04-Network Connectivity Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Points Cloud Mode Command References(E2442 R2442)-6W10004-Network Connectivity Command Reference
08-Layer 2 forwarding commands
08-Layer 2 forwarding commands 64.91 KB
Normal Layer 2 forwarding commands
display mac-forwarding statistics
Use display mac-forwarding statistics to display Layer 2 forwarding statistics.
display mac-forwarding statistics [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays Layer 2 forwarding statistics on all interfaces.
# Display Layer 2 forwarding statistics on all interfaces.
<Sysname> display mac-forwarding statistics
Input:
   Sum:               888        Unknown Unicast:   0
   Broadcast:         0          Multicast:         0
   Filtered:          0          STP discarded:     0
   Service dropped:   0          Source dropped:    0
   Unknown dropped: 0          Learning dropped:  0
   Blackhole dropped: 0          Suppress dropped:  0
   Source MAC dropped:0
Deliver:
   Sum:               111        L2 protocol:       11
   Local MAC address: 100
Output:
   Sum:               666        Filtered:          0
   Blackhole dropped: 0          STP discarded:     0
   Service dropped:   0          Dest MAC dropped:  0
# Display Layer 2 forwarding statistics on GigabitEthernet 1/0/1.
<Sysname> display mac-forwarding statistics interface gigabitethernet 1/0/1
GigabitEthernet1/0/1:
Input frames: 100    Output frames:100
Filtered:     0
Input
Inbound Ethernet frame statistics.
·     Sum—Total number of received Ethernet frames.
·     Filtered—Number of Ethernet frames filtered out by 802.1Q VLAN inbound filtering rules.
·     STP discarded—Number of inbound Ethernet frames dropped on the ports blocked by STP.
·     Service dropped—Number of Ethernet frames dropped by inbound service features.
·     Source dropped—Number of Ethernet frames dropped because their source MAC addresses are all-zeros, multicast, or broadcast MAC addresses.
·     Unknown dropped—Number of Ethernet frames dropped because the device is disabled from forwarding frames with unknown source MAC addresses.
·     Learning dropped—Number of Ethernet frames dropped because the device is disabled from forwarding unknown frames after the number of learned MAC addresses reaches the upper limit.
·     Suppress dropped—Number of Ethernet frames dropped by storm suppression.
·     Broadcast—Number of received broadcast Ethernet frames.
·     Multicast—Number of received multicast Ethernet frames.
·     Unknown unicast—Number of received unknown unicast Ethernet frames.
·     Blackhole dropped—Number of Ethernet frames dropped because they are sourced from blackhole MAC addresses.
·     Source MAC dropped—Number of Ethernet frames dropped by features based on the source MAC addresses.
Deliver
Statistics of Ethernet frames delivered to the CPU.
·     Sum—Total number of Ethernet frames delivered to the CPU.
·     L2 protocol—Number of Layer 2 protocol Ethernet frames delivered to the CPU.
·     Local MAC address—Number of Ethernet frames that use the MAC addresses of local Layer 3 VLAN interfaces as the destination MAC addresses.
Output
Outbound Ethernet frame statistics.
·     Sum—Total number of sent Ethernet frames.
·     Filtered—Number of Ethernet frames filtered out by 802.1Q VLAN outbound filtering rules.
·     Blackhole dropped—Number of Ethernet frames dropped because they are destined for blackhole MAC addresses.
·     STP discarded—Number of outbound Ethernet frames dropped on the ports blocked by STP.
·     Service dropped—Number of Ethernet frames dropped by outbound service features.
·     Dest MAC dropped—Number of Ethernet frames dropped by features based on the destination MAC addresses.
Layer 2 forwarding statistics on GigabitEthernet 1/0/1:
·     Input frames—Number of Ethernet frames received on the interface.
·     Output frames—Number of Ethernet frames sent out of the interface.
·     Filtered—Number of Ethernet frames filtered out because they are from other VLANs.
reset mac-forwarding statistics
Use reset mac-forwarding statistics to clear Layer 2 forwarding statistics.
# Clear Layer 2 forwarding statistics.
<Sysname> reset mac-forwarding statistics
Fast Layer 2 forwarding commands
display mac-forwarding cache ip
Use display mac-forwarding cache ip to display IPv4 fast forwarding entries.
display mac-forwarding cache ip [ ip-address ]
ip-address: Specifies an IPv4 address. If you do not specify an IPv4 address, this command displays all IPv4 fast forwarding entries.
# Display all IPv4 fast forwarding entries.
<Sysname> display mac-forwarding cache ip
Total number of mac-forwarding entries: 2
SIP            SPort DIP             DPort Pro Input_If    Output_If   VLAN
1.1.1.2        99    1.1.1.1         2048  1   GE1/0/1     GE1/0/2     2
1.1.1.1        98    1.1.1.2         2012  1   GE1/0/2     GE1/0/1     2
Total number of IPv4 fast forwarding entries.
SIP
Source IPv4 address.
SPort
Source port number.
DIP
Destination IPv4 address.
DPort
Destination port number.
Pro
Protocol number.
Input_If
Input interface type and number.
If no input interface is involved in fast forwarding, this field displays N/A.
If no input interface is available, this field displays a hyphen (-).
Output_If
Output interface type and number.
If no output interface is involved in fast forwarding, this field displays N/A.
If no output interface is available, this field displays a hyphen (-).
VLAN
VLAN ID.
display mac-forwarding cache ip fragment
Use display mac-forwarding cache ip fragment to display IPv4 fast forwarding entries for fragments.
display mac-forwarding cache ip fragment [ ip-address ]
ip-address: Specifies an IPv4 address. If you do not specify an IPv4 address, this command displays IPv4 fast forwarding entries for all fragments.
# Display IPv4 fast forwarding entries for all fragments.
<Sysname> display mac-forwarding cache ip fragment
Total number of fragment mac-forwarding entries: 2
SIP             SPort DIP             DPort Pro Input_If    ID     VLAN
1.1.1.1         117   1.1.1.2         0     1   GE1/0/1     2828   1
1.1.1.2         110   1.1.1.1         67    17  GE1/0/2     2322   1
Total number of IPv4 fast forwarding entries for fragments.
SIP
SPort
Source port number.
DIP
DPort
Pro
Protocol number.
Input_If
ID
Fragment ID.
VLAN
VLAN ID.
display mac-forwarding cache ipv6
Use display mac-forwarding cache ipv6 to display IPv6 fast forwarding entries.
display mac-forwarding cache ipv6 [ ipv6-address ]
ipv6-address: Specifies an IPv6 address. If you do not specify an IPv6 address, this command displays all IPv6 fast forwarding entries.
# Display all IPv6 fast forwarding entries.
<Sysname> display mac-forwarding cache ipv6
Total number of IPv6 mac-forwarding items: 1
Src IP: 2002::1                                        Src port: 129
Dst IP: 2001::1                                        Dst port: 65535
VLAN ID: 2
Protocol: 2
Input interface: GE1/0/2
Output interface: GE1/0/1
Total number of IPv6 fast forwarding entries.
Src IP
Source IPv6 address.
Src port
Source port number.
Dst IP
Destination IPv6 address.
Dst Port
Protocol
Protocol number.
Input interface
Output interface
