05-Network Connectivity
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(R5426P02)-6W10405-Network Connectivity
18-Policy-based routing commands
18-Policy-based routing commands 113.91 KB
The following compatibility matrixes show the support of hardware platforms for policy-based routing:
Hardware series
Model
Product code
Policy-based routing compatibility
WX1800H series
WX1804H
EWP-WX1804H-PWR-CN
Yes
WX2500H series
WX2508H-PWR-LTE
WX2510H
WX2510H-F
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
Yes
WX3000H series
WX3010H
WX3010H-X
WX3010H-L
WX3024H
WX3024H-L
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
No
WX3500H series
WX3508H
WX3510H
WX3520H
WX3520H-F
WX3540H
EWP-WX3508H
EWP-WX3510H
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
Yes
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
Yes
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
Yes
Access controller modules
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
Yes
Hardware series
Model
Product code
WX1800H series
WX1804H
WX1810H
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
Yes
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
Yes
WX5800H series
WX5860H
EWP-WX5860H-GL
Yes
apply continue
Use apply continue to compare packets with the next policy node upon failure on the current node.
Use undo apply continue to restore the default.
apply continue
undo apply continue
PBR does not compare packets with the next policy node upon failure on the current node.
Policy node view
This command takes effect only when the match mode of the node is permit.
This command applies when the following clauses are not configured or become invalid:
·     apply next-hop
·     apply output-interface
·     apply default-next-hop
·     apply default-output-interface
For example, the command applies when the specified next hop is unreachable or the specified output interface is down.
# Compare with the next policy node upon failure on the current node.
[Sysname] policy-based-route aa permit node 11
[Sysname-pbr-aa-11] apply continue
Use apply default-next-hop to set default next hops.
Use undo apply default-next-hop to remove default next hops.
apply default-next-hop { ip-address [ direct ] [ track track-entry-number ] }&<1-n>
undo apply default-next-hop [ ip-address&<1-n> ]
No default next hops are set.
Policy node view
ip-address: Specifies the IP address of a default next hop.
direct: Specifies a directly connected default next hop.
track track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
&<1-n>: Indicates that you can specify up to n default next hops, each of which can be associated with a track entry.
You can specify multiple default next hops for backup or load sharing in one command line or by executing this command multiple times.
With a default next hop specified, the undo apply default-next-hop command removes the default next hop.
Without any default next hop specified, the undo apply default-next-hop command removes all default next hops.
# Set a directly-connected default next hop of 1.1.1.1.
[Sysname-pbr-aa-11] apply default-next-hop 1.1.1.1 direct
apply loadshare
Use apply default-output-interface to set default output interfaces.
Use undo apply default-output-interface to remove default output interfaces.
apply default-output-interface { interface-type interface-number [ track track-entry-number ] }&<1-n>
undo apply default-output-interface [ { interface-type interface-number }&<1-n> ]
No default output interfaces are set.
Policy node view
&<1-n>: Indicates that you can specify up to n interfaces, each of which can be associated with a track entry. The value for n varies by device model.
You can specify multiple default output interfaces for backup or load sharing in one command line or by executing this command multiple times.
The default output interface must be P2P type. Using a non-P2P default output interface can result in forwarding failures when the interface has multiple next hops. Non-P2P interfaces include broadcast and non-broadcast multi-access (NBMA) interfaces such as Ethernet and virtual-template interfaces. In NBMA networks, packets are sent in unicast.
With a default output interface specified, the undo apply default-output-interface command removes the default output interface.
Without any default output interface specified, the undo apply default-output-interface command removes all default output interfaces.
# Specify VLAN-interface 2 as the default output interface for IP packets.
[Sysname-pbr-aa-11] apply default-output-interface vlan-interface 2
apply loadshare
apply ip-df
Use apply ip-df to set the Don't Fragment (DF) bit in the IP header of matching packets.
Use undo apply ip-df to restore the default.
apply ip-df df-value
undo apply ip-df
The DF bit is not set.
Policy node view
df-value: Sets the DF bit in the IP header of matching packets. The value can be 0 or 1.
Setting the DF bit to 0 allows packet fragmentation.
Setting the DF bit to 1 prohibits packet fragmentation.
# Set the DF bit in the IP header of matching packets to 0.
[Sysname-pbr-aa-11] apply ip-df 0
apply loadshare
Use apply loadshare to enable load sharing among multiple next hops, output interfaces, default next hops, or default output interfaces.
Use undo apply loadshare to restore the default.
apply loadshare { default-next-hop | default-output-interface | next-hop | output-interface }
undo apply loadshare { default-next-hop | default-output-interface | next-hop | output-interface }
Multiple next hops, output interfaces, default next hops, or default output interfaces operate in primary/backup mode.
Policy node view
default-next-hop: Enables load sharing among multiple default next hops.
default-output-interface: Enables load sharing among multiple default output interfaces.
next-hop: Enables load sharing among multiple next hops.
output-interface: Enables load sharing among multiple output interfaces.
Multiple next hops, output interfaces, default next hops, or default output interfaces operate in either primary/backup or load sharing mode. For example:
·     Primary/backup mode—The first configured output interface is used. When the primary output interface fails, the first configured backup output interface takes over.
·     Load sharing mode—Multiple output interfaces load share traffic on a per-packet basis in turn, according to the configuration order.
Multiple next hops load share traffic according to their weights. By default, all next hops have the same weight and traffic is load balanced among them.
# Enable load sharing among multiple next hops.
[Sysname-pbr-aa-11] apply next-hop 1.1.1.1 2.2.2.2
[Sysname-pbr-aa-11] apply loadshare next-hop
# Enable load sharing among multiple output interfaces.
[Sysname-pbr-aa-11] apply output-interface vlan-interface 1 vlan-interface 2
[Sysname-pbr-aa-11] apply loadshare output-interface
# Enable load sharing among multiple default next hops.
[Sysname-pbr-aa-11] apply default-next-hop 1.1.1.1 2.2.2.2
[Sysname-pbr-aa-11] apply loadshare default-next-hop
# Enable load sharing among multiple default output interfaces.
[Sysname-pbr-aa-11] apply default-output-interface vlan-interface 1 vlan-interface 2
[Sysname-pbr-aa-11] apply loadshare default-output-interface
apply next-hop
apply next-hop
Use apply next-hop to set next hops.
Use undo apply next-hop to remove next hops.
apply next-hop { ip-address [ direct ] [ track track-entry-number ] [ weight weight-value ] }&<1-n>
undo apply next-hop [ ip-address&<1-n> ]
No next hops are set.
Policy node view
ip-address: Specifies the IP address of a next hop.
direct: Specifies that the next hop must be directly connected to take effect.
weight weight-value: Specifies a load sharing weight for the next hop, in the range of 1 to 100. The default is 10. If you specify weights 1, 1, and 2 for three next hops, they share 1/4, 1/4, and 1/2 of the whole traffic, respectively.
&<1-n>: Indicates that you can specify up to n next hops, each of which can be associated with a track entry. The value for n varies by device model.
You can specify multiple next hops for backup or load sharing in one command line or by executing this command multiple times.
With a next hop specified, the undo apply next-hop command removes the next hop.
Without any next hop specified, the undo apply next-hop command removes all next hops.
# Set a directly-connected next hop of 1.1.1.1.
[Sysname-pbr-aa-11] apply next-hop 1.1.1.1 direct
apply loadshare
Use apply output-interface to set output interfaces.
Use undo apply output-interface to remove output interfaces.
apply output-interface { interface-type interface-number [ track track-entry-number ] }&<1-n>
undo apply output-interface [ { interface-type interface-number }&<1-n> ]
No output interfaces are set.
Policy node view
You can specify multiple output interfaces for backup or load sharing in one command line or by executing this command multiple times.
The output interface must be P2P type. Using a non-P2P output interface can result in forwarding failures when the interface has multiple next hops. Non-P2P interfaces include broadcast and NBMA interfaces such as Ethernet and virtual-template interfaces.
With an output interface specified, the undo apply output-interface command removes the output interface.
Without any output interface specified, the undo apply output-interface command removes all output interfaces.
# Specify VLAN-interface 2 as the output interface for IP packets.
[Sysname-pbr-aa-11] apply output-interface vlan-interface 2
apply loadshare
apply precedence
Use apply precedence to set a precedence for IP packets.
Use undo apply precedence to restore the default.
No precedence is set for IP packets.
Policy node view
type: Specifies the precedence type for IP packets.
value: Specifies the precedence for IP packets. Eight precedence values (0 to 7) are available. Each precedence value corresponds to a precedence type, as shown in Table 1. You can set either a precedence value or a precedence type for IP packets.
Table 1 IP precedences and corresponding types
Precedence value
Precedence type
0
routine
1
priority
2
immediate
3
flash
4
flash-override
5
critical
6
internet
7
network
# Set the precedence to 5 (critical) for IP packets.
[Sysname-pbr-aa-11] apply precedence critical
display ip policy-based-route
Use display ip policy-based-route to display PBR policy information.
display ip policy-based-route [ policy policy-name ]
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command displays information for all PBR policies.
# Display all policy information.
<Sysname> display ip policy-based-route
Policy name: aaa
  node 1 permit:
    if-match acl 2000
node 1 permit
The match mode of Node 1 is permit.
if-match acl
Compares packets with the ACL.
apply next-hop
Specifies a next hop for permitted packets.
policy-based-route
display ip policy-based-route interface
Use display ip policy-based-route interface to display interface PBR configuration and statistics.
In standalone mode:
display ip policy-based-route interface interface-type interface-number
In IRF mode:
display ip policy-based-route interface interface-type interface-number [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays information on the master device. (In IRF mode.)
# Display PBR configuration and statistics on VLAN-interface 2.
<Sysname> display ip policy-based-route interface vlan-interface 2
Policy based routing information for interface Vlan-interface2(failed):
Policy name: aaa
  node 0 deny:
  Matched: 0
  node 1 permit:
    if-match acl 3999
  Matched: 0
  node 2 permit:
    if-match acl 2000
    apply next-hop 2.2.2.2
  Matched: 0
  node 5 permit:
    if-match acl 3101
    apply output-interface Vlan-interface3 track 1 (down)
    apply output-interface Vlan-interface4 track 2 (inactive)
  Matched: 0
Total matched: 0
Policy based routing information for interface Vlan-interface2:
Policy name: aaa
  node 0 deny(not support):
  Matched: 0
  node 1 permit:
    if-match acl 3999
  Matched: 0
  node 2 permit(no resource):
    if-match acl 2000
  Matched: 0
  node 5 permit:
    if-match acl 3101
  Matched: 0 (no statistics resource)
Total matched: 0
Policy based routing information for interface XXXX(failed)
PBR configuration and statistics on the interface.
This field displays failed in brackets if none of the nodes in the policy has been successfully issued to the driver. The failed status will persist even after the policy is successfully issued. To clear the failed status, you must remove the policy from the interface and then apply it on the interface again.
The failed status is available on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
·     For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces.
·     For a physical interface, specify its slot number.
Match mode of the node, permit or deny.
If a node fails to be issued to the driver, the command displays the cause in brackets, which include:
·     not support—The device does not support the match criteria configured on the node.
·     no resource—No sufficient resources (for example, ACLs) are available for the node.
The cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
if-match acl
apply next-hop
apply output-interface  track 1 (down)
Specifies an output interface and its associated track entry for permitted packets.
This field displays the interface status in brackets.
·     up—The interface is up.
·     down—The interface is down at network layer.
·     inactive—The card that hosts the interface is not in position.
Number of successful matches on the node. If the device does not have sufficient resources to count matches, this field displays no statistics resource in brackets.
The statistics collection failure cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command.
Total matched
Total number of successful matches on all nodes.
reset ip policy-based-route statistics
display ip policy-based-route local
Use display ip policy-based-route local to display local PBR configuration and statistics.
In standalone mode:
In IRF mode:
display ip policy-based-route local [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays local PBR configuration and statistics for the master device. (In IRF mode.)
# Display local PBR configuration and statistics.
<Sysname> display ip policy-based-route local
Policy based routing information for local:
Policy name: aaa
  node 0 deny:
  Matched: 0
  node 1 permit:
    if-match acl 3999
  Matched: 0
  node 2 permit:
    if-match acl 2000
  Matched: 0
  node 5 permit:
    if-match acl 3101
  Matched: 0
Total matched: 0
Local PBR configuration and statistics.
node 0 deny/node 2 permit
Match mode of the node: permit or deny.
if-match acl
apply next-hop
Matched: 0
Total matched
display ip policy-based-route setup
Use display ip policy-based-route setup to display PBR configuration.
# Display PBR configuration.
<Sysname> display ip policy-based-route setup
Policy Name              Interface Name
pr01                     Vlan-interface2
Table 5 Command output
Interface Name
Interface where the policy is applied.
if-match acl
Use if-match acl to set an ACL match criterion.
Use undo if-match acl to restore the default.
undo if-match acl
No ACL match criterion is set.
Policy node view
acl-number: Specifies an ACL by its number in the range of 2000 to 2999 for a basic ACL, and in the range of 3000 to 3999 for an advanced ACL.
name acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters starting with letter a to z or A to Z. The ACL name cannot be all. For the command to take effect, make sure the specified ACL is a basic or advanced ACL.
# Configure Node 11 of policy aa to permit the packets matching ACL 2011.
[Sysname-pbr-aa-11] if-match acl 2011
# Configure Node 11 of policy aa to permit the packets matching ACL aaa.
[Sysname-pbr-aa-11] if-match acl name aaa
ip local policy-based-route
Use ip local policy-based-route to specify a policy for local PBR.
Use undo ip local policy-based-route to restore the default.
ip local policy-based-route policy-name
No policy is specified for local PBR.
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
Local PBR guides the forwarding of locally generated packets, such as ICMP packets generated by using the ping command.
Local PBR might affect local services, such as ping and Telnet. When you use local PBR, make sure you fully understand its impact on local services of the device.
You can specify only one policy for local PBR and must make sure the specified policy already exists.
Before you apply a new policy, you must first remove the current policy.
# Configure local PBR based on policy aaa.
[Sysname] ip local policy-based-route aaa
policy-based-route
Use ip policy-based-route to specify a policy for interface PBR on an interface.
Use undo ip policy-based-route to restore the default.
ip policy-based-route policy-name
No policy is applied to an interface.
Interface view
# Apply policy aaa to VLAN-interface 2.
[Sysname-Vlan-interface2] ip policy-based-route aaa
policy-based-route
policy-based-route
Use policy-based-route to create a policy node and enter its view, or enter the view of an existing policy node.
Use undo policy-based-route to delete a policy or policy node.
undo policy-based-route policy-name [ deny | node node-number | permit ]
No policy nodes exist.
deny: Specifies the match mode for the policy node as deny.
permit: Specifies the match mode for the policy node as permit (default mode).
node node-number: Specifies a policy node by its number. A smaller number has a higher priority.
A policy that has been applied to an interface or locally cannot be deleted. To delete it, you must first cancel the application.
·     If a policy node is specified, the undo policy-based-route command deletes the specified policy node.
·     If a match mode is specified, the command deletes all nodes configured with the match mode.
·     If no policy node or match mode is specified, the command deletes the whole policy.
# Create permit-mode of Node 10 for policy policy1 and enter its view.
[Sysname] policy-based-route policy1 permit node 10
[Sysname-pbr-policy1-10]
Use reset ip policy-based-route statistics to clear PBR statistics.
reset ip policy-based-route statistics [ policy policy-name ]
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command clears PBR statistics for all policies.
# Clear all PBR statistics.
<Sysname> reset ip policy-based-route statistics
snmp-agent trap enable policy-based-route
Use snmp-agent trap enable policy-based-route to enable SNMP notifications for PBR.
Use undo snmp-agent trap enable policy-based-route to disable SNMP notifications for PBR.
SNMP notifications are enabled for PBR.
After you enable this feature, PBR can generate notifications and send them to the SNMP module when the next hop becomes invalid. For the PBR notifications to be sent correctly, you must also configure SNMP on the device. For more information about configuring SNMP, see the network management and monitoring configuration guide for the device.
# Enable SNMP notifications for PBR.
[Sysname] snmp-agent trap enable policy-based-route
