| 00-Preface | 30.04 KB |
Preface
The H3C IMC User Access Manager Administrator Guide includes 36 chapters, which describe the management of access users and services on the IMC EIA, the generic configuration procedures, and the important parameters.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C IMC.
Conventions
This section describes the conventions used in the documentation.
Port numbering in examples
The port numbers in the documentation are for illustration only and might be unavailable on your device.
Command conventions
Convention |
Boldface |
Italic |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
NOTE: |
Documentation feedback
We appreciate your comments.
