- 05-Network Connectivity
- 01-ARP commands
- 02-DHCP commands
- 03-DHCPv6 commands
- 04-GRE commands
- 05-IGMP snooping commands
- 06-IP addressing commands
- 07-Basic IP routing commands
- 08-IP performance optimization commands
- 09-IP forwarding basics commands
- 10-L2TP commands
- 11-LLDP commands
- 12-MAC address table commands
- 13-NAT commands
- 14-PPP commands
- 15-MLD snooping commands
- 16-VLAN commands
- 17-VLAN termination commands
- 18-Policy-based routing commands
- 19-Port isolation commands
- 20-Layer 2 forwarding commands
- 21-Loop detection commands
- 22-RIP commands
- 23-RIPng commands
- 24-IPv6 static routing commands
- 25-IPv6 policy-based routing commands
- 26-IPv6 basics commands
- 27-Static routing commands
- 28-Spanning tree commands
- 29-Tunneling commands
- 30-Ethernet link aggregation commands
- 31-DNS commands
- 32-Modem management commands
- 33-3G and 4G modem management commands
17-VLAN termination commands | 82.24 KB |
The following compatibility matrixes show the support of hardware platforms for VLAN termination:
Hardware series |
Model |
Product code |
VLAN termination compatibility |
WX1800H series |
WX1804H |
EWP-WX1804H-PWR-CN |
Yes |
WX2500H series |
WX2508H-PWR-LTE WX2510H WX2510H-F WX2540H WX2540H-F WX2560H |
EWP-WX2508H-PWR-LTE EWP-WX2510H-PWR EWP-WX2510H-F-PWR EWP-WX2540H EWP-WX2540H-F EWP-WX2560H |
Yes |
WX3000H series |
WX3010H WX3010H-X WX3010H-L WX3024H WX3024H-L WX3024H-F |
EWP-WX3010H EWP-WX3010H-X-PWR EWP-WX3010H-L-PWR EWP-WX3024H EWP-WX3024H-L-PWR EWP-WX3024H-F |
Yes: · WX3010H · WX3024H · WX3024H-F No: · WX3010H-L · WX3010H-X · WX3024H-L |
WX3500H series |
WX3508H WX3510H WX3520H WX3520H-F WX3540H |
EWP-WX3508H EWP-WX3510H EWP-WX3520H EWP-WX3520H-F EWP-WX3540H |
Yes |
WX5500E series |
WX5510E WX5540E |
EWP-WX5510E EWP-WX5540E |
No |
WX5500H series |
WX5540H WX5560H WX5580H |
EWP-WX5540H EWP-WX5560H EWP-WX5580H |
Yes |
Access controller modules |
LSUM1WCME0 EWPXM1WCME0 LSQM1WCMX20 LSUM1WCMX20RT LSQM1WCMX40 LSUM1WCMX40RT EWPXM2WCMD0F EWPXM1MAC0F |
No |
Hardware series |
Model |
Product code |
WX1800H series |
WX1804H WX1810H WX1820H WX1840H |
EWP-WX1804H-PWR EWP-WX1810H-PWR EWP-WX1820H EWP-WX1840H-GL |
Yes |
WX3800H series |
WX3820H WX3840H |
EWP-WX3820H-GL EWP-WX3840H-GL |
No |
WX5800H series |
WX5860H |
EWP-WX5860H-GL |
No |
second-dot1q
Use second-dot1q to enable QinQ termination on an interface, and specify the Layer 2 VLAN IDs of the VLAN-tagged packets that can be terminated by the interface.
Use undo second-dot1q to disable QinQ termination on an interface.
second-dot1q { vlan-id-list | any }
undo second-dot1q { vlan-id-list | any }
QinQ termination is disabled on an interface.
VLAN interface view
vlan-id-list: Specifies a space-separated list of up to 10 Layer 2 VLAN ID items. Each item specifies a Layer 2 VLAN ID or a range of Layer 2 VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
any: Specifies all values between 1 and 4094.
When you execute this command, the Layer 1 VLAN ID of VLAN-tagged packets that can be terminated by the interface is the interface number. This Layer 1 VLAN ID is not configurable.
# Configure VLAN-interface 10 to terminate VLAN-tagged packets with Layer 2 VLAN IDs in the range of 10 to 20.
[Sysname-Vlan-interface10] second-dot1q 10 to 20
[Sysname-Vlan-interface10] quit
# Configure VLAN-interface 12 to terminate VLAN-tagged packets with Layer 2 VLAN ID 100.
[Sysname] interface vlan-interface 12
[Sysname-Vlan-interface12] second-dot1q 100
[Sysname-Vlan-interface12] quit
# Configure VLAN-interface 100 to terminate VLAN-tagged packets with any Layer 2 VLAN IDs.
[Sysname-Vlan-interface100] second-dot1q any
The following table describes the configuration results:
VLAN interface |
Layer 1 VLAN ID of VLAN-tagged packets that the VLAN interface can terminate |
Layer 2 VLAN IDs of VLAN-tagged packets that the VLAN interface can terminate |
VLAN-interface 10 |
10 |
10–20 |
VLAN-interface 12 |
12 |
100 |
VLAN-interface 100 |
100 |
1–4094 |
vlan-termination broadcast enable
Use vlan-termination broadcast enable to enable an interface to transmit broadcasts and multicasts.
Use undo vlan-termination broadcast enable to disable an interface from transmitting broadcasts and multicasts.
An ambiguous Dot1q or QinQ termination-enabled interface drops broadcast and multicast packets.
VLAN interface view
IMPORTANT: This command affects system performance. If system performance is seriously affected by this command, execute the undo form of this command to remove the command configuration. |
.To transmit a broadcast or multicast packet, the interface starts a traversal over the VLAN IDs specified for ambiguous termination. It copies the packet and tags each copy with a VLAN ID, until all VLAN IDs in the specified range are traversed. For example, when ambiguous QinQ termination is configured, both layers of VLAN ID ranges are traversed.
Use this command when ambiguous Dot1q or QinQ termination is enabled on an interface.
Configure GigabitEthernet 1/0/1.10 to tag a multicast or broadcast packet with each VLAN tag in the range of 10 to 20.
# Enable Dot1q termination on GigabitEthernet 1/0/1.10 to terminate VLAN-tagged packets with outermost VLAN IDs in the range of 10 to 20.
[Sysname] interface gigabitethernet 1/0/1.10
[Sysname-GigabitEthernet1/0/1.10] vlan-type dot1q vid 10 to 20
# Enable GigabitEthernet 1/0/1.10 to transmit broadcast and multicast packets.
[Sysname-GigabitEthernet1/0/1.10] vlan-termination broadcast enable
Configure GigabitEthernet 1/0/1.10 to tag a multicast or broadcast packet with each Layer 1 VLAN ID and each Layer 2 VLAN ID. The Layer 1 and Layer 2 VLAN IDs are in the range of 300 to 400 and 500 to 600, respectively.
# Configure GigabitEthernet 1/0/1.10 to terminate VLAN-tagged packets whose Layer 1 and Layer 2 VLAN IDs are in the range of 300 to 400 and 500 to 600, respectively.
[Sysname-GigabitEthernet1/0/1.10] vlan-type dot1q vid 300 to 400 second-dot1q 500 to 600
[Sysname-GigabitEthernet1/0/1.10] vlan-termination broadcast enable.
Configure VLAN-interface 10 to tag a multicast or broadcast packet with two layers of VLAN IDs. The Layer 1 VLAN ID is 10. The Layer 2 VLAN ID is each VLAN ID in the range of 10 to 20.
# Enable VLAN-interface 10 to transmit broadcast and multicast packets.
[Sysname-Vlan-interface10] vlan-termination broadcast enable
vlan-termination broadcast ra
Use vlan-termination broadcast ra to enable an interface to transmit router advertisement (RA) multicast packets.
Use undo vlan-termination broadcast ra to disable an interface from transmitting RA multicast packets.
VLAN interface view
To transmit an RA multicast packet, the interface starts a traversal over the VLAN IDs specified for ambiguous termination. It copies the packet and tags each copy with a VLAN ID, until all VLAN IDs in the specified range are traversed. For example, when ambiguous QinQ termination is configured, both layers of VLAN ID ranges are traversed.
As a best practice, use this command to enable an ambiguous Dot1q or QinQ termination-enabled interface to transmit RA multicast packets on an IPv6 network. This command prohibits transmission of broadcast packets and other types of multicast packets, and consumes less CPU resources than the vlan-termination broadcast enable command.
Configure GigabitEthernet 1/0/1.10 to tag RA multicast packets with each VLAN tag in the range of 10 to 20.
# Enable GigabitEthernet 1/0/1.10 to transmit RA multicast packets.
[Sysname-GigabitEthernet1/0/1.10] vlan-termination broadcast ra
Configure GigabitEthernet 1/0/1.10 to tag RA multicast packets with each Layer 1 VLAN ID and each Layer 2 VLAN ID. The Layer 1 and Layer 2 VLAN IDs are in the range of 300 to 400 and 500 to 600, respectively.
Configure VLAN-interface 10 to tag RA multicast packets with two layers of VLAN IDs. The Layer 1 VLAN ID is 10. The Layer 2 VLAN ID is each VLAN ID in the range of 10 to 20.
# Enable VLAN-interface 10 to transmit RA multicast packets.
[Sysname-Vlan-interface10] vlan-termination broadcast ra
vlan-type dot1q default
Use vlan-type dot1q default to enable default termination on a subinterface.
Use undo vlan-type dot1q default to disable default termination on a subinterface.
Default termination is disabled on a subinterface.
This command enables the subinterface to process packets that cannot be terminated by other subinterfaces on the same main interface.
# Enable default termination on GigabitEthernet 1/0/1.1.
[Sysname-GigabitEthernet1/0/1.1] vlan-type dot1q default
[Sysname-GigabitEthernet1/0/1.1] quit
vlan-type dot1q untagged
Use vlan-type dot1q untagged to enable untagged termination on a subinterface.
Use undo vlan-type dot1q untagged to disable untagged termination on a subinterface.
Untagged termination is disabled on a subinterface.
This command enables the subinterface to process untagged packets.
# Enable untagged termination on GigabitEthernet 1/0/1.1.
[Sysname-GigabitEthernet1/0/1.1] vlan-type dot1q untagged
vlan-type dot1q vid
Use vlan-type dot1q vid to enable Dot1q termination on a subinterface, and specify the outermost VLAN IDs in the VLAN-tagged packets that can be terminated by the subinterface.
Use undo vlan-type dot1q vid to disable Dot1q termination on a subinterface.
vlan-type dot1q vid vlan-id-list
undo vlan-type dot1q vid vlan-id-list
Dot1q termination is disabled on a subinterface.
vlan-id-list: Specifies a space-separated list of up to 10 outermost VLAN ID items. Each item specifies an outermost VLAN ID or a range of outermost VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
The VLAN ID ranges specified by the vlan-id-list argument for different subinterfaces of a main interface cannot overlap.
# Configure GigabitEthernet 1/0/1.1 to terminate VLAN-tagged packets with outermost VLAN IDs in the range of 2 to 100.
[Sysname-GigabitEthernet1/0/1.1] vlan-type dot1q vid 2 to 100
vlan-type dot1q vid second-dot1q
Use vlan-type dot1q vid second-dot1q to enable QinQ termination on a subinterface, and specify the outermost two layers of VLAN IDs of VLAN-tagged packets that can be terminated by the subinterface.
Use undo vlan-type dot1q vid second-dot1q to disable QinQ termination on a subinterface.
vlan-type dot1q vid vlan-id-list second-dot1q { vlan-id-list | any }
undo vlan-type dot1q vid vlan-id-list second-dot1q { vlan-id-list | any }
QinQ termination is disabled on a subinterface.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN ID items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
L2VE subinterfaces support only unambiguous QinQ termination, and do not support the loose keyword.
Two subinterfaces of the same Ethernet interface cannot terminate packets that include the same two layers of VLAN IDs. If you configure the subinterfaces to terminate the same Layer 1 VLAN ID, make sure their Layer 2 VLAN ID ranges do not overlap. If you specify both any and vlan-id-list as the respective Layer 2 VLAN ID ranges of the subinterfaces, the any keyword does not include the VLAN IDs specified by vlan-id-list.
# Enable QinQ termination on the Layer 3 Ethernet subinterfaces, and configure each subinterface to terminate VLAN-tagged packets with the specified Layer 1 and Layer 2 VLAN IDs.
· Configure GigabitEthernet 1/0/1.1 to terminate VLAN-tagged packets whose Layer 1 and Layer 2 VLAN IDs are both 100.
[Sysname-GigabitEthernet1/0/1.1] vlan-type dot1q vid 100 second-dot1q 100
· Configure GigabitEthernet 1/0/1.2 to terminate VLAN-tagged packets with Layer 1 VLAN ID 100 and Layer 2 VLAN IDs in the range of 200 to 300.
[Sysname] interface gigabitethernet 1/0/1.2
[Sysname-GigabitEthernet1/0/1.2] vlan-type dot1q vid 100 second-dot1q 200 to 300
[Sysname-GigabitEthernet1/0/1.2] quit
· Configure GigabitEthernet 1/0/1.3 to terminate VLAN-tagged packets whose Layer 1 VLAN ID is 100 and Layer 2 VLAN ID is any value between 1 and 4094.
[Sysname] interface gigabitethernet 1/0/1.3
[Sysname-GigabitEthernet1/0/1.3] vlan-type dot1q vid 100 second-dot1q any
[Sysname-GigabitEthernet1/0/1.3] quit
· Configure GigabitEthernet 1/0/1.4 to terminate VLAN-tagged packets whose Layer 1 VLAN ID is 100 and Layer 2 VLAN ID is in the range of 500 to 600.
[Sysname] interface gigabitethernet 1/0/1.4
[Sysname-GigabitEthernet1/0/1.4] vlan-type dot1q vid 100 second-dot1q 500 to 600
[Sysname-GigabitEthernet1/0/1.4] quit
· Configure GigabitEthernet 1/0/1.5 to terminate VLAN-tagged packets whose Layer 1 VLAN ID is 200 and Layer 2 VLAN ID is in the range of 500 to 600.
[Sysname] interface gigabitethernet 1/0/1.5
[Sysname-GigabitEthernet1/0/1.5] vlan-type dot1q vid 200 second-dot1q 500 to 600
[Sysname-GigabitEthernet1/0/1.5] quit
· Configure GigabitEthernet 1/0/1.6 to terminate VLAN-tagged packets whose Layer 1 VLAN ID is in the range of 300 to 400 and Layer 2 VLAN ID is 100.
[Sysname] interface gigabitethernet 1/0/1.6
[Sysname-GigabitEthernet1/0/1.6] vlan-type dot1q vid 300 to 400 second-dot1q 100
[Sysname-GigabitEthernet1/0/1.6] quit
· Configure GigabitEthernet 1/0/1.7 to terminate VLAN-tagged packets whose Layer 1 and Layer 2 IDs are in the range of 300 to 400 and 500 to 600, respectively.
[Sysname] interface gigabitethernet 1/0/1.7
[Sysname-GigabitEthernet1/0/1.7] vlan-type dot1q vid 300 to 400 second-dot1q 500 to 600
[Sysname-GigabitEthernet1/0/1.7] quit
· Configure GigabitEthernet 1/0/1.8 to terminate VLAN-tagged packets with a Layer 1 VLAN ID in the range of 300 to 400 and any Layer 2 VLAN ID.
[Sysname] interface gigabitethernet 1/0/1.8
[Sysname-GigabitEthernet1/0/1.8] vlan-type dot1q vid 300 to 400 second-dot1q any
Layer 3 Ethernet subinterface |
Layer 1 VLAN IDs of VLAN-tagged packets that the subinterface can terminate |
Layer 2 VLAN IDs of VLAN-tagged packets that the subinterface can terminate |
GigabitEthernet 1/0/1.1 |
100 |
100 |
GigabitEthernet 1/0/1.2 |
100 |
200–300 |
GigabitEthernet 1/0/1.3 |
100 |
1–99, 101–199, 301–499, and 601–4094 |
GigabitEthernet 1/0/1.4 |
100 |
500–600 |
GigabitEthernet 1/0/1.5 |
200 |
500–600 |
GigabitEthernet 1/0/1.6 |
300–400 |
100 |
GigabitEthernet 1/0/1.7 |
300–400 |
500–600 |
GigabitEthernet 1/0/1.8 |
300–400 |
1–99, 101–499, and 601–4094 |
