H3C S12500R-2L Switch Router Installation Guide-6W102
HomeSupportSwitchesS12500R SeriesInstall & UpgradeInstallation GuidesH3C S12500R-2L Switch Router Installation Guide-6W102
09-Appendix C LEDs
09-Appendix C LEDs 256.72 KB
1 Appendix C LEDs
Table1-1 lists the LEDs available for the device.
Table1-1 LEDs at a glance
LEDs
SEU LEDs:
·     Management Ethernet port LEDs
·     Fan tray status LED
·     Power supply status LED
·     Module status LEDs
·     SEU active/standby status LED
Interface module LEDs
Fan tray LEDs
Power supply LEDs
SEU LEDs
Figure1-1 LSXM1SUP02LR1 SEU LEDs
 (1) Fan tray status LED (FAN)
(2) Power supply status LED (PWR)
(3) Module status LED (SLOT)
(4) SEU active/standby status LED (ACTIVE)
(5) SFP management Ethernet port LED
(6) 10/100/1000BASE-T management Ethernet port LED
The module status LED for slot 4 is reserved for future use.
The SEU provides a LED for the 10/100/1000BASE-T management Ethernet port to indicate the link status and data forwarding status of the port.
Table1-2 10/100/1000BASE-T management Ethernet port LED description
Status
Flashing
The port is receiving or sending data.
On
A link is present on the port.
Off
No link is present on the port.
The SEU provides a LED for the SFP management Ethernet port to indicate the link status and data forwarding status of the port.
Table1-3 SFP management Ethernet port LED description
Status
Flashing
On
Off
Fan tray status LED
The SEU provides a fan tray status LED to indicate the status of the fan trays.
Table1-4 Fan tray status LED description
Status
Steady green
All fan trays are operating correctly.
Steady red
A fan tray has failed or no fan tray is present.
Off
The device is not powered on.
The SEU provides a power supply status LED to indicate the status of the power supplies.
Table1-5 Power supply status LED description
Status
Steady green
All power supplies are operating correctly.
Steady red
A minimum of one power supply is faulty.
Off
Module status LEDs
The SEU provides a status LED for each module slot to indicate the status of the module.
The SEU and interface module slot numbers are marked at the left and right sides of the slots.
Table1-6 Module LED description
Status
Flashing green (0.5 Hz)
The module is operating correctly.
Flashing green (4 Hz)
The module is loading software.
If the LED keeps in this state, the software versions of the device and the module do not match.
Steady green
The module is starting up.
Steady red
A high severity alarm has occurred on the module or the module is faulty.
Flashing red (0.25 Hz)
The temperature of the module is higher than the warning threshold or lower than the low-temperature threshold.
Off
The module is not present or the module is faulty.
The SEU has one ACTIVE LED to indicate the active or standby status of the SEU.
Table1-7 SEU ACTIVE LED description
LED status
On
The SEU is active.
Off
·     The SEU is in standby status.
·     The SEU is faulty. Examine the module status LED for the SEU to further determine the SEU status.
The interface modules provide one LED for each QSFP28 port to indicate the link status and data receiving/transmitting status of the QSFP28 ports.
Table1-8 QSFP28 port LED description
LED status
Flashing
On
Off
Fan tray LEDs
A fan tray uses a RUN/ALM LED to indicate its operating status.
Table1-9 Fan tray LED description
Status
Steady green
The fan tray is operating correctly.
Steady red
The fan tray is faulty.
Off
The fan tray is not powered on.
Power supply LEDs
Each power supply provides two LEDs to indicate its operating status.
Table1-10 Power supply LED description
LED
Status
PSR1800-56A
AC OK
Green
Normal power input
Off
Abnormal or no power input
DC OK
Green
Normal power output
Red
Abnormal power output
Off
No power output
PSR1800-56D
IN OK
Green
Normal power input
Off
OUT OK
Green
Normal power output
Red
Off
No power output
