| 00-Preface | 28.83 KB |
Preface
The H3C IMC Endpoint Profiling System Administrator Guide includes four chapters, which describe EPS fundamentals, generic configuration procedures, and configuration examples.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C IMC EPS.
Conventions
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Documentation feedback
We appreciate your comments.
