04-Network Connectivity Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Points Cloud Mode Command References(E2442 R2442)-6W10004-Network Connectivity Command Reference
21-IPv6 static routing commands
21-IPv6 static routing commands 69.54 KB
delete ipv6 static-routes all
Use delete ipv6 static-routes all to delete all IPv6 static routes.
When you use this command, the system will prompt you to confirm the operation before deleting all the IPv6 static routes.
# Delete all IPv6 static routes.
[Sysname] delete ipv6 static-routes all
This will erase all IPv6 static routes and their configurations, you must reconfigure all static routes.
Are you sure?[Y/N]:y
ipv6 route-static
display ipv6 route-static nib
Use display ipv6 route-static nib to display IPv6 static route next hop information.
display ipv6 route-static nib [ nib-id ] [ verbose ]
nib-id: Specifies a NIB by its ID, a hexadecimal string in the range of 1 to ffffffff.
verbose: Displays detailed IPv6 static route next hop information. If you do not specify this keyword, the command displays brief IPv6 static route next hop information.
# Display brief IPv6 static route next hop information.
<Sysname> display ipv6 route-static nib
Total number of nexthop(s): 35
      NibID: 0x21000000        Sequence: 0
       Type: 0x41               Flushed: Yes
   UserKey0: 0x0                VrfNthp: 0
   UserKey1: 0x0                Nexthop: 2::3
    IFIndex: 0x0              LocalAddr: ::
   TopoNthp: Invalid
      NibID: 0x21000001        Sequence: 1
   UserKey1: 0x0                Nexthop: 3::4
   TopoNthp: Invalid
NibID
ID of the NIB.
Sequence
Sequence number of the NIB.
Type of the NIB.
Flushed
Indicates whether the route with the NIB has been flushed to the FIB.
UserKey0
Reserved data 1.
UserKey1
Reserved data 2.
VrfNthp
Index of the VPN instance to which the next hop belongs. This field displays 0 if the next hop is on the public network.
Nexthop
Next hop address.
IFIndex
Interface index
LocalAddr
Local interface address.
TopoNthp
Index of the topology that contains the next hop.
This field displays Invalid if the next hop is on an IPv6 network, because the router does not support non-base topologies.
# Display detailed IPv6 static route next hop information.
<Sysname> display ipv6 route-static nib verbose
   TopoNthp: Invalid
     RefCnt: 1              FlushRefCnt: 0
       Flag: 0x12               Version: 1
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 2::3
  RelyDepth: 2              RealNexthop: ::
  Interface: NULL0            LocalAddr: ::
  TunnelCnt: 0                      Vrf: default-vrf
   TunnelID: N/A               Topology:
     Weight: 0
   TopoNthp: Invalid
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 3::4
  RelyDepth: 1              RealNexthop: ::
  Interface: Vlan11           LocalAddr: ::
     Weight: 0
x nexthop(s)
Number of next hops.
PrefixIndex
Prefix index of the next hop for an ECMP route.
Vrf
VPN instance name. For the public network, this field displays default-vrf.
OrigNexthop
Original next hop.
RealNexthop
Real next hop.
Output interface.
localAddr
RelyDepth
Recursion depth.
TunnelCnt
Number of tunnels after route recursion.
TunnelID
ID of the tunnel after route recursion.
Topology
Topology name. This field is blank for IPv6, because IPv6 does not support non-base topologies.
Weight
ECMP route weight. This field displays 0 for non-ECMP routes.
RefCnt
Reference count of the next hop.
FlushRefCnt
Reference count of the next hop that is flushed to the FIB.
Flag
Flag of the next hop.
Version
Version of the next hop.
display ipv6 route-static routing-table
Use display ipv6 route-static routing-table to display IPv6 static routing table information.
display ipv6 route-static routing-table [ ipv6-address prefix-length ]
ipv6-address: Specifies the destination IPv6 address.
prefix-length: Specifies the prefix length in the range of 0 to 128.
# Display IPv6 static routing table information.
<Sysname> display ipv6 route-static routing-table
Total number of routes: 5
Status: * - valid
*Destination: 1::1/128
       NibID: 0x21000000        NextHop: 2::2
   MainNibID: N/A             BkNextHop: N/A
     BkNibID: N/A             Interface: Vlan-interface11
     TableID: 0xa           BkInterface: N/A
        Flag: 0x80d0a          BfdSrcIp: N/A
     DbIndex: 0x3            BfdIfIndex: 0x0
        Type: Normal        BfdVrfIndex: 0
  TrackIndex: 0xffffffff          Label: NULL
  Preference: 60            vrfIndexDst: 0
     BfdMode: N/A            vrfIndexNH: 0
   Permanent: 0                     Tag: 0
*Destination: 1::1234/128
     BkNibID: N/A             Interface: NULL0
     DbIndex: 0x1            BfdIfIndex: 0x0
   Permanent: 0                     Tag: 0
Destination
Destination address/prefix.
NibID
ID of the NIB.
MainNibID
ID of the primary next hop for static route FRR.
BkNibID
ID of the backup next hop for static route FRR.
NextHop
Next hop address.
BkNextHop
Backup next hop address.
Output interface of the route.
BkInterface
Backup output interface.
TableID
ID of the table to which the route belongs.
DbIndex
Index of the database to which the route belongs.
Route type:
·     Normal.
·     DHCP.
·     NAT.
BfdSrcIp
Source IPv6 address of the indirect BFD session.
BfdIfIndex
Index of the interface where BFD is enabled.
BfdVrfIndex
Index of the VPN instance where BFD is enabled. This field displays 0 if BFD is enabled for the public network.
BfdMode
BFD session mode:
·     N/A—No BFD session is configured.
·     Ctrl—Control packet mode.
·     Echo—Echo packet mode.
TrackIndex
NQA Track index.
vrfIndexDst
Index of the VPN instance to which the destination belongs. For the public network, this field displays 0.
vrfIndexNH
Index of the VPN instance to which the next hop belongs. For the public network, this field displays 0.
Permanent
Permanent static route flag. 1 indicates a permanent static route.
ipv6 route-static
Use ipv6 route-static to configure an IPv6 static route.
Use undo ipv6 route-static to remove an IPv6 static route.
ipv6 route-static ipv6-address prefix-length { interface-type interface-number [ next-hop-address ] | next-hop-address } [ permanent ] [ preference preference ] [ tag tag-value ] [ description text ]
undo ipv6 route-static ipv6-address prefix-length [ interface-type interface-number [ next-hop-address ] | next-hop-address ] [ preference preference ]
No IPv6 static route is configured.
ipv6-address prefix-length: Specifies the IPv6 address and prefix length.
interface-type interface-number: Specifies an output interface by its type and number. If the output interface is a non-P2P interface (for example, an NBMA interface or broadcast interface), the next hop address must be specified.
next-hop-address: Specifies the next hop IPv6 address.
permanent: Specifies the IPv6 route as a permanent IPv6 static route. If the output interface is down, the permanent IPv6 static route is still active.
preference preference: Specifies a preference for IPv6 static routes, in the range of 1 to 255. The default is 60.
tag tag-value: Sets a tag for marking the static route, in the range of 1 to 4294967295. The default is 0. Tags of routes are used for route control in routing policies.
description text: Configures a description for the IPv6 static route, which consists of 1 to 60 characters, including special characters such as the space, but excluding the question mark (?).
An IPv6 static route that has the destination address configured as ::/0 (a prefix length of 0) is the default IPv6 route. If the destination address of an IPv6 packet does not match any entry in the routing table, this default route is used to forward the packet.
Follow these guidelines to configure the output interface, next hop address, or both for a static route:
·     If the output interface is a broadcast interface or an NBMA interface, the next hop address must be specified.
·     If the output interface is a P2P interface, you can specify only the output interface. You do not need to change the configuration of the route even if the peer address is changed.
# Configure an IPv6 static route, with the destination address 1:1:2::/64 and next hop 1:1:3::1.
[Sysname] ipv6 route-static 1:1:2:: 64 1:1:3::1
display ipv6 routing-table protocol
ipv6 route-static default-preference
Use ipv6 route-static default-preference to set a default preference for IPv6 static routes.
Use undo ipv6 route-static default-preference to restore the default.
ipv6 route-static default-preference default-preference
The default preference of IPv6 static routes is 60.
default-preference: Specifies a default preference for IPv6 static routes, in the range of 1 to 255.
If no preference is specified for an IPv6 static route, the default preference applies.
When the default preference is reconfigured, it applies only to newly added IPv6 static routes.
# Set a default preference of 120 for IPv6 static routes.
[Sysname] ipv6 route-static default-preference 120
