01-License Management Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C Access Controllers Configuration Guides(R5426P02)-6W10401-License Management Configuration Guide
01-AP license synchronization configuration
01-AP license synchronization configuration 124.04 KB
Configuring AP license synchronization
About AP license synchronization
This feature enables master ACs to synchronize local licenses to the backup AC in an AP license synchronization group via AP license synchronization connections. In an N+1 cold-backup or dual-link backup network, licenses are installed on a per-AC basis. When the master AC fails, the backup AC will take over the service and APs will be reassociated with the backup AC. This feature avoids AP association failures on the backup AC due to lack of AP licenses.
AP license synchronization networking
CAUTION
CAUTION:
AP license synchronization is supported only in an N+1 cold-backup network or a dual-link backup network.
In an N+1 cold-backup network, a backup AC can back up licenses of multiple master ACs. You can configure a minimum of one AC as the backup and a maximum of four ACs as the masters in an AP license synchronization group.
Figure 1 Network diagram for N+1 cold-backup
In a dual-link backup network, the two ACs back up licenses for each other . You must configure both ACs as the master ACs.
Figure 2 Network diagram for dual-link backup
AP license synchronization connection establishment
When both ACs are configured with the AP license synchronization feature, an AP license synchronization connection is established between them by using the following procedure:
1.     In a N+1 cold-backup network, the backup AC initiates a connection request to the master AC. In a dual-link backup network, the AC with the lower IP address initiates a connection request to the AC with the higher IP address.
2.     The master AC compares the license synchronization group configuration in the received request packet with the local license synchronization group configuration. If a match is found, the master AC accepts the connection request.
3.     When the connection is established, the backup AC initiates a license synchronization request.
4.     The master AC synchronizes the local license information to the backup AC and copies local activation files to the backup AC.
Figure 3 Establishing an AP license synchronization connection
The backup AC initiates synchronization requests every 10 minutes to obtain information about installed and used licenses on each master AC. The supported number of online APs in the network is license-restricted. If the existing AP number exceeds the supported number, the backup AC will log off APs until the existing AP number is no more than the supported number.
Restrictions and guidelines: AP license synchronization configuration
Before enabling AP license synchronization, you must specify IP addresses and roles for the AC and its member ACs in the AP license synchronization group.
Restrictions: Hardware compatibility with AP license synchronization
Hardware series
Model
Product code
AP license synchronization compatibility
WX1800H series
WX1804H
EWP-WX1804H-PWR-CN
No
WX2500H series
WX2508H-PWR-LTE
WX2510H
WX2510H-F
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
No
WX3000H series
WX3010H
WX3010H-X
WX3010H-L
WX3024H
WX3024H-L
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
No
WX3500H series
WX3508H
WX3510H
WX3520H
WX3520H-F
WX3540H
EWP-WX3508H
EWP-WX3510H
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
Yes
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
Yes
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
Yes
Access controller modules
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
Yes
Hardware series
Model
Product code
WX1800H series
WX1804H
WX1810H
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
No
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
Yes
WX5800H series
WX5860H
EWP-WX5860H-GL
Yes
Configuring the AP license synchronization feature
2.     Enter AP license synchronization group view.
wlan ap-license-group
3.     Specify the IP address and role for the local AC in the AP license synchronization group.
local ip ipv4-address [ backup ]
By default, no IP address or role is specified for the local AC in the AP license synchronization group.
4.     Add a member to the AP license synchronization group.
member ip ipv4-address [ backup ]
5.     Enable AP license synchronization.
ap-license-synchronization enable
By default, AP license synchronization is disabled.
Display and maintenance commands for AP license synchronization
Display AP license synchronization group information
display wlan ap-license-group
