- 04-Network Connectivity
- 01-About the network connectivity configuration guide
- 02-MAC address table configuration
- 03-Ethernet link aggregation configuration
- 04-Port isolation configuration
- 05-VLAN configuration
- 06-Loop detection configuration
- 07-Spanning tree configuration
- 08-LLDP configuration
- 09-Layer 2 forwarding configuration
- 10-ARP configuration
- 11-IP addressing configuration
- 12-DHCP configuration
- 13-DHCPv6 configuration
- 14-DNS configuration
- 15-IP performance optimization configuration
- 16-IPv6 basics configuration
- 17-Basic IP routing configuration
- 18-Static routing configuration
- 19-IPv6 static routing configuration
- 20-Multicast overview
- 21-IGMP snooping configuration
- 22-MLD snooping configuration
| 17-Basic IP routing configuration | 69.26 KB |
Configuring basic IP routing
This chapter focuses on unicast routing protocols. For more information about multicast routing protocols, see multicast overview, IGMP snooping configuration, and MLD snooping configuration in Network Connectivity Configuration Guide.
About IP routing
IP routing directs IP packet forwarding on routers. Based on the destination IP address in the packet, a router looks up a route for the packet in a routing table and forwards the packet to the next hop. Routes are path information used to direct IP packets.
Routing table
A RIB contains the global routing information and related information, including route recursion, route extension, and route redistribution information. The router selects optimal routes from the routing table and puts them into the FIB table. It uses the FIB table to forward packets.
Route categories
Table 1 categorizes routes by different criteria.
Criterion |
Categories |
Origin |
· Direct route—A direct route is discovered by the data link protocol on an interface, and is also called an interface route. · Static route—A static route is manually configured by an administrator. · Dynamic route—A dynamic route is dynamically discovered by a routing protocol. |
Destination |
· Network route—The destination is a network. The subnet mask is less than 32 bits. · Host route—The destination is a host. The subnet mask is 32 bits. |
Whether the destination is directly connected |
· Direct route—The destination is directly connected. · Indirect route—The destination is indirectly connected. |
Dynamic routing protocols
Static routes work well in small, stable networks. They are easy to configure and require fewer system resources. However, in networks where topology changes occur frequently, a typical practice is to configure a dynamic routing protocol. Compared with static routing, a dynamic routing protocol is complicated to configure, requires more router resources, and consumes more network resources.
Dynamic routing protocols dynamically collect and report reachability information to adapt to topology changes. They are suitable for large networks.
Dynamic routing protocols can be classified by different criteria, as shown in Table 2.
Table 2 Categories of dynamic routing protocols
Criterion |
Categories |
Operation scope |
· IGPs—Work within an AS. Examples include RIP, OSPF, and IS-IS. · EGPs—Work between ASs. The most popular EGP is BGP. |
Routing algorithm |
· Distance-vector protocols—Examples include RIP and BGP. BGP is also considered a path-vector protocol. · Link-state protocols—Examples include OSPF and IS-IS. |
Destination address type |
· Unicast routing protocols—Examples include RIP, OSPF, BGP, and IS-IS. · Multicast routing protocols—Examples include PIM-SM and PIM-DM. |
IP version |
· IPv4 routing protocols—Examples include RIP, OSPF, BGP, and IS-IS. · IPv6 routing protocols—Examples include RIPng, OSPFv3, IPv6 BGP, and IPv6 IS-IS. |
An AS refers to a group of routers that use the same routing policy and work under the same administration.
Route preference
Routing protocols, including static and direct routing, each by default have a preference. If they find multiple routes to the same destination, the router selects the route with the highest preference as the optimal route.
The preference of a direct route is always 0 and cannot be changed. You can configure a preference for each static route and each dynamic routing protocol. The following table lists the route types and default preferences. The smaller the value, the higher the preference.
Table 3 Route types and default route preferences
Route type |
Preference |
Direct route |
0 |
Multicast static route |
1 |
OSPF |
10 |
IS-IS |
15 |
Unicast static route |
60 |
RIP |
100 |
OSPF ASE |
150 |
OSPF NSSA |
150 |
IBGP |
255 |
EBGP |
255 |
Unknown (route from an untrusted source) |
256 |
Load sharing
A routing protocol might find multiple optimal equal-cost routes to the same destination. You can use these routes to implement equal-cost multi-path (ECMP) load sharing.
Static routing, IPv6 static routing, RIP, RIPng, OSPF, OSPFv3, BGP, IPv6 BGP, IS-IS, and IPv6 IS-IS support ECMP load sharing.
Route backup
Route backup can improve network availability. Among multiple routes to the same destination, the route with the highest priority is the primary route and others are secondary routes.
The router forwards matching packets through the primary route. When the primary route fails, the route with the highest preference among the secondary routes is selected to forward packets. When the primary route recovers, the router uses it to forward packets.
Route recursion
To use a BGP, static, or RIP route that has an indirectly connected next hop, a router must perform route recursion to find the output interface to reach the next hop.
Link-state routing protocols, such as OSPF and IS-IS, do not need route recursion, because they obtain directly connected next hops through route calculation.
The RIB records and saves route recursion information, including brief information about related routes, recursive paths, and recursion depth.
Route redistribution
Route redistribution enables routing protocols to learn routing information from each other. A dynamic routing protocol can redistribute routes from other routing protocols, including direct and static routing. For more information, see the respective chapters on those routing protocols in this configuration guide.
The RIB records redistribution relationships of routing protocols.
Extension attribute redistribution
Extension attribute redistribution enables routing protocols to learn route extension attributes from each other, including BGP extended community attributes, OSPF area IDs, route types, and router IDs.
The RIB records extended attributes of each routing protocol and redistribution relationships of different routing protocol extended attributes.
Display and maintenance commands for basic IP routing
Task |
Command |
Display routing table information. |
display ip routing-table [ verbose ] |
Display information about routes permitted by an IPv4 basic ACL. |
display ip routing-table acl ipv4-acl-number [ verbose ] |
Display information about routes to a specific destination address. |
display ip routing-table ip-address [ mask-length | mask ] [ longer-match ] [ verbose ] |
Display information about routes to a range of destination addresses. |
display ip routing-table ip-address1 to ip-address2 [ verbose ] |
Display information about routes installed by a protocol. |
display ip routing-table protocol protocol [ inactive | verbose ] |
Display IPv4 route statistics. |
display ip routing-table [ all-routes ] statistics |
Display brief IPv4 routing table information. |
display ip routing-table summary |
Display next hop information in the IPv6 RIB. |
display ipv6 rib nib [ self-originated ] [ nib-id ] [ verbose ] display ipv6 rib nib protocol protocol [ verbose ] |
Display next hop information for IPv6 direct routes. |
display ipv6 route-direct nib [ nib-id ] [ verbose ] |
Display IPv6 routing table information. |
display ipv6 routing-table [ verbose ] |
Display information about routes permitted by an IPv6 basic ACL. |
display ipv6 routing-table acl ipv6-acl-number [ verbose ] |
Display information about routes to an IPv6 destination address. |
display ipv6 routing-table ipv6-address [ prefix-length ] [ longer-match ] [ verbose ] |
Display information about routes to a range of IPv6 destination addresses. |
display ipv6 routing-table ipv6-address1 to ipv6-address2 [ verbose ] |
Display information about routes installed by an IPv6 protocol. |
display ipv6 routing-table protocol protocol [ inactive | verbose ] |
Display IPv6 route statistics. |
display ipv6 routing-table [ all-routes ] statistics |
Display brief IPv6 routing table information. |
display ipv6 routing-table summary |
Display next hop information in the RIB. |
display rib nib [ self-originated ] [ nib-id ] [ verbose ] display rib nib protocol protocol [ verbose ] |
Display next hop information for direct routes. |
display route-direct nib [ nib-id ] [ verbose ] |
Clear IPv4 route statistics. |
reset ip routing-table statistics protocol { protocol | all } |
Clear IPv6 route statistics. |
reset ipv6 routing-table statistics protocol { protocol | all } |
