount the server. For more information, see "Rack-mounting the server."
11.     Connect the power cord. For more information, see "Connecting the power cord."
12.     Power on the server. For more information, see "Powering on the server."
Guidelines
The drives are hot swappable. If you hot swap an HDD repeatedly within 30 seconds, the system might fail to identify the drive.
If you are using the drives to create a RAID, follow these restrictions and guidelines:
·     To build a RAID (or logical drive) successfully, make sure all drives in the RAID are the same type (HDDs or SSDs) and have the same connector type (SAS or SATA).
·     For efficient use of storage, use drives that have the same capacity to build a RAID. If the drives have different capacities, the lowest capacity is used across all drives in the RAID.
·     If one drive is used by several logical drives, RAID performance might be affected and maintenance complexities will increase.
·     If the installed drive contains RAID information, you must clear the information before configuring RAIDs. For more information, see the storage controller user guide for the server.
To configure RAID settings after the drive is replaced, see the storage controller user guide for the server.
Back up data in the RAID array.
1.     Remove the security bezel, if any. For more information, see "Removing the security bezel."
2.     Observe the drive LEDs to verify that the drive is not selected by the storage controller and is not performing a RAID migration or rebuilding. For more information about drive LEDs, see drive LEDs in "Appendix B  Component specifications."
3.     Remove the drive:
¡     To remove an SSD, press the button on the drive panel to release the locking lever, and then hold the locking lever and pull the drive out of the slot.
¡     To remove an HDD, press the button on the drive panel to release the locking lever. Pull the drive 3 cm (1.18 in) out of the slot. Wait for a minimum of 30 seconds for the drive to stop rotating, and then pull the drive out of the slot.
4.     Remove the drive bracket. Remove the screws that secure the drive and then remove the drive from the bracket.
1.     Attach the drive to the drive bracket. Place the drive in the bracket and then use four screws to secure the drive into place.
2.     Insert the drive into the slot and push it gently until you cannot push it further, and then close the locking lever.
3.     Install the removed security bezel. For more information, see "Installing the security bezel."
Use one of the following methods to verify that the drive has been replaced correctly:
·     Verify the drive properties (including capacity) by using one of the following methods:
¡     Log in to HDM. For more information, see H3C Servers HDM online help.
¡     Access the BIOS. For more information, see the storage controller user guide for the server.
¡     Access the CLI or GUI of the server.
·     Observe the drive LEDs to verify that the drive is operating correctly. For more information about drive LEDs, see drive LEDs in "Appendix B  Component specifications."
Guidelines
NVMe drives support hot insertion.
Support for hot removal and managed hot removal of NVMe drives varies by operating system. For more information, see "Appendix C  Hot removal and managed hot removal of NVMe drives." To remove an NVMe drive in an operating system that does not support hot removal and managed hot removal of NVMe drives, first power off the server.
·     For efficient use of storage, use drives that have the same capacity to build a RAID. If the drives have different capacities, the lowest capacity is used across all drives in the RAID. A drive with extra capacity cannot be used to build other RAIDs.
1.     Identify whether the operating system of the server supports hot removal and managed hot removal of NVMe drives.
¡     If the operating system supports hot removal or managed hot removal, identify the NVMe drive to be removed, and then remove the drive or perform managed hot removal for the drive.
For data security purposes, perform hot removal as a best practice. For more information about managed hot removal, see "Appendix C  Hot removal and managed hot removal of NVMe drives."
¡     If the operating system does not support hot removal or managed hot removal, power off the server. For more information, see "Powering off the server."
2.     Remove the security bezel, if any. For more information, see "Removing the security bezel."
3.     Remove the drive. For more information, see "Replacing a SAS/SATA drive."
4.     Install a new drive. For more information, see "Replacing a SAS/SATA drive."
5.     Install the removed security bezel, if any. For more information, see "Installing the security bezel."
Use the following methods to verify that the drive is installed correctly:
¡     Access HDM. For more information, see HDM online help.
¡     Access the BIOS. For more information, see the BIOS user guide for the server.
·     Observe the drive LEDs to verify that the drive is operating correctly. For more information, see drive LEDs in "Appendix B  Component specifications."
WARNING
WARNING!
4.     Remove the processor mezzanine board or mezzanine air baffle kit, if any. For more information, see "Removing the processor mezzanine board."
5.     Pinch the NVMe VROC module with a finger passing through the ring part, and then pull the module out of the chassis.
1.     Insert the NVMe VROC module onto the NVMe VROC module connector on the system board.
2.     Install the removed processor mezzanine board or mezzanine air baffle kit. For more information, see "Installing the processor mezzanine board."
3.     Install the access panel. Place the access panel on top of the server chassis and slide the access panel toward the server front until it snaps into place.
4.     Rack-mount the server. For more information, see "Rack-mounting the server."
5.     Connect the power cord. For more information, see "Connecting the power cord."
6.     Power on the server. For more information, see "Powering on the server."
Guidelines
·     The power supplies are hot swappable.
·     Make sure the installed power supplies are the same model. HDM will perform power supply consistency check and generate an alarm if the power supply models are different.
·     To avoid hardware damage, do not use third-party power supplies.
·     If two power supplies are installed and sufficient space is available for replacement, you can replace a power supply without powering off or removing the server from the rack.
3.     Remove the power cord from the power supply:
a.     Press the tab to disengage the ratchet from the tie mount, slide the cable clamp outward, and then release the tab.
b.     Open the cable clamp and remove the power cord out of the clamp.
c.     Unplug the power cord.
4.     Uninstall the CMA on the side of the power supply, if any:
a.     Take out cables that hinder the replacement from the cable baskets of the CMA. During this operation, make sure cables required for server operation remain connected.
b.     Press the tab on the CMA connector next to the power supply and then pull the connector out.
5.     Holding the power supply by its handle and pressing the retaining latch with your thumb, pull the power supply slowly out of the slot.
IMPORTANT
IMPORTANT:
If the server was configured with only one power supply before the replacement, you must install the new power supply in the same slot as the removed power supply.
1.     Push the power supply into the slot until it snaps into place.
2.     Install the removed CMA.
WARNING
WARNING!
The server provides three PCIe riser connectors on the system board to connect riser cards, which hold PCIe modules. For more information about the connector locations, see system board components in "Appendix A  Server specifications."
Guidelines
·     You can install a PCIe module in a PCIe slot for a larger-sized PCIe module. For example, an LP PCIe module can be installed in a slot for an FHFL PCIe module.
·     A PCIe slot can supply power to the installed PCIe module if the maximum power consumption of the module does not exceed 75 W. If the maximum power consumption exceeds 75 W, a power cord is required.
·     If a processor is faulty or absent, the corresponding PCIe slots are unavailable. For more information about processor and PCIe slot mapping relationship, see riser cards in "Appendix B  Component specifications."
·     For more information about PCIe module and riser card compatibility, see riser cards in "Appendix B  Component specifications."
·     For more information about riser card installation location, see Table 7.
Table 7 Riser card installation location
Riser card module
RC-8*NVME-1*FHHL-G3
1 and 2
RC-3FHHL-2U-G3-1
RC-4*NVME-3*FHHL-G3
RC-3*FHHL-G3
RC-2*FHHL-G3
3
RC-2LP-2U-G3-2
RC-2LP-2U-G3-3
4
The removal procedure is the same for riser cards in PCIe connectors 1, 2, 3, and 4.
To remove a riser card and a PCIe module:
4.     Disconnect all cables that might hinder the replacement.
5.     Lift the riser card out the chassis to remove the riser card.
6.     Remove the screws that secures the PCIe module, and then pull the PCIe module out of the slot.
1.     Install the PCIe module to the riser card:
a.     Remove the screw on the PCIe module blank in the target PCIe slot, and then pull the blank out of the slot.
b.     Insert the PCIe module into the slot along the guide rails and use the removed screw to secure it into place.
2.     Install the riser card to the server:
a.     Lift the riser card blank out of the chassis.
b.     Install the riser card on the PCIe riser connector. Align the standouts on the riser card with the notches on the chassis edges, and insert the riser card in the PCIe riser connector.
3.     Connect cables to the riser card or PCIe modules, if any.
4.     Install the access panel. Place the access panel on top of the server chassis and slide the access panel toward the server front until it snaps into place.
5.     Rack-mount the server. For more information, see "Rack-mounting the server."
6.     Connect the power cord. For more information, see "Connecting the power cord."
7.     Power on the server. For more information, see "Powering on the server."
4.     Lift the riser card blank out of the chassis to remove the blank.
5.     Install the PCIe module to the riser card:
a.     Remove the PCIe module blank. Remove the screw that secures the blank and then pull the blank out of the slot.
b.     Install the PCIe module to the riser card. Insert the PCIe module into the PCIe slot along the guide rails, and then use the removed screw to secure the module into place.
6.     Install the riser card bracket. Align the guide pins on the bracket with the guide holes in the chassis, and then use screws to secure the bracket into place.
7.     To install the riser card on PCIe riser connector 4, remove the screw from the captive screw hole on the system board.
8.     Install the riser card on the PCIe riser connector.
9.     For the riser card on PCIe riser connector 4, fasten the captive screw to secure the riser card into place.
10.     Connect cables to the riser card or PCIe modules, if any.
11.     Install a blank over the empty 2SFF drive cage bay. Place the blank over the chassis, with the standouts of the blank aligned with the notches on the chassis edges, and then insert the blank into the chassis.
WARNING
WARNING!
Guidelines
You can install M.2 transfer modules in PCIe slots 1 through 6.
If you are installing two SATA M.2 SSDs, install two SATA M.2 SSDs of the same model to ensure high availability.
As a best practice, use SATA M.2 SSDs to install the operating system.
4.     Remove the riser card that has a M.2 transfer module attached:
a.     Disconnect the SATA M.2 SSD cable from the M.2 transfer module.
b.     Lift the riser card out of the chassis.
5.     Remove the M.2 transfer module from the riser card. Remove the screw that secures the M.2 transfer module and then pull the module out of the slot.
6.     Remove the SATA M.2 SSD. Remove the screw that secures the SSD on the transfer module and then pull the SSD out of the connector.
1.     Install the SATA M.2 SSD to the M.2 transfer module. Insert the connector of the SSD into the socket and then use the screw to secure the SSD into place.
2.     Install the transfer module to a riser card. Insert the PCIe module into the slot along the guide rails and use the screw to secure it into place.
3.     Install the riser card to the server:
a.     Install the riser card on the PCIe riser connector.
b.     Connect the SATA M.2 SSD cable. For more information, see "Connecting the SATA M.2 SSD cable."
WARNING
WARNING!
5.     Disconnect the SATA M.2 SSD cable from the system board.
6.     Remove the M.2 transfer module from the riser card. Remove the screw that secures the M.2 transfer module and then pull the module out of the slot.
7.     Remove the SATA M.2 SSDs. Remove the screw that secures the SSDs on the transfer module and then pull the SSDs out of the connector.
1.     Install two threaded studs into place. Move the threaded studs from the screw holes that are far away from the SATA M.2 SSD connectors on the transfer module to the screw holes closer to the connectors.
2.     Install the SATA M.2 SSDs to the M.2 transfer module. Insert the connector of each SSD into the socket and then use a screw to secure the SSD onto the threaded stud.
3.     Install the transfer module to a riser card. Insert the PCIe module into the slot along the guide rails and use the screw to secure it into place.
4.     Install the riser card to the server:
a.     Insert the riser card in the PCIe riser connector.
5.     Install the access panel. Place the access panel on top of the server chassis and slide the access panel toward the server front until it snaps into place.
WARNING
WARNING!
CAUTION
CAUTION:
To avoid thermal damage to the server, do not operate the server for long periods with the access panel open or uninstalled.
Guidelines
The two SD cards installed on the dual SD card extended module form a RAID 1 array by default. To avoid storage space waste, install two SD cards with the same capacity as a best practice.
Removing an SD card
4.     Remove the PCIe riser card that might hinder the removal.
5.     Remove the dual SD card extended module. Press the top clip and the side clip on the dual SD card extended module, pull the module out of the connector, and then release the clips.
6.     Press the SD card to release it and then pull the SD card out of the slot.
1.     Insert the SD card into the slot, and press the SD card down gently to secure the SD card into the slot.
2.     Install the dual SD card extended module. Insert the dual SD card extended module downwards slowly into the connector until it snaps into space.
3.     Install the removed riser card.
WARNING
WARNING!
4.     For the ease of replacement, remove the PCIe riser card that might hinder the removal.
6.     Remove the SD cards installed on the extended module. Press an SD card to release it and then pull the SD card out of the slot.
1.     Install the removed SD cards to the new dual SD card extended module. Insert an SD card into the slot, and press the SD card down gently to secure the SD card into the slot.
2.     Insert the new dual SD card extended module. Insert the dual SD card extended module downwards slowly into the connector until it snaps into space.
3.     Install the removed PCIe riser card.
WARNING
WARNING!
For some storage controllers, you can order a power fail safeguard module to prevent data loss when power outage occurs.
A power fail safeguard module provides a flash card and a supercapacitor. When a system power failure occurs, this supercapacitor can provide power for a minimum of 20 seconds. During this interval, the storage controller transfers data from DDR memory to the flash card, where the data remains indefinitely or until the controller retrieves the data.
A supercapacitor has a lifespan of 3 to 5 years. If the lifespan of a supercapacitor expires, a supercapacitor exception might occur. The system notifies users of supercapacitor exceptions by using the following methods:
·     For a PMC storage controller, the status of the flash card will become Abnormal_status code. You can check the status code to identify the exception. For more information, see HDM online help.
·     For an LSI storage controller, the status of the flash card of the power fail safeguard module will become Abnormal.
You can also review log messages from HDM to identify supercapacitor exceptions.
For the power fail safeguard module to take effect, replace the supercapacitor before its lifespan expires.
IMPORTANT
IMPORTANT:
After the supercapacitor replacement, verify that cache related settings are enabled for logical drives. For more information, see HDM online help.
Guidelines
To install multiple storage controllers, make sure they are of the same vendor. For information about the available storage controllers and their vendors, visit the query tool at http://www.h3c.com/cn/Service/Document_Software/Document_Center/Server/.
Make sure the power fail safeguard module or supercapacitor is compatible with the storage controller. Use Table 8 to identify the compatibility and supercapacitor installation location.
Table 8 Storage controller compatibility with power fail safeguard module or supercapacitor
Storage controller
Power fail safeguard module/supercapacitor
Supercapacitor location
RAID-LSI-9361-8i(1G)-A1-X
Flash-LSI-G2-2U-2 or SCAP-LSI-G2-2U power fail safeguard module
On the air baffle
RAID-LSI-9361-8i(2G)-1-X
RAID-P460-B4
BAT-PMC-G3-2U-1 or SCAP-PMC-G3-2U supercapacitor
RAID-LSI-9460-8i(2G)
SCAP-LSI-G3-2U or BAT-LSI-G3 supercapacitor
RAID-LSI-9460-8i(4G)
RAID-LSI-9460-16i(4G)
HBA-LSI-9300-8i-A1-X
Not supported
N/A
HBA-H460-B1
HBA-LSI-9311-8i
HBA-LSI-9440-8i
The supercapacitor might have a low charge after the power fail safeguard module is installed or after the server is powered up. If the system displays that the supercapacitor has low charge, no action is required. The system will charge the supercapacitor automatically. You can view the status of the supercapacitor from the BIOS.
Each supercapacitor has a short supercapacitor cable attached to it and requires an extension cable for storage controller connection. The required extension cable varies by supercapacitor model and storage controller model. Use Table 9 to determine the extension cable to use.
Table 9 Supercapacitor extension cable selection
Standard storage controller model
Supercapacitor
Extension cable P/N
·     RAID-LSI-9361-8i(1G)-A1
·     RAID-LSI-9361-8i(2G)-1
Supercapacitor of the Flash-LSI-G2-2U-2 power fail safeguard module
0404A12J
Supercapacitor of the SCAP-LSI-G2-2U power fail safeguard module
0404A0SV
·     RAID-LSI-9460-8i(2G)
·     RAID-LSI-9460-8i(4G)
SCAP-LSI-G3-2U
0404A0VC
BAT-LSI-G3
0404A0W6
·     RAID-LSI-9460-16i(4G)
·     RAID-LSI-9560-LP-16i-8GB
BAT-LSI-G3
0404A0W6
RAID-P460-B4
BAT-PMC-G3-2U-1
0404A11X
SCAP-PMC-G3-2U
0404A0TG
You can install a supercapacitor on the processor mezzanine board or mezzanine air baffle kit or in a supercapacitor container. The installation location varies by supercapacitor model. Table 10 shows the supercapacitors that can be deployed at each location.
Table 10 Supercapacitors available for each installation location
Available supercapacitors
On the processor mezzanine board
·     Supercapacitor of the Flash-LSI-G2-2U-2 power fail safeguard module
·     BAT-LSI-G3
·     BAT-PMC-G3-2U-1
In the supercapacitor container
·     Supercapacitor of the SCAP-LSI-G2-2U power fail safeguard module
·     SCAP-LSI-G3-2U
·     SCAP-PMC-G3-2U
To replace the storage controller with a controller of the same model, identify the following information before the replacement:
·     Storage controller location and cabling.
·     Storage controller model, operating mode, and firmware version.
·     BIOS boot mode.
·     First boot option in Legacy mode.
To replace the storage controller with a controller of a different model, back up data in drives and then clear RAID information before the replacement.
4.     Remove the processor mezzanine board or mezzanine air baffle kit. For more information, see "Removing the processor mezzanine board."
5.     Disconnect data cables from the standard storage controller.
6.     Remove the supercapacitors:
¡     For the supercapacitors are installed on the processor mezzanine board or mezzanine air baffle kit, skip this step because the supercapacitors have been removed when you remove the processor mezzanine board or mezzanine air baffle kit.
¡     For the supercapacitor installed in a supercapacitor container, remove the screw that secures the supercapacitor container, and then pull the cage out of the slot. Then, open the cable clamp and take the supercapacitor out of the cage.
7.     Remove the storage controller:
a.     Remove the riser card in which the storage controller is installed. Lift the riser card out of the chassis.
b.     Remove the storage controller. Remove the screw that secures the storage controller, and then lift the storage controller to remove it.
8.     Remove the flash card on the standard storage controller, if any. Remove the screws that secure the flash card, and then remove the flash card.
1.     (Optional.) Install the flash card of the power fail safeguard module to the standard storage controller:
IMPORTANT
IMPORTANT:
Skip this step if no power fail safeguard module is required or the storage controller has a built-in flash card. For information about storage controllers with a built-in flash card, see storage controllers in "Appendix B  Component specifications."
a.     Install the two internal threaded studs supplied with the power fail safeguard module on the standard storage controller.
b.     Slowly insert the flash card connector into the socket and use screws to secure the flash card on the storage controller.
c.     Connect one end of the extension cable provided with the power fail safeguard module to the supercapacitor.
CAUTION
CAUTION:
Make sure the extension cable is the correct one. For more information, see Table 9.
2.     (Optional.) Install the supercapacitor in the supercapacitor container:
a.     Insert the supercapacitor into the supercapacitor container and place the supercapacitor cable into the cable clip.
b.     Insert the supercapacitor container into the target slot on the front panel, and use the screw to secure the supercapacitor container.
c.     Install the security bezel. For more information, see "Installing the security bezel."
3.     Install the standard storage controller to the riser card. Insert the storage controller into the PCIe slot along the guide rails, and use the screw to secure it into place.
4.     Install the riser card to the server. For more information, see "Replacing riser cards and PCIe modules."
5.     Connect the drive data cables to the standard storage controller. For more information, see "Connecting internal cables."
6.     Connect the other end of the extension cable provided with the power fail safeguard module to the flash card.
¡     If the storage controller is installed with an external flash card, connect the supercapacitor extension cable to the flash card.
¡     If the storage controller uses a built-in flash card, connect the supercapacitor extension cable to the supercapacitor connector on the storage controller.
7.     Install the processor mezzanine board or mezzanine air baffle kit:
a.     Align the standouts on both sides of the processor mezzanine board or mezzanine air baffle kit with the notches on the chassis edges, and place the processor mezzanine board or mezzanine air baffle kit in the chassis.
b.     (Optional.) Install the supercapacitors. Insert the connector end of a supercapacitor into the holder. Pull the clip on the holder, insert the other end of the supercapacitor into the holder, and then release the clip.
c.     Close the handle of the processor mezzanine board or mezzanine air baffle kit.
8.     Install the access panel. Place the access panel on top of the server chassis and slide the access panel toward the server front until it snaps into place.
9.     Rack-mount the server. For more information, see "Rack-mounting the server."
10.     Connect the power cord. For more information, see "Connecting the power cord."
11.     Power on the server. For more information, see "Powering on the server."
Replacing a GPU module
WARNING
WARNING!
Guidelines
A riser card is required when you install a GPU module.
Use Table 11 to determine the installation locations of the available riser card and GPU modules. For information about the locations of PCIe riser connectors, see system board components in "Appendix A  Server specifications". For information about PCIe slots, see riser cards in "Appendix B  Component specifications."
Table 11 GPU module and riser card compatibility
Riser card
PCIe slot
Available GPU modules
RC-3*FHHL-G3
Connector 1 or 2
Slot 1, 2, 4, or 5
·     GPU-P4-X
·     GPU-T4
RC-3FHHL-2U-G3-1
Slot 1, 2, 3, 4, 5, or 6
RC-2LP-2U-G3-2
Connector 3
Slot 7 or 8
Removing a GPU module
4.     Disconnect cables that might hinder the removal from the riser card.
5.     Lift the riser card that holds the GPU module to remove the riser card from the chassis.
6.     Remove the GPU module. Remove the screw that secures the GPU module and pull the GPU module out of the PCIe slot.
Installing a GPU module
1.     Insert the GPU module into the PCIe slot along the guide rails and fasten the screw to secure the module into place.
2.     Install the riser card onto the PCIe riser connector along the guide rails.
3.     Connect cables to the riser card as needed.
Replacing a network adapter
Guidelines
The server supports both standard PCIe network adapters and sLOM network adapters.
You can install an sLOM network adapter only in the sLOM network adapter connector on the system board. For more information about the connector location, see system board components in "Appendix A  Server specifications."
A riser card is required when you install a standard PCIe network adapter. For more information about standard PCIe network adapter and riser card compatibility, see riser cards in "Appendix B  Component specifications."
By default, port 1 on the sLOM network adapter acts as the HDM shared network port. You can configure another port on the sLOM network adapter as the HDM shared network port from the HDM Web interface. For more information, see H3C Servers HDM online help.
Removing an sLOM network adapter
2.     Disconnect cables from the network adapter.
3.     Loosen the captive screws and then pull the network adapter out of the slot.
Installing an sLOM network adapter
1.     Install the sLOM network adapter. Insert the sLOM network adapter into the slot along the guide rails and then fasten the captive screws to secure the network adapter into place.
2.     Connect cables for the sLOM network adapter.
Replacing a standard PCIe network adapter
WARNING
WARNING!
Removing a standard PCIe network adapter
4.     Disconnect cables that might hinder access to the riser card.
5.     Lift the riser card to remove it from the chassis.
6.     Remove the standard PCIe network adapter. Remove the screw that secures the standard PCIe network adapter, and then pull the standard PCIe network adapter out of the slot.
Installing a standard PCIe network adapter
1.     Install the standard PCIe network adapter to the riser card. Insert the standard PCIe network adapter into the slot along the guide rails and then fasten the screw to secure the network adapter into place.
2.     Install the riser card on the target PCIe riser connector.
3.     Connect cables for the standard PCIe network adapter.
Replacing a drive backplane
WARNING
WARNING!
Removing a drive backplane
3.     Remove the drives attached to the backplane.
6.     Disconnect cables from the backplane.
7.     Remove the drive backplane. Loosen the captive screws that secure the backplane, and then lift the backplane out of the chassis.
Installing a drive backplane
1.     Install a drive backplane. Place the backplane in the slot and then fasten the captive screws.
2.     Connect cables to the drive backplane.
3.     Install the removed fan cage. Place the fan cage in the chassis and then close the locking levers at the two ends of the fan cage.
5.     Install the removed drives.
Replacing the processor mezzanine board or mezzanine air baffle kit
The replacement procedure is similar for the processor mezzanine board and the mezzanine air baffle kit. This section replaces the processor mezzanine board.
If you replace the mezzanine air baffle, you do not need to replace processors or DIMMs.
4.     Remove the processor mezzanine board:
a.     Press the UNLOCK button to release the handle of the processor mezzanine board. The handle automatically pops out.
b.     Remove the supercapacitors, if any.
c.     Hold the handle and lift the processor mezzanine board out of the chassis.
5.     Remove DIMMs from the processor mezzanine board.
6.     Remove processors from the processor mezzanine board.
7.     Install a protective cover for each processor socket.
1.     Remove the protective cover from each processor socket.
2.     Install the removed processors.
3.     Install the removed DIMMs.
4.     Install the processor mezzanine board:
a.     Align the standouts at both sides of the board with the notches on the chassis edges, and then place the processor mezzanine board in the chassis.
b.     Install the removed supercapacitors. Insert the connector end of a supercapacitor into the supercapacitor holder. Pull the clip on the holder, insert the other end of the supercapacitor into the holder, and then release the clip.
c.     Close the handle of the processor mezzanine board.
Replacing a DIMM
WARNING
WARNING!
The server supports DCPMMs and DRAM DIMMs (both LRDIMM and RDIMM supported). Compared with DRAM DIMMs, DCPMMs provide larger capacity and can protect data from getting lost in case of unexpected system failures. RDIMMs can perform parity checking on addresses. Compared with RDIMMs, LRDIMMs provide larger capacity and higher bandwidth.
Both DCPMMs and DRAM DIMMs are referred to as DIMMs in this document, unless otherwise stated.
Guidelines
WARNING
WARNING!
The DIMMs are not hot swappable.
You can install a maximum of 12 DIMMs for each processor, six DIMMs per memory controller. For more information, see DIMM slots in "Appendix A  Server specifications."
For a DIMM to operate at 2933 MHz, make sure the following conditions are met:
·     Use Cascade Lake processors that support 2933 MHz data rate.
·     Use DIMMs with a maximum of 2933 MHz data rate.
·     Install only one DIMM per channel.
The supported DIMMs vary by processor model, as shown in Table 12.
Table 12 Supported DIMMs of a processor
Processor
Supported DIMMs
Skylake
Only DRAM DIMMs.
Cascade Lake
·     Only DRAM DIMMs.
·     Mixture of DCPMM and DRAM DIMMs.
Jintide-C series
Only DRAM DIMMs.
For DIMMs compatible with the server and detailed DIMM information, visit the query tool at http://www.h3c.com/cn/Service/Document_Software/Document_Center/Server/.
Guidelines for installing only DRAM DIMMs
When you install only DRAM DIMMs, follow these restrictions and guidelines:
·     Make sure all DRAM DIMMs installed on the server have the same product code.
·     Make sure the corresponding processor is present before powering on the server.
·     For the memory mode setting to take effect, make sure the following installation requirements are met when you install DRAM DIMMs for a processor:
Memory mode
DIMM requirements
Independent
·     If only one processor is present, see Figure 15.
·     If two processors are present, see Figure 16.
·     If four processors are present, see Figure 17.
Mirror
Partial Mirror
·     A minimum of two DIMMs for a processor.
·     This mode does not support DIMM population schemes that are not recommended in Figure 15, Figure 16, and Figure 17.
·     DIMM installation schemes:
¡     If only one processor is present, see Figure 15.
¡     If two processors are present, see Figure 16.
¡     If four processors are present, see Figure 17.
Memory Rank Sparing
·     A minimum of 2 ranks per channel.
If the DIMM configuration does not meet the requirements for the configured memory mode, the system uses the default memory mode (Independent mode). For more information about memory modes, see the BIOS user guide for the server.
Figure 15 DIMM population schemes (one processor present)
Figure 16 DIMM population schemes (two processors present)
Figure 17 DIMM population schemes (four processors present)
Guidelines for mixture installation of DCPMMs and DRAM DIMMs
When you install DRAM DIMMs and DCPMMs on the server, follow these restrictions and guidelines:
·     Make sure the corresponding processors are present before powering on the server.
·     Make sure all DRAM DIMMs have the same product code and all DCPMMs have the same product code.
·     As a best practice to increase memory bandwidth, install DRAM and DCPMM DIMMs in different channels.
·     A channel supports a maximum of one DCPMM.
·     Make sure all DCPMMs installed on the server have the same capacity.
·     As a best practice, install DCPMMs symmetrically across the two memory processing units for a processor.
·     To install both DRAM DIMM and DCPMM in a channel, install the DRAM DIMM in the white slot and the DCPMM in the black slot. To install only one DIMM in a channel, install the DIMM in the white slot if the DIMM is DCPMM.
Removing a DIMM
4.     Remove the processor mezzanine board or mezzanine air baffle kit if the target DIMM is installed on the system board.
5.     Remove the DIMM. Open the DIMM slot latches and pull the DIMM out of the slot.
Installing a DIMM
1.     Install the DIMM:
a.     Identify the location of the DIMM slot.
b.     Open the DIMM slot latches.
c.     Align the notch on the DIMM with the connector key in the DIMM slot and press the DIMM into the socket until the latches lock the DIMM in place.
To avoid damage to the DIMM, do not use force to press the DIMM into the socket when you encounter resistance. Instead, re-align the notch with the connector key, and then reinsert the DIMM again.
During server startup, you can access the BIOS to configure the memory mode of the newly installed DIMM. For more information, see the BIOS user guide for the server.
Verifying the replacement
Use one of the following methods to verify that the memory size is correct:
·     Access the GUI or CLI of the server:
¡     In the GUI of a windows OS, click the Start icon in the bottom left corner, enter msinfo32 in the search box, and then click the msinfo32 item.
¡     In the CLI of a Linux OS, execute the cat /proc/meminfo command.
·     Log in to HDM. For more information, see HDM online help.
·     Access the BIOS, select Socket Configuration > Memory Configuration > Memory Topology, and then press Enter.
If the memory size is incorrect, re-install or replace the DIMM.
It is normal that the CLI or GUI of the server OS displays a smaller memory size than the actual size if the mirror or memory rank sparing memory mode is enabled. In this situation, you can verify the memory size from HDM or the BIOS.
Replacing a fan
WARNING
WARNING!
CAUTION
CAUTION:
The fans are hot swappable. If sufficient space is available for replacement, you can replace a fan without powering off the server or removing the server from the rack. The following procedure is provided based on the assumption that no sufficient space is available for replacement.
3.     Remove the access panel. Press the locking tabs on both sides of the access panel, slide the access panel backward, and then lift the access panel to remove it.
4.     Pinch the latches on both sides of the fan to pull the fan out of the slot.
5.     Install a new fan. Insert the fan into the slot and push it until it snaps into place.
6.     Install the access panel. Place the access panel on top of the server chassis and slide the access panel toward the server front until it snaps into place.
7.     Rack-mount the server. For more information, see "Rack-mounting the server."
8.     Connect the power cord. For more information, see "Connecting the power cord."
9.     Power on the server. For more information, see "Powering on the server."
Replacing a processor
WARNING
WARNING!
Guidelines
·     The server supports only one, two, or four processors. If you install only two processors, make sure processors 1 and 2 are installed.
·     To avoid damage to a processor or the system board, only H3C authorized or professional server engineers can install, replace, or remove a processor.
·     Make sure the processors on the server are the same model.
·     The pins in the processor sockets are very fragile and prone to damage. Install a protective cover if a processor socket is empty.
·     For the server to operate correctly, make sure processor 1 is in position. For more information about processor locations, see system board components in "Appendix A  Server specifications"."
·     Make sure a protective cover is installed over each empty processor socket.
Removing a processor
4.     Remove the processor mezzanine board or mezzanine air baffle kit if the target processor is installed on the system board.
5.     Remove the processor heatsink:
a.     Loosen the four captive screws in the sequence from screw 4 to screw 1 as shown by the marks on the heatsink.
IMPORTANT
IMPORTANT:
An incorrect sequence might cause the captive screws to fall off.
b.     Lift the heatsink slowly to remove it.
6.     Remove the processor retaining bracket from the heatsink:
a.     Insert a flat-head tool (such as a flat-head screwdriver) into the notch marked with TIM BREAKER to pry open the retaining bracket.
b.     Press the four clips in the four corners of the bracket to release the retaining bracket.
You must press one clip and its cater-cornered clip outward, and press the other two clips inward.
c.     Lift the retaining bracket to remove it from the heatsink.
7.     Remove the processor. Separate the processor from the retaining bracket with one hand pushing down and the other hand tilting the processor.
Installing a processor
1.     Install the processor onto the retaining bracket:
a.     Align the small triangle on the processor with the alignment triangle in the retaining bracket, and align the guide pin on the bracket with the notch on the triangle side of the processor.
b.     Lower the processor gently and make sure the guide pins on the opposite side of the bracket fit snugly into notches on the processor.
2.     Smear thermal grease onto the processor:
a.     Clean the processor and heatsink with isopropanol wipes. Allow the isopropanol to evaporate before continuing.
b.     Use the thermal grease injector to inject 0.6 ml of thermal grease to the five dots on the processor, 0.12 ml for each dot.
3.     Install the retaining bracket onto the heatsink. Align the alignment triangle on the retaining bracket with the cut-off corner of the heatsink. Place the bracket on top of the heatsink, with the four corners of the bracket clicked into the four corners of the heatsink.
4.     Install the heatsink onto the server.
a.     Place the heatsink on the processor socket. Make sure the alignment triangle on the retaining bracket and the pin holes in the heatsink are aligned with the cut-off corner and guide pins of the processor socket, respectively.
b.     Fasten the four captive screws on the heatsink from screw 1 to screw 4 as shown by the marks on the heatsink.
CAUTION
CAUTION:
To avoid poor contact between the processor and the system board or damage to the pins in the processor socket, tighten the screws to a torque value of 1.4 Nm (12 in-lbs).
5.     Paste bar code label supplied with the processor over the original label on the heatsink.
IMPORTANT
IMPORTANT:
This step is required for you to obtain H3C's processor servicing.
6.     Install the removed processor mezzanine board or mezzanine air baffle kit.
7.     Install the access panel. Place the access panel on top of the server chassis and slide the access panel toward the server front until it snaps into place.
8.     Rack-mount the server. For more information, see "Rack-mounting the server."
9.     Connect the power cord. For more information, see "Connecting the power cord."
10.     Power on the server. For more information, see "Powering on the server."
Log in to HDM to verify that the processor is operating correctly. For more information, see HDM online help.
Installing and setting up a TCM or TPM
Trusted platform module (TPM) is a microchip embedded in the management module. It stores encryption information (such as encryption keys) for authenticating server hardware and software. The TPM operates with drive encryption programs such as Microsoft Windows BitLocker to provide operating system security and data protection. For information about Microsoft Windows BitLocker, visit the Microsoft website at http://www.microsoft.com.
Trusted cryptography module (TCM) is a trusted computing platform-based hardware module with protected storage space, which enables the platform to implement password calculation.
Installation and setup flowchart
Figure 18 TCM/TPM installation and setup flowchart
Installing a TCM or TPM
Guidelines
·     Do not remove an installed TCM or TPM. Once installed, the module becomes a permanent part of the system board.
·     If the installed TPM/TCM is faulty, remove the system board, and contact H3C Support for system board and TPM/TCM replacement.
·     When installing or replacing hardware, H3C service providers cannot enable the TCM or TPM or the encryption technology. For security reasons, only the customer can enable these features.
·     When replacing the system board, do not remove the TCM or TPM from the system board. H3C will provide a TCM or TPM with the spare system board for system board or module replacement.
·     Any attempt to remove an installed TCM or TPM from the system board breaks or disfigures the TCM or TPM security rivet. Upon locating a broken or disfigured rivet on an installed TCP or TPM, administrators should consider the system compromised and take appropriate measures to ensure the integrity of the system data.
·     H3C is not liable for blocked data access caused by improper use of the TCM or TPM. For more information, see the encryption technology feature documentation provided by the operating system.
The installation procedure is the same for a TPM and a TCM. The following information uses a TPM to show the procedure.
To install a TPM:
4.     Remove the riser cards that might hinder TPM installation.
5.     Install the TPM:
a.     Press the TPM into the TPM connector on the system board.
b.     Insert the rivet pin.
c.     Insert the security rivet into the hole in the rivet pin and press the security rivet until it is firmly seated.
6.     Install the removed riser cards.
Enabling the TCM or TPM in the BIOS
The TPM and TCM features are enabled by default.
1.     Access the BIOS. For more information, see the BIOS user guide for the server.
2.     Click Advanced > Trusted Computing, and then press Enter.
3.     Enable the TPM or TCM:
¡     To enable the TPM, select TPM State > Enabled, and then press Enter. Then, click Device Select, press Enter, and select the TPM version supported by the server.
¡     To enable the TCM, select TCM State > Enabled, and then press Enter. Then, click Device Select, press Enter, and select the TCM version supported by the server.
CAUTION
CAUTION:
After a TPM is installed and enabled, data access is locked if you fail to follow the proper procedures for updating the system or option firmware, replacing the system board, replacing a drive, or modifying OS application TPM settings. For more information about modifying OS application TPM settings, visit the Microsoft website at http://technet.microsoft.com/en-us/library/cc732774.aspx.
Log in to HDM to verify that the TCM or TPM is operating correctly. For more information, see HDM online help.
Configuring encryption in the operating system
For more information about this task, see the encryption technology feature documentation that came with the operating system.
The recovery key/password is generated during BitLocker setup, and can be saved and printed after BitLocker is enabled. When using BitLocker, always retain the recovery key/password. The recovery key/password is required to enter Recovery Mode after BitLocker detects a possible compromise of system integrity or firmware or hardware change.
For security purposes, follow these guidelines when retaining the recovery key/password:
·     Always store the recovery key/password in multiple locations.
·     Always store copies of the recovery key/password away from the server.
·     Do not save the recovery key/password on the encrypted hard drive.
For more information about Microsoft Windows BitLocker drive encryption, visit the Microsoft website at http://technet.microsoft.com/en-us/library/cc732774.aspx.
Replacing the system battery
WARNING
WARNING!
The server comes with a system battery (Panasonic BR2032) installed on the system board, which supplies power to the real-time clock and has a lifespan of 5 to 10 years. If the server no longer automatically displays the correct date and time, you might need to replace the battery. As a best practice, use a new Panasonic BR2032 battery to replace the old one.
The BIOS will restore to the default settings after the replacement. You must reconfigure the BIOS to have the desired settings, including the system date and time. For more information, see the BIOS user guide for the server.
Removing the system battery
4.     Gently tilt the system battery to remove it from the battery holder.
For environment protection purposes, dispose of the used-up system battery at a designated site.
Installing the system battery
1.     Orient the system battery with the plus-sign (+) side facing up, and place the system battery into the system battery holder.
2.     Press the system battery to seat it in the holder.
7.     Access the BIOS to reconfigure the system date and time. For more information, see the BIOS user guide for the server.
Replacing the system board
WARNING
WARNING!
Guidelines
To prevent electrostatic discharge, place the removed parts on an antistatic surface or in antistatic bags.
Removing the system board
3.     Remove the sLOM network adapter, if any.
4.     Remove the power supplies.
7.     Remove the processor mezzanine board or mezzanine air baffle kit, if any. For more information, see "Removing the processor mezzanine board."
8.     Remove the PCIe riser cards and PCIe modules, if any.
9.     Disconnect all cables connected to the system board.
10.     Remove the NVMe VROC module, if any.
11.     Removed the DIMMs.
12.     Remove the processors and heatsinks.
13.     Install protective covers over the empty processor sockets. Place a cover on each socket and press the cover diagonally to secure it.
14.     Remove the system board:
a.     Loosen the two captive screws on the system board.
b.     Hold the system board by its handle and slide the system board toward the server front. Then, lift the system board to remove it from the chassis.
Installing the system board
1.     Hold the system board by its handle and slowly place the system board in the chassis. Then, slide the system board toward the server rear until the connectors (for example, USB connectors and the Ethernet port) on it are securely seated.
The connectors are securely seated if you cannot use the system board handle to lift the system board.
2.     Fasten the two captive screws on the system board.
4.     Remove the installed protective covers over the processor sockets. Hold a cover and lift it straight up and away from a socket.
5.     Install the removed processors and heatsinks.
6.     Install the removed NVMe VROC module.
7.     Install the removed PCIe riser cards and PCIe modules.
8.     Reconnect cables to the system board.
9.     Install the removed processor mezzanine board or mezzanine air baffle kit, if any. For more information, see "Replacing the processor mezzanine board or mezzanine air baffle kit."
10.     Install the removed fan cage. Place the fan cage in the chassis and then close the locking levers at the two ends of the fan cage.
12.     Install the removed sLOM network adapter.
13.     Install the removed power supplies.
14.     Rack-mount the server. For more information, see "Rack-mounting the server."
15.     Connect the power cord. For more information, see "Connecting the power cord."
16.     Power on the server. For more information, see "Powering on the server."
Properly route the internal cables and make sure they are not squeezed.
Guidelines
When connecting SAS/SATA data cables, make sure you connect the corresponding peer ports on a drive backplane with the correct SAS/SATA data cable.
Front 16SFF SAS/SATA drive cabling
Connecting SAS/SATA data cables
Use Table 13 to select the method for connecting two 8SFF SAS/SATA drive backplanes to storage controllers depending on the storage controller configuration.
Table 13 16SFF SAS/SATA drive cabling methods
Storage controller
Cabling method
2 × standard storage controllers in PCIe slots 1 and 2
See Figure 19.
1 × RAID-LSI-9460-16i(4G) or RAID-LSI-9560-LP-16i-8GB standard storage controller in PCIe slot 2
See Figure 20.
When connecting SAS/SATA data cables with RAID-LSI-9460-16i(4G) or RAID-LSI-9560-LP-16i-8GB standard storage controller installed, make sure you connect the corresponding peer ports with the correct SAS/SATA data cable. Use Table 14 to determine the ports and connectors to be connected. For information about the locations of drive cage bays, see front panel view in "Appendix A  Server specifications."
Table 14 SAS/SATA data cable and the corresponding connectors for the storage controller and the drive backplane
Mark on the storage controller connector
Mark on the SAS/SATA data cable end
Drive cage bay
C0, C1
C0, C1
Drive cage bay 2
C2, C3
C2, C3
Drive cage bay 3
C0
C0
Drive cage bay 2
C1
C1
Drive cage bay 3
Figure 19 16SFF SAS/SATA drives connected to the standard storage controllers in PCIe slots 1 and 2
(1) SAS/SATA data cable 1 to the storage controller in PCIe slot 2
(2) SAS/SATA data cable 2 to the storage controller in PCIe slot 1
Figure 20 16SFF SAS/SATA drives connected to the standard storage controller in PCIe slot 2
The cabling method is the same for RAID-LSI-9460-16i(4G) and RAID-LSI-9560-LP-16i-8GB storage controllers. This section connects RAID-LSI-9460-16i(4G) storage controller.
Connecting AUX signal cables and power cords
(1) and (3) AUX signal cables
(2) and (4) Power cords
Connecting supercapacitor extension cables
Use Table 13 to select the method for connecting supercapacitor extension cables to storage controllers depending on the storage controller configuration.
Table 15 Connecting supercapacitor extension cables
Storage controller
Cabling method
See Figure 21.
1 ×RAID-LSI-9460-16i(4G) or RAID-LSI-9560-LP-16i-8GB standard storage controller in PCIe slot 2
See Figure 22.
Figure 21 Connecting supercapacitor extension cables to the standard storage controllers in PCIe slots 1 and 2
(1) Supercapacitor extension cable 1 to the storage controller in PCIe slot 1
(2) Supercapacitor extension cable 2 to the storage controller in PCIe slot 2
Figure 22 Connecting the supercapacitor extension cable to the standard storage controller in PCIe slot 2
Front hybrid 8SFF SAS/SATA and 8SFF UniBay drive cabling
Connect SAS/SATA data cables to the standard storage controllers in PCIe slots 1 and 7 as shown by callouts 2 and 3 in Figure 31.
Connecting NVMe data cables
When connecting NVMe data cables, make sure you connect the corresponding peer ports with the correct NVMe data cable. Use Table 18 to determine the ports and connectors to be connected.
Figure 23 Connecting NVMe data cables
Figure 24 Connecting supercapacitor extension cables
(1) Supercapacitor extension cable 1 to the storage controller in PCIe slot 7
(2) Supercapacitor extension cable 2 to the storage controller in PCIe slot 1
Front hybrid 8SFF SAS/SATA and 8SFF NVMe drive cabling
Connect the SAS/SATA data cable to the standard storage controllers in PCIe slot 7 as shown by callout 2 in Figure 31.
Figure 25 Connecting NVMe data cables
Connect the supercapacitor extension cable as shown by callout 1 in Figure 24.
Front 24SFF SAS/SATA drive cabling
Use Table 16 to select the method for connecting the front 24 SFF SAS/SATA drives to storage controllers depending on the storage controller configuration.
Table 16 24SFF SAS/SATA drive cabling methods
Storage controllers
Cabling method
3 × standard storage controllers in PCIe slots 1, 2, and 7
See Figure 26.
1 × RAID-LSI-9460-16i(4G) standard storage controller in PCIe slot 2 and 1 × standard storage controller in PCIe slot 7
See Figure 27.
Figure 26 24SFF SAS/SATA drives connected to the standard storage controllers in PCIe slots 1, 2, and 7
(1) SAS/SATA data cable 1 to the storage controller in PCIe slot 7
(2) SAS/SATA data cable 2 to the storage controller in PCIe slot 2
(3) SAS/SATA data cable 3 to the storage controller in PCIe slot 1
Figure 27 24SFF SAS/SATA drives connected to the standard storage controllers in PCIe slots 2 and 7
(1) SAS/SATA data cable to the storage controller in PCIe slot 7
(2) SAS/SATA data cables to the storage controller in PCIe slot 2
For the data cables connecting PCIe slot 2, connect the data cable marked with C0 and C1 at the storage controller end to the drive backplane for drive cage bay 2. Connect the data cable marked with C2 and C3 at the storage controller end to the drive backplane for drive cage bay 3. For information about the locations of drive cage bays, see front panel view in "Appendix A  Server specifications."
(1), (3), and (5) AUX signal cables
(2), (4), and (6) Power cords
Use Table 17 to select the method for connecting supercapacitor extension cables to storage controllers depending on the storage controller configuration.
Table 17 Connecting supercapacitor extension cables
Storage controllers
Cabling method
See Figure 28.
See Figure 29.
Figure 28 Connecting supercapacitor extension cables for the standard storage controllers in PCIe slots 1, 2, and 7
(3) Supercapacitor extension cable 3 to the storage controller in PCIe slot 2
Figure 29 Connecting supercapacitor extension cables for the standard storage controllers in PCIe slots 2 and 7
Front hybrid 16SFF SAS/SATA and 8SFF UniBay drive cabling
Figure 30 Connecting NVMe data cables
Table 18 NVMe data cable and the corresponding connectors on the drive backplane and the RC-8*NVME-1*FHHL-G3 riser card
Connector on the riser card
Mark on the NVMe data cable
Connector on the drive backplane
Single-port end for the riser card
Dual-port end for the drive backplane
NVMe A1
NVMe A1
NVMe-A1
NVMe A1
NVMe-A2
NVMe A2
NVMe A3
NVMe A3
NVMe-A3
NVMe A3
NVMe-A4
NVMe A4
NVMe B1
NVMe B1
NVMe-B1
NVMe B1
NVMe-B2
NVMe B2
NVMe B3
NVMe B3
NVMe-B3
NVMe B3
NVMe-B4
NVMe B4
Use Table 19 to select the method for connecting three 8SFF SAS/SATA drive backplanes to storage controllers depending on the storage controller configuration.
Table 19 SAS/SATA drive cabling method
Storage controller
Cabling method
3 × standard storage controllers in PCIe slots 1, 7, and 8
See Table 19Figure 31.
1 × standard storage controller in PCIe slot 1 and 1 × RAID-LSI-9460-16i(4G) standard storage controller in PCIe slot 7
See Table 19Figure 32.
Figure 31 SAS/SATA drives connected to the standard storage controllers in PCIe slot 1, 7, and 8
(1) SAS/SATA data cable 1 to the storage controller in PCIe slot 8
(2) SAS/SATA data cable 2 to the storage controller in PCIe slot 7
Figure 32 SAS/SATA drives connected to the standard storage controllers in PCIe slots 1 and 7)
(1) SAS/SATA data cables to storage controller in PCIe slot 7
(2) SAS/SATA data cable to storage controller in PCIe slot 1
For the cables connecting PCIe slot 7, connect the data cable marked with C0 and C1 at the storage controller end to the drive backplane for drive cage bay 1. Connect the data cable marked with C2 and C3 at the storage controller end to the drive backplane for drive cage bay 2. For information about the locations of drive cage bays, see front panel view in "Appendix A  Server specifications."
Use Table 20 to select the method for connecting supercapacitor extension cables to storage controllers depending on the storage controller configuration.
Table 20 Connecting supercapacitor extension cables
Storage controllers
Cabling method
See Figure 33.
1 × standard storage controllers in PCIe slot 1 and 1 × RAID-LSI-9460-16i(4G) standard storage controller in PCIe slot 7
See Figure 34.
Figure 33 Connecting supercapacitor extension cables for the standard storage controllers in PCIe slots 1, 7, and 8
(1) Supercapacitor extension cable 1 to the storage controller in PCIe slot 8
(2) Supercapacitor extension cable 2 to the storage controller in PCIe slot 7
(3) Supercapacitor extension cable 3 to the storage controller in PCIe slot 1
Figure 34 Connecting supercapacitor extension cables for the standard storage controllers in PCIe slots 1 and 7
Front hybrid 16SFF SAS/SATA and 8SFF NVMe drive cabling
Figure 35 Connecting NVMe data cables
Use Table 21 to select the method for connecting three 8SFF SAS/SATA drive backplanes to storage controllers depending on the storage controller configuration.
Table 21 SAS/SATA drive cabling method
Storage controller
Cabling method
2 × standard storage controllers in PCIe slots 7 and 8
See callouts 1 and 2 in Figure 31.
See callout 1 in Figure 32.
Use Table 22 to select the method for connecting supercapacitor extension cables to storage controllers depending on the storage controller configuration.
Table 22 Connecting supercapacitor extension cables
Storage controllers
Cabling method
See callouts 1 and 2 in Figure 33.
See callout 1 in Figure 34.
Front hybrid 4SFF UniBay and 4SFF SAS/SATA drive cabling
When connecting NVMe data cables, make sure you connect the corresponding peer ports with the correct NVMe data cable. Use Table 23 to determine the ports and connectors to be connected.
Figure 36 shows the method for connecting NVMe data cables between the drive backplane and RC-4*NVME-3*FHHL-G3 riser card.
Figure 36 Connecting NVMe data cables
Table 23 NVMe data cable and the corresponding connectors on the drive backplane and RC-4*NVME-3*FHHL-G3 riser card
NVMe A1
NVMe A1
NVMe-B1
NVMe B1
NVMe-B2
NVMe B2
NVMe A3
NVMe A3
NVMe-B3
NVMe B3
NVMe-B4
NVMe B4
Use Table 24 to select the method for connecting SAS/SATA drives depending on the storage controller type.
Table 24 SAS/SATA drive cabling methods
Storage controllers
Cabling method
RSTe embedded storage controller
See Figure 37.
Standard storage controller in PCIe slot 2
See Figure 38.
Figure 37 Connecting the SATA data cable to the RSTe embedded storage controller
Figure 38 Connecting the SAS/SATA data cable to the standard storage controller
(1) Power cord
(2) AUX signal cable
In this drive configuration, the supercapacitor can only be installed on the processor mezzanine board.
Figure 39 Connecting the supercapacitor extension cable
Front 8SFF UniBay drive cabling
Figure 40 shows the method for connecting NVMe data cables between the drive backplane and RC-4*NVME-3*FHHL-G3 riser card.
Figure 40 Connecting NVMe data cables
Use Table 25 to select the method for connecting SAS/SATA drives depending on the storage controller type.
Table 25 SAS/SATA drive cabling methods
Storage controllers
Cabling method
See Figure 41.
See Figure 42.
Figure 41 Connecting the SATA data cable to the RSTe embedded storage controller
Figure 42 Connecting the SAS/SATA data cable to the standard storage controller
(1) Power cord
Figure 43 Connecting the supercapacitor extension cable
Front 16SFF NVMe drive cabling
Figure 40 shows the method for connecting NVMe data cables between the drive backplane and RC-8*NVME-1*FHHL-G3 riser cards.
Figure 44 Connecting NVMe data cables
(1) NVMe data cables (0404A12E)
(2) NVMe data cables (0404A12F)
Front 16SFF UniBay drive cabling
Figure 45 shows the method for connecting NVMe data cables between the drive backplane and RC-8*NVME-1*FHHL-G3 riser cards.
Figure 45 Connecting NVMe data cables
Use Table 25 to select the method for connecting SAS/SATA drives depending on the storage controller configuration.
Table 26 SAS/SATA drive cabling methods
Storage controllers
Cabling method
2 × standard storage controllers in PCIe slots 1 and 4
See Figure 46.
1 × RAID-LSI-9460-16i(4G) standard storage controller in PCIe slot 1
See Figure 47.
Figure 46 Connecting SATA data cables to the standard storage controllers in PCIe slots 1 and 4
(1) SAS/SATA data cable 1 (0404A12H)
(2) SAS/SATA data cable 2 (0404A12C)
Figure 47 Connecting SAS/SATA data cables to the standard storage controller in PCIe slot 1
Connect the data cable marked with C0 and C1 at the storage controller end to the drive backplane for drive cage bay 2. Connect the data cable marked with C2 and C3 at the storage controller end to the drive backplane for drive cage bay 3. For information about the locations of drive cage bays, see front panel view in "Appendix A  Server specifications."
The supercapacitors are installed on the processor mezzanine board. Use Table 27 to determine the method for connecting supercapacitor extension cables to storage controllers depending on the storage controller configuration.
Table 27 SAS/SATA drive cabling methods
Storage controllers
Cabling method
See Figure 48.
See Figure 49.
Figure 48 Connecting supercapacitor extension cables to the standard storage controllers in PCIe slots 1 and 4
Figure 49 Connecting the supercapacitor extension cable to the standard storage controller in PCIe slot 2
Front hybrid 8SFF SAS/SATA and 16SFF UniBay drive cabling
Figure 50 Connecting NVMe data cables
Table 28 SAS/SATA drive cabling methods
Storage controllers
Cabling method
3 × standard storage controllers in PCIe slots 1, 4, and 7
See Figure 51.
1 × RAID-LSI-9460-16i(4G) standard storage controller in PCIe slot 1 and 1 × standard storage controllers in PCIe slot 7
See Figure 52.
Figure 51 Connecting SATA data cables to the standard storage controllers in PCIe slots 1, 4, and 7
Figure 52 Connecting SAS/SATA data cables to the standard storage controllers in PCIe slots 1 and 7
(1) SAS/SATA data cable (to the storage controller in PCIe slot 7)
(2) SAS/SATA data cables (to the storage controller in PCIe slot 1)
For the cable connecting PCIe slot 1, connect the data cable marked with C0 and C1 at the storage controller end to the drive backplane for drive cage bay 2. Connect the data cable marked with C2 and C3 at the storage controller end to the drive backplane for drive cage bay 3. For information about the locations of drive cage bays, see front panel view in "Appendix A  Server specifications."
(1), (3) and (5) AUX signal cables
(2), (4) and (6) Power cords
Table 29 SAS/SATA drive cabling methods
Storage controllers
Cabling method
See Figure 53.
See Figure 54.
Figure 53 Connecting supercapacitor extension cables to the standard storage controllers in PCIe slots 1, 4, and 7
(2) Supercapacitor extension cable 2 to the storage controller in PCIe slot 4
Figure 54 Connecting the supercapacitor extension cable to the standard storage controllers in PCIe slots 1 and 7
(3) Supercapacitor extension cable 2 to the storage controller in PCIe slot 1
Connecting drive cables for the rear 2SFF UniBay drives
Connecting the NVMe data cable
Connect the NVMe data cable to the SlimSAS A4 connector on the processor mezzanine board or the SlimSAS A1 connector on the RC-4*NVME-3*FHHL-G3 riser card, as shown in Figure 55 and Figure 56, respectively.
Figure 55 Connecting NVMe data cable to the processor mezzanine board
Figure 56 Connecting NVMe data cable to RC-4*NVME-3*FHHL-G3 riser card in PCIe riser connector 2
Connect the SATA data cable to the embedded RSTe storage controller, as shown in Figure 57.
Figure 57 Connecting the SATA data cable
Connecting the AUX signal cable and the power cord
(1) AUX signal cable
(2) Power cord
The cabling method is the same for the M.2 transfer module in different PCIe slots. This section uses the M.2 transfer module in PCIe slot 6 as an example, as shown in Figure 58.
Figure 58 Connecting the SATA M.2 SSD cable
Connecting PCIe signal cables
When connecting PCIe signal cables, make sure you connect the corresponding peer ports with the correct PCIe signal cable. Use Table 18 to determine the ports and connectors to be connected.
Figure 59 Connecting PCIe signal cables
Figure 60 PCIe signal data cable and the corresponding riser card, connectors on the riser card and processor mezzanine board
Mark on the PCIe signal cable to riser card
Mark on the PCIe signal cable to the processor mezzanine board
Connector on the processor mezzanine board
Connector 4
SlimSAS A
PCIE A
NVMe D1
SlimSAS 4A
SlimSAS B
PCIE B
NVMe D3
SlimSAS 4B
Connector 3
SlimSAS A
PCIE A
NVMe A1/C1
SlimSAS 3A
SlimSAS B
PCIE B
NVMe A3/C3
SlimSAS 3B
Connector 2
SlimSAS A
PCIE A
NVMe B1
SlimSAS 2A
SlimSAS B
PCIE B
NVMe B3
SlimSAS 2B
Connector 1
SlimSAS A
PCIE A
NVMe A1/C1
SlimSAS 1A
SlimSAS B
PCIE B
NVMe A3/C3
SlimSAS 1B
·     For information about SlimSAS connectors on the riser card in PCIe slot 4, see RC-2LP-2U-G3-3 in "Appendix B  Component specifications."
·     For information about SlimSAS connectors on the riser card in PCIe slot 3, see RC-2LP-2U-G3-2 in "Appendix B  Component specifications."
·     For information about SlimSAS connectors on the riser cards in PCIe slots 1 and 2, see RC-3FHHL-2U-G3-1 in "Appendix B  Component specifications."
·     For information about SlimSAS connectors on the processor mezzanine board, see processor mezzanine board in "Appendix A  Server specifications."
Maintenance
The following information describes the guidelines and tasks for daily server maintenance.
Guidelines
·     Keep the equipment room clean and tidy. Remove unnecessary devices and objects from the equipment room.
·     Make sure the temperature and humidity in the equipment room meet the server operating requirements.
·     Regularly check the server from HDM for operating health issues.
·     Keep the operating system and software up to date as required.
·     Make a reliable backup plan:
¡     Back up data regularly.
¡     If data operations on the server are frequent, back up data as needed in shorter intervals than the regular backup interval.
¡     Check the backup data regularly for data corruption.
·     Stock spare components on site in case replacements are needed. After a spare component is used, prepare a new one.
·     Keep the network topology up to date to facilitate network troubleshooting.
Maintenance tools
The following are major tools for server maintenance:
·     Temperature humidity meterMonitor the operating environment of the server.
·     HDM and FIST—Monitor the operating status of the server.
Maintenance tasks
Observing LED status
Observe the LED status on the front and rear panels of the server to verify that the server modules are operating correctly. For more information about the status of the front and rear panel LEDs, see front panel and rear panel in "Appendix A  Server specifications."
Monitoring the temperature and humidity in the equipment room
Use a temperature humidity meter to monitor the temperature and humidity in the equipment room.
The temperature and humidity in the equipment room must meet the server requirements described in "Appendix A  Server specifications."
Examining cable connections
Verify that the cables and power cords are correctly connected.
Guidelines
·     Do not use excessive force when connecting or disconnecting cables.
·     Do not twist or stretch the cables.
·     Organize the cables appropriately. For more information, see "Cabling guidelines."
Checklist
·     The cable type is correct.
·     The cables are correctly and firmly connected and the cable length is appropriate.
·     The cables are in good condition and are not twisted or corroded at the connection point.
Technical support
If you encounter any complicated problems during daily maintenance or troubleshooting, contact H3C Support.
Before contacting H3C Support, collect the following server information to facilitate troubleshooting:
·     Log and sensor information:
¡     Log information:
-     Event logs, HDM logs, and SDS logs in HDM.
-     Logs in iFIST.
¡     Sensor information in HDM.
·     Product serial number.
·     Product model and name.
·     Snapshots of error messages and descriptions.
·     Hardware change history, including installation, replacement, insertion, and removal of hardware.
·     Third-party software installed on the server.
·     Operating system type and version.
H3C reserves the right to modify its collaterals without any prior notice. For the latest information of the collaterals, please consult H3C sales or call 400 hotline.
