14-Telemetry Configuration Guide
HomeSupportSwitchesH3C S12500G-AF Switch SeriesConfigure & DeployConfiguration GuidesH3C S12500G-AF Switch Series Configuration Guides-Release759X-6W10014-Telemetry Configuration Guide
02-INT configuration
02-INT configuration 212.71 KB
Configuring INT
About INT
The Inband Telemetry (INT) feature is a network monitoring technology designed to collect data from the device. The device sends data to a collector in real time for device performance monitoring and network monitoring.
INT network components
As shown in Figure 1, an INT network contains the following INT-enabled devices: one entry node, one transit node, and one exit node.
Figure 1 INT network
INT packet formats
INT generates INT packets by mirroring original packets, inserting INT headers, and collecting data. The INT header and collected data are in the original IP header. Therefore, an INT packet and its original packet have the same IP header and forwarding path.
The device supports generating INT packets from TCP packets, UDP packets, and VXLAN packets. Figure 2 shows the INT packet formats. The 64 most significant bits of the INT header are fixed at 0xaaaaaaaabbbbbbbb, which are the INT mark.
Figure 2 INT packet formats
How INT works
INT supports common INT and flexible INT. The two types of INT have the following differences:
·     Common INT—Each node needs to be configured with an INT role on its input interface: ingress, transit, and egress. Traffic flows are defined on the entry node by using a QoS policy. INT flows are automatically identified on the transit node and exit node and processed according to configured actions. On each input interface in the path, you can perform INT processing only on the flows defined on the entry node.
·     Flexible INT—No device role needs to be configured on each node. On each node, an ACL can be used to define a flow and an action used to take on the defined flow. For the same flow, the original packets are matched on the entry node, and the INT packets are matched on the transit node and exit node. You can define multiple flows on an interface and take different actions on different flows.
Common INT is easy to configure and is recommended. Use flexible INT only when you need to process multiple flows on an interface.
Common INT
As shown in Figure 3, the nodes in common INT perform the following functions:
1.     On the entry node, the ingress port uses a QoS policy to sample matching packets, and mirrors sampled packets to the INT processor. Then, the INT processor adds an INT header to the INT packet and loops it back to the ingress port. The ingress port identifies the looped-back INT packet according to the INT mark, adds collected data to it, and forwards it to the egress port. The egress port adds collected data to the INT packet and sends it to the transit node.
2.     On the transit node, the ingress port identifies the INT packet according to the INT mark, adds collected data to it, and forwards it to the egress port. The egress port adds collected data to the INT packet, and sends it to the exit node.
3.     On the exit node, the ingress port identifies the INT packet according to the INT mark, adds collected data to the INT packet, encapsulates the INT packet with the configured parameters, and sends it to the collector.
Flexible INT
As shown in Figure 3, the nodes in flexible INT perform the following functions:
1.     On the entry node, the ingress port uses an ACL to sample matching packets, and mirrors sampled packets to the INT processor. Then, the INT processor adds an INT header to the INT packet and loops it back to the ingress port. The ingress port identifies the looped-back INT packet according to an ACL and adds collected data to it, and forwards it. The egress port adds collected data to the INT packet and sends it to the transit node.
2.     On the transit node, the ingress port uses an ACL to identify INT packets, adds collected data to INT packets, and forwards them to the egress port. The egress port adds collected data to INT packets and sends them to the exit node.
3.     On the exit node, the ingress port uses an ACL to sample matching original packets, and mirrors sampled packets to the INT processor. The INT processor encapsulates the INT packets and sends them to the collector.
Figure 3 INT network diagram
Restrictions and guidelines: INT configuration
Common INT can be deployed in both underlay and overlay networks. Flexible INT can only be deployed in underlay networks.
As a best practice, configure the transit node and exit node before configuring the entry node.
In flexible INT, the interface role setting in interface view has higher priority over that in system view. In common INT, if the interface role setting is configured in both views:
·     The interface role setting in system view takes effect on INT packets with the destination IP address as the IP address of the local device.
·     The interface role setting in interface view takes effect on INT packets that need to be forwarded.
To ensure timestamp accuracy, you must configure PTP for INT. The exit node ensures only nanosecond accuracy for added timestamps.
INT can collect information about only unicast packets of TCP, UDP, and VXLAN.
INT is supported only on Layer 2 and Layer 3 Ethernet interfaces on SH interface modules.
·     Layer 3 Ethernet interfaces do not support the telemetry ifa loopback command.
·     Layer 3 Ethernet subinterfaces inherit the INT settings of their main interface.
An interface cannot act as the ingress port in both an underlay network and an overlay network at the same time.
INT is not supported in an overlay network that uses VXLAN over IPv6 or VXLAN-DCI over IPv6 tunnels.
In an overlay network, INT is not supported on a VTEP if multiple ARP entries of a VXLAN tunnel have different MAC addresses or VLAN IDs but have the same transport-facing interface as the outgoing interface.
In an overlay network, you must disable the static source check feature on the ingress port by using the undo mac-address static source-check enable command to ensure normal INT traffic forwarding.
Make sure the source IP address and destination IP addresses specified in the telemetry ifa collector command are reachable.
For INT to work correctly, do not specify an IP address in the form of 255.255.*.* or *.*.255.255 as the device ID. The asterisk (*) represents any number in the range of 0 to 255.
For INT to work correctly, do not specify the interface connecting the exit node to the collector as the outgoing interface for a multiport ARP entry. For more information about configuring a multiport ARP entry, see ARP in Layer 3—IP Services Configuration Guide.
The sampler used for INT must be in random mode. For information about configuring a sampler, see Network Management and Monitoring Configuration Guide.
Configuring common INT
Configuring the exit node
1.     Specify a device ID.
a.     Enter system view.
b.     Specify a device ID for the exit node.
telemetry ifa device-id address
By default, the exit node does not have a device ID.
2.     Configure the interface role.
¡     Execute the following commands in sequence to specify the interface as the egress interface:
telemetry ifa role egress
After an interface is configured as an egress interface, the interface automatically identifies INT packets and takes the corresponding action on them.
¡     Specify the interface role as for all interfaces globally.
telemetry ifa role transit-egress
After an interface is configured as a transit-egress interface, it acts as an egress interface for INT packets with the destination IP address as the IP address of the local device. The interface acts as a transit interface for INT packets that need to be forwarded.
By default, no interface role is configured.
3.     Configure addressing parameters to encapsulate in INT packets sent to the collector.
telemetry ifa collector source source-address destination dest-address source-port port destination-port port [ vlan vlan-id ]
By default, no addressing parameters are configured for INT packets.
4.     Enable INT globally.
telemetry ifa global enable
By default, INT is enabled globally.
Configuring the transit node
b.     Specify a device ID for the transit node.
By default, the transit node does not have a device ID.
¡     Execute the following commands in sequence to specify the interface as the transit interface:
After an interface is configured as a transit interface, the interface automatically identifies INT packets and takes the corresponding action on them.
¡     Specify the interface role as transit-egress for all interfaces globally.
3.     Enable INT globally.
Configuring the entry node
b.     Specify a device ID for the entry node.
By default, the entry node does not have a device ID.
2.     Configure the ingress interface.
a.     Enter interface view.
b.     Specify the interface as the ingress interface.
telemetry ifa role ingress
By default, an interface is not used as the ingress interface.
c.     Return to system view
3.     Enable internal loopback on an interface.
b.     Enable internal loopback on the interface.
By default, internal loopback is disabled on an interface.
Enable internal loopback on any interface that is in the same port group as the ingress port. To view port grouping information, execute the display qos-acl resource command. Ports under the same Interfaces field are in the same port group.
4.     Mirror packets to the INT processor.
a.     Execute the following commands in sequence to define a traffic class:
if-match match-criteria
For more information about the if-match command, see QoS commands in ACL and QoS Command Reference.
b.     Execute the following commands in sequence to define a traffic behavior:
Underlay network:
mirror-to ifa-processor [ sampler sampler-name ]
Overlay network:
mirror-to ifa-processor [ sampler sampler-name ] vxlan
For more information about the mirror-to command, see mirroring commands in Network Management and Monitoring Command Reference.
c.     Execute the following commands in sequence to define a QoS policy:
qos [ mirroring ] policy policy-name
classifier classifier-name behavior behavior-name
d.     Execute the following commands in sequence to apply the QoS policy to the inbound direction of an interface:
qos apply [ mirroring ] policy policy-name inbound
5.     Enable INT globally.
Configuring flexible INT
Flexible INT tasks at a glance
To configure flexible INT, perform the following tasks:
1.     Configuring the exit node
¡     Configuring a device ID
¡     Configuring the interface role
¡     Configuring addressing parameters and INT status
2.     Configuring the transit node
¡     Configuring INT status
3.     Configuring the entry node
Perform either of the following tasks:
·     Configure the interface role as egress for a single interface.
a.     Create a user-defined ACL and enter user-defined ACL view.
For information about the acl configuration command, see ACL commands in ACL and QoS Command Reference.
b.     Configure a rule for the user-defined ACL.
For information about the rule (user-defined ACL view) configuration command, see ACL commands in ACL and QoS Command Reference.
If the entry node uses an ACL when mirroring packets to the INT processor, the ACLs used for any other action on any node must have the same identification attributes plus an attribute to identify the INT flag. The identification attributes and the attribute to identify the INT flag must be in the same rule. For example, if the rule in the ACL used on the entry node is rule permit tcp source 10.0.0.3 0, the rule in the ACL used for any other action must be rule permit tcp source 10.0.0.3 0 ifa.
c.     Return to system view.
d.     Enter interface view.
e.     Configure the action of mirroring incoming INT packets on the ingress port to the INT processor and dropping the original INT packets.
telemetry ifa ifa-id acl user-defined { acl-number | name acl-name } action mirror-to-processor drop
By default, no action is configured.
f.     Return to system view.
·     Configure the interface role as transit-egress for all interfaces.
1.     Configure addressing parameters to encapsulate in INT packets sent to the collector.
2.     Enable INT globally.
·     Configure the interface role as transit for a single interface.
a.     ‍‍Create a user-defined ACL and enter user-defined ACL view.
e.     Configure the action of adding collected data to INT packets.
telemetry ifa ifa-id acl user-defined { acl-number | name acl-name } action add-metadata
2.     Configure the interface role as transit-egress for all interfaces.
1.     Enable INT globally.
2.     Mirror original packets on the ingress port to the INT processor.
a.     Create an IPv4, Layer 2, or user-defined ACL and enter ACL view.
b.     Configure a rule for the ACL.
For information about the rule configuration command, see ACL commands in ACL and QoS Command Reference.
e.     Configure the action of mirroring original packets on the ingress port to the INT processor.
telemetry ifa ifa-id [ acl [ ipv6 | mac | user-defined ] { acl-number | name acl-name } ] action mirror-to-processor [ sampler sampler-name ]
4.     Add collected data to local loopback traffic on the ingress port.
e.     Configure the action of adding collected data to local loopback traffic.
telemetry ifa ifa-id acl user-defined { acl-number | name acl-name } local-loopback action add-metadata
Enabling global INT packet dropping
Perform this task if you do not want to send INT packets to the downstream node.
2.     Enable global INT packet dropping.
telemetry ifa global packet-drop
By default, global INT packet dropping is disabled.
Display and maintenance commands for INT
Display information about QoS policies applied to interfaces (see ACL and QoS Command Reference).
In standalone mode:
display qos [ mirroring ] policy interface [ interface-type interface-number ] [ slot slot-number ] inbound
In IRF mode:
display qos [ mirroring ] policy interface [ interface-type interface-number ] [ chassis chassis-number slot slot-number ] inbound
Display INT configuration.
display telemetry ifa
INT configuration examples
Example: Configuring common INT
As shown in Figure 4, configure common INT to test the link delay.
Figure 4 Network diagram
1.     Assign IP addresses to interfaces and configure routes. Make sure the network connections are available. (Details not shown.)
2.     Configure Device C:
# Specify 10.0.0.3 as the device ID of the exit node.
[DeviceC] telemetry ifa device-id 10.0.0.3
# Specify HundredGigE 3/0/1 as the egress interface.
[DeviceC] interface hundredgige 3/0/1
[DeviceC-HundredGigE3/0/1] telemetry ifa role egress
[DeviceC-HundredGigE3/0/1] quit
# Configure addressing parameters to encapsulate in INT packets sent to the collector.
[DeviceC] telemetry ifa collector source 20.0.0.2 destination 30.0.0.1 source-port 12 destination-port 14
# Enable INT globally.
[DeviceC] telemetry ifa global enable
3.     Configure Device B:
# Specify 10.0.0.2 as the device ID of the transit node.
[DeviceB] telemetry ifa device-id 10.0.0.2
# Specify HundredGigE 3/0/1 as the transit interface.
[DeviceB] interface hundredgige 3/0/1
[DeviceB-HundredGigE3/0/1] telemetry ifa role transit
[DeviceB-HundredGigE3/0/1] quit
[DeviceB] telemetry ifa global enable
4.     Configure Device A:
# Specify 10.0.0.1 as the device ID of the entry node.
[DeviceA] telemetry ifa device-id 10.0.0.1
# Specify HundredGigE 3/0/1 as the ingress interface.
[DeviceA] interface hundredgige 3/0/1
[DeviceA-HundredGigE3/0/1] telemetry ifa role ingress
[DeviceA-HundredGigE3/0/1] quit
# Enable internal loopback on HundredGigE 3/0/3.
[DeviceA] interface hundredgige 3/0/3
[DeviceA-HundredGigE3/0/3] telemetry ifa loopback
[DeviceA-HundredGigE3/0/3] quit
# Create a sampler named samp in random sampling mode, and set the sampling rate to 8. One packet from 256 packets is selected.
[DeviceA] sampler samp mode random packet-interval n-power 8
# Create a traffic class named classifier1, and use destination MAC address a08c-fdd7-fd99 as the match criterion in the traffic class.
[DeviceA] traffic classifier classifier1
[DeviceA-classifier-classifier1] if-match destination-mac a08c-fdd7-fd99
[DeviceA-classifier-classifier1] quit
# Create a traffic behavior named behavior1, and configure the action of mirroring traffic to the INT processor.
[DeviceA] traffic behavior behavior1
[DeviceA-behavior-behavior1] mirror-to ifa-processor sampler samp
[DeviceA-behavior-behavior 1] quit
# Create a QoS policy named ifa1, and associate traffic class classifier1 with traffic behavior behavior1 in the QoS policy.
[DeviceA] qos policy ifa1
[DeviceA-qospolicy-ifa1] classifier classifier1 behavior behavior1
[DeviceA-qospolicy-ifa1] quit
# Apply QoS policy ifa1 to the incoming traffic of HundredGigE 3/0/1.
[DeviceA-HundredGigE3/0/1] qos apply policy ifa1 inbound
[DeviceA] telemetry ifa global enable
Verify the configuration
# Verify the configuration on Device A.
[DeviceA] display qos policy interface hundredgige 3/0/1 inbound
Interface: HundredGigE3/0/1
  Direction: Inbound
  Policy: ifa1
   Classifier: classifier1
     Operator: AND
     Rule(s) :
      If-match destination-mac a08c-fdd7-fd99
     Behavior: behavior1
      Mirroring:
        Mirror to the ifa-processor sampler samp
[DeviceA] display telemetry ifa
  Telemetry ifa status          : Enabled
  Telemetry ifa packet-drop     : Disabled
  Telemetry ifa device-id       : 10.0.0.1
  Telemetry ifa role:
    HundredGigE3/0/1: Ingress
  Telemetry ifa loopback:
    HundredGigE3/0/3
# Verify the configuration on Device B.
[DeviceB] display telemetry ifa
  Telemetry ifa device-id       : 10.0.0.2
  Telemetry ifa role:
    HundredGigE3/0/1: Transit
# Verify the configuration on Device C.
[DeviceC] display telemetry ifa
  Telemetry ifa device-id       : 10.0.0.3
  Telemetry ifa role:
    HundredGigE3/0/1: Egress
  Telemetry ifa collector:
    Source IP: 20.0.0.2
    Destination IP: 30.0.0.1
    Source-port: 12
    Destination-port: 14
Example: Configuring flexible INT
As shown in Figure 5, configure flexible INT to send the INT packets to the collector.
Figure 5 Network diagram
<DeviceC> system-view
# Create user-defined ACL 5000, and configure a rule to match INT packets with source IP address 192.168.1.2.
[DeviceC] acl user-defined 5000
[DeviceC-acl-user-5000] rule permit tcp source 192.168.1.2 0 ifa
[DeviceC-acl-user-5000] rule permit udp source 192.168.1.2 0 ifa
[DeviceC-acl-user-5000] quit
# Configure the action of mirroring incoming INT packets on HundredGigE 3/0/1 to the INT processor and dropping the original INT packets.
[DeviceC-HundredGigE3/0/1] telemetry ifa 1 acl user-defined 5000 action mirror-to-processor drop
[DeviceB] acl user-defined 5000
[DeviceB-acl-user-5000] rule permit tcp source 192.168.1.2 0 ifa
[DeviceB-acl-user-5000] rule permit udp source 192.168.1.2 0 ifa
[DeviceB-acl-user-5000] quit
# Configure the action of mirroring INT packets on HundredGigE 3/0/1 to the INT processor.
[DeviceB-HundredGigE3/0/1] telemetry ifa 1 acl user-defined 5000 action add-metadata
# Create IPv4 basic ACL 2000, and configure a rule to match packets with source IP address 192.168.1.2.
[DeviceA] acl basic 2000
[DeviceA-acl-ipv4-basic-2000] rule permit source 192.168.1.2 0
# Configure the action of mirroring original packets on HundredGigE 3/0/1 to the INT processor.
[DeviceA-HundredGigE3/0/1] telemetry ifa 2 acl 2000 action mirror-to-processor sampler samp
[DeviceA] acl user-defined 5000
[DeviceA-acl-user-5000] rule permit tcp source 192.168.1.2 0 ifa
[DeviceA-acl-user-5000] rule permit udp source 192.168.1.2 0 ifa
[DeviceA-acl-user-5000] quit
# Configure the action of adding collected data to local loopback traffic.
[DeviceA-HundredGigE3/0/1] telemetry ifa 3 acl user-defined 5000 local-loopback action add-metadata
  Telemetry ifa action:
    HundredGigE3/0/1:
      Telemetry ifa 1 acl 2000 action mirror-to-processor sampler samp
      Telemetry ifa 2 acl user-defined 5000 local-loopback action add-metadata
    HundredGigE3/0/3
    HundredGigE3/0/1:
      Telemetry ifa 1 acl user-defined 5000 action add-metadata
    HundredGigE3/0/1:
      Telemetry ifa 1 acl user-defined 5000 action mirror-to-processor drop
    Source IP: 20.0.0.2
    Source-port: 12
