16-EPON Configuration Examples
HomeSupportSwitchesS7500X SeriesConfigure & DeployConfiguration ExamplesH3C S7500X Switch Series Configuration Examples-R7595-6W10016-EPON Configuration Examples
01-H3C EPON Configuration Examples
01-H3C EPON Configuration Examples 98.76 KB
Software version: Release 7595
Document version: 6W100-20201031
Copyright © 2020 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
This document provides examples of configuring Ethernet Passive Optical Network (EPON).
EPON combines the benefits of Ethernet and PON, and is applicable to remote broadband IP services.
This document assumes that you have basic knowledge of EPON.
Example: Configuring the EPON video monitoring service (VLAN tag mode)
As shown in Figure 1, a community uses ONUs to connect video monitoring cameras. Configure EPON to meet the following requirements:
·     Use the OLT to remotely manage the ONUs.
·     The data from cameras is managed in a separate VLAN in the EPON network, and can be transmitted to an external IP network.
·     To guarantee video quality, expand the maximum uplink bandwidth to 1 Gbps and perform flow control on the video traffic.
Figure 1 Network diagram
Analysis
To meet the requirements, perform the following tasks on the OLT:
·     Bind ONUs to the OLT, and then remotely manage ONUs through ONU interfaces. This section uses ONU 1/0/1:1 to manage ONU1 as an example.
·     Use VLAN 100 as the management VLAN of ONUs.
¡     Configure the downlink packets from the OLT interface and its ONU interfaces to carry VLAN tag 100.
¡     To Telnet to ONUs, create VLAN interface 100 on the OLT for the management VLAN of ONUs.
·     Use VLAN 200 as the video service VLAN.
¡     To tag the data packets from cameras with VLAN tag 200, configure the VLAN tag mode on the UNIs connecting to cameras.
¡     To transmit the video packets in VLAN 200 to an external network, assign the uplink interface XGE 1/0/25 to VLAN 200.
Procedures
1.     Bind ONUs to the OLT.
# Set the device name for the OLT.
[Sysname] sysname OLT
# Bind the two ONUs to ONU interfaces on the OLT. This example uses automatic binding. ONU interfaces ONU 1/0/1:1 and ONU 1/0/1:2 will be automatically created and bound to ONUs separately.
[OLT] ftth
[OLT-ftth] onu bind auto slot 1
[OLT-ftth] quit
2.     Configure the management VLAN for ONUs.
# Create VLAN 100 on the OLT. Create VLAN-interface 100, and assign IP address 172.16.42.254 to the VLAN interface. The IP address will be used as the gateway IP address of ONUs.
[OLT] vlan 100
[OLT-vlan100] quit
[OLT] interface vlan-interface 100
[OLT-Vlan-interface100] ip address 172.16.42.254 24
[OLT-Vlan-interface100] quit
# Configure OLT 1/0/1 as a hybrid port, and assign it to VLAN 100 as a tagged member.
[OLT] interface olt1/0/1
[OLT-Olt1/0/1] port link-type hybrid
[OLT-Olt1/0/1] port hybrid vlan 100 tagged
[OLT-Olt1/0/1] quit
# Configure ONU 1/0/1:1 as a trunk port and assign it to all VLANs.
[OLT] interface onu1/0/1:1
[OLT-Onu1/0/1:1] port link-type trunk
[OLT-Onu1/0/1:1] port trunk permit vlan all
# Configure VLAN 100 as the management VLAN for ONU1 bound to ONU 1/0/1:1. Bring up management VLAN interface 100, assign IP address 172.16.42.24 to it, and specify the gateway address as the IP address of VLAN 100 on the OLT.
[OLT-Onu1/0/1:1] management-vlan 100
[OLT-Onu1/0/1:1] undo shutdown management-vlan-interface
[OLT-Onu1/0/1:1] ip address 172.16.42.24 24 gateway 172.16.42.254
[OLT-Onu1/0/1:1] quit
3.     Configure the video service VLAN:
# Create VLAN 200, which is to be used as the video service VLAN. Set the VLAN operation mode to tag mode on UNI 1 on ONU1. Then, packets received on UNI 1 will be tagged with VLAN 200.
[OLT] vlan 200
[OLT-vlan200] quit
[OLT-Onu1/0/1:1] uni 1 vlan-mode tag pvid 200
# Assign the interfaces that video packets pass through (including ONU 1/0/1:1, OLT 1/0/1, and uplink interface XGE 1/0/25 connecting to the external network) to VLAN 200. ONU 1/0/1:1 has been assigned to all VLANs, so you do not need to assign it to VLAN 200 again.
[OLT-Olt1/0/1] port hybrid vlan 200 tagged
[OLT-Olt1/0/1] quit
[OLT] interface ten-gigabitethernet 1/0/25
[OLT-Ten-GigabitEthernet1/0/25] port link-type hybrid
[OLT-Ten-GigabitEthernet1/0/25] port hybrid vlan 200 tagged
[OLT-Ten-GigabitEthernet1/0/25] quit
4.     Configure the maximum uplink bandwidth and flow control
# Set the maximum uplink bandwidth to 1000000 kbps on ONU 1. Because the maximum-bandwidth argument is measured in 64 kbps, set the maximum-bandwidth argument to 1000000/64=15625.
[OLT-Onu1/0/1:1] upstream-sla maximum-bandwidth 15625
The maximum-bandwidth of upstream is 1000000 kbps
# Enable flow control on UNI 1 to avoid packet loss caused by congestion.
[OLT-Onu1/0/1:1] uni 1 flow-control
You also need to enable flow control on the peer of the UNI, the camera connecting to the UNI.
1.     Display information about VLAN 200 on the OLT.
<OLT> display vlan 200
 VLAN ID: 200
 VLAN type: Static
 Description: VLAN 0200
 Tagged ports:
    Olt1/0/1
    Onu1/0/1:1
 Untagged ports: None
The output shows that the interfaces that video packets pass through are assigned to VLAN 200.
When untagged packets are received on UNI 1 of ONU1, packets carrying VLAN tag 200 can be received on XGE 1/0/25 of the OLT.
2.     Verify that you can Telnet to the ONU through the IP address of the ONU's management VLAN interface 100.
<OLT> telnet 172.16.42.24
Trying 172.16.42.24 ...
Press CTRL+K to abort
Connected to 172.16.42.24 ...
Login: admin
Password:
Copyright (c) 2004-2019 New H3C Technologies Co., Ltd. All rights reserved.
H3C ET354 uptime is 01:13:40 11 days
Hardware version : A
Vendor ID        : H3C
Onu Model        : 3540
Build time       : 2019-04-24 13:48:28
Internal version : V100R001B01D016SP01
Configuration files
 sysname OLT
vlan 100
vlan 200
ftth
interface Vlan-interface100
 ip address 172.16.42.254 255.255.255.0
interface Ten-GigabitEthernet1/0/25
 port hybrid vlan 1 untagged
interface Olt1/0/1
 using onu 1
 port hybrid vlan 100 200 tagged
interface Onu1/0/1:1
 bind onu-id 9428-2ec3-61b6
 management-vlan 100
 ip address 172.16.42.24 255.255.255.0 gateway 172.16.42.254
 uni 1 flow-control
Example: Configuring an EPON campus wireless network (VLAN trunk mode)
As shown in Figure 2, a campus has multiple APs deployed to provide wireless network access services. Configure EPON to meet the following requirements:
·     Use an AC to manage the attached APs through an EPON network.
·     Each AP can use VLANs 1000 through 2000 to isolate the network accessing traffic. Packets from these VLANs can be forwarded to Internet through the EPON network.
Figure 2 Network diagram
Analysis
·     Bind ONUs to the OLT.
·     Configure VLAN 100 as the management VLAN. Assign the interfaces along the management packet transmission path (AC-> OLT-> ONU-> AP) to VLAN 100.
·     Configure VLANs 1000 through 2000 as the network access service VLANs.
¡     Because APs have added VLAN tags to packets, you only need to set the VLAN operation mode to trunk mode on ONU UNIs connecting to APs and allow packets from these VLANs to pass through. This section uses ONU 1/0/1:1 to manage ONU1 as an example.
¡     To transmit the packets from these VLANs to Internet, assign the uplink interface XGE 1/0/25 to VLANs 1000 through 2000.
Procedures
[OLT] ftth
[OLT-ftth] quit
2.     Configure the management VLAN.
# Create VLAN 100 on the OLT. The VLAN is to be used as the management VLAN.
[OLT] vlan 100
[OLT-vlan100] quit
# Configure GE 1/0/18 (interface connecting to the AC) and OLT 1/0/1 (interface connecting to ONUs) as hybrid ports and assign them to VLAN 100 as tagged members.
[OLT] interface gigabitethernet 1/0/18
[OLT-GigabitEthernet1/0/18] port link-type hybrid
[OLT-GigabitEthernet1/0/18] port hybrid vlan 100 tagged
[OLT-GigabitEthernet1/0/18] quit
[OLT-Olt1/0/1] quit
3.     Configure the network access service VLANs:
# Create network access service VLANs 1000 through 2000.
[OLT] vlan 1000 to 2000
[OLT-vlan200] quit
# Set the VLAN operation mode to trunk on UNI 1 of ONU1. Specify the PVID as 100, so that the untagged management packets from APs will be tagged with VLAN 100. Permit packets from network access service VLANs 1000 through 2000 to pass through.
[OLT-Onu1/0/1:1] uni 1 vlan-mode trunk pvid 100 1000 to 2000
# Assign the interfaces that network accessing packets pass through (including ONU 1/0/1:1, OLT 1/0/1, and uplink interface XGE 1/0/25 connecting to the external network) to VLANs 1000 through 2000. ONU 1/0/1:1 has been assigned to all VLANs, so you do not need to assign it to VLAN 200 again.
[OLT-Olt1/0/1] port hybrid vlan 1000 to 2000 tagged
[OLT-Olt1/0/1] quit
[OLT-Ten-GigabitEthernet1/0/25] port hybrid vlan 1000 to 2000 tagged
1.     When the AC and an AP are on the same network segment, they can ping each other, and the AP can register with the AC.
2.     When an AP sends packets from VLANs 1000 through 2000 to the ONU, uplink interface XGE 1/0/25 on the OLT can receive these packets.
Configuration profiles
 sysname OLT
vlan 100
vlan 1000 to 2000
ftth
interface GigabitEthernet1/0/18
 combo enable copper
interface Olt1/0/1
 using onu 1
 port hybrid vlan 100 1000 to 2000 tagged
Related documentation
·     H3C S7500X Switch Series EPON Configuration Guide-R759X
·     H3C S7500X Switch Series EPON Command Reference-R759X
