H3C WLAN Products Safety & Configuration Cautions and Guidelines-6W100
HomeSupportConfigure & DeploySafety & Configuration Cautions and GuidelinesH3C WLAN Products Safety & Configuration Cautions and Guidelines-6W100
00-Preface
00-Preface 101.66 KB
Preface
This document describes important information that if not understood or followed can result in undesirable situations, including bodily injury, hardware damage, service interruption, or service anomalies. It contains hardware safety guidelines, CLI-based and Web-based configuration cautions and guidelines. Before you work on or configure your device, read the information in this document carefully.
·     Audience.
·     Prerequisites
·     Conventions
·     Documentation feedback
Audience
·     Network planners.
·     Network administrators.
This document is not restricted to specific software or hardware versions. If a conflict occurs between this document and a product-specific document, the product-specific document overrides.
This document provides only generic technical information, some of which might not apply to your devices.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
We appreciate your comments.
