01-Fundamentals Configuration Examples
HomeSupportSwitchesS10500X SeriesConfigure & DeployConfiguration ExamplesH3C S10500X Switch Series Configuration Examples-R7595-6W10001-Fundamentals Configuration Examples
04-H3C_Software_Patching_Examples
04-H3C_Software_Patching_Examples 54.84 KB
H3C Software Patching Examples
Software version: Release 7595
Document version: 6W100-20201031
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides software patching examples that use ISSU install commands.
This document assumes that you have basic knowledge of ISSU.
Example: Patching software
As shown in Figure 1, the device and the TFTP server can reach each other. The device has one active MPU (slot 0) and one standby MPU (slot 1). The MPUs are running boot image BOOT-R7595 and system image SYSTEM-R7595.
Use patch image file SYSTEM-R7595H01.bin to fix bugs without rebooting the device.
Figure 1 Network diagram
When you patch software, follow these restrictions and guidelines:
·     The first time you install patch images, you must start with the active MPU. For subsequent patch installations, you must start with the standby MPU.
·     The patch image version must match the device model and Comware version. For example, to fix bugs in R7595, you must use SYSTEM-R7595H01.bin.
Procedures
# Download patch image file SYSTEM-R7595H01.bin from the TFTP server to the root directory on the active MPU.
<Sysname> tftp 2.2.2.2 get SYSTEM-R7595H01.bin
Press CTRL+C to abort.
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 25.2M    0 25.2M    0     0   210k      0 --:--:--  0:02:02 --:--:--  209k
# Activate the patch images on the active MPU and standby MPU.
<Sysname> install activate patch flash:/SYSTEM-R7595H01.bin slot 0
This operation maybe take several minutes, please wait.............Done.
<Sysname> install activate patch flash:/SYSTEM-R7595H01.bin slot 1
The patch images take effect immediately after they are activated.
# For the patch images to take effect after a reboot, commit the software changes.
<Sysname> install commit
# Verify that the patch images have been activated successfully.
<Sysname> display install active
Active packages on slot 0:
  flash:/BOOT-R7595.bin
  flash:/SYSTEM-R7595.bin
Active packages on slot 1:
Active packages on slot 3:
Active packages on slot 14:
# Verify that the patch image file has been added to the main startup software image list so the images can take effect after a reboot.
<Sysname> display install committed
Committed packages on slot 0:
Committed packages on slot 1:
Configuration files
The system does not save the commands used in the configuration procedures to a configuration file.
Related documentation
·     H3C S10500X Switch Series Fundamentals Command Reference-R759X
·     H3C S10500X Switch Series Fundamentals Configuration Guide-R759X
