- 04-Network Connectivity Command Reference
- 01-MAC address table commands
- 02-Ethernet link aggregation commands
- 03-Port isolation commands
- 04-VLAN commands
- 05-Loop detection commands
- 06-Spanning tree commands
- 07-LLDP commands
- 08-Layer 2 forwarding commands
- 09-PPP commands
- 10-ARP commands
- 11-IP addressing commands
- 12-DHCP commands
- 13-DHCPv6 commands
- 14-DNS commands
- 15-NAT commands
- 16-IP performance optimization commands
- 17-IPv6 basics commands
- 18-EoGRE commands
- 19-Basic IP routing commands
- 20-Static routing commands
- 21-IPv6 static routing commands
- 22-IGMP snooping commands
- 23-MLD snooping commands
03-Port isolation commands | 39.85 KB |
display port-isolate group
Use display port-isolate group to display port isolation group information.
# Display port isolation group information.
<Sysname> display port-isolate group
Port isolation group information:
Group ID: 1
Group members:
GigabitEthernet1/0/2
Group ID |
ID of the isolation group. |
Group members |
Isolated ports in the isolation group. No ports indicates that the isolation group does not contain isolated ports. |
port-isolate enable
port-isolate enable
Use port-isolate enable to assign a port to an isolation group.
Use undo port-isolate enable to remove a port from an isolation group.
port-isolate enable
The port is not assigned to an isolation group.
The configuration in Layer 2 Ethernet interface view applies only to the interface.
The configuration in Layer 2 aggregate interface view applies to the Layer 2 aggregate interface and its aggregation member ports. If the device fails to apply the configuration to the aggregate interface, it does not assign any aggregation member port to the isolation group. If the failure occurs on an aggregation member port, the device skips the port and continues to assign other aggregation member ports to the isolation group.
You cannot assign the member ports of a service loopback group to an isolation group, and vice versa.
This command assigns a port to the default isolation group (isolation group 1).
# Assign GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to the default isolation group.
[Sysname-GigabitEthernet1/0/1] port-isolate enable
[Sysname-GigabitEthernet1/0/2] port-isolate enable
# Assign Layer 2 aggregate interface Bridge-Aggregation 1 to the default isolation group.
[Sysname-Bridge-Aggregation1] quit
[Sysname-GigabitEthernet1/0/1] port link-aggregation group 1
[Sysname-GigabitEthernet1/0/2] port link-aggregation group 1
[Sysname-GigabitEthernet1/0/2] quit
[Sysname-Bridge-Aggregation1] port-isolate enable
