H3C S12500R-2L Switch Router Installation Guide-6W102
HomeSupportSwitchesS12500R SeriesInstall & UpgradeInstallation GuidesH3C S12500R-2L Switch Router Installation Guide-6W102
08-Appendix B Removable Components and Compatibility Matrixes
1 Appendix B Removable components and compatibility matrixes
For the transceiver modules and cables available for the modules, see H3C S12500R Switch Router Series Modules and Transceiver Modules Compatibility Matrixes.
SEUs
The device uses a supervisor engine unit (SEU, also called MPU) for system control and management. You can install one SEU, or two SEUs for redundancy on the device. Do not install SEUs of different models on the same device. The LSXM1SUP02LR1 SEU is available for the device.
Table1-1 LSXM1SUP02LR1 SEU specifications
Item
Specification
Processor
Intel processor (Quad-Core) @ 2.2 GHz
SDRAM
16GB DDR4 SDRAM for one DIMM slot (two DIMM slots)
Flash
8 GB EMMC
NVRAM
512 KB
Connector type
·     RJ-45
·     LC
·     USB (Type A)
Ports
·     1 × console port
·     1 × 10/100/1000BASE-T port for management and upgrade
·     1 × GE SFP port for management and upgrade
·     1 × USB port (USB2.0, host port)
Transmission rate
·     Console port: 9600 bps (default) to 115200 bps
·     10/100/1000BASE-T port: 10/100/1000 Mbps
·     SFP port: 1000 Mbps
Cables and max transmission distance
·     Console port: 15 m (49.21 ft) over a common asynchronous serial interface cable
·     10/100/1000BASE-T port: 100 m (328.08 ft) over category-5 twisted pairs
IMPORTANT
IMPORTANT:
·     To verify compatibility of the module with the software release you are using, see the release notes.
·     The USB port outputs power as prescribed by USB 2.0. You can only install a USB 2.0-compliant device in the USB port.
·     Set the same speed and duplex mode for a management Ethernet port and its peer port.
·     To upgrade software or BootWare from the BootWare menu, you can only use the 10/100/1000BASE-T port (M0/0/1) rather than the GE SFP port (M0/0/0) for image file transferring.
Interface modules
The LSXM1CGQ48KBR1 interface module is available for the device.
Table1-2 LSXM1CGQ48KBR1 interface module specification
Interface module
Connector type
Port number
Transmission rate
Available transceiver modules and cables
LSXM1CGQ48KBR1
48-port 100GBASE Ethernet optical interface module (QSFP28)
·     MPO
·     LC
48
100 Gbps
·     QSFP28 transceiver module
·     QSFP28 copper cable
·     QSFP28 fiber cable
·     QSFP+ transceiver module
·     QSFP+ copper cable
·     QSFP+ fiber cable
Power supplies
CAUTION
CAUTION:
You must install power supplies of the same model for the device.
The device supports N+N (dual power input sources) or N+1 (single power input source) power supply redundancy. Determine the number of power supplies based on the power supply mode and system power consumption. Make sure the maximum total output power of the installed power supplies is greater than the system power consumption. Reserve a 20% power surplus as a best practice.
The PSR1800-56A and PSR1800-56D power supplies are available for the device.
Table1-3 PSR1800-56A power supply specifications
Item
Specifications
Rated input voltage
100 to 240 VAC @ 50 or 60 Hz
Rated output voltage
56 VDC
Maximum input current
·     13 A @ 110 VAC
·     9 A @ 220 VAC
Maximum output current
32.2 A
Maximum output power
·     1100 W @ 100 VAC to 200 VAC
·     1800 W @ 201 VAC to 240 VAC
·     1800 W @ 240 VDC
Dimensions (H × W × D)
40.1 × 82.6 × 297.7 mm (1.58 × 3.25 × 11.72 in)
Ambient temperature
Operating temperature
–10°C to +50°C (–14°F to +122°F)
Storage temperature
–40°C to + 70°C (–40°F to +158°F)
Table1-4 PSR1800-56D power supply specifications
Item
Specifications
Rated input voltage
–48 to –60 VDC
56 VDC
45 A
32.2 A
1800 W
Ambient temperature
Storage temperature
The power supply shuts down automatically when its temperature exceeds the acceptable range. When the temperature returns to the acceptable range, the power supply automatically restarts.
Fan trays
The FAN-120-1-A fan tray is available for the device.
Table1-5 FAN-120-1-A fan tray specifications
Fan tray
Number of fans
Fan diameter
Maximum airflow
FAN-120-1-A
2
120 mm (4.72 in)
1240 CFM
DC power cords
A DC power cord is used to connect a DC power supply on the device to an external DC power source.
Table1-6 describes DC power cords available for the device.
Table1-6 Specifications for the DC power cords
DC power cord BOM code
Applicable power supplies
Cable length
0404A0RB
PSR1800-56D
3 m (9.84 ft)
Connects the DC power supply to an external DC power source.
0404A0RA
15 m (49.21 ft)
AC power cords
An AC power cord is used to connect an AC power supply on the device to an external AC power source. AC power cords include standard power cords and jumper power cords.
Selection of an AC power cord depends on the power supply (the current-carrying capacity of the power cord must meet the power supply requirement), power supply system in the equipment room, and connector and plug types in the country or region. Make sure you select a compliant power cord for a power supply.
For more information about AC power cords, see H3C Power Cords & Cables User Guide.
Chassis component ordering information
To purchase chassis components, contact the sales agent or H3C sales personnel.
Table1-7 Chassis component ordering information
Product code
Product name
SEUs
0231ABV3
LSXM1SUP02LR1
H3C S12500R-2L supervisor engine unit
Interface modules
0231ABV2
LSXM1CGQ48KBR1
H3C S12500R 48-port 100GBASE Ethernet optical interface module (QSFP28) (KB)
Fan tray
0231ABVR
LSXM102LFAN
H3C S12500R-2L Ethernet switch router fan module
Power supply
0231A2KX
LSVM3PSRA
H3C port-to-power airflow 1800W AC power supply
0231A2KY
PSR1800-56D
H3C port-to-power airflow 1800W DC power supply
